This patch adds esdhc support for ls2085a.
Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
This adds NAND boot support for LS2085AQDS, using SPL framework.
Details of forming NAND image can be found in README.
[York Sun: Remove +S from defconfig after commit 252ed872]
IFC has two register pages.Till IFC version 1.4 each
register page is 4KB each.But IFC ver 2.0 register page
size is 64KB each.IFC regiters structure is break into
two viz FCM and RUNTIME.FCM(Flash control machine) registers
are defined in PAGE0 and controls IFC generic functionality.
RUNTIME registers are defined in PAGE1 and controls NAND and
GPCM funcinality.
FCM and RUNTIME structures defination is common for IFC
version 1.4 and 2.0.
Signed-off-by: Jaiprakash Singh <b44839@freescale.com>
Add support of ethernet:
- eth.c: mapping lane to slot for (0x2A, 0x07)
- ls2085a.c: To enable/disable dpmac and get link type
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Wire rate IO Processor (WRIOP) provide support of receive and transmit
ethernet frames from the ethernet MAC. Here Each WRIOP block supports
upto 64 DPMACs.
Create a house keeping data structure to support upto 16 DPMACs and
store external phy related information.
The memac for PHY management on little endian SoCs is similar on big
endian SoCs, so we modify the driver by using I/O accessor function to
handle the endianness, so the driver can be reused on little endian
SoCs, we introduce CONFIG_SYS_MEMAC_LITTLE_ENDIAN for little endian
SoCs, if the CONFIG_SYS_MEMAC_LITTLE_ENDIAN is defined, the I/O access
is little endian, if not, the I/O access is big endian. Move fsl_memac.h
out of powerpc include.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Changed MC firmware loading to comply with the new MC boot architecture.
Flush D-cache hierarchy after loading MC images. Add environment
variables "mcboottimeout" for MC boot timeout in milliseconds,
"mcmemsize" for MC DRAM block size. Check MC boot status before calling
flib functions.
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Fix comilation warning which is emitted when
firmware address is more than 32 bit.
Signed-off-by: pankaj chauhan <pankaj.chauhan@freescale.com>
Fix flush_dcache_range() input parameter to use start and end addresses.
Change ethernet interface name to DPNI. Update entry criteria for
ldpaa_eth_stop. Ethernet stack first stop the device before performing
next operation. At the time of Ethernet driver registration,
net_dev->state is set as ETH_STATE_INIT So take care net_dev->state as
ETH_STATE_INIT in ldpaa_eth_stop.
Undef CONFIG_PHYLIB temorarily because ldpaa_eth driver currently does
not support PHYLIB.
Instead of clearing pull descriptor one time, clear it before issuing any
volatile dequeue command.
Volatile command does not return frame immidiately, wait till a frame
is available in DQRR. This frame can be valid or expired.
Flush buffer before releasing to BMan ensure the core does not have any
cachelines that the WRIOP will DMA to.
Signed-off-by: Roy Pledge <Roy.Pledge@freescale.com>
The patch removes unnecessary whitespace to fix checkpatch's
warning: unnecessary whitespace before a quoted newline
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
This erratum only applies to general purpose DDR controllers in LS2.
It shouldn't be applied to DP-DDR controller. Check DDRC versoin number
before applying workaround.
Add built-in memory test to catch errors after DDR is initialized, before
any other transactions. To enable this test, define CONFIG_FSL_DDR_BIST.
An environmental variable "ddr_bist" is checked before starting test.
It takes a while (several seconds) depending on system memory size.
CS0 was not allowed to be empty by u-boot driver in the past to simplify
the driver. This may be inconvenient for some debugging. This patch lifts
the restrictions. Controller interleaving still requires CS0 populated.
Add/update registers for DDR4, including DQ mappings. Allow raw timing
method used for all controllers. Update mode_9 register to 0x500 for
improved stability. Check DDR controller version number individually
in case a SoC has multiple DDR controllers of different versions.
Increase read-write turnaround for DDR4 high speeds.
Some SoCs have more than two I2C busses. Instead of adding ifdef
to the driver, macros are put into board header file where
CONFIG_SYS_I2C_MXC is defined.
CC: Heiko Schocher <hs@denx.de>
IFC 2.0 doubled the SRAM size, which means double the number of
ECCSTAT registers. Fix the resulting array overflow.
For fsl-lsch3, IFC is binded with address within 32-bit at fist.
After u-boot relocates to DDR, CS1, CS3 can be binded to higher
address to support large space.
LDPAA Ethernet driver is a freescale's new ethernet driver based on
Layerscape architecture.
Every ethernet driver controls on DPNI object. Where all DPNIs share
one common DPBP and DPIO object to support Rx and Tx flows.
CC: Cristian Sovaiala <cristian.sovaiala@freescale.com>
CC: Bogdan Hamciuc <bogdan.hamciuc@freescale.com>
CC: J. German Rivera <German.Rivera@freescale.com>
[York Sun: s/NetReceive/net_process_received_packet]
Freescale's Layerscape Management Complex (MC) provide support various
objects like DPRC, DPNI, DPBP and DPIO.
Where:
DPRC: Place holdes for other MC objectes like DPNI, DPBP, DPIO
DPBP: Management of buffer pool
DPIO: Used for used to QBMan portal
DPNI: Represents standard network interface
These objects are used for DPAA ethernet drivers.
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
Signed-off-by: Geoff Thorpe <Geoff.Thorpe@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Cristian Sovaiala <cristian.sovaiala@freescale.com>
The Debug Server driver is responsible for loading the Debug
server FW on the Service Processor (Cortex-A5 core) on LS2085A like
SoCs and then polling for the successful initialization of the same.
TOP MEM HIDE is adjusted to ensure the space required by Debug Server
FW is accounted for. MC uses the DDR area which is calculated as:
MC DDR region start = Top of DDR - area reserved by Debug Server FW
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Muram will power off during deepsleep, and the microcode of qe
in muram will be lost, it should be reload when resume.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
Check if USB Erratum A005697 is applicable on BSC913x and
add corresponding property in the device tree via device
tree fixup which is used by linux driver
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
1. LS2085a provides PCIE_LUT_DBG register rather than PCIE_LDBG
to show the link status, so the patch fixes it.
2. Increase the delay time to make sure that link training
has finished.
3. Return invalid value when accessing multi-function device
4. For LS2085a DBI_RO_WR_EN bit is cleared as default, so we
must set this bit before change DBI register value.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
The patch uses the common function name ft_pci_setup to replace
ft_pcie_setup, then removes unnecessary pcie_layerscape.h because
all the functions have been declared in common.h.
Identify soc(s) having dual phy so as to add "utmi_dual" as phy_mode
for all these socs. This is required for supporting deel-sleep feature
in linux for usb driver
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
commit aed2fbef5e9a0ab5a7cd01e742039a962f0b24ef
"dm: serial: Tidy up the pl01x driver"
caused a regression on (real hardware) PL010 by omitting
to update the line control register when switching baudrate.
Fix this by inlining the missing write to the baud control
register.
Also renaming the set_line_control() function to
pl011_set_line_control() since this function is clearly
PL011-specific, and it won't suffice to call that to
set up line control.
Tested on the Integrator/AP hardware.
The name "pch_gbe.%x" exceeds the limit of the name in the
'struct eth_device'. Rename it as just "pch_gbe".
Use phys_addr_t which is used in function prototype
in system.h.
commit 3c6928fd7b0f84 "net: phy: fix warnings with W=1" caused
some PHYs(e.g. CS4315/CS4340) not working. This patch fixes the
warning and make those special PHYs working as well.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
This patch adds a support for KSZ8081MNX in MII mode.
Signed-off-by: Luca Ellero <luca.ellero@brickedbrain.com>
Acked-by: Pavel Machek <pavel@denx.de>
Turn ioaddr into an unsigned long rather than a sized 32-bit variable.
While at it, fix a couple of pointer to integer cast size mismatch
warnings by casting through unsigned long going from pointers to
integers and vice versa.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Some Realtek Ethernet PHYs, like RTL8211D(G/N) and RTL8211E(G), have
interrupts enabled by default. If the interrupt is not treated later by
the OS and the PHY's interrupt line is enabled and shared with other
interrupts, the system will get an interrupt storm. This patch disables
the interrupt for PHY devices that use one of the current Realtek
Ethernet PHY drivers. Some of Realtek Ethernet PHYs, such as RTL8211B(L)
have the interrupt masked. In this case, the functionality of the PHY
should not be afected since this patch brings INER and INSR registers to
their default values.
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
According to the MPC8555/MPC8541 reference manual the SS_EN (source
synchronous enable) bit in the DDR_SDRAM_CLK_CNLT register must be set
during initialization.
>From section 9.4.1.8 of that manual:
Source synchronous enable. This bit field must be set during
initialization. See Section 9.6.1, "DDR SDRAM Initialization
Sequence," details.
0 - Reserved
1 - The address and command are sent to the DDR SDRAMs source
synchronously.
In addition, Freescale application note AN2805 is also very clear that
this bit must be set.
This patch reverts a change introduced by commit
457caecdbca3df21a93abff19eab12dbc61b7897.
Testing Done:
Compiled targets CONFIG_TARGET_MPC8555CDS and CONFIG_TARGET_MPC8541CDS
and inspected the generated assembly code to verify the SS_EN bit was being
set. There is one extra instruction emitted:
fff9b774: 65 29 80 00 oris r9,r9,32768
Compiled the CONFIG_TARGET_MPC8548CDS target and verified that no
additional instructions were emitted related to this patch.
Booted an image on a MPC8541 based board successfully.
Signed-off-by: Curt Brune <curt@cumulusnetworks.com>
the ldb clock can be setup in board code (for example set through PLL5).
Update the ldb_clock rate also through board code.
This should be removed, if a clock framework is availiable.
Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
make the ldb_clock configurable through the new define
CONFIG_SYS_LDB_CLOCK. This is needed as the ldb clock is not
always 650000000, for example on the aristainetos2 board,
where the ldb clock derives from PLL5 clock.
Don't store it in a u32.
Don't dereference the bus address as if it were a virtual address
(fixes 284231e49a2b4 ("ahci: Support splitting of read transactions
into multiple chunks")).
Fixes crash on boot in MPC8641HPCN_36BIT target.
Cc: Vadim Bendebury <vbendeb@chromium.org>
Acked-by: York Sun <yorksun@freescale.com>
Move this over to Kconfig and tidy up.
Acked-by: Heiko Schocher<hs@denx.de>
