Add AM43xx support in the required places
There are many musb prints in SPL and U-Boot log.
These prints are required only during musb debug.
So replacing printk with pr_debug in musb_core.
Tested-by: Heiko Schocher <hs@denx.de>
Acked-by: Heiko Schocher <hs@denx.de>
Add the tca642x gpio expander driver
Datasheet:
http://www.ti.com/product/tca6424a
Signed-off-by: Dan Murphy <dmurphy@ti.com>
accessing a lan9303 switch with the cpsw driver results in wrong
speed detection, as the switch sets the BMSR_ERCAP in BMSR
register, and follow read of the MII_STAT1000 register fails, as
the switch does not support it. Current code did not check,
if a phy_read() fails ... fix this.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Enable hardware statistics for all ports, enabling only to host port is useless
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
BD ram address may vary in various SOC, so removing the hardcoding and
passing the same information through platform data
Conflict over SPDX changes means that one change was effectively dropped
as it was fixing typos in a removed hunk of text.
arch/mips/cpu/mips64/start.S
There is no reason to wait for the entire frame to start DMA on receive,
so enable rx cut-thru for better performance.
Qemu emulates the Galileo GT64120 System Controller
which provides a CPU bus to PCI bus bridge.
The patch adds driver for this bridge and enables
PCI support for the emulated Malta board.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
The pcnet driver uses the pci_phys_to_mem function
to get the memory address of the DMA buffers. This
This assumes an 1:1 mapping between the PCI and
physical memory which is not true on all platforms.
On MIPS platform U-Boot is running within a mapped
memory region, and the pci_phys_to_mem macro can't
be used to obtain the memory address of the buffers.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Even though the header files is used only by the
pci_ftpci100 driver, it contains declaration for
a function which is used by external code.
Move the header file to a common location which
lets external code use it.
Compile tested only.
Cc: Macpaul Lin <macpaul@andestech.com>
The pci_ftpci_init() function is implemented
in 'drivers/pci/pci_ftpci100.c' however it is
always called by external code.
Add function declaration into ftpci100.h to
make it visible for external code.
Add a const keyword to the sect_buf argument of
ide_write_data to fix the following warning:
cmd_ide.c: In function '__ide_output_data':
cmd_ide.c:548: warning: passing argument 2 of 'ide_write_data' discards qualifiers from pointer target type
/devel/u-boot.git/include/ide.h:76: note: expected 'ulong *' but argument is of type 'const ulong *'
Also modify the driver-model documentation to
match with the new prototype.
The FTSDC010_DCR_FIFO_RST symbol is conditionally
defined in <faraday/ftsdc010.h> and it is available
available when CONFIG_FTSDC010_SDIO is enabled.
However the actual driver code unconditionally uses
the FTSDC010_DCR_FIFO_RST constant and this causes
build error if CONFIG_FTSDC010_SDIO is not enabled.
The following error happens when compiling for the
adp-ag101 board:
ftsdc010_mci.c: In function 'ftsdc010_request':
ftsdc010_mci.c:178: error: 'FTSDC010_DCR_FIFO_RST' undeclared (first use in this function)
ftsdc010_mci.c:178: error: (Each undeclared identifier is reported only once
ftsdc010_mci.c:178: error: for each function it appears in.)
The patch ensures that the FTSDC010_DCR_FIFO_RST
symbol gets used only if CONFIG_FTSDC010_SDIO is
defined.
Cc: Kuo-Jung Su <dantesu@faraday-tech.com>
Reviewed-by: Kuo-Jung Su <dantesu@faraday-tech.com>
Faraday FTI2C010 is a multi-function I2C controller
which supports both master and slave mode.
This patch simplily implements the master mode only.
Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com>
CC: Heiko Schocher <hs@denx.de>
This patch adds support for Vybrid VF610 platform.
There are some differences between i.MX6 and Vybrid for I2C controller.
(1) The registers' offset are different.
(2) The I2C clock divider values are different.
(3) In I2C control register, the enable/disable/reset bit is inverted for Vybrid comparing to i.MX6.
(4) In I2C status register, the interrupt flag bit is cleared by writing "1" for Vybrid.
For i.MX6, this bit is cleared by writing "0".
(5) In I2C status register, the arbitration lost flag bit is cleared by writing "1" for Vybrid.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra
i2c driver to support this.
Rather than using a variable in various places, add a single function,
tegra_i2c_get_bus(), which returns a pointer to information about a
bus.
This will make it easier to move to the new i2c framework.
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
- added to soft_i2c driver new multibus/multiadpater support
This Patch introduce the new i2c_core file, which holds
the I2C core functions, for the rework of the multibus/
multiadapter support.
Also adds changes in i2c.h for the new I2C multibus/multiadapter
support. This new support can be activated with the
CONFIG_SYS_I2C define.
Cc: Mike Frysinger <vapier@gentoo.org>
Commit de1d786e (add support for Xilinx 1000BASE-X phy (GTX)) introduced the
checking for ESTATUS_1000_XHALF, but it incorrectly sets the
SUPPORTED_1000baseX_Full flag in this case.
Set the SUPPORTED_1000baseX_Half flag instead.
Acked-by: Charles Coldwell <coldwell@gmail.com>
Reviewed-By: Sascha Silbe <t-uboot@infra-silbe.de>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
de1d786 [add support for Xilinx 1000BASE-X phy (GTX)] introduced a
check for the extended status register in order to support
1Gbps-capable PHYs that don't have the 1000BASE-T registers. Since
Extended Status only indicates what the PHY (i.e. the local side) is
capable of, this broke communication with non-1Gbps peers.
Only check the extended status if the 1000BASE-T registers are
actually missing so we don't end up setting speed to 1Gbps even though
the previous test (for the combination of local and peer support for
1Gbps) already indicated we can't do 1Gbps with the current peer.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Dealing with the sys ctrl register should touch only the
relevant bits and not accidently the whole register. On i.MX6,
the sys control register contains bits which shouldn't be reset to
0, e.g. SYS_CTRL[3-0] and IPP_RST_N (SYS_CTRL[23]).
Do this by read/modify/write instead of just a 32bit write.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
1. No contents of "asm/arch/clk.h" is used within "dw_mmc.c".
2. If arch doesn't have "asm/arch/clk.h" driver won't build.
Without mentioned inclusion dw_mmc driver could be built for arches
other than ARM. For ARM driver still builds without it.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Cc: Amar <amarendra.xt@samsung.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Fill the right command type when using CMD12 to stop data transfer.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
CC: Fleming Andrew-AFLEMING <AFLEMING@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
Add support for Atmel TPM devices with two wire interface.
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
if alen is 0: no longer start a write cycle before reading data.
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail()
because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC
mode.
Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
The MX28 multi-layer AHB bus can be too slow and trigger the
FEC DMA too early, before all the data hit the DRAM. This patch
ensures the data are written in the RAM before the DMA starts.
Please see the comment in the patch for full details.
This patch was produced with an amazing help from Albert Aribaud,
who pointed out it can possibly be such a bus synchronisation
issue.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
Remove incorrectly called and duplicate flush_dcache_range() call
from fec_mxc driver. The call is not needed, since the caches are
already flushed in fec_tbd_init(), moreover the second argument should
be the ending address, not size.
Reported-by: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Tegra30 and Tegra114 are compatible except PLL parameters.
Tested on Tegra30 Cardhu, and Tegra114 Dalmore
platforms. All works well.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Newer gcc versions warn about unused variables. This patch corrects a few of
those warnings that popped up in a build for the palmtreo680 board.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
The DFU's state machine original implementation author and copyright were
missing.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
This patch resolves the below mentioned compilation error of i2c driver
for non-FDT case
Compilation error:
s3c24x0_i2c.c: In function 'board_i2c_init':
s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use
in this function) s3c24x0_i2c.c:544:18: note: each undeclared
identifier is reported only once for each function it appears in
s3c24x0_i2c.c:545:3: warning: implicit declaration of function
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Signed-off-by: Amar <amarendra.xt@samsung.com>
Code for checking "splashpos" environment variable is
duplicated in drivers, move it to the common function.
Call this function also in the bmp display command to
consider "splashpos" settings.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
