Reset the eSDHC controller first before initialize the eSDHC controller.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Including boot from eSDHC and eSPI.
This patch is from MPC8536, and fixed some hunk failed error.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
The max clock of MMC is 52MHz, and the clock mask is wrong.
Therefore, fixed them.
Signed-off-by: Jerry Huang <Changm-Ming.Huang@freescale.com>
Auto CMD12 command support for P1022DS eSDHC driver.
Multiple block read support
Moved the mdio regs out of the tsec structure,and
provided different offsets for tsec base and mdio
base so that provision for etsec2.0 can be provided.
This patch helps in providing the support for etsec2.0
In etsec2.0, the MDIO register space and the etsec reg
space are different.
Also, moved the TSEC_BASE_ADDR and MDIO_BASE_ADDR definitons into
platform specific files.
Signed-off-by: Sandeep Kumar <Sandeep.Kumar@freescale.com>
In Rev 1.0 of P1022, in the esdhc Host Capabilities register
the 1.8V bit is set; it should not be. So we exclude this
setting in the driver.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
On P1022, the data snoop bit (in the sata ip) is at bit 28.
Account for this. Additionally, change the mode to enterprise mode
since on reset, it is in legacy mode.
This patch adds support for P1022DS to u-boot. The following items
have been tested - DDR (spd-based), I2C, Flash, Vetsec1, 2, DIU,
PEX 1,2,3.
Currently, the last block of NAND devices can't be accessed. This patch
fixes this issue by correcting the boundary checking (off-by-one error).
Cc: Scott Wood <scottwood@freescale.com>
Depending on offset, flash size and the number of bad blocks,
get_len_incl_bad may return a too small value which may lead to:
1) If there are no bad blocks, nand_{read,write}_skip_bad chooses the
bad block aware read/write code. This may hurt performance, but does
not have any adverse effects.
2) If there are bad blocks, the nand_{read,write}_skip_bad may choose
the bad block unaware read/write code (if len_incl_bad == *length)
which leads to corrupted data.
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
The only missing chipselect line support is CS2, and I need it on
CS2...
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Reported-by: Peter Gombos <gombos@protecta.hu>
Signed-off-by: Jason McMullan <jason.mcmullan@gmail.com>
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Edited commit message.
Make smc911x_initialize return -1 on error and number of interfaces
detected otherwise.
Sometimes, inside NetLoop, eth_halt() is called before eth_init() has
been called. This is harmless except for free() calls to pointers
which have not been allocated yet.
This patch initializes those pointers to NULL and allocates them only
the first time. This way we can get rid of free calls in halt callback.
This has been tested in i.MX27 Litekit board and eldk-4.2 toolchains.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
This patch fixes erroneous access to the ethernet PHY which broke the driver.
1. Selector field in the auto-negotiation register must be 0x00001 for
using 802.3, not 0x00000 which is reseved.
2. Access to the PHY address specified by CONFIG_FEC_MXC_PHYADDR, not
0x0 fixed address.
Now using proper defines for auto-negotiation register.
This patch fixes the following warnings:
Configuring for xaeniax board...
smc91111_eeprom.c: In function 'print_macaddr':
smc91111_eeprom.c:278: warning: suggest parentheses around + or - in operand of &
smc91111_eeprom.c:281: warning: suggest parentheses around + or - in operand of &
Configuring for xsengine board...
smc91111_eeprom.c:278: warning: suggest parentheses around + or - inside shift
smc91111_eeprom.c:281: warning: suggest parentheses around + or - inside shift
The following error was seen on impa7 board, due to its use of a 32-bit bus
on CS8900.
cs8900.c:137:37: error: macro "get_reg_init_bus" passed 2 arguments, but takes just 1
This patch gives the macro the correct number of arguments
Ensure all CS8900 data structures are assigned before accessing device
Signed-off-by: Hui.Tang <zetalabs@gmail.com>
commit 70ed869e broke fsl pcie end-point initialization.
Returning 0 is not correct. The function must return the first free
bus number for the next controller.
fsl_pci_init() must still be called and a bus allocated even if the
controller is an end-point.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Vivek Mahajan <vivek.mahajan@freescale.com>
This reverts commit 70ed869ea5f6b1d13d7b140c83ec0dcd8a127ddc.
There isn't any need to modify the API for fsl_pci_init_port to pass the
status of host/agent(end-point) status. We can determine that
internally to fsl_pci_init_port. Revert the patch that makes the API
change.
Proper behavior is to pull MAC address from NVRAM in the initialization() an
stuff it in dev->address, then program the device from dev->address in
the init() function.
Currently the CFI driver issues both AMD and Intel reset commands.
This is because the driver doesn't know yet which chips are connected.
This dual reset seems to cause problems with the M29W128G chips as
reported by Richard Retanubun. This patch now introduces a weak default
function for the CFI reset command, still with both resets. This can
be overridden by a board specific version if necessary.
Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
Add missing newline.
Cc: Luigi Mantellini <luigi.mantellini@idf-hit.com>
Cc: Ben Warren <biggerbadderben@gmail.com>
Setup QE pin multiplexing for USB function, configure needed BCSRs
and add some fdt fixups.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Originally written by Jason Jin and Mingkai Hu for mpc8536.
When QorIQ based board is configured as a PCIe agent, then unlock/enable
inbound PCI configuration cycles and init a 4K inbound memory window;
so that a PCIe host can access the PCIe agents SDRAM at address 0x0
* Supported in fsl_pci_init_port() after adding pcie_ep as a param
* Revamped copyright in drivers/pci/fsl_pci_init.c
* Mods in 85xx based board specific pci init after this change
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
Some of the new spi flash files were missing explicit license lines.
CC: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Move the test up in the function to not hang on systems without ethernet.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
fix the following compile warnings
warning: dereferencing type-punned pointer will break strict-aliasing rules
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
This patch re-formats the arm920t s3c24x0 nand driver in preparation for changes
to add support for the Embest SBC2440-II Board.
The changes are as follows:
- re-indent the code using Lindent
- make sure register layouts are defined using a C struct
- replace the upper-case typedef'ed C struct names with lower case
non-typedef'ed ones
- make sure registers are accessed using the proper accessor functions
- run checkpatch.pl and fix any error reports
It assumes the following patch has been applied first:
- [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009
- patches 1/4, 2/4 and 3/4 of this series
Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have
any s3c2400 or s3c2410 boards but need this patch applying before I can submit
patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400,
smdk2410 and trab configs to use the mtd nand driver (which isn't used by any
board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or
errors were found.
Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk>
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand
driver, in preparation for changes to add support for the Embest SBC2440-II Board.
non-typedef'ed ones
- patches 1/4 and 2/4 of this series
errors were found.
This patch includes the serial driver for s5pc1xx.
s5pc1xx uart driver needs own register setting and clock configuration.
So, need to special driver.
This patch includes the onenand driver for s5pc100
Refactor the smc911x driver to allow for detecting when the chip is missing.
I.e. the detect_chip() function is called earlier and will abort gracefully
when the Chip ID read returns all 1's.
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
Fix warning
Dereferencing type-punned pointer will break strict-aliasing rules
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
CC: Steve Sakoman <sakoman@gmail.com>
Acked-by: Tom Rix <Tom.Rix@windriver.com>
Forcing the tables into got2 caused extra relocation when using -mrelocatable.
This patch requires any board defining CONFIG_BIOSEMU to use -mrelocatable.
Acked-by: Jin Zhengxiong <Jason.Jin@freescale.com>
arbitrary number of mii buses.
This feature is useful when your board uses different mii buses for different
phys and all (or a part) of these buses are implemented via bit-banging mode.
The driver requires that the following macros should be defined into the board
configuration file:
CONFIG_BITBANGMII - Enable the miiphybb driver
CONFIG_BITBANGMII_MULTI - Enable the multi bus support
If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs
to define at least the following macros:
MII_INIT - Generic code to enable the MII bus (optional)
MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional)
MDIO_ACTIVE - Activate the MDIO pin as out pin
MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin
MDIO_READ - Read the MDIO pin
MDIO(v) - Write v on the MDIO pin
MDC_DECLARE - Declaration needed to access to the MDC pin (optional)
MDC(v) - Write v on the MDC pin
The previous macros make the driver compatible with the previous version
(that didn't support the multi-bus).
When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill
the bb_miiphy_buses[] array with a record for each required bus and declare
the bb_miiphy_buses_num variable with the number of mii buses.
The record (struct bb_miiphy_bus) has the following fields/callbacks (see
miiphy.h for details):
char name[] - The symbolic name that must be equal to the MII bus
registered name
int (*init)() - Initialization function called at startup time (just
before the Ethernet initialization)
int (*mdio_active)() - Activate the MDIO pin as output
int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin
int (*set_mdio)() - Write the MDIO pin
int (*get_mdio)() - Read the MDIO pin
int (*set_mdc)() - Write the MDC pin
int (*delay)() - Delay function
void *priv - Private data used by board specific code
The board code will look like:
struct bb_miiphy_bus bb_miiphy_buses[] = {
{ .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... },
{ .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... },
int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) /
sizeof(bb_miiphy_buses[0]);
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Modify all existing *.c files to use the new register names
as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
