Update various build and test components to use the new schema.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Add a CONFIG option to deal with this automatically, printing a warning
when U-Boot starts up. This can be useful if the device tree comes from
another project.
We will maintain this through the 2023.07 release, providing 6 months
for people to notice.
Version 4:
Acked-by: Michal Simek <michal.simek@amd.com>
These are only present in SPL. Drop the references to non-SPL versions.
Tighten up symbol dependencies in a number of places. Ensure that a VPL
specific option has at least a direct dependency on VPL. In places
where it's clear that we depend on something more specific, use that
dependency instead.
Reported-by: Pali Rohár <pali@kernel.org>
Add VPL versions of commonly used Kconfig options.
When building for a custom board, it is quite common to maintain a
private branch which include some defconfig and .dts files. But to
hook up those .dts files requires modifying a file "belonging" to
upstream U-Boot, the arch/*/dts/Makefile. Forward-porting that branch
to a newer upstream then often results in a conflict which, while it
is trivial to resolve by hand, makes it harder to have a CI do "try to
build our board against latest upstream".
The .config usually includes information on precisely what .dtb(s) are
needed, so to avoid having to modify the Makefile, simply add the
files in (SPL_)OF_LIST to dtb-y.
A technicality is that (SPL_)OF_LIST is not always defined, so rework
the Kconfig symbols so that (SPL_)OF_LIST is always defined (when
(SPL_)OF_CONTROL), but only prompted for in the cases which used to be
their "depends on".
nios2 and microblaze already have something like this in their
dts/Makefile, and the rationale in commit 41f59f68539 is similar to
the above. So this simply generalizes existing practice. Followup
patches could remove the logic in those two makefiles, just as there's
potential for moving some common boilerplate from all the
arch/*/dts/Makefile files to the new scripts/Makefile.dts.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
The build system already automatically looks for and includes an
in-tree *-u-boot.dtsi when building the control .dtb. However, there
are some things that are awkward to maintain in such an in-tree file,
most notably the metadata associated to public keys used for verified
boot.
The only "official" API to get that metadata into the .dtb is via
mkimage, as a side effect of building an actual signed image. But
there are multiple problems with that. First of all, the final U-Boot
(be it U-Boot proper or an SPL) image is built based on a binary
image, the .dtb, and possibly some other binary artifacts. So
modifying the .dtb after the build requires the meta-buildsystem
(Yocto, buildroot, whatnot) to know about and repeat some of the steps
that are already known to and handled by U-Boot's build system,
resulting in needless duplication of code. It's also somewhat annoying
and inconsistent to have a .dtb file in the build folder which is not
generated by the command listed in the corresponding .cmd file (that
of course applies to any generated file).
So the contents of the /signature node really needs to be baked into
the .dtb file when it is first created, which means providing the
relevant data in the form of a .dtsi file. One could in theory put
that data into the *-u-boot.dtsi file, but it's more convenient to be
able to provide it externally: For example, when developing for a
customer, it's common to use a set of dummy keys for development,
while the consultants do not (and should not) have access to the
actual keys used in production. For such a setup, it's easier if the
keys used are chosen via the meta-buildsystem and the path(s) patched
in during the configure step. And of course, nothing prevents anybody
from having DEVICE_TREE_INCLUDES point at files maintained in git, or
for that matter from including the public key metadata in the
*-u-boot.dtsi directly and ignore this feature.
There are other uses for this, e.g. in combination with ENV_IMPORT_FDT
it can be used for providing the contents of the /config/environment
node, so I don't want to tie this exclusively to use for verified
boot.
Fix doc formatting error (make htmldocs)
U-Boot always needs some sort of a device tree in the build. Some boards
never actually use this, at least in production systems, since a prior
firmware stage sets one up and passes it to U-Boot. At present the only
mechanism to do that is with custom function (OF_BOARD), but future work
will include a standard way of doing this ('standard passage').
It can be confusing to see a device tree emitted from the U-Boot build in
this situation. Add an option to drop it.
When U-Boot is started from another firmware program, not just a prior
phase of U-Boot, special behaviour is typically used. In particular, the
device tree may come from that prior stage.
At present this is sort-of indicated by OF_BOARD, although the
correlation is not 1:1, since that option simply means that the board has
a custom mechanism for obtaining the device tree. For example, sandbox
defines OF_BOARD. Also the board_fdt_blob_setup() function can in fact
make use of the devicetree in U-Boot if it wishes, as used by
dragonboard410c until very recently.
Add an explicit Kconfig for this situation. Update the OF_BOARD option to
more-accurately reflect what it is doing, e.g. for sandbox.
Drop the docs in the README as it is out of date.
Refactor the code to drop the #ifdefs for this feature.
This was added as a hack to work around not having an in-tree devicetree.
Now that this is fixed it is not needed.
Drop it.
This should not be a separate option from OF_SEPARATE. It is a run-time
option to override the devicetree, even if present.
Move the option out of the choice.
Disable BINMAN_FDT for a few boards which don't actually use it.
OF_HOSTFILE is used on sandbox configs only. Although it's pretty
unique and not causing any confusions, we are better of having simpler
config options for the DTB.
So let's replace that with the existing OF_BOARD. U-Boot would then
have only three config options for the DTB origin.
- OF_SEPARATE, build separately from U-Boot
- OF_BOARD, board specific way of providing the DTB
- OF_EMBED embedded in the u-boot binary(should not be used in production
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
At present U-Boot always builds dtc if CONFIG_OF_CONTROL is defined, even
when DTC is provided. The built dtc is not actually used, so this is a
waste of time.
Update the Makefile logic to build dtc only if one is not provided to the
build with the DTC variable. Add documentation to explain this.
This saves about 3.5 seconds of elapsed time on a clean build of
sandbox_spl for me.
The previous patches removed OF_PRIOR_STAGE from the last consumers of the
Kconfig option. Cleanup any references to it in documentation, code and
configuration options.
At some point back in 2018 prior_stage_fdt_address and OF_PRIOR_STAGE got
introduced, in order to support a DTB handed over by an earlier stage boo
loader. However we have another option in the Kconfig (OF_BOARD) which has
identical semantics.
On RISC-V some of the boards pick up the DTB from a1 and copy it in their
private gd_t. Apart from that they copy it to prior_stage_fdt_address, if
the Kconfig option is selected, which is unnecessary.
So let's switch the config option for those boards to OF_BOARD and define
the required board_fdt_blob_setup() for them.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Use this new Kconfig to simplify the compilation conditions where
appropriate.
The condition to indicate whether there is a runtime devicetree available
is OF_CONTROL && !OF_PLATDATA. This is a bit unweidly and is repeated in
a lot of places.
Add a new OF_REAL Kconfig which provides this information directly.
Note: This is similar in effect to LIBFDT. We might consider dropping
LIBFDT and using this instead, but this is left for now as we also have
OF_LIBFDT_OVERLAY which it would not make sense to change.
For scenarios like OF_BOARD or OF_PRIOR_STAGE, no device tree blob is
provided in the U-Boot build phase hence the binman node information
is not available. In order to support such use case, a new Kconfig
option BINMAN_STANDALONE_FDT is introduced, to tell the build system
that a device tree blob containing binman node is explicitly required
when using binman to package U-Boot.
At present when driver model needs to change a device it simply updates
the struct udevice structure. But with of-platdata-inst most of the fields
are not modified at runtime. In fact, typically only the flags need to
change.
For systems running SPL from read-only memory it is convenient to separate
out the runtime information, so that the devices don't need to be copied
before being used.
Create a new udevice_rt table, similar to the existing driver_rt. For now
it just holds the flags, although they are not used in this patch.
Add a new Kconfig for the driver_rt data, since this is not needed when
of-platdata-inst is used.
Some systems (e.g. x86 APL) run SPL from read-only memory. The device
instances created by dtoc are therefore not writeable. To make things work
we would need to copy the devices to read/write memory.
To avoid this, add an option to use a separate runtime struct for devices,
just as is done for drivers. This can be used to hold information that
changes at runtime, avoiding the need for a copy.
Also add a Kconfig option for read-only SPL, which selects this feature.
With OF_PLATDATA_INST devices are bound at build time. We should not need
binding of devices at runtime in most cases. However it is inflexible to
absolutely prohibit it, so add an option to control this.
Update the driver model core so that it does not bind devices. Update
device_bind() to return an error if called.
Add Kconfig options to support build-time device instantiation. When
fully implemented, this will allow dtoc to create U-Boot devices (i.e.
struct udevice records) at build time, thus reducing code space in
SPL.
For now this defaults to off, but will be enabled when the rest of
the implementation is in place.
lib/of_live.c references the following 2 ofnode APIs:
of_alias_scan() and of_get_property().
These APIs get built only when DM is on. Fix the dependency then.
Make it more obvious what .dts file was expected by the build system.
When adding support for a new board, I kept getting this error message,
assuming I passed a wrong DEVICE_TREE parameter.
However, what was really the mistake was that the entry in
`arch/arm/dts/Makefile` was missing, and u-boot didn't like not being
able to find the .dtb file that should have been produced.
Simply logging the expected .dtb file name should make it easier to spot
such mistakes.
Signed-off-by: Florian Klink <flokli@flokli.de>
The current macro is a misnomer since it does not declare a device
directly. Instead, it declares driver_info record which U-Boot uses at
runtime to create a device.
The distinction seems somewhat minor most of the time, but is becomes
quite confusing when we actually want to declare a device, with
of-platdata. We are left trying to distinguish between a device which
isn't actually device, and a device that is (perhaps an 'instance'?)
It seems better to rename this macro to describe what it actually is. The
macros is not widely used, since boards should use devicetree to declare
devices.
Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is
declaring a new driver_info record, not a device.
Use the SPL_NAME variable to simplify the rules. Drop the SPL targets
clean-files since the SPL and TPL dts/ directories are removed by
existing rules. Move the SPL rules into a new spl_dtbs to avoid the
complicated $(if) construct.
Also drop unused pieces from the 'targets' variable.
With this, SPL and TPL have separate dtbs which respect the various
u-boot,dm-spl / u-boot,dm-tpl tags.
Rather than putting these in the top-level dts/ directory (which is
intended for U-Boot proper), put them in the correct subdirectory for
SPL (either spl/ or tpl/). This is where other SPL targets are kept,
so this is more consistent.
At present both SPL and TPL use the same devicetree binary. While there
is logic to run fdtgrep separately on each one, it does not actually
happen.
Add a new TPL rule and use that instead. Make this rule conditional on
there actually being a TPL. Do the same for SPL for consistency.
Note that the SPL and TPL dtbs are build by a Makefule rule used for
U-Boot proper. This is the 'dtbs' target in dts/Makefile. So the check
for CONFIG_TPL_BUILD in cmd_fdtgrep never actually works at present.
We don't support CONFIG_OF_EMBED for TPL at present.
At present of-platdata does not provide parent information. But this is
useful for I2C devices, for example, since it allows them to determine
which bus they are on.
Add support for setting the parent correctly, by storing the parent
driver_info index in dtoc and reading this in lists_bind_drivers(). This
needs multiple passes since we must process children after their parents
already have been bound.
At present MKIMAGE_DTC_PATH is in the devicetree menu but not within
'devicetree control' since it does not relate to that. As a result it
shows up in the top menu.
It actually relates to the mkimage tool, so create a new tools menu for it
and move it there.
This can be used for device tree size reduction similar as
CONFIG_OF_SPL_REMOVE_PROPS option. Some boards must pass the
built-in DTB unchanged to the kernel, thus we may not cut it
down unconditionally. Therefore enable the property removal
list option only if CONFIG_OF_DTB_PROPS_REMOVE is selected.
Some features implicitly depended on MALLOC_F and OF_LIBFDT and would
fail at link-time if these features were not enabled.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
If u-boot.img is a FIT image, CONFIG_OF_OVERLAY_LIST can be used to add
DT overlays to u-boot.img.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This choice is not about SPL for which we have a separate choice.
Fixes: 95f4bbd581 ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot")
Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
As initially this feature was implemented as a negative CONFIG and
later it was redesigned to be positive the help text should be
updated to reflect this change.
This commit updates the help text to match the current implementation.
Signed-off-by: Walter Lozano <wlozano@collabora.com>
interrupt-parent property is removed already that's why there is no
reason to keep interrupts property if parent doesn't exist.
Add required Kconfig symbols, Makefile bits and macro fixes in a
few places to support LZO and DT compression in U-Boot. This can
save a lot of space with multi-DTB fitImages.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
This reverts commit 27cb7300ffda7a3f1581f0f5a2d3bfe59b97ad67.
I am not sure if I correctly understood the log of commit 27cb7300ffda
("Ensure device tree DTS is compiled"), but the code-diff looks like
it was trying to solve the missed re-compilation when .dts was modified.
Recently, commit 2737dfe096b6 ("kbuild: make arch-dtbs target PHONY")
fixed the issue in a more correct and more complete way.
Anyway, since the former commit, we see a clumsy log like this:
make[2]: 'arch/sandbox/dts/sandbox.dtb' is up to date
Another problem is, it created multiple paths to descend into
arch/*/dts/, causing a race in parallel building.
So, let's revert it.
Without this, the arch-dtbs target only gets evaluated when building
U-Boot the first time, not when re-building (incrementally building)
U-Boot. Thus incremental builds ignore changes to DTB files.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Improve some things in the documentation of OF_PLATDATA that I found
while porting socfgpa_gen5 to it.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Based on the following Linux commits:
- 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove
.PRECIOUS markers")
- 8e9b61b293d9 ("kbuild: move .SECONDARY special target to
Kbuild.include")
GNU Make automatically deletes intermediate files that are updated
in a chain of pattern rules.
Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts
Example 2) %.o <- %.c <- %.c_shipped
A couple of makefiles mark such targets as .PRECIOUS to prevent Make
from deleting them, but the correct way is to use .SECONDARY.
.SECONDARY
Prerequisites of this special target are treated as intermediate
files but are never automatically deleted.
.PRECIOUS
When make is interrupted during execution, it may delete the target
file it is updating if the file was modified since make started.
If you mark the file as precious, make will never delete the file
if interrupted.
Both can avoid deletion of intermediate files, but the difference is
the behavior when Make is interrupted; .SECONDARY deletes the target,
but .PRECIOUS does not.
The use of .PRECIOUS is relatively rare since we do not want to keep
partially constructed (possibly corrupted) targets.
.SECONDARY with no prerequisites causes all targets to be treated as
secondary. This agrees the policy of Kbuild.
scripts/Kbuild.include seems a suitable place to add it because it is
included from almost all sub-makes.
Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Reviewed-by: Rick Chen <rick@andestech.com>
Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Fix typo in Kconfig description.
Remove additional trailing whitespaces in prompt reported by kconfiglib:
warning: DM_PMIC_SANDBOX (defined at drivers/power/pmic/Kconfig:133) has
leading or trailing whitespace in its prompt
warning: <choice> (defined at dts/Kconfig:204) has leading or trailing
Reviewed-by: Felix Brack <fb@ltec.ch>
Add support for loading U-Boot on the Broadcom 7445 SoC. This port
assumes Broadcom's BOLT bootloader is acting as the second stage
bootloader, and U-Boot is acting as the third stage bootloader, loaded
as an ELF program by BOLT.
Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Stefan Roese <sr@denx.de>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Follow Linux commit 10b62a2f785a (".gitignore: move *.dtb and *.dtb.S
patterns to the top-level .gitignore").
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
With commit 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through
fdtgrep"), CONFIG_SPL_MULTI_DTB_FIT has been broken because
cmd_fdtgrep was now unknown in scripts/Makefile.spl after moving
it to dts/Makefile. This bug has been introduced with v2018.01.
This patch moves cmd_fdtgrep from dts/Makefile to scripts/Makefile.lib
and includes scripts/Makefile.lib in scripts/Makefile.spl.
Fixes: 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through fdtgrep")
Reported-by: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
