Round the serial port clock divisor value returned by
calc_divisor()
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This got changed by commit 93c56f212c
[cfi_flash: support of long cmd in U-boot.]
Long is the wrong type because it will behave differently on 64bit
machines in a way that is probably not expected. u32 should be
enough.
Cc: Alexey Korolev <akorolev@infradead.org>
Cc: Vasiliy Leonenko <vasiliy.leonenko@mail.ru>
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
Add function of new PCI, pci_skip_dev and pci_print_dev.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
We need to wait while drawing engine clears frame
buffer before any further software accesses to frame
buffer will be initiated. Otherwise software drawn
parts could be partially destroyed by the drawing
engine or even GDC chip freeze could occur (as
observed on socrates board).
Clean Makefile
Move device specific values to driver for better reading
Redesign uartlite driver to in_be32 and out_be32 macros
Fix missing header in io.h
which happened when rounding the serial port clock divisor
The formula "counter = (u32) (gd->bus_clk / gd->baudrate) / 32"
can generate the wrong divisor due to integer division truncation.
Round the calculated divisor value by adding 1/2 the baudrate
before dividing by the baudrate.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Some boards based on AT91SAM926X-EK use smaller DF chips to keep
bootstrap, u-boot and its environment, using NAND or other external
storage for kernel and rootfs. This patch adds support for
small 1024x263 chip.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
This patch fixes bugs in usbdcore*.c related to the use of devices
with multiple configurations.
The original code made mistakes about the meaning of configuration value and
configuration index, and the resulting off-by-one errors resulted in:
* SET_CONFIGURATION always selected the first configuration, no matter what
wValue is being passed.
* GET_DESCRIPTOR/CONFIGURATION always returned the descriptor for the first
configuration (index 0).
Signed-off-by: Harald Welte <laforge@openmoko.org>
Acked-by: Markus Klotzbuecher <mk@denx.de>
This patch fixes NAND related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
This patch moves the check, if a device should be skipped in PCI PNP
configuration into the function pci_skip_dev(). This function is defined
as weak so that it can be overwritten by a platform specific one if
needed. The check if the device should get printed in the PCI summary upon
bootup (when CONFIG_PCI_SCAN_SHOW is defined) is moved to the function
pci_print_dev() which is also defined as weak too.
This PCI-X e1000 variant works by just adding in the correct
PCI IDs in the appropriate places.
calc_divisor().
Signed-off-by: John Roberts <john.roberts@pwav.com>
This is particularly problematic now that non-NAND-specific code is
including <nand.h>, and thus all debugging code is being compiled
regardless of whether it was requested, as reported by Scott McNutt
<smcnutt@psyent.com>.
This makes it easier to use the driver on other platforms.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
In order to consolidate more of the various MMC drivers around the
tree, we must first have a common place to put them.
As pointed out by Jerry Hicks, this patch corrects the device ID of
the Spansion AM29DL800BB NOR device. Verified against latest Spansion
datasheet (rev C4 from Dezember 2006).
Remove duplicate definitions in include/lxt971a.h.
Remove duplicate registers and bits definitions in
include/lxt971a.h for standard MII registers, and
use values in include/miiphy.h instead.
Renesas SH7763 has 2 channel Ethernet device.
This is 10/100/1000 Base support.
But this patch check 10/100 Base only.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
If enable DEBUG, can not compile ne2000 driver.
The driver need wait for the device updating signature to host.
If we don't wait for it, the driver can not detect the device(disk)
when the system powers up.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Stuart Wood <stuart.wood@labxtechnologies.com>
Signed-off-by: Tor Krill <tor@excito.com>
