Patch by Stefan Roese, 1 Mar 2006
* Add env-variable "unlock" to handle initial state of sectors
(locked/unlocked).
Only the U-Boot image and it's environment is protected,
all other sectors are unprotected (unlocked) if flash
hardware protection is used (CFG_FLASH_PROTECTION) and
the environment variable "unlock" is set to "yes".
Patch by Stefan Roese, 28 Feb 2006
* Update drivers/cfi_flash.c:
- find_sector() called in both versions of flash_write_cfiword()
Patch by Peter Pearse, 27th Feb 2006
* CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode
Patch by Jose Maria Lopez, 16 Jan 2006
* Add support for AMD/Spansion Flashes in flash_write_cfibuffer
Patch by Alex Bastos and Thomas Schaefer, 2005-08-29
* Changes/fixes for drivers/cfi_flash.c:
We *should* check if there are any error bits if the previous call
returned ERR_OK (Otherwise we will have output an error message in
flash_status_check() already.) The original code would only check for
error bits if flash_status_check() returns ERR_TIMEOUT.
Patch by Marcus Hall, 23 Aug 2005
- Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c
- Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c
Patch by Sangmoon Kim, 19 Aug 2005
* Fixes for drivers/cfi_flash.c:
- Fix wrong timeout value usage in flash_status_check()
- Round write_tout up when converting to msec in flash_get_size()
- Remove clearing flash status at the end of flash_write_cfibuffer()
which sets Intel 28F640J3 flash back to command mode on CSB472
Patch by Tolunay Orkun, 02 July 2005
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file().
Patch by Reinhard Arlt, 30 Dec 2005
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c
- CFG_FLASH_QUIET_TEST added to use the common CFI driver
for bank autodetection
Patch by Stefan Roese, 22 Nov 2005
Patch by Art Shipkowski, 12 May 2005
Cleanup.
Patch by James MacAulay, 07 Oct 2005
Patch by Anders Larsen, 07 Oct 2005
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board.
Patch by Stefan Roese, 08 Oct 2005
Patch by Marcus Hall, 24 Aug 2005
Patch by Anders Larsen, 29 Apr 2005
* Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005
(8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
Patch by Rowel Atienza, 06 Apr 2005
Patch by Gleb Natapov, 21 Mar 2005
- Resolve the FIXME with respect to saving the u-boot environment.
- Make the default load address land in real memory.
- Fix lan91c96 SMC_{in,out}{b,w,l}() macros
Patch by David Brownell, 10 Mar 2005
- fix for ES2 differences.
- switch to using the cfi_flash driver.
- fix SRAM build address.
- fix for GP device operation.
- unlock SRAM for GP devices.
- display more device information.
- fix potential deadlock in omap24xx_i2c driver.
- fix DLL load values to match dpllout*1 operation.
- fix 2nd chip select init for combo DDR device.
- add support for CFI Intel 28F256L18 on H4 board.
Patch by Richard Woodruff, 03 Mar 2005
Patch by Zachary Landau, 11 Feb 2005
Use drivers/cfi_flash.c instead of private flash driver;
Remove hardcoded personalized settings from omap5912osk.h;
Fix spacing with (RO) marks in 'flinfo' output.
Patch by Michael Bendzick, 14 Jan 2005
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
Fix "WARNING: flash_make_cmd: unsuppported LittleEndian mode"
message when probing for nonexistent flash in little endian mode.
As a side effect more efficient and smaller code is generated,
which is always a Good Thing (TM).
Patch by Ladislav Michl, 24 Sep 2005
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP).
Add support for eeprom write-enable (CFG_EEPROM_WREN).
Patch by Stefan Roese, 22 Sep 2005
Patch by Stefan Roese, 21 Sep 2005
Patch by Anders Larsen, 26 Apr 2005
Patch by Stefan Roese, 08 Aug 2005
Patch by Josef Wagner, 03 Aug 2005
Patch by Denis Peter, 06 Dec 2004
- C++ comments
- Trailing white space
- Indentation not by TAB
- Excessive amount of empty lines
- Trailing empty lines
Patch by Steven Blakeslee, 27 Jul 2005
Add support for the Freescale MPC8349ADS board.
Move the TSEC driver out of cpu/mpc85xx as it will be shared
by the upcoming mpc83xx family as well.
(0 = infinite)
* Use CONFIG_DRIVER_KS8695ETH to enable KS8695 ethernet driver on
those boards that use it.
add support for the KS8695P (ARM 922 based) CPU
* Patch by Steven Scholz, 19 May 2005:
Add support for CONFIG_SERIAL_TAG on ARM boards
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
Cleanup.
- fix clock rates
- remove debug messages
- fix flash sector protection
* Patch by Steven Scholz, 07 Apr 2005:
Fix warning in cpu/arm920t/at91rm9200/i2c.c
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
Cleanup duplicate definition of overwrite_console()
* Update TQM5200 configuration;
prepare for Rev. 200 starter kit boards
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
