Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997
power management device.
The MUIC device will work with redesigned PMIC framework.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Trats battery is now treated in the same way as other power related
devices. This approach allows for more unified handling of all devices
responsible for power management.
The PMIC framework has been moved to its more natural place
./drivers/power from ./drivers/misc directory.
The PMIC framework has been extended to support multiple instances of
the variety of devices responsible for power management.
This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB
Interface Circuit).
Power related includes have been moved to ./include/power directory.
This is a first of a series of patches - in the future "pmic" will be
replaced with "power".
Two important issues:
1. The PMIC needs to be initialized just after malloc is configured
2. It uses list to hold information about available PMIC devices
PMIC MAX8997 is now ready to work with single and multibus soft I2C
implementation.
Since the pmic_reg_read is the u32 value, the order in which bytes
are placed to form u32 value is important.
Support for big and little sensor endianess is added.
Moreover calls to [leXX|beXX]_to_cpu have been added to support
little and big endian SoCs.
This patch adds support for proper handling of a PMIC I2C transmission
comprising of two bytes.
The gadget ethernet driver needs to keep copies of the MAC address (at
both endpoints) as strings so it needs a custom function for validation
of the MAC. It was not however performing a totally correct check and
also was emitting a warning about a set but unused variable. The
solution to both is that after checking the string contents we use the
standard test for a valid MAC.
nand_ecc.c:82:5: warning: symbol 'nand_calculate_ecc' was not declared. Should it be static?
nand_ecc.c:155:5: warning: symbol 'nand_correct_data' was not declared. Should it be static?
nand_base.c:2854:1: error: directive in argument list
nand_base.c:2856:1: error: directive in argument list
Acked-by: Scott Wood <scottwood@freescale.com>
cfi_flash.c:756:43: warning: Using plain integer as NULL pointer
cfi_flash.c:1150:52: warning: cast to non-scalar
cfi_flash.c:1433:46: warning: cast truncates bits from constant value (890089 becomes 89)
cfi_flash.c:1490:61: warning: cast truncates bits from constant value (1f001f becomes 1f)
cfi_flash.c:1508:61: warning: cast truncates bits from constant value (10001 becomes 1)
cfi_flash.c:1738:63: warning: cast truncates bits from constant value (10001 becomes 1)
cfi_flash.c:1857:6: warning: symbol '__flash_cmd_reset' was not declared. Should it be static?
fsl_esdhc.c:71:6: warning: symbol 'esdhc_xfertyp' was not declared. Should it be static?
fsl_esdhc.c:413:6: warning: symbol 'set_sysctl' was not declared. Should it be st
mmc.c:137:5: warning: symbol 'mmc_send_cmd' was not declared. Should it be static?
mmc.c:203:5: warning: symbol 'mmc_send_status' was not declared. Should it be static?
mmc.c:247:5: warning: symbol 'mmc_set_blocklen' was not declared. Should it be static?
mmc.c:440:5: warning: symbol 'mmc_read_blocks' was not declared. Should it be static?
mmc.c:510:5: warning: symbol 'mmc_go_idle' was not declared. Should it be static?
mmc.c:532:1: warning: symbol 'sd_send_op_cond' was not declared. Should it be static?
mmc.c:597:5: warning: symbol 'mmc_send_op_cond' was not declared. Should it be static?
mmc.c:661:5: warning: symbol 'mmc_send_ext_csd' was not declared. Should it be static?
mmc.c:683:5: warning: symbol 'mmc_switch' was not declared. Should it be static?
mmc.c:705:5: warning: symbol 'mmc_change_freq' was not declared. Should it be static?
mmc.c:775:5: warning: symbol 'sd_switch' was not declared. Should it be static?
mmc.c:796:5: warning: symbol 'sd_change_freq' was not declared. Should it be static?
mmc.c:935:6: warning: symbol 'mmc_set_ios' was not declared. Should it be static?
mmc.c:953:6: warning: symbol 'mmc_set_bus_width' was not declared. Should it be static?
mmc.c:1108:26: warning: dubious: !x & y
mmc.c:960:5: warning: symbol 'mmc_startup' was not declared. Should it be static?
mmc.c:1243:5: warning: symbol 'mmc_send_if_cond' was not declared. Should it be s
input.c:97:5: warning: symbol 'input_queue_ascii' was not declared. Should it be
mpc83xx_gpio.c:166:26: warning: non-ANSI function declaration of function 'mpc83xx_gpio_init_f'
mpc83xx_gpio.c:190:26: warning: non-ANSI function declaration of function 'mpc83xx_gpio_init_r'
sata_sil.c:371:7: warning: symbol 'sil_sata_rw_lba28' was not declared. Should it be static?
sata_sil.c:399:7: warning: symbol 'sil_sata_rw_lba48' was not declared. Should it be static?
sata_sil.c:429:6: warning: symbol 'sil_sata_cmd_flush_cache' was not declared. Should it be static?
sata_sil.c:441:6: warning: symbol 'sil_sata_cmd_flush_cache_ext' was not declared. Should it be static?
sata_sil.c:489:7: warning: symbol 'sata_read' was not declared. Should it be static?
sata_sil.c:505:7: warning: symbol 'sata_write' was not declared. Should it be static?
sata_sil.c:526:5: warning: symbol 'init_sata' was not declared. Should it be static?
sata_sil.c:588:5: warning: symbol 'scan_sata' was not declared. Should it be static?
fsl_sata.c:59:6: warning: symbol 'dprint_buffer' was not declared. Should it be static?
fsl_sata.c:187:42: warning: incorrect type in assignment (different base types)
fsl_sata.c:187:42: expected unsigned int [unsigned] [usertype] cda
fsl_sata.c:187:42: got restricted __le32 [usertype] <noident>
fsl_sata.c:291:6: warning: symbol 'fsl_sata_hardware_reset' was not declared. Should it be static?
fsl_sata.c:418:27: warning: incorrect type in assignment (different base types)
fsl_sata.c:418:27: expected unsigned int [unsigned] [usertype] dba
fsl_sata.c:418:27: got restricted __le32 [usertype] <noident>
fsl_sata.c:424:41: warning: incorrect type in assignment (different base types)
fsl_sata.c:424:41: expected unsigned int [unsigned] [usertype] ext_c_ddc
fsl_sata.c:424:41: got restricted __le32 [usertype] <noident>
fsl_sata.c:431:41: warning: incorrect type in assignment (different base types)
fsl_sata.c:431:41: expected unsigned int [unsigned] [usertype] ext_c_ddc
fsl_sata.c:431:41: got restricted __le32 [usertype] <noident>
fsl_sata.c:442:22: warning: incorrect type in assignment (different base types)
fsl_sata.c:442:22: expected unsigned int [unsigned] [usertype] cda
fsl_sata.c:442:22: got restricted __le32 [usertype] <noident>
fsl_sata.c:446:31: warning: incorrect type in assignment (different base types)
fsl_sata.c:446:31: expected unsigned int [unsigned] [usertype] prde_fis_len
fsl_sata.c:446:31: got restricted __le32 [usertype] <noident>
fsl_sata.c:448:22: warning: incorrect type in assignment (different base types)
fsl_sata.c:448:22: expected unsigned int [unsigned] [usertype] ttl
fsl_sata.c:448:22: got restricted __le32 [usertype] <noident>
fsl_sata.c:460:28: warning: incorrect type in assignment (different base types)
fsl_sata.c:460:28: expected unsigned int [unsigned] [usertype] attribute
fsl_sata.c:460:28: got restricted __le32 [usertype] <noident>
fsl_sata.c:623:6: warning: symbol 'fsl_sata_flush_cache' was not declared. Should it be static?
fsl_sata.c:667:5: warning: symbol 'fsl_sata_rw_ncq_cmd' was not declared. Should it be static?
fsl_sata.c:710:6: warning: symbol 'fsl_sata_flush_cache_ext' was not declared. Should it be static?
fsl_sata.c:725:6: warning: symbol 'fsl_sata_software_reset' was not declared. Should it be static?
fsl_sata.c:760:5: warning: symbol 'ata_low_level_rw_lba48' was not declared. Should it be static?
fsl_sata.c:795:5: warning: symbol 'ata_low_level_rw_lba28' was not declared. Should it be static?
the following compiler warnings show up after fixing the above, so
remove those three functions:
fsl_sata.c:59:13: warning: 'dprint_buffer' defined but not used [-Wunused-function]
fsl_sata.c:291:13: warning: 'fsl_sata_hardware_reset' defined but not used [-Wunused-function]
fsl_sata.c:726:13: warning: 'fsl_sata_software_reset' defined but not used [-Wunused-function]
Other than that, the following are fixed by __iomem annotation:
fsl_sata.c:84:39: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:84:39: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:84:39: got unsigned int volatile *addr
fsl_sata.c:172:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:172:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:172:26: got unsigned int *<noident>
fsl_sata.c:175:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:175:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:175:19: got unsigned int *<noident>
fsl_sata.c:181:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:181:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:181:19: got unsigned int *<noident>
fsl_sata.c:184:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:184:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:184:26: got unsigned int *<noident>
fsl_sata.c:186:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:186:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:186:19: got unsigned int *<noident>
fsl_sata.c:189:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:189:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:189:26: got unsigned int *<noident>
fsl_sata.c:191:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:191:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:191:19: got unsigned int *<noident>
fsl_sata.c:194:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:194:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:194:26: got unsigned int *<noident>
fsl_sata.c:195:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:195:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:195:19: got unsigned int *<noident>
fsl_sata.c:198:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:198:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:198:19: got unsigned int *<noident>
fsl_sata.c:201:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:201:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:201:19: got unsigned int *<noident>
fsl_sata.c:204:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:204:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:204:26: got unsigned int *<noident>
fsl_sata.c:205:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:205:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:205:19: got unsigned int *<noident>
fsl_sata.c:208:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:208:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:208:26: got unsigned int *<noident>
fsl_sata.c:209:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:209:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:209:19: got unsigned int *<noident>
fsl_sata.c:212:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:212:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:212:26: got unsigned int *<noident>
fsl_sata.c:213:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:213:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:213:19: got unsigned int *<noident>
fsl_sata.c:216:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:216:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:216:19: got unsigned int *<noident>
fsl_sata.c:219:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:219:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:219:19: got unsigned int *<noident>
fsl_sata.c:222:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:222:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:222:19: got unsigned int *<noident>
fsl_sata.c:225:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:225:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:225:26: got unsigned int *<noident>
fsl_sata.c:227:19: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:227:19: expected unsigned int volatile [noderef] <asn:2>*addr
fsl_sata.c:227:19: got unsigned int *<noident>
fsl_sata.c:242:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:242:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:242:26: got unsigned int *<noident>
fsl_sata.c:256:32: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:256:32: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:256:32: got unsigned int *<noident>
fsl_sata.c:262:26: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:262:26: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:262:26: got unsigned int *<noident>
fsl_sata.c:274:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:274:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:274:53: got unsigned int *<noident>
fsl_sata.c:275:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:275:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:275:53: got unsigned int *<noident>
fsl_sata.c:276:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:276:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:276:53: got unsigned int *<noident>
fsl_sata.c:277:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:277:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:277:53: got unsigned int *<noident>
fsl_sata.c:278:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:278:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:278:53: got unsigned int *<noident>
fsl_sata.c:279:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:279:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:279:53: got unsigned int *<noident>
fsl_sata.c:280:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:280:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:280:53: got unsigned int *<noident>
fsl_sata.c:281:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:281:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:281:53: got unsigned int *<noident>
fsl_sata.c:282:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:282:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:282:53: got unsigned int *<noident>
fsl_sata.c:283:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:283:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:283:53: got unsigned int *<noident>
fsl_sata.c:284:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:284:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:284:53: got unsigned int *<noident>
fsl_sata.c:285:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:285:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:285:53: got unsigned int *<noident>
fsl_sata.c:286:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:286:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:286:53: got unsigned int *<noident>
fsl_sata.c:287:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:287:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:287:53: got unsigned int *<noident>
fsl_sata.c:288:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:288:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:288:53: got unsigned int *<noident>
fsl_sata.c:289:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:289:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:289:53: got unsigned int *<noident>
fsl_sata.c:290:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:290:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:290:53: got unsigned int *<noident>
fsl_sata.c:291:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:291:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:291:53: got unsigned int *<noident>
fsl_sata.c:292:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:292:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:292:53: got unsigned int *<noident>
fsl_sata.c:293:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:293:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:293:53: got unsigned int *<noident>
fsl_sata.c:294:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:294:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:294:53: got unsigned int *<noident>
fsl_sata.c:295:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:295:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:295:53: got unsigned int *<noident>
fsl_sata.c:296:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:296:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:296:53: got unsigned int *<noident>
fsl_sata.c:297:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:297:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:297:53: got unsigned int *<noident>
fsl_sata.c:298:53: warning: incorrect type in argument 1 (different address spaces)
fsl_sata.c:298:53: expected unsigned int const volatile [noderef] <asn:2>*addr
fsl_sata.c:298:53: got unsigned int *<noident>
phy.c:46:5: warning: symbol 'genphy_config_advert' was not declared. Should it be static?
phy.c:121:5: warning: symbol 'genphy_setup_forced' was not declared. Should it be static?
phy.c:468:5: warning: symbol 'phy_probe' was not declared. Should it be static?
phy.c:491:19: warning: symbol 'get_phy_driver' was not declared. Should it be static?
phy.c:508:19: warning: symbol 'phy_device_create' was not declared. Should it be static?
phy.c:552:5: warning: symbol 'get_phy_id' was not declared. Should it be static?
phy.c:584:19: warning: symbol 'get_phy_device' was not declared. Should it be sta
vitesse.c:126:5: warning: symbol 'vsc8601_config' was not declared. Should it be static?
vsc7385.c:33:5: warning: symbol 'vsc7385_upload_firmware' was not declared. Should it be static?
tgec_phy.c:33:5: warning: symbol 'tgec_mdio_write' was not declared. Should it be static?
tgec_phy.c:75:5: warning: symbol 'tgec_mdio_read' was not declared. Should it be static?
tgec_phy.c:117:5: warning: symbol 'tgec_mdio_reset' was not declared. Should it be static?
eth.c:48:6: warning: symbol 'dtsec_configure_serdes' was not declared. Should it be static?
p4080.c:26:5: warning: symbol 'port_to_devdisr' was not declared. Should it be static?
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static?
bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static?
bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static?
arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static?
arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static?
arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static?
atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static?
net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static?
net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static?
ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static?
ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static?
tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static?
tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static?
eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static?
Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020
"net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING
clause from when it was necessary to avoid warnings when it was embedded
in net.c.
u-boot's byteorder headers did not contain endianness attributions
for use with sparse, causing a lot of false positives. Import the
kernel's latest definitions, and enable them by including compiler.h
and types.h. They come with 'const' added for some swab functions, so
fix those up, too:
include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default]
Also, note: u-boot's historic __BYTE_ORDER definition has been
preserved (for the time being at least).
We also remove ad-hoc barrier() definitions, since we're including
compiler.h in files that hadn't in the past:
macb.c:54:0: warning: "barrier" redefined [enabled by default]
In addition, including compiler.h in byteorder changes the 'noinline'
definition to expand to __attribute__((noinline)). This fixes
arch/powerpc/lib/bootm.c:
bootm.c:329:16: error: attribute '__attribute__': unknown attribute
bootm.c:329:16: error: expected ')' before '__attribute__'
bootm.c:329:25: error: expected identifier or '(' before ')' token
powerpc sparse builds yield:
include/common.h:356:22: error: marked inline, but without a definition
the unknown-reason inlining without a definition is considered obsolete
given it was part of the 2002 initial commit, and no arm version was
'fixed.'
also fixed:
ydirectenv.h:60:0: warning: "inline" redefined [enabled by default]
and:
Configuring for devconcenter - Board: intip, Options: DEVCONCENTER
make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1
make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2
powerpc-fsl-linux-size: './u-boot': No such file
4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration':
include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available
4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here
and:
In file included from crc32.c:50:0:
crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration]
crc32table.h:4:1: error: initializer element is not constant
crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]')
[trini: Remove '#endif' in include/common.h around setenv portion]
Currently, this driver uses a 28bit interface to AHCI, this
limits the number of blocks addressable to 2^28, or the max
disk size to 512(2^28) or about 137GB. This change allows
supporting drives up to about 2TB.
Testing this is a bit difficult. There is test code that
can be inserted into U-Boot that will write test patterns
into certain unused blocks. These patterns can be manually
checked using 'dd' after boot. Another way is to confirm the
original error that exposed this bug is fixed. IOW: see if
AU (Auto Update) will now work on the drive. Also, check
that there are no warning messages from the 'cgpt' utility.
Signed-off-by: Walter Murphy <wmurphy@chromium.org>
Writes in u-boot are so rare, and the logic to know when is
the last write and do a flush only there is sufficiently
difficult. Just do a flush after every write. This incurs,
usually, one extra flush when the rare writes do happen.
Signed-off-by: Marc Jones <marc.jones@chromium.org>
Add HDD handling to the SSD-only AHCI driver, by separately dealing with
spin-up and link-up.
Note: These are timeout values and not delay values, so the event being
timed out will complete whenever it is actually ready, with a
measurement granularity of 1 millisecond, up till the timeout value.
Therefore, there is no effect on SSD booting.
The values were determined by instrumenting the code and measuring the
actual time taken by several different models of HDD for each of the
parameters and then adding 50% more for the spinup value and just
doubling the command timeout value.
Exynos5 automatically performs DMA when the SATA controller executes
commands. This adds the necessary dcache-to-memory flush &
invalidation calls to allow the DMA to properly function.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Update the assignment of various physical memory buffers used by the
SATA controller to explicitly be denoted as physical addresses.
The memory is identity-mapped, so these function calls are a nop, but
they provide good semantic documentation for any maintainers.
The return value of virt_to_phys() is 'unsigned long'. On machines
where sizeof(unsigned long) != sizeof(pointer), a cast through
(uintptr_t) is needed to appease the compiler due to the potential of
losing the upper 32 bits of the address.
In compilation this scenario, a physical address could be 64-bits, yet
the C pointer environment only allows 32-bit addresses; the constraint
is that pointers cannot address more than 4Gb of memory and if
virt_to_phys() ever returns an out-of-range value for the physical
address, there are issues with emmory mapping which must be solved.
However, since the memory is identify mappeed, there is no problem
introducing the cast: the original pointer will reside in 32-bits, so
the physical address will also be within in 32-bits.
This fixes a spelling error in a message which can be output to the
console.
This cleanup replaces the hardcoded use of '20', which represents the
number of bytes in the FIS, with sizeof(fis).
In the structure returned by the ATA identify device command, there are two
fields which describe the device capacity. One is a 32 bit data type which
reports the number of sectors as a 28 bit LBA, and the other is a 64 bit data
type which is for a 48 bit LBA. If the device doesn't support 48 bit LBAs,
the small value is the only value with the correct size. If it supports more,
if the number of sectors is small enough to fit into 28 bits, both fields
reflect the correct value. If it's too large, the smaller field has 28 bits of
1s, 0xfffffff, and the other field has the correct value.
The AHCI driver is implemented by attaching to the generic SCSI code and
translating on the fly between SCSI binary data structures and AHCI data
structures. It responds to requests to execute specific SCSI commands by
executing the equivalent AHCI commands and then crafting a response which
matches what a SCSI disk would send.
The AHCI driver now considers both fields and chooses the correct one when
implementing both the SCSI READ CAPACITY (10) and READ CAPACITY (16) commands.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
The "scsi write" command requires support from underlying driver.
This CL enables SCSI_WRITE10 in AHCI driver.
Tested in U-Boot console, try to i/o with sector #64:
scsi read 1000 40 1
md.b 1000 200 # check if things are not 0xcc
mw.b 1000 cc 200 # try to fill with 0xcc
scsi write 1000 40 1
mw.b 1000 0 200 # fill with zero
md.b 1000 200 # should be all 0
scsi read 1000 40 1
md.b 1000 200 # should be all 0xcc
Signed-off-by: Hung-Te Lin <hungte@chromium.org>
This command doesn't really do anything when talking to a SATA device, and
sending it confuses some of them. This change makes sending the command
optional, and defaults to not. The situations where it should be sent are not
the common case.
With the standard SSD in the machine, here are some times with the option
turned off:
1. 8277
2. 8273
3. 8050
And turned on:
1. 8303
2. 8155
3. 8276
Sending that command seems to have no meaningful effect on performance.
This fixes problems with an SSD marked Toshiba NV6424, Taiwan 11159AE P
and TC58NVG5D2FTA10.
- print the correct speed
- print all the AHCI capability flags
(information taken from Linux kernel driver)
- clean up some comments
For example, this might show the following string:
AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
Tested-by: Stefan Reinauer <reinauer@chromium.org>
- remove unused ssleep macro
- add some useful debugging information
The existing code waits a whole second for the AHCI controller to reset.
Instead, let's poll the status register to see if the reset has
succeeded and return earlier if possible. This brings down the time for
AHCI probing from 1s to 20ms.
With an Intel AHCI controller, the driver does not operate properly
if the requested amount of blocks to read exceeds 255.
It is probably possible to specify 0 as the block count and the driver
will read 256 blocks, but it was decided to limit the number of blocks
read at once to 128 (it should be a power of 2 for the optimal
performance of solid state drives).
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Add optional support for some ANSI escape sequences to the
cfb_console driver. Define CONFIG_CFB_CONSOLE_ANSI to enable
cursor moving, color reverting and clearing the cfb console
via ANSI escape codes.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Deassert the CONFIG pin before asserting it again. This assures that the
FPGA will be resetted and therefore configuration will be correctly
enabled.
This is also already done on other FPGA's, e.g. Stratix.
Signed-off-by: Stephan Gatzka <stephan.gatzka@hbm.com>
Add the missing bits to the Tegra NAND driver to make ONFI detection work
properly.
Also add it to the Tegra default config, as it seems to be a reasonable thing
to have it available on all boards that use any kind of NAND.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This driver is no longer used, remove it.
This stuff has been rotting in the tree for a while now. Remove it.
This stuff has been rotting in the tree for a year now. Remove it.
Increase the possible number of ns16550 serial devices from 4 to 6.
Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
serial_ns16550.c:222:1: warning: symbol 'eserial1_init' was not declared. Should it be static?
serial_ns16550.c:222:1: warning: symbol 'eserial1_setbrg' was not declared. Should it be static?
serial_ns16550.c:222:1: warning: symbol 'eserial1_getc' was not declared. Should it be static?
serial_ns16550.c:222:1: warning: symbol 'eserial1_tstc' was not declared. Should it be static?
serial_ns16550.c:222:1: warning: symbol 'eserial1_putc' was not declared. Should it be static?
serial_ns16550.c:222:1: warning: symbol 'eserial1_puts' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_init' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_setbrg' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_getc' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_tstc' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_putc' was not declared. Should it be static?
serial_ns16550.c:225:1: warning: symbol 'eserial2_puts' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_init' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_setbrg' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_getc' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_tstc' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_putc' was not declared. Should it be static?
serial_ns16550.c:228:1: warning: symbol 'eserial3_puts' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_init' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_setbrg' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_getc' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_tstc' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_putc' was not declared. Should it be static?
serial_ns16550.c:231:1: warning: symbol 'eserial4_puts' was not declared. Should it be static?
fsl_i2c.c:217:14: warning: symbol 'get_i2c_clock' was not declared. Should it be static?
Acked-by: Heiko Schocher <hs@denx.de>
