path: root/dts
2022-02-09dts: automatically build necessary .dtb filesRasmus Villemoes
When building for a custom board, it is quite common to maintain a private branch which include some defconfig and .dts files. But to hook up those .dts files requires modifying a file "belonging" to upstream U-Boot, the arch/*/dts/Makefile. Forward-porting that branch to a newer upstream then often results in a conflict which, while it is trivial to resolve by hand, makes it harder to have a CI do "try to build our board against latest upstream". The .config usually includes information on precisely what .dtb(s) are needed, so to avoid having to modify the Makefile, simply add the files in (SPL_)OF_LIST to dtb-y. A technicality is that (SPL_)OF_LIST is not always defined, so rework the Kconfig symbols so that (SPL_)OF_LIST is always defined (when (SPL_)OF_CONTROL), but only prompted for in the cases which used to be their "depends on". nios2 and microblaze already have something like this in their dts/Makefile, and the rationale in commit 41f59f68539 is similar to the above. So this simply generalizes existing practice. Followup patches could remove the logic in those two makefiles, just as there's potential for moving some common boilerplate from all the arch/*/dts/Makefile files to the new scripts/Makefile.dts. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-01-25introduce CONFIG_DEVICE_TREE_INCLUDESRasmus Villemoes
The build system already automatically looks for and includes an in-tree *-u-boot.dtsi when building the control .dtb. However, there are some things that are awkward to maintain in such an in-tree file, most notably the metadata associated to public keys used for verified boot. The only "official" API to get that metadata into the .dtb is via mkimage, as a side effect of building an actual signed image. But there are multiple problems with that. First of all, the final U-Boot (be it U-Boot proper or an SPL) image is built based on a binary image, the .dtb, and possibly some other binary artifacts. So modifying the .dtb after the build requires the meta-buildsystem (Yocto, buildroot, whatnot) to know about and repeat some of the steps that are already known to and handled by U-Boot's build system, resulting in needless duplication of code. It's also somewhat annoying and inconsistent to have a .dtb file in the build folder which is not generated by the command listed in the corresponding .cmd file (that of course applies to any generated file). So the contents of the /signature node really needs to be baked into the .dtb file when it is first created, which means providing the relevant data in the form of a .dtsi file. One could in theory put that data into the *-u-boot.dtsi file, but it's more convenient to be able to provide it externally: For example, when developing for a customer, it's common to use a set of dummy keys for development, while the consultants do not (and should not) have access to the actual keys used in production. For such a setup, it's easier if the keys used are chosen via the meta-buildsystem and the path(s) patched in during the configure step. And of course, nothing prevents anybody from having DEVICE_TREE_INCLUDES point at files maintained in git, or for that matter from including the public key metadata in the *-u-boot.dtsi directly and ignore this feature. There are other uses for this, e.g. in combination with ENV_IMPORT_FDT it can be used for providing the contents of the /config/environment node, so I don't want to tie this exclusively to use for verified boot. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Fix doc formatting error (make htmldocs) Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-23fdt: Avoid emitting an device tree when not neededSimon Glass
U-Boot always needs some sort of a device tree in the build. Some boards never actually use this, at least in production systems, since a prior firmware stage sets one up and passes it to U-Boot. At present the only mechanism to do that is with custom function (OF_BOARD), but future work will include a standard way of doing this ('standard passage'). It can be confusing to see a device tree emitted from the U-Boot build in this situation. Add an option to drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-23fdt: Add a Kconfig for boards with a prior stageSimon Glass
When U-Boot is started from another firmware program, not just a prior phase of U-Boot, special behaviour is typically used. In particular, the device tree may come from that prior stage. At present this is sort-of indicated by OF_BOARD, although the correlation is not 1:1, since that option simply means that the board has a custom mechanism for obtaining the device tree. For example, sandbox defines OF_BOARD. Also the board_fdt_blob_setup() function can in fact make use of the devicetree in U-Boot if it wishes, as used by dragonboard410c until very recently. Add an explicit Kconfig for this situation. Update the OF_BOARD option to more-accurately reflect what it is doing, e.g. for sandbox. Drop the docs in the README as it is out of date. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-23fdt: Drop #ifdefs with MULTI_DTB_FITSimon Glass
Refactor the code to drop the #ifdefs for this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-23fdt: Drop CONFIG_BINMAN_STANDALONE_FDTSimon Glass
This was added as a hack to work around not having an in-tree devicetree. Now that this is fixed it is not needed. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-23fdt: Make OF_BOARD a bool optionSimon Glass
This should not be a separate option from OF_SEPARATE. It is a run-time option to override the devicetree, even if present. Move the option out of the choice. Disable BINMAN_FDT for a few boards which don't actually use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-10-27sandbox: Remove OF_HOSTFILEIlias Apalodimas
OF_HOSTFILE is used on sandbox configs only. Although it's pretty unique and not causing any confusions, we are better of having simpler config options for the DTB. So let's replace that with the existing OF_BOARD. U-Boot would then have only three config options for the DTB origin. - OF_SEPARATE, build separately from U-Boot - OF_BOARD, board specific way of providing the DTB - OF_EMBED embedded in the u-boot binary(should not be used in production Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-10-19Makefile: Only build dtc if neededSimon Glass
At present U-Boot always builds dtc if CONFIG_OF_CONTROL is defined, even when DTC is provided. The built dtc is not actually used, so this is a waste of time. Update the Makefile logic to build dtc only if one is not provided to the build with the DTC variable. Add documentation to explain this. This saves about 3.5 seconds of elapsed time on a clean build of sandbox_spl for me. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-10-18treewide: Remove OF_PRIOR_STAGEIlias Apalodimas
The previous patches removed OF_PRIOR_STAGE from the last consumers of the Kconfig option. Cleanup any references to it in documentation, code and configuration options. Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-10-18riscv: Remove OF_PRIOR_STAGE from RISC-V boardsIlias Apalodimas
At some point back in 2018 prior_stage_fdt_address and OF_PRIOR_STAGE got introduced, in order to support a DTB handed over by an earlier stage boo loader. However we have another option in the Kconfig (OF_BOARD) which has identical semantics. On RISC-V some of the boards pick up the DTB from a1 and copy it in their private gd_t. Apart from that they copy it to prior_stage_fdt_address, if the Kconfig option is selected, which is unnecessary. So let's switch the config option for those boards to OF_BOARD and define the required board_fdt_blob_setup() for them. Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
2021-09-25treewide: Simply conditions with the new OF_REALSimon Glass
Use this new Kconfig to simplify the compilation conditions where appropriate. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-09-25fdt: Create a new OF_REAL KconfigSimon Glass
The condition to indicate whether there is a runtime devicetree available is OF_CONTROL && !OF_PLATDATA. This is a bit unweidly and is repeated in a lot of places. Add a new OF_REAL Kconfig which provides this information directly. Note: This is similar in effect to LIBFDT. We might consider dropping LIBFDT and using this instead, but this is left for now as we also have OF_LIBFDT_OVERLAY which it would not make sense to change. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-05-19binman: Support packaging U-Boot for scenarios like OF_BOARD or OF_PRIOR_STAGEBin Meng
For scenarios like OF_BOARD or OF_PRIOR_STAGE, no device tree blob is provided in the U-Boot build phase hence the binman node information is not available. In order to support such use case, a new Kconfig option BINMAN_STANDALONE_FDT is introduced, to tell the build system that a device tree blob containing binman node is explicitly required when using binman to package U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-03-26dm: core: Create a struct for device runtime infoSimon Glass
At present when driver model needs to change a device it simply updates the struct udevice structure. But with of-platdata-inst most of the fields are not modified at runtime. In fact, typically only the flags need to change. For systems running SPL from read-only memory it is convenient to separate out the runtime information, so that the devices don't need to be copied before being used. Create a new udevice_rt table, similar to the existing driver_rt. For now it just holds the flags, although they are not used in this patch. Add a new Kconfig for the driver_rt data, since this is not needed when of-platdata-inst is used. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-26dm: core: Add an option to support SPL in read-only memorySimon Glass
Some systems (e.g. x86 APL) run SPL from read-only memory. The device instances created by dtoc are therefore not writeable. To make things work we would need to copy the devices to read/write memory. To avoid this, add an option to use a separate runtime struct for devices, just as is done for drivers. This can be used to hold information that changes at runtime, avoiding the need for a copy. Also add a Kconfig option for read-only SPL, which selects this feature. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-22dm: core: Allow dropping run-time binding of devicesSimon Glass
With OF_PLATDATA_INST devices are bound at build time. We should not need binding of devices at runtime in most cases. However it is inflexible to absolutely prohibit it, so add an option to control this. Update the driver model core so that it does not bind devices. Update device_bind() to return an error if called. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-22dm: of-platadata: Add option for device instantiationSimon Glass
Add Kconfig options to support build-time device instantiation. When fully implemented, this will allow dtoc to create U-Boot devices (i.e. struct udevice records) at build time, thus reducing code space in SPL. For now this defaults to off, but will be enabled when the rest of the implementation is in place. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-03dts: Fix OF_LIVE dependencyBin Meng
lib/of_live.c references the following 2 ofnode APIs: of_alias_scan() and of_get_property(). These APIs get built only when DM is on. Fix the dependency then. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-16dts: Log name of expected .dtb fileFlorian Klink
Make it more obvious what .dts file was expected by the build system. When adding support for a new board, I kept getting this error message, assuming I passed a wrong DEVICE_TREE parameter. However, what was really the mistake was that the entry in `arch/arm/dts/Makefile` was missing, and u-boot didn't like not being able to find the .dtb file that should have been produced. Simply logging the expected .dtb file name should make it easier to spot such mistakes. Signed-off-by: Florian Klink <flokli@flokli.de>
2021-01-05dm: Rename U_BOOT_DEVICE() to U_BOOT_DRVINFO()Simon Glass
The current macro is a misnomer since it does not declare a device directly. Instead, it declares driver_info record which U-Boot uses at runtime to create a device. The distinction seems somewhat minor most of the time, but is becomes quite confusing when we actually want to declare a device, with of-platdata. We are left trying to distinguish between a device which isn't actually device, and a device that is (perhaps an 'instance'?) It seems better to rename this macro to describe what it actually is. The macros is not widely used, since boards should use devicetree to declare devices. Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is declaring a new driver_info record, not a device. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-01-05Makefile: Tidy up SPL dtb productionSimon Glass
Use the SPL_NAME variable to simplify the rules. Drop the SPL targets clean-files since the SPL and TPL dts/ directories are removed by existing rules. Move the SPL rules into a new spl_dtbs to avoid the complicated $(if) construct. Also drop unused pieces from the 'targets' variable. With this, SPL and TPL have separate dtbs which respect the various u-boot,dm-spl / u-boot,dm-tpl tags. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-01-05Makefile: Build SPL dtbs in the spl/ directorySimon Glass
Rather than putting these in the top-level dts/ directory (which is intended for U-Boot proper), put them in the correct subdirectory for SPL (either spl/ or tpl/). This is where other SPL targets are kept, so this is more consistent. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-01-05Makefile: Build a separate .dtb for TPLSimon Glass
At present both SPL and TPL use the same devicetree binary. While there is logic to run fdtgrep separately on each one, it does not actually happen. Add a new TPL rule and use that instead. Make this rule conditional on there actually being a TPL. Do the same for SPL for consistency. Note that the SPL and TPL dtbs are build by a Makefule rule used for U-Boot proper. This is the 'dtbs' target in dts/Makefile. So the check for CONFIG_TPL_BUILD in cmd_fdtgrep never actually works at present. We don't support CONFIG_OF_EMBED for TPL at present. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-10-29dm: Support parent devices with of-platdataSimon Glass
At present of-platdata does not provide parent information. But this is useful for I2C devices, for example, since it allows them to determine which bus they are on. Add support for setting the parent correctly, by storing the parent driver_info index in dtoc and reading this in lists_bind_drivers(). This needs multiple passes since we must process children after their parents already have been bound. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-10-09Kconfig: Create a new tools menuSimon Glass
At present MKIMAGE_DTC_PATH is in the devicetree menu but not within 'devicetree control' since it does not relate to that. As a result it shows up in the top menu. It actually relates to the mkimage tool, so create a new tools menu for it and move it there. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-27dts: add property removal option CONFIG_OF_REMOVE_PROPSAnatolij Gustschin
This can be used for device tree size reduction similar as CONFIG_OF_SPL_REMOVE_PROPS option. Some boards must pass the built-in DTB unchanged to the kernel, thus we may not cut it down unconditionally. Therefore enable the property removal list option only if CONFIG_OF_DTB_PROPS_REMOVE is selected. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2020-01-15Add dependencies for MALLOC_F and OF_LIBFDTSean Anderson
Some features implicitly depended on MALLOC_F and OF_LIBFDT and would fail at link-time if these features were not enabled. Signed-off-by: Sean Anderson <seanga2@gmail.com>
2020-01-07dts: Add support for adding DT overlays in u-boot.imgJean-Jacques Hiblot
If u-boot.img is a FIT image, CONFIG_OF_OVERLAY_LIST can be used to add DT overlays to u-boot.img. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-10-31dts: fix MULTI_DTB_FIT compression choice promptBaruch Siach
This choice is not about SPL for which we have a separate choice. Fixes: 95f4bbd581 ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot") Cc: Marek Vasut <marek.vasut+renesas@gmail.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2019-10-30dts: Kconfig: Fix help for SPL_OF_CONTROLWalter Lozano
As initially this feature was implemented as a negative CONFIG and later it was redesigned to be positive the help text should be updated to reflect this change. This commit updates the help text to match the current implementation. Signed-off-by: Walter Lozano <wlozano@collabora.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-11dm: Also remove interrupts property from SPL DTMichal Simek
interrupt-parent property is removed already that's why there is no reason to keep interrupts property if parent doesn't exist. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09lib: fdt: Allow LZO and GZIP DT compression in U-BootMarek Vasut
Add required Kconfig symbols, Makefile bits and macro fixes in a few places to support LZO and DT compression in U-Boot. This can save a lot of space with multi-DTB fitImages. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2019-03-22Revert "Ensure device tree DTS is compiled"Masahiro Yamada
This reverts commit 27cb7300ffda7a3f1581f0f5a2d3bfe59b97ad67. I am not sure if I correctly understood the log of commit 27cb7300ffda ("Ensure device tree DTS is compiled"), but the code-diff looks like it was trying to solve the missed re-compilation when .dts was modified. Recently, commit 2737dfe096b6 ("kbuild: make arch-dtbs target PHONY") fixed the issue in a more correct and more complete way. Anyway, since the former commit, we see a clumsy log like this: make[2]: 'arch/sandbox/dts/sandbox.dtb' is up to date Another problem is, it created multiple paths to descend into arch/*/dts/, causing a race in parallel building. So, let's revert it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-02-28kbuild: make arch-dtbs target PHONYStephen Warren
Without this, the arch-dtbs target only gets evaluated when building U-Boot the first time, not when re-building (incrementally building) U-Boot. Thus incremental builds ignore changes to DTB files. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-02-09of-platdata: improve documentationSimon Goldschmidt
Improve some things in the documentation of OF_PLATDATA that I found while porting socfgpa_gen5 to it. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-26dts: riscv: update makefile to also clean the RISC-V dts directoryLukas Auer
Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-09-27powerpc/dts: Makefile changes to clean and build dtsJagdish Gediya
Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2018-08-17dts: Fix typo in OF_LIVE Kconfig helpMichal Simek
Fix typo in Kconfig description. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-30Kconfig: Remove trailing whitespaces in promptMichal Simek
Remove additional trailing whitespaces in prompt reported by kconfiglib: warning: DM_PMIC_SANDBOX (defined at drivers/power/pmic/Kconfig:133) has leading or trailing whitespace in its prompt warning: <choice> (defined at dts/Kconfig:204) has leading or trailing whitespace in its prompt Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Felix Brack <fb@ltec.ch>
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
2018-06-18.gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignoreMasahiro Yamada
Follow Linux commit 10b62a2f785a (".gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignore"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-14spl: unbreak CONFIG_SPL_MULTI_DTB_FIT after fixing CONFIG_OF_EMBEDSimon Goldschmidt
With commit 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through fdtgrep"), CONFIG_SPL_MULTI_DTB_FIT has been broken because cmd_fdtgrep was now unknown in scripts/Makefile.spl after moving it to dts/Makefile. This bug has been introduced with v2018.01. This patch moves cmd_fdtgrep from dts/Makefile to scripts/Makefile.lib and includes scripts/Makefile.lib in scripts/Makefile.spl. Fixes: 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through fdtgrep") Reported-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-11-29spl: make CONFIG_OF_EMBED pass dts through fdtgrepGoldschmidt Simon
Building spl with CONFIG_OF_EMBED enabled results in an error message on my board: "SPL image too big". This is because the fdtgrep build step is only executed for CONFIG_OF_SEPARATE. Fix this by moving the fdtgrep build step ('cmd_fdtgreo') from scripts/Makefile.spl to dts/Makefile so that the reduced dtb is available for all kinds of spl builds. The resulting variable name for the embedded device tree blob changes, too, which is why common.h and fdtdec.c have tiny changes. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-17pylibfdt: compile pylibfdt only when dtoc/binman is necessaryMasahiro Yamada
Currently, pylibfdt is always compiled if swig is installed on your machine. It is really annoying because most of targets (excepts x86, sunxi, rockchip) do not use dtoc or binman. "checkbinman" and "checkdtoc" are wrong. It is odd that the final build stage checks if we have built necessary tools. If your platform depends on dtoc/binman, you must be able to build pylibfdt. If swig is not installed, it should fail immediately. I added PYLIBFDT, DTOC, BINMAN entries to Kconfig. They should be property select:ed by platforms that need them. Kbuild will descend into scripts/dtc/pylibfdt/ only when CONFIG_PYLIBFDT is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-06spl: dm: Make it possible for the SPL to pick its own DTB from a FITJean-Jacques Hiblot
u-boot can be embedded within a FIT image with multiple DTBs. It then selects at run-time which one is best suited for the platform. Use the same principle here for the SPL: put the DTBs in a FIT image, compress it (LZO, GZIP, or no compression) and append it at the end of the SPL. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> [trini: Move default y of SPL_MULTI_DTB_FIT_DYN_ALLOC to it being the default choice if SYS_MALLOC_F, drop spl.h include from lib/fdtdec.c it's unused.] Signed-off-by Tom Rini <trini@konsulko.com>
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-24tools/mkimage: Make the path to the dtc binary that mkimage calls configurableTom Rini
In some cases, such as FreeBSD, the path to an alternative dtc needs to be used. Rather than override the one given in the Makefile on the command line, make this part of the build configuration. Signed-off-by: Tom Rini <trini@konsulko.com>
