path: root/drivers
2013-03-04Merge branch 'mem' of git://git.denx.de/u-boot-x86Tom Rini
2013-03-04Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-03-04blackfin: add bf6xx spi driverScott Jiang
Spi driver for bf60x is different from old one, so implement a new driver for it. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add rsi/sdh supportSonic Zhang
Add rsi/sdh support for bf60x. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-02-28net: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in net/ Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28sandbox: Improve sandbox serial port keyboard interfaceTaylor Hutt
Implements the tstc() interface for the serial driver. Multiplexing the console between the serial port and a keyboard uses a polling method of checking if characters are available; this means that the serial console must be non-blocking when attempting to read characters. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-22mtd: nand: Check if NAND is locked tight before lock cmdsJoe Hershberger
If the NAND is locked tight, commands such as lock and unlock will not work, but the NAND chip may not report an error. Check the lock tight status before attempting such operations so that an error status can be reported if we know the operation will not succeed. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-02-20gpio: Build the da8xx_gpio code for the davinci644x deviceHolger Hans Peter Freyther
The differences include the number of GPIOs and that one is not required to set the pinmux on request. Signed-off-by: Holger Hans Peter Freyther <holger@freyther.de>
2013-02-19serial/ns16550: don't generate functions for undefined portsScott Wood
This saved 640 bytes on MPC8536DS (a board with two of the six ports defined). Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-02-15kmeter1_nand: allow uasge of NAND_ECC_SOFT_BCHHolger Brunck
If CONFIG_NAND_ECC_BCH is set we use 4-bit error corretion code instead of the 1-bit error correction code on the NAND device within this driver. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-11tegra: add SPI SLINK driverAllen Martin
Add driver for tegra SPI "SLINK" style driver. This controller is similar to the tegra20 SPI "SFLASH" controller. The difference is that the SLINK controller is a genernal purpose SPI controller and the SFLASH controller is special purpose and can only talk to FLASH devices. In addition there are potentially many instances of an SLINK controller on tegra and only a single instance of SFLASH. Tegra20 is currently ths only version of tegra that instantiates an SFLASH controller. This driver supports basic PIO mode of operation and is configurable (CONFIG_OF_CONTROL) to be driven off devicetree bindings. Up to 4 devices per controller may be attached, although typically only a single chip select line is exposed from tegra per controller so in reality this is usually limited to 1. To enable this driver, use CONFIG_TEGRA_SLINK Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: spi: add fdt support to tegra SPI SFLASH driverAllen Martin
Add support for configuring tegra SPI driver from devicetree. Support is keyed off CONFIG_OF_CONTROL. Add entry in seaboard dts file for spi controller to describe seaboard spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-06sf: stmicro: Add support for N25Q256AJagannadha Sutradharudu Teki
Add support for Numonyx N25Q256A SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-06sf: stmicro: Add support for N25Q32AJagannadha Sutradharudu Teki
Add support for Numonyx N25Q32A SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-06sf: stmicro: Add support for N25Q32Jagannadha Sutradharudu Teki
Add support for Numonyx N25Q32 SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-06sf: stmicro: Add support for N25Q64AJagannadha Sutradharudu Teki
Add support for Numonyx N25Q64A SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-06sf: winbond: Add W25Q64WJagannadha Sutradharudu Teki
Add support for Winbond's W25Q64W SPI flash. This device is used on xilinx zynq emulation platform. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-06sf: spansion: Correct the first byte of idcode1 for S25FL256S partJagannadha Sutradharudu Teki
This patch corrected the first byte of idcode1 for S25FL256S SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-02-04serial: arm_dcc: Fix compilation warning and remove unneeded initializationMichal Simek
- arm_dcc_dev is already initialized. - Remove unused rc variable Warning log: arm_dcc.c: In function 'drv_arm_dcc_init': arm_dcc.c:145:6: warning: unused variable 'rc' [-Wunused-variable] Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2013-02-04serial: arm_dcc: Remove CONFIG_ARM_DCC_MULTI optionMichal Simek
CONFIG_ARM_DCC_MULTI should be also removed in the patch "serial: Remove CONFIG_SERIAL_MULTI from serial drivers" (sha1: a3827250606895ec2dd4b8d867342b7cabf3692f) Because the driver defines serial_* functions which cause conflict with serial.c (multiple definition of serial_*) Removing CONFIG_SERIAL_MULTI function also require to define default_serial_console for cases where another serial driver is not available in the system. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2013-02-04sf: stmicro: add support for N25Q064Jagannadha Sutradharudu Teki
Add support for Numonyx N25Q064 SPI flash. Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-02-04drivers/block/systemace - fixed data type in "systemace_read" to match ↵Alexey Brodkin
prototype in "block_dev_desc_t" Currently we have "unsigned long blkcnt" which is fine with CONFIG_SYS_64BIT_LBA undefined because "lbaint_t" is basically the same "unsigned long". If CONFIG_SYS_64BIT_LBA gets defined "lbaint_t" is defined as "unsigned long long". Even though not many embedded systems have CONFIG_SYS_64BIT_LBA defined it's good to have types in function implementation that match exactly with prototypes. Signed-off-by: Alexey Brodkin <alexey.brodkin@gmail.com>
2013-02-04ppc: arm: Move sdhc_clk into arch_global_dataSimon Glass
This is used by both powerpc and arm, but I think it still qualifies as architecture-specific. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move mpc512x clocks to arch_global_dataSimon Glass
Move ips_clk and csb_clk into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move mpc5xxx clocks to arch_global_dataSimon Glass
Move ipb_clk and pci_clk into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move CONFIG_QE to arch_global_dataSimon Glass
Move the quantative easing fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: m68k: Move i2c1_clk, i2c2_clk to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. This is needed for both ppc and m68k since they share the i2c driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04spi: xilinx_spi: Perform software reset during slave setupJason Wu
to make sure it is in the clear state. Signed-off-by: Jason Wu <huanyu@xilinx.com>
2013-02-04block: systemace: Added missing "else" in "ace_writew"Alexey Brodkin
System ACE compact flash controller supports either 8-bit (default) or 16-bit data transfers. And in corresponding driver we need to implement read/write of 16-bit data words properly for both modes of operation. In existing code if width==8 both branches get executed which may cause unexpected behavior of SystemAce controller. Addition of "else" fixes described issue and execution is done as expected for both (8-bit and 16-bit) data bus widths. Signed-off-by: Alexey Brodkin <alexey.brodkin@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-02Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-02-01ppc: Move brg_clk to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-30powerpc/mpc85xx:Add support of B4420 SoCPoonam Aggrwal
B4420 is a reduced personality of B4860 with fewer core/clusters(both SC3900 and e6500), fewer DDR controllers, fewer serdes lanes, fewer SGMII interfaces and reduced target frequencies. Key differences between B4860 and B4420 ---------------------------------------- B4420 has: 1. Fewer e6500 cores: 1 cluster with 2 e6500 cores 2. Fewer SC3900 cores/clusters: 1 cluster with 2 SC3900 cores per cluster. 3. Single DDRC 4. 2X 4 lane serdes 5. 3 SGMII interfaces 6. no sRIO 7. no 10G Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/mpc85xx: Few updates for B4860 cpu changesPoonam Aggrwal
- Added some more serdes1 and serdes2 combinations serdes1= 0x2c, 0x2d, 0x2e serdes2= 0x7a, 0x8d, 0x98 - Updated Number of DDR controllers to 2. - Added FMAN file for B4860, drivers/net/fm/b4860.c Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-29i2c: mxs: Staticize the functions in the driverMarek Vasut
The local functions in the mxs i2c driver are not marked static, make it so. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de>
2013-01-28mxs: mmc: Fix the MMC driver for MX23Marek Vasut
The MX23 has different layout of DMA channels. Fix the MMC driver to support MX23. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28mxs: mmc: Allow overriding default card detect implementationMarek Vasut
Some MXS based boards do not implement the card-detect signal. Allow user to specify alternate card-detect implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28mxs: mmc: Fix MMC reset on iMX23Otavio Salvador
This does the same reset mask as done in v3.7 Linux kernel code. The block is properly configured for MMC operation that way. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28mxs: dma: Fix APBH DMA driver for MX23Marek Vasut
The MX23 has less channels for the APBH DMA, sligtly different register layout and some bits in those registers are placed differently. Reflect this in the driver. This patch fixes MMC/DMA issue on MX23. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28net: fec_mxc: get phydev before fec_probeTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-28net: fec_mxc: only call phy_connect in fec_probeTroy Kisky
This allows us to create the phydev before calling fec_probe in later patch. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-28net: fec_mxc: use fec_set_dev_name to set nameTroy Kisky
2013-01-28phy: add phy_find_by_mask/phy_connect_devTroy Kisky
It is useful to be able to try a range of possible phy addresses to connect. Also, an ethernet device is not required to use phy_find_by_mask leading to better separation of mii vs ethernet, as suggested by Andy Fleming. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-28net: fec_mxc: have fecmxc_initialize call fecmxc_initialize_multiTroy Kisky
Having only one call to fec_probe will ease the changing of its parameters. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-28net: fec_mxc: change fec_mii_setspeed parameterTroy Kisky
Only the hardware ethernet registers are needed for this function, so don't pass the more general structure. I'm trying to separate MII and fec. This also fixes MX28 fec_mii_setspeed use on secondary ethernet port This was found by inspection of the code and should be checked on real hardware. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-28net: fec_mxc: delete CONFIG_FEC_MXC_MULTITroy Kisky
It is more logical to test for CONFIG_FEC_MXC_PHYADDR to determine whether to define the function fecmxc_initialize. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-21mmc: Limit the number of used SSP ports on MX23Marek Vasut
The MX23 can only use two SSP ports. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andy Fleming <afleming@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: clock: Use 'mxs' prefix for methodsOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: ssp: Pull out the SSP bus to regs conversionMarek Vasut
Create function which converts SSP bus number to SSP register pointer. This functionality is reimplemented multiple times in the code, thus make one common implementation. Moreover, make it a switch(), since the SSP ports are not mapped in such nice linear fashion on MX23, therefore having it a switch will simplify things there. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andy Fleming <afleming@freescale.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
