Adds support for set-speed on the OMAP24xx I2C Adapter.
Changes to omap24_i2c_write(...) for polling ARDY Bit from IRQ-Status.
Otherwise on a subsequent call the transfer of last byte from the
predecessor is aborted and therefore lost. For exmaple when
i2c_write(...) is followed by a i2c_setspeed(...) (which has to
deactivate and activate master for changing psc,...).
Minor cosmetical changes.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Make sure the I2C write queue is empty before leaving the mxs_i2c_write().
If we start and I2C write and only wait for ACK, the MXS I2C IP block may
enter next operation while still processing the write aftermath internally.
This will in turn disrupt one or more subsequent transfer(s).
A testcase for this issue is as such. This testcase is also interesting because
the first I2C_WRITE which becomes disruptive happens in the 'i2c read' command.
The 'i2c read' command first uses I2C_WRITE to send I2C address of the chip and
then uses I2C_READ to read data from the chip. After this command completes, the
'i2c probe' will use sequence of I2C_WRITE commands to probe the I2C bus. The
problem is that the first I2C_WRITE disrupted the I2C IP block operation and
this sideeffect propagates all the way to this next I2C_WRITE used by the 'i2c
probe' call. The result is the 'i2c probe' receives an ACK on I2C address 0x00,
even if this ACK was owned by the previous I2C_WRITE operation. Note that the
'i2c read' command must read from a valid I2C chip address.
Wrong:
> i2c probe
Valid chip addresses: 50 51
> i2c read 0x50 0x0.2 0x10 0x42000000
> i2c probe
Valid chip addresses: 00 50 51
With this patch
> i2c probe
> i2c probe
Cc: Fabio Estevam <festevam@gmail.com>
Enhance the DesignWare I2C driver to support address length more
than 1 byte. This enhancement is required as some I2C slave
device such as EEPROM chip might have 16 bit address byte.
Signed-off-by: Chin Liang See <clsee@altera.com>
Acked-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
cc: Armando Visconti <armando.visconti@st.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
add support for bootcounter on an i2c device. And add a
README for all bootcounter options.
The ADI twi peripheral is not binding to Blackfin processor only.
Access i2c registers by standard io functions.
Fix coding style.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Change to a generic name.
Initialize the second i2c controller.
Signed-off-by: Michael Burr <michael.burr@logicpd.com>
Fixed bug with alen == 0 in 'i2c_write', 'i2c_read'
Further minor corrections:
- Write 'address' register before 'data' register.
- Write 'transfer_size' register before 'address' register.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
commit 626ee1e3 "phylib: update atheros ar803x phy"
leads in failing ethernet on the pxm2 board.
Calling genphy_config() instead of ar8021_config(),
which seems for ar8021 phys not ar803x phys, make
it working again.
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Remove hard coded frequencies and use Zynq's clock framework to obtain
the UART clock frequency.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Remove hard coded clock divider setting and use the Zynq clock framework
to dynamically calculate appropriate dividers at run time.
The GEM driver should not need to know about Zynq specific details of
RCLK related registers and bitfields in the SLCR. Move those details to
the slcr driver.
Define both serial uarts in the driver and return
default uart based on board configuration.
- Move baseaddresses to hardware.h
- Define default baudrate and clock values
Without this delay, write/read is failing.
Looks like, the WIP always remain set and hence a timeout
occurs leading to the error.
Without this patch, device does not get probed also.
Here is the log.
U-Boot#
U-Boot#
U-Boot#
U-Boot# sf probe 0
SF: Unsupported flash IDs: manuf ff, jedec ffff, ext_jedec ffff
Failed to initialize SPI flash at 0:0
U-Boot# sf probe 0
While with this patch, log is
U-Boot# sf probe 0
SF: Detected MX25L51235F with page size 256 Bytes, erase size 64 KiB, total 64 MiB, mapped at 30000000
U-Boot# sf erase 0 0x80000
SF: 524288 bytes @ 0x0 Erased: OK
U-Boot# mw 81000000 0xdededede 0x40000
U-Boot# sf write 81000000 0 0x40000
SF: 262144 bytes @ 0x0 Written: OK
U-Boot# sf read 82000000 0 0x40000
SF: 262144 bytes @ 0x0 Read: OK
U-Boot# md 0x82000000
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Add AM43xx specific changes.
SPI_MODE_3 requires clk high when inactive. The SCLK_CTL
field of the config reg was not configured in case of CPOL.
Fix configuration so that SPI_MODE_3 which uses CPOL configures
the clk line to be high in inactive state.
Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
Timeout calculation should be out of the data loop.
This patch increase spi bandwidth for 30%.
The prescaler value for MDC is calculated wrong for
MX6S. Implement the same logic as linux here which handles
ENET_MAC different then original FEC.
Tested on a custom board with i.MX6S and 100MBit PHY
Add a callback so that a board can implement it's own specific routine to
toggle the port's #PERST line or #define a GPIO to do so.
The implementation of oc_serial_setbrg() for CONFIG_SYS_NIOS_FIXEDBAUD and
!CONFIG_SYS_NIOS_FIXEDBAUD are very similar.
Add a baudrate variable and set it to either CONFIG_BAUDRATE or gd->baudrate.
Then we can unify the code for both cases.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Fix build error due to missing include of serial.h and a trivial typo.
Driver for non-standard on-chip UART, instantiated in the ARC (Synopsys)
FPGA Boards such as ARCAngel4/ML50x
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Francois Bedard <fbedard@synopsys.com>
The open and close mmc sub-commands implement a hard-coded set of values
specific to the SMDK5250 platform. Remove these commands as what they
did can be done instead with a series of mmc dev / bootpart / bootbus
commands instead now.
Cc: Amar <amarendra.xt@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Add a bootbus sub-command to the mmc command to allow for setting
the boot_bus_width, reset_boot_bus_width and boot_mode fields of
BOOT_BUS_WIDTH (EXT_CSD[177]).
Add a partconf sub-command to the mmc command to allow for setting
the boot_ack, boot_partition and partition_access fields of
PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this
requires changing the check for 'part' from an strncmp to a strcmp, like
the rest of the sub-commands.
Cc: Andy Fleming <afleming@gmail.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
As per the below commit
"mmc: sdhci: add the quirk for broken r1b response"
(sha1: 3a6383207be3f71b39004e64464a6e99290b16fa)
need to add quirk SDHCI_QUIRK_BROKEN_R1B, when the
response type is R1b.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch corrects the divider value written to CLKDIV register.
Since SDCLKIN is divided inside controller by the DIVRATIO value set
in the CLKSEL register, we need to use the same output clock value to
calculate the CLKDIV value.
as per user manual: cclk_in = SDCLKIN / (DIVRATIO + 1)
Input parameter to mmc_clk is changed to dwmci_host, since
we need the same to read DWMCI_CLKSEL register.
This improves the read timing values for channel 0 on SMDK5250
from 0.288sec to 0.144sec
Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
U-Boot currently sets MMC cards' RCA register to 0. This value is
reserved according to the specification. Use a value of 1 instead, just
like the Linux kernel.
Up until now this driver only worked with data cache disabled.
To make it work with enabled data cache following changes were required:
* Flush Tx/Rx buffer descriptors their modification
* Invalidate Tx/Rx buffer descriptors before reading its values
* Flush cache for data passed from CPU to GMAC
* Invalidate cache for data passed from GMAC to CPU
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
With this change driver will benefit from existing phylib and thus
custom phy functionality implemented in the driver will go away:
* Instantiation of the driver is now much shorter - 2 parameters
instead of 4.
* Simplified phy management/functoinality in driver is replaced with
rich functionality of phylib.
* Support of custom phy initialization is now done with existing
"board_phy_config".
Note that after this change some previously used config options
(driver-specific PHY configuration) will be obsolete and they are simply
substituted with similar options of phylib.
For example:
* CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled
by default.
* CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy
explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise
automatically the first discovered on MDIO bus phy will be used
I believe there's no need now in "doc/README.designware_eth" because
user only needs to instantiate the driver with "designware_initialize"
whose prototype exists in "include/netdev.h".
Driver "init" function might be called multiple times.
On every "init" Tx/Rx buffer descriptors are initialized: "descs_init"
-> "{tx|rx}_descs_init".
In its turn those init functions set MAC's "{tx|rx}desclistaddr" to
point on the first buffer descriptor in the list.
So CPU to start operation from the first buffer descriptor as well after
every "init" we have to reset "{tx|rx}_currdescnum".
EMAC_VLANx regs is not properly initiallized in u-boot, once it's overwrite in the
kernel when DSA enabled, hot reset will lead to bringing up EMAC fail in u-boot.
Signed-off-by: Aaron Wu <Aaron.Wu@analog.com>
When ARCH_DMA_MINALIGN is greater than header size of the bit file, and buf is
not aligned, new_buf address became greater then buf_start address and the
load_word loop corrupts bit file data.
A work around is to decrease new_buf of ARCH_DMA_MINALIGN, it might corrupt data
before buf but permits to load correctly.
Signed-off-by: Stany MARCEL <smarcel@novasys-ingenierie.com>
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive
generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc
instead.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
This driver is no longer used, remove it.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Michael Schwingen <michael@schwingen.org>
The driver is no longer used, remove it.
