This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
Add support for 4bpp bitmaps, currently only for GDF_32BIT_X888RGB
frame buffer format.
Fixes most of checkpatch warnings and errors in USB gadget stack.
The most frequently encountered problems are:
1) "(foo*)", "foo * bar", "foo* bar"
2) C99 // comments
3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '('
4) Spaces before '['
5) Spaces between function names and '('
6) Block braces in wrong places
7) Spaces before tabs
8) Macros with complex values not enclosed in parenthesis
9) Multiline comments start just after /*
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
The patch removes an endless loop in the usb_eth_send
if the tx_complete is not called before going
in the loop. The driver interrupt routine is called
allowing the driver to check if the TX is completed.
The buffer for the status request must be word aligned
because it is accessed with 32 bit pointer in the
eth_status_complete function.
The patch is based on commit bb9496c6f7e853e5d4edd5397c9d45f1968d623c
(done by Julia Lawall <julia@diku.dk>) from linux-2.6.git.
Since num is unsigned, it would seem better to use simple_strtoul that
simple_strtol.
Fix potential oops on rare error path.
The patch is based on commit e7b13ec9235b9fded90f826ceeb8c34548631351
(done by David Brownell <david-b@pacbell.net>) from linux-2.6.git.
Description of the issue taken from linux kernel bugzilla:
(https://bugzilla.kernel.org/show_bug.cgi?id=9594)
The potential error can be tracked down as follows:
(1) line 807: let the second conjunct on the "if" statment be false
meaning "dev->status_ep" is null. This means the "if" evaluates
to false.
follow thru the code until...
(2) line 808: usb_ep_disable(dev->status_ep) passes in a null argument,
however "usb_ep_disable" cannot handle that:
(from include/linux/usb/gadget.h)
191 static inline int
192 usb_ep_disable (struct usb_ep *ep)
193 {
194 return ep->ops->disable (ep);
195 }
Fix possible oops on stat_req->buf initialization and fix ep0 and
status_ep confusion (last one is just intended for stat_req keeping).
Replace 'strcpy' by more safe 'strlcpy' that is implemented in ether.c
Fix in_ep and out_ep confusion (rx_req was allocated from out_ep, not
from in_ep) and add lost dev->req freeing.
Replace Linux-like debug printout macros by native ones.
Applied after removing dead code like '#define DEBUG/#undef DEBUG'
Add lost 'qmult' definition for High Speed devices and make it
configurable through CONFIG_USB_ETH_QMULT.
Prohibit simultaneous usage of both old and new gadget stacks and
allow UDC drivers to be dependent on CONFIG_USB_ETHER.
Derived from Linux kernel 2.6.27
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The MUSB_TXCSR_MODE register setting isn't supported on Blackfin musb
parts, so stub it out to 0. This matches Linux behavior.
Now that the defines are moved to header files we don't need this
conditional compilation any more. Remove it.
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
cfi_flash_bank_addr(int bank_nr) returns the base addresses of the
requested bank. Introducing this weak default enables boards to override
this functions with a board specific version when required.
This feature will be used in the lwmon5 board update, supporting runtime
detection of 2 board revisions with different flash layouts.
This patch removes an unecessary check in the return statement. This is
not needed, since "info" is initializes to NULL. And "info" will not be
written to again, if the flash address is not found.
Additionally "info" is not initialized to "0" but to "NULL".
Recent changes caused that the HMI10 board now is included in the
boards built by MAKEALL, which revealed that compilation for this
board has been broken for a long time:
ps2ser.c: In function 'ps2ser_init':
ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function)
ps2ser.c:155: error: (Each undeclared identifier is reported only once
ps2ser.c:155: error: for each function it appears in.)
ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function)
ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function)
ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function)
ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function)
ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function)
ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function)
ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_putc':
ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_getc_hw':
ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_interrupt':
ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL.
Drop support for it.
Portions of this work were supported by funding from
the CE Linux Forum.
Commit d2bf29e3 caused a number of compiler warnings:
mmc.c: In function 'mmc_bwrite':
mmc.c:97: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
mmc.c:97: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'lbaint_t'
mmc.c: In function 'mmc_bread':
mmc.c:229: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'long unsigned int'
mmc.c:229: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'lbaint_t'
Fix these.
Cc: Lei Wen <leiwen@marvell.com>
Signed-off-by: Lei Wen <leiwen@marvell.com>
Due to a register glitch (result code <4 might show up right after the
start-calculation-bit was set), make sure the ECC has really started.
See 1c3275b656045aff9a75bb2c9f3251af1043ebb3 in the kernel.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
The Blackfin implementation of musb has a TXCOUNT register that needs to
be programmed when transmitting data.
Coding style cleanup.
This printk was added recently and results in ugly output on systems
with no NAND:
NAND: nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x00, Chip ID: 0x00 0 MiB
instead of:
NAND: 0 MiB
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch adds a function to allow one to easily set the target
voltage for the TWL4030 regulators. It also modifies the existing
code to use this new function. Applicable definitions are moved
out of the driver file and into the header file so that they are
generally accessible
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Use more bits to support 36-bit addressing
Signed-off-by: York Sun <yorksun@freescale.com>
This rewrite of the mvtwsi driver is 25% smaller and much
faster and simpler than the previous code.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Acked-by: Prafulla Wadaskar<prafulla@marvell.com>
Acked-by: Heiko Schocher<hs@denx.de>
This driver is not kirkwood-specific and can also be used
e.g. by orion5x. Rename to a SoC-neutral name.
Because of peripheral devices can select clock sources,
separate the peripheral clocks. (pwm, uart and so on)
It just return the pclk at s5pc1xx SoC,
but s5pc210 SoC must be calculated by own clock register setting.
Use the same configuration around S5P SoCs.
(s5pc100, s5pc110, s5pc210 and so on)
Make the header guard to be generic to stop conflicting with
omap2 i2c header file arch/arm/include/asm/arch-omap24xx/i2c.h
Cc: Steve Sakoman <steve@sakoman.com>
Cc: Heiko <hs@denx.de>
Cc: Wolfang Denk <wd@denx.de>
Signed-off-by: Nishanth Menon <nm@ti.com>
Acked-by: Steve Sakoman <steve@sakoman.com>
I have "ported" U-boot to a in house made board with Numonyx Axcell P33/P30
256-Mbit 65nm flash chips.
After some time :( searching for bugs in our board or soft, we have
discovered that those chips have a small but annoying bug, documented in
"Numonyx Axcell P33/P30 256-Mbit Specification Update"
It states :
When customer uses [...] block unlock, the block lock status might be
altered inadvertently. Lock status might be set to either 01h or 03h
unexpectedly (00h as expected data), which leads to program/erase failure
on certain blocks.
A working workaround is given, which I have applied and tested with success :
Workaround: If the interval between 60h and its subsequent command
can be guaranteed within 20us, Option I is recommended,
otherwise Option II (involves hardware) should be selected.
Option I: The table below lists the detail command sequences:
Command
Data bus Address bus Remarks
Sequence
1 90h Block Address
Read Lock Status
2 Read Block Address + 02h
(2)(3) (1)
3 60h Block Address
(2)(3) (1) Lock/Unlock/RCR Configuration
4 D0h/01h/03h Block Address
Notes:
(1) Block Address refers to RCR configuration data only when the 60h
command sequence is used to set RCR register combined with 03h
subsequent command.
(2) For the third and fourth command sequences, the Block Address must
be the same.
(3) The interval between 60h command and its subsequent D0h/01h/2Fh/03h
commands should be less than 20us.
And here is a log comparison of a simple (destructive) flash test without
and with the workaround.
diff without-numonyx-workaround.log with-numonyx-workaround.log
-U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:07:47)
+U-Boot 2010.06-00696-g22b002c-dirty (Aug 16 2010 - 15:25:19)
CPU: Freescale MCF5484
CPU CLK 200 MHz BUS CLK 100 MHz
Board: Macq Electronique ME2060
I2C: ready
DRAM: 64 MiB
FLASH: 32 MiB
In: serial
Out: serial
Err: serial
Net: FEC0, FEC1
-> flinfo
Bank # 1: CFI conformant FLASH (16 x 16) Size: 32 MB in 259 Sectors
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x8922
Erase timeout: 4096 ms, write timeout: 1 ms
Buffer write timeout: 5 ms, buffer size: 1024 bytes
Sector Start Addresses:
FE000000 RO FE008000 RO FE010000 RO FE018000 RO FE020000 RO
FE040000 RO FE060000 RO FE080000 RO FE0A0000 RO FE0C0000 RO
FFF80000 RO FFFA0000 RO FFFC0000 RO FFFE0000 RO
-> protect off all
Un-Protect Flash Bank # 1
................... done
-> erase all
Erase Flash Bank # 1
-> cp.b 1000000 fe000000 2000000
-Copy to Flash... Flash not Erased
+Copy to Flash... done
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
This patch does the following:
- Extract code to detect if sector is erased into function
sector_erased().
- Because of this, we don't have variable declarations inside the
sector loop in flash_print_info()
- Change "return" to "break" in the "if (ctrlc()) statement:
This fixes a problem with the resulting output. Before this
patch the output was:
FC000000 FC020000 FC040000 =>
With this patch it is now:
Cc: Kim Phillips <kim.phillips@freescale.com>
