Arndale board has AX88760, which is USB 2.0 Hub & USB 2.0 Ethernet Combo
controller, connected to HSIC Phy of USB host controller via USB3503 hub.
This patch uses board specific board_usb_init function to perform reset
sequence for USB3503 hub and enables the relevant config options for
network to work.
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
The controller has 3 ports. The port0 is for USB 2.0 Phy, port1 and port2
are for HSIC phys. The usb 2.0 phy is already being setup. This patch
sets up the hsic phys.
The fifo size of ep0 is 64 bytes, and if the packet size grater than
64 bytes, the driver would have to fill up the fifo multiple times,
and before filling up the fifo, the driver should make sure the fifo
is empty by checking fifo empty indication.
However there is a hardware bug that the fifo empty indication is
somehow a bit earlier than fifo reset. So if I don't add an extra
delay here, the data might be corrupted. (i.e., 1 byte missing)
After a couple of tests, it truns out that 1 usec is good enough.
This workaround should be applied to all hardware revisions.
Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com>
CC: Marek Vasut <marex@denx.de>
Since hardware revision 1.11.0, the following interrupt status
registers are now W1C (i.e., write 1 clear):
1. Interrupt Source Group 0 Register (0x144) (EP0 Abort: BIT5)
2. Interrupt Source Group 2 Register (0x14C) (All bits)
And before revision 1.11.0, these registers are all R/W.
Which means software must write a 0 to clear the status.
The array reserved as a placeholder in the structure ipu_idmac
should contain 44 32bit unsigned integer entries instead of 45
ones, because the placeholder is located bewteen the register
IDMAC_SC_CORD1 and the register IDMAC_CH_BUSY_1 with the address
offsets of 0x804c and 0x8100 respectively.
Reported-by: Robin Gong <b38343@freescale.com>
Acked-by: Robin Gong <b38343@freescale.com>
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
The array reserved1 as a placeholder in the structure ipu_cm
should contain 4 32bit unsigned integer entries instead of 16
IPU_CH_DB_MODE_SEL_1 and the register IPU_ALT_CH_DB_MODE_SEL_0
with the address offsets of 0x154 and 0x168 respectively.
Remove the flag SECT_4K for device N25Q128 as the 4K-byte
sub sector erase granularity is available only for top/bottom
8 sectors in some of the N25Q128 chips.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This config will use for defining greater than single flash support.
currently - DUAL_STACKED and DUAL_PARALLEL.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch added support for accessing dual memories in
parallel connection with single chipselect line from controller.
For more info - see doc/SPI/README.dual-flash
stacked connection with single chipselect line from controller.
Unified the bar code from read_ops into a spi_flash_bar()
- comment typo's
- func args have a proper names
QEB code comprises of couple of flash register read/write operations,
this patch moved flash register operations on to sf_op
Added macronix flash quad read/write commands support and
it's up to the respective controller driver usecase to
configure the respective commands by defining SPI RX/TX
operation modes from include/spi.h on the driver.
This patch adds set QEB support for macronix flash devices
which are trying to program/read quad operations.
Discovered the read dummy_byte based on the
configured read command.
This patch adds support QUAD_IO_FAST read command.
Moved the flash params table from sf_probe.c and
placed on to sf_params.c, hence flash params file will
alter based on new addons.
This patch enabled RD_FULL and WR_QPP for supported flashes
in micron, winbond and spansion.
Remaining parts will be add in future patches.
This patch provides support to set the quad enable bit on flash.
quad enable bit needs to set before performing any quad IO
operations on respective SPI flashes.
Currently added set quad enable bit for winbond and spansion flash
devices. stmicro flash doesn't require to set as qeb is volatile.
remaining flash devices support will add in future patches.
This patch provides support to program a flash config register.
Configuration register contains the control bits used to configure
the different configurations and security features of a device.
This patch add quad commands support like
- QUAD_PAGE_PROGRAM => for write program
- QUAD_OUTPUT_FAST ->> for read program
Current sf uses FAST_READ command, this patch adds support to
use the different/extended read command.
This implementation will determine the fastest command by taking
the supported commands from the flash and the controller, controller
is always been a priority.
We have a sh_spi_clear_bit() function, there's no reason not to use it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
The Faraday FTSSP010 is a multi-function controller
which supports I2S/SPI/SSP/AC97/SPDIF. However This
patch implements only the SPI mode.
NOTE:
The DMA and CS/Clock control logic has been altered
since hardware revision 1.19.0. So this patch
would first detects the revision id of the underlying
chip, and then switch to the corresponding software
control routines.
CC: Tom Rini <trini@ti.com>
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be
added to include/configs/exynos5-dt.h now.
include/configs/exynos5250-dt.h
To add the DesignWare MMC driver support for Altera SOCFPGA. It
required information such as clocks and bus width from platform
specific files (SOCFPGA handoff files)
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The eMMC and the SD-Card specifications describe the optional SET_DSR command.
During measurements at our lab we found that some cards implementing this feature
having really strong driver strengts per default. This can lead to voltage peaks
above the specification of the host on signal edges for data sent from a card to
the host.
Since availability of a given card type may be shorter than the time a certain
hardware will be produced it is useful to have support for this command (Alternative
would be changing termination resistors and adapting the driver strength of the
host to the used card.)
Following proposal for an implementation:
- new field that reflects CSD field DSR_IMP in struct mmc
- new field for design specific DSR value in struct mmc
- board code can set DSR value in mmc struct just after registering an controller
- mmc_startup sends the the stored DSR value before selecting a card, if DSR_IMP is set
Additionally the mmc command is extended to make is possible to play around with different
DSR values.
The concept was tested on a i.MX53 based platform using a Micron eMMC card where the default
DSR is 0x0400 (12mA) but in our design 0x0100 (0x0100) were enough. To use this feature for
instance on a mx53loco one have to add a call to mmc_set_dsr() in board_mmc_init() after
calling fsl_esdhc_initialize() for the eMMC.
Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
Fixup prints to show where the print is done from, and
a few minor formatting/grammar issues.
Signed-off-by: Darwin Rambo <drambo@broadcom.com>
Bounce buffer implementation takes care of proper data buffer alignemt
and correct flush/invalidation of data cache at once so we no longer
depend on input data variety and make sure CPU and MMC controller deal
with expected data in case of enabled data cache.
Bounce buffer requires to add its definition (CONFIG_BOUNCE_BUFFER) in
board configuration, otherwise corresponding library won't be compiled
and linker will fail to build resulting executable.
Difference since v1 - fixed compile-time warning with type casting to
"void *":
Slight edit to remove UTF8 characters in the commit message.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
passing argument 2 of 'bounce_buffer_start' discards 'const' qualifier
from pointer target type
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Alim Akhtar <alim.akhtar@samsung.com>
Cc: Amar <amarendra.xt@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Andy Fleming <afleming@gmail.com>
The original codes misused recvbuf in source buffer instead of sendbuf,
and read from incorrect offset 14 instead of 22.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
Add a simple TPM emulator for sandbox. It only supports a small subset of
TPM operations. However, these are enough to perform common tasks.
Note this is an initial commit to get this working, but it could use
cleaning up (for example constants instead of open-coded values).
Provide a way to use any host file or device as a block device in U-Boot.
This can be used to provide filesystem access within U-Boot to an ext2
image file on the host, for example.
The support is plumbed into the filesystem and partition interfaces.
We don't want to print a message in the driver every time we find a missing
device. Pass the information back to the caller where a message can be printed
if desired.
Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net>
- Removed change to part.c get_device_and_partition()
To enhance the SDMMC DesignWare driver to use calloc instead of
malloc. This will avoid the incident that uninitialized members
of mmc structure are later used for NULL comparison.
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Andy Fleming <afleming@freescale.com>
The omap3_zoom2 board has not been updated for a correct CONFIG_SYS_HZ
and Tom Rix's email has long been bouncing.
include/micrel.h
The conflict above was trivial, caused by four lines being
added in both branches with different whitepace.
Enable fuse supply before fuse programming and disable after.
Signed-off-by: Sergey Alyoshin <alyoshin.s@gmail.com>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Fix unaligned access in OneNAND core. The problem is that the ffchars[] array
is an array of "unsigned char", but in onenand_write_ops_nolock() can be passed
to the memcpy_16() function. The memcpy_16() function will treat the buffer as
an array of "unsigned short", thus triggering unaligned access if the compiler
decided ffchars[] to be not aligned.
I managed to trigger the problem with regular ELDK 5.4 GCC compiler.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Tom Rini <trini@ti.com>
claim spi bus while doing memory copy, this will set up
the spi controller device control register before doing
a memory read.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Tested-by: Yebio Mesfin <ymesfin@ti.com>
Fix the register access in EHCI HCD. We need to use address of the register
as an ehci_writel() argument.
In case the controller is not initialized, we shall not de-initialize it.
As the control structure will not be filled, we will produce a null ptr
dereference if the controller is not inited.
The detection function of the EHCI PCI controller was really cryptic,
add a beefy comment and clean the portion of the code up a bit. No
change in the logic of the code.
Code cleanup for dfu_bind_config function
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
It is necessary to deter the host from sending subsequent DFU_GETSTATUS
request in the case of e.g. writing the buffer to medium.
Here the timeout is increased when we fill up the whole buffer. This delay
allows eMMC memory to perform its internal operations.
Otherwise we end up with HOST's error regarding GET_STATUS receive timeout.
The method for exporting size of allocated buffer is provided.
It is afterwards used by USB's dfu function code.
