path: root/drivers
2008-03-16Merge branch 'master' of git+ssh://10.10.0.7/home/wd/git/u-boot/masterWolfgang Denk
Conflicts: drivers/rtc/Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-16drivers/rtc/Makefile: keep list sortedWolfgang Denk
2008-03-16Add support for Intersil isl1208 RTCTor Krill
Signed-off-by: Tor Krill <tor@excito.com>
2008-03-15usb: Add CFG_OHCI_USE_NPS to common USB-OHCI driverStefan Roese
This patch adds CFG_OHCI_USE_NPS to the common USB-OHCI driver. This way a board just needs to define this new option to enable the "force NoPowerSwitching mode" instead of adding new CPU/architecture defines to the USB source itself. This new option will be used first with the new AMCC 460EX Canyonlands board port, which will be posted in a few days. This patch also fixes a small compilation problem when DEBUG is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15rtc: Add M41T62 supportStefan Roese
This patch add support for the STM M41T62 RTC. It is used and tested on the AMCC Canyonlands 406EX platform. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-08net: rtl8169: Add processing when OWNbit did't enable in rtl_recv()Nobuhiro Iwamatsu
When rtl_recv() of rtl8169 is called, OWNbit of status register is not enable occasionally. rtl_recv() doesn't work normally when the driver doesn't do appropriate processing. This patch fix this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-07net: uec_phy: actually increment the timeout counterKim Phillips
allow u-boot to recover (and, e.g., switch to another interface) in the case where a PHY does not report autonegotiation is complete within its two second timeout value. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-03fix QE firmware uploading limitTimur Tabi
Fix a typo in qe_upload_firmware() that prevented uploading firmware on systems with more than one RISC core. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-03-02net: uec_phy: handle 88e1111 rev.B2 erratum 5.6Kim Phillips
erratum 5.6 states the autoneg completion bit is functional only if the autoneg bit is asserted. This fixes any secondarily-issued networking commands on non-gigabit links on the mpc8360 mds board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-02-22LM75 bug fix for negative temperaturesLarry Johnson
When the LM75 temperature sensor measures a temperature below 0 C, the current driver does not perform sign extension, so the result returned is 256 C too high. This patch fixes the problem. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-02-22Merge branch 'master' of git://www.denx.de/git/u-boot-cfi-flashWolfgang Denk
2008-02-22uli526x: Fix multiple differ in signedness and parentheses around comparisonJean-Christophe PLAGNIOL-VILLARD
2008-02-21CFI: Do not use uninitialized cmd_resetMichael Schwingen
Do not use uninitialized cmd_reset; issue both AMD and Intel reset commands instead From a short test, it looks like AMD-style flash roms treat *any* unknown command write as a reset, at least when in CFI Query mode, so issuing the Intel reset command to AMD-style flashs seems safe (from the small sample I have), plus the 3-cycle magic sequence should kick the state machine into the right state even without a reset command. Since the AMD-style flashs require the unlock sequence for real operation, I chose to try the AMD reset command first, so that Intel flashs do no see an invalid command prior to the CFI query. I have tested the patch on AM29LV320-style flashs from Fujitsu and Macronix, plus Intel StrataFlash. Signed-off-by: Michael Schwingen <michael@schwingen.org> Signed-off-by: Stefan Roese <sr@denx.de>
2008-02-16Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-02-16Wipe out assembler warnings while compiling x86 biosemuAnatolij Gustschin
This patch tries to get rid of some assembler warnings about changed .got2 section type while compiling x86 bios emulator code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Add Radeon Mobility 9200 pci device id to the radeon driverAnatolij Gustschin
This patch extends PCI device id table of the radeon driver so that the driver will also support Radeon Mobility 9200 (M9+) based boards. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-02-15Extend ATI Radeon driver to support more video modesAnatolij Gustschin
Adds ATI Radeon 9200 support for 1280x1024, 1024x768, 800x600, 640x480 at 24, 16 and 8 bpp. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-mpc86xxWolfgang Denk
Conflicts: common/cmd_reginfo.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Use #ifdef CONFIG_FSLDMAFECVlad Lungu
MCD_tasks.c lacks [subject] so compilation of mips targets (and more, probably) fails Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-02-14Merge commit 'wd/master'Jon Loeliger
2008-02-14AT91CAP9 support : MACB changesStelian Pop
Signed-off-by: Stelian Pop <stelian <at> popies.net> Acked-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
2008-02-14AT91CAP9 support : build integrationStelian Pop
Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-14Improve DataFlash CS definition.Stelian Pop
Use a structure instead of the error prone unnamed array to define the possible dataflash banks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-02-14Remove duplicate defines for ARRAY_SIZEKumar Gala
2008-02-14Fix incorrect address test in AT91F_DataflashSelect().Stelian Pop
2008-02-13Merge commit 'wd/master'Jon Loeliger
2008-02-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-02-12QE: Move FDT support into a common fileKumar Gala
Move the flat device tree setup for QE related devices into a common file shared between 83xx & 85xx platforms that have QE's. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-04rewrite/cleanup Blackfin RTC driverMike Frysinger
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-05OMAP5912: fix FIFO handling in UART driverWolfgang Denk
According to the OMAP5912 Serial Interfaces Reference Guide (see http://focus.ti.com/lit/ug/spru760c/spru760c.pdf, page 150), the FIFO_EN enable bit in the FIFO Control Register (FCR) can only be changed when the baud clock is not running, i. e. when both DLL and DLH are set to 0. Thus make sure that DLL and DLH are 0 when writing the FCR. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-29Fix conditional compilation of mpx8xxx_spi driverBen Warren
This driver should only compile if CONFIG_MPC8XXX_SPI is set Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-2486xx: Add print_laws function to fsl_law.cBecky Bruce
This can be used for debug, and will be used by board code to help implement reginfo. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-23Merge ../custodiansWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-netWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxWolfgang Denk
2008-01-17Merge branch 'kumar'Andy Fleming
2008-01-17ColdFire: Add MCF547x_8x FEC driverTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF547x_8x dma code and header filesTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF547x_8x dma code - 2TsiChungLiew
2008-01-17ColdFire: Add MCF547x_8x dma code - 1TsiChungLiew
2008-01-17codingstyle cleanup for spi driverKim Phillips
..and rm unused CONFIG_FSL_SPI define Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17Add support for a Freescale non-CPM SPI controllerBen Warren
This patch adds support for the SPI controller found on Freescale PowerPC processors such as the MCP834x family. Additionally, a new config option, CONFIG_HARD_SPI, is added for general purpose SPI controller use. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17sh: Update SuperH SCIF driverNobuhiro Iwamatsu
This patch fixed wrong SH7720 CPU macro and changed macro that calculated value of SCBRR register. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
