To avoid thermal burn out, program thermal shutdown
value in VTM (Voltage and Thermal Manager) IP.
Signed-off-by: Udit Kumar <u-kumar1@ti.com>
Signed-off-by: Neha Francis <n-francis@ti.com>
Reviewed-by: Dhruva Gole <d-gole@ti.com>
This prevents from getting some 'No USB device found' error,
in usb_ether_init() function for instance.
Signed-off-by: Julien Panis <jpanis@baylibre.com>
commit 7c9267e5115f5cae729a27a0c8ecc35d6297f2b3 upstream.
Approved DT binding has the port mode register in the
"phys" property. Get it from there instead of the custom
"cpsw-phy-sel" property.
This will allow us to keep DT in sync with Linux.
Signed-off-by: Roger Quadros <rogerq@kernel.org>
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Siddharth Vadapalli <s-vadapalli@ti.com>
commit edacf6a44d2383f9137a99ffdf61a24de4a47307 upstream.
The different CPSW sub-system Ethernet ports have different PHY mode
control registers. In order to allow the modes to get configured
independently only the register for the port in question must be
accessed, otherwise we would just be re-configuring the mode for port 1,
while leaving all others at their power-on defaults. Fix this issue by
adding a port-number based offset to the mode control base register
address based on the fact that the control registers for the different
ports are spaced exactly 0x4 bytes apart.
Fixes: 9d0dca1199d1 ("net: ethernet: ti: Introduce am654 gigabit eth switch subsystem driver")
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Reviewed-by: Siddharth Vadapalli <s-vadapalli@ti.com>
commit fcb513e5f2396e276653c29098faf4739c588041 upstream.
The approved DT property for MAC efuse (ROM) address is
"ti,syscon-efuse".
Use that and drop custom property "mac_efuse".
commit 9b33be392b30deeda242212a0a7b09adc9f91b26 upstream.
The binding represents the MDIO controller as a child device tree
node of the MAC device tree node.
The U-Boot driver mostly ignores that child device tree node and just
hardcodes the resources it uses to support both the MAC and MDIO in a
single driver.
However, some resources like pinctrl muxing states are thus ignored.
This has been a problem with some device trees that will put some
pinctrl states on the MDIO device tree node, like the SK-AM62 Device
Tree does.
Let's rework the driver a bit to create a dummy MDIO driver that we will
then get during our initialization to force the core to select the right
muxing.
Signed-off-by: Maxime Ripard <mripard@kernel.org>
Acked-by: Roger Quadros <rogerq@kernel.org>
This change fixes following build error:
drivers/remoteproc/ti_k3_m4_rproc.c:151:9: error:
implicit declaration of function 'ti_secure_image_post_process'
Upstream-Status: Inappropriate [other]
This is downstream specific so far. This file is not present in mainline.
Related-to: ELB-5351
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
When DDR ECC is off (ecc_reserved_space = 0) k3_ddrss_ddr_fdt_fixup()
doesn't update the DDR size in the memory node of DT. Fix this by
dropping check for ecc_reserved_space to be non zero.
This allows R5 SPL to fixup A53 SPL DT with right DDR size as discovered
during DDR init or based on R5 SPL DT input.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Signed-off-by: Nitin Yadav <n-yadav@ti.com>
Perform removal of DSS if kconfigs VIDEO_REMOVE or SPL_VIDEO_REMOVE is
set by user. Otherwise if above Kconfigs are not selected, it is assumed
that user wants splash screen to be displayed until linux kernel boots
up. In such scenario, leave the power domain of DSS as "on" so that
splash screen stays intact until kernel boots up.
Signed-off-by: Nikhil M Jain <n-jain1@ti.com>
Reviewed-by: Devarsh Thakkar <devarsht@ti.com>
Change remove method of DSS video driver to disable video port instead
of performing a soft reset, as soft reset takes longer duration. Video
port is disabled by setting enable bit of video port to 0.
When one of the functions does not support super speed, the composite
driver forces the gadget to high speed. But the speed is never
configured in the cdns3 gadget driver. So configure the speed
in cdns3_gadget_udc_start just like in the kernel.
Signed-off-by: Ravi Gunasekaran <r-gunasekaran@ti.com>
MT35XU512ABA has only BFPT and 4-Byte Address Instruction Table
in SFDP. Commit bebdc237507c (" mtd: spi-nor: Parse SFDP SCCR Map")
added checks in spi_nor_octal_dtr_enable() to bail out if the 22nd DWORD
in SCCR does not indicate DTR Octal Mode Enable, since MT35XU512ABA device
supports octal DTR mode, add this property in SFDP fixup.
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
If the function is called with no NAND device attached, then this
function can return error value, proceeding further ignoring the same
can cause system crash. This is seen when "mtd list" is run with no NAND
addon cards connected.
To support u-boot driver model. Retain support legacy way of
doing things if ELM_BASE is defined in <asm/arch/hardware.h>
We could completely get rid of that if all platforms defining
ELM_BASE get rid of that definition. enable CONFIG_SYS_NAND_SELF_INIT
commit 7363cf0581a3 ("mtd: rawnand: omap_elm: u-boot driver model
support") upstream
At first SPI transfers, multiple chip selects can be
enabled simultaneously. This is due to chip select
polarity, which is not properly initialized for all
channels. This patch fixes the issue.
In absence of Device Manager (DM) services such as at R5 SPL stage,
driver will have to natively setup TCHAN/RCHAN/RFLOW cfg registers.
Existing UDMA driver performed the above mentioned configuration
for UDMA. Add similar configuration for PKTDMA here.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Expectation of k3_ringacc_ring_reset_raw() is to reset the ring to
requested size and not to 0. Fix this.
Initialize base address of ring config registers required to natively
setup ring cfg registers in the absence of Device Manager (DM) services
at R5 SPL stage.
RX_FL_CFG message should not be forwarded to TIFS
and should be handled within R5 SPL (when DM services
are not available). Add a no-op function to not handle
RX_FL_CFG messages.
Sec proxy data buffer is 60 bytes with the last of the registers
indicating transmission completion. This however poses a bit of a
challenge.
The backing memory for sec_proxy is regular memory, and all sec proxy
does is to trigger a burst of all 60 bytes of data over to the target
thread backing ring accelerator. It doesn't do a memory scrub when
it moves data out in the burst. When we transmit multiple messages,
remnants of previous message is also transmitted which results in
some random data being set in TISCI fields of messages that have been
expanded forward.
The entire concept of backward compatibility hinges on the fact that
the unused message fields remain 0x0 allowing for 0x0 value to be
specially considered when backward compatibility of message extension
is done.
So, instead of just writing the completion register, we continue
to fill the message buffer up with 0x0 (note: for partial message
involving completion, we already do this).
This allows us to scale and introduce ABI changes back also work with
other boot stages that may have left data in the internal memory.
While at this, drop the unused accessor function.
Fixes: f9aa41023bd9 ("mailbox: Introduce K3 Secure Proxy Driver")
Signed-off-by: Nishanth Menon <nm@ti.com>
Acked-by: Andrew Davis <afd@ti.com>
ti_secure_image_post_process was being used implicitly. Includes
security.h to make it work
Signed-off-by: Manorit Chawdhry <m-chawdhry@ti.com>
This is required since user may want to either call the remove method
of video driver and reset the display or not call the remove method
to continue displaying until next stage.
U-boot proper can use frame buffer address passed from SPL to reserve
the memory area used by framebuffer set in SPL so that splash image
set in SPL continues to get displayed while u-boot proper is running.
Put the framebuffer address and size in a bloblist to make them
available at u-boot proper, if in u-boot proper CONFIG_VIDEO is defined.
Add method to reserve video framebuffer information using blob,
received from previous stage.
When video is set up in SPL, U-Boot proper needs to use the correct
parameters so it can write to the display.
Put these in a bloblist so they are available to U-Boot proper.
To support video driver at SPL use CONFIG_IS_ENABLED and CONFIG_VAL,
which checks for stage specific configs and thus enables video support
at respective stage.
To enable TIDSS driver only at SPL stage add rule to compile the TIDSS
video driver.
CONFIG_$(SPL_)VIDEO_TIDSS will compile tidss_drv, at SPL only if
CONFIG_SPL_VIDEO_TIDSS is defined and at u-boot proper if
CONFIG_VIDEO_TIDSS is defined.
To enable video driver at SPL, need to compile video-uclass,
vidconsole-uclass, backlight-uclass, panel-uclass, simple-panel, add
rules to compile them at SPL and u-boot proper. To support
splash_display at SPL, need to compile video-bmp, add rule to compile at
Compile video driver at SPL using CONFIG_SPL_VIDEO.
Tested-by: Simon Glass <sjg@chromium.org> # qemu-x86_64
To enable tidss display driver only at SPL stage, add necessary config,
CONFIG_SPL_VIDEO_TIDSS.
Add Kconfigs which enable the video driver and splash screen at SPL
stage only and not at u-boot proper. The existing Kconfigs from u-boot
proper were not used to make SPL splash screen independent to them.
On DTR capable flashes like Micron Xcella the writes cannot start or end
at an odd address in DTR mode. Extra 0xff bytes need to be prepended or
appended respectively to make sure both the start and end addresses are
even.
Signed-off-by: Pratyush Yadav <p.yadav@ti.com>
Reviewed-by: Vignesh Raghavendra <vigneshr@ti.com>
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Disable rising edge sampling is set by previous stage. This is
not supported by the driver at the moment
Update the HyperBus calibration sequence to fix the instabilities
seen during calibration.The current calibration sequence is same
as described in J721E TRM which is as follows:
1) Ensure FIFO RAM Auto-init is complete
2) Attempt to read 64 bytes of data from CFI region
for 16 iterations and if data is same in 4 successive iterations
then consider Delay Locked Loop(DLL) is stabilized.
3) Verify DLL lock by verifying MDLL_LOCK and SDL_LOCK bit set in
CFG_DLL_STAT register.
4) Confirm calibration by checking for "QRY" string in CFI region.
Also perform minor cleanup and update am654_hyperbus_calibrate()
to return non-zero value on failure.
After performing DFS on A72, the clk-k3 driver causes the reboot to fail
due to fault clock re-initialization
The clk-k3.c driver performs PLL setup based on the difference between
the requested clock rate and current clock rate. If the difference is
found to be more that 50%, in that case it recurses to the clock's parent
for changing its frequency and setting up the PLL. If the difference is
found to be less than that, it assumes that it is a rounding error in the
divider and tries to accommodate for that without touching the parent
clocks.
So, 5% to 50% difference, it assumes it to be a rounding error. From 50%
difference onward it treats it as a HSDIV+PLL configuration case and
sets everything correctly.
So when a fresh boot happens, the A72 clock frequency is found to be at
19.2MHz, which is way less than 2GHz and hence it crosses 50% barrier and
gets properly setup. But when we change the A72 frequency to 1.5 GHz
through DFS, the difference is only of 25% (<50%). So, when we do a
reboot, it doesn't configure the parent clocks and PLLs, it just tries to
make the value close to 2GHz, but that doesn't work.
So, reduce the threshold from 50% to 12.5%, to reconfigure the clocks
correctly at reboot, allowing to boot up after a DFS operation.
Also, check if the parent pll rate is indeed set to target rate, if not
fallback adjusting dividers to get within 5% of requested rate.
This is required to set correct rate for DDR PLLs on AM62A resulting in
lower DDR bandwidth when measured with lmbench (bw_mem)
U-Boot is fail to boot class U1 UHS SD cards (such as microcenter)
due to incorrect OTAP and ITAP delay select values. Update OTAP and
ITAP delay select values based on recommeded RIOT values to fix boot
issue.
Some K3 devices like AM64, AM62 devices have a M4 processor in MCU
voltage domain.
Add a remote proc driver to support this subsystem to be able to load
and boot the M4 core.
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
AM62A SoC has a single C71x DSP subsystem with analytics engine in
main voltage domain. Extend support to AM62A with compatible strings.
AM62A has a R5F core in MCU voltage domain.
Extend support for R5F remote proc driver on AM62A with compatible
strings.
Remoteproc firmware images aren't authenticated in the current boot flow.
Authenticates remoteproc firmware images to complete the root of trust
in secure booting.
The K3 J721S2 SoCs have two C71x DSP subsystems in MAIN voltage domain,
and there are no C66x DSP subsystems on these SoCs. The C71x DSP subsystem
is a slighly updated version of the C71x DSP subsystem on J721e. The
C71x DSPs are 64 bit machine with fixed and floating point DSP
operations.
Extend support to the C71x DSPs with J721S2 compatible strings.
The K3 J721S2 SoCs have three dual-core R5F subsystems, one in MCU
voltage domain and the other two in MAIN voltage domain. These R5F
clusters are similar to the R5F clusters in J7200 SoCs.
Compatible Info is updated to support J721S2 SoCs.
Select MISC class for R5FSS driver. The R5F core driver is under the
REMOTEPROC class.
Flash settings such as Octal-DTR mode and other register configurations
should be resetted before the flash is removed. This would enable
a clean removal and re-plug for later boot stages.
The soft-reset command doesn't restore the flash into 1S mode, so
add support for executing 66h+99h PoR flash reset when in Octal DTR mode.
Datasheet:
https://www.winbond.com/export/sites/winbond/datasheet/W35N01JW_Datasheet_Brief.pdf
Releasing the flash into proper state, after the loading completes,
is important for the next stage bootloader/kernel to be able to use
the MTD device. This would enable to reset the device for fresh
use by next boot stage.
Winbond W35N01JW is a SPI NAND flash supporting Octal DTR SPI protocol.
Add op_variants and ctrl_ops_variants for W35N01JW, thus adding all
required Octal DTR ops.
Datasheet:
Add implementation of change_protocol() for Winbond's manufacturer_ops,
that executes octal_dtr_enable() and octal_dtr_disable() according
to requested protocol.
Datasheet:
Add implementation of octal_dtr_enable() and octal_dtr_disable()
manufacturer_ops for Winbond. To switch to Ocatl DTR mode, setting
programmable dummy cycles and SPI IO mode using the volatile
configuration register is required. To function at max 120MHz SPI clock
in Octal DTR mode, 12 programmable dummy clock cycle setting is
required. (Default number of dummy cycle are 8 clocks)
Set the programmable dummy cycle to 12 clocks, and SPI IO mode to
Octal DTR with Data Strobe in the VCR. Also, perform a READ ID
operation in Octal DTR SPI mode to ensure the switch was successful.
To disable Octal DTR mode, restore the VCR registers to their default
values and verify it using READ ID operation.
Datasheet:
Volatile configuration register are a different set of configuration
registers, i.e. they differ from the status registers. A different
SPI instruction is required to write to these registers. Any changes
to the Volatile Configuration Register get transferred directly to
the Internal Configuration Register and instantly reflect on the
device operation.
In Winbond W35N01JW, these volatile configuration register must be
configured in order to switch to Octal DTR SPI mode.
Add support for writing to volatile configuration registers using a
new WRITE_VCR_OP template.
Datasheet:
Enable Octal DTR SPI mode, i.e. 8D-8D-8D mode, if the SPI NAND flash
device supports it. Mixed OSPI (1S-1S-8S & 1S-8S-8S), mixed DTR modes
(1S-1D-8D), etc. aren't supported yet.
The method to switch to Octal DTR SPI mode may vary across
manufacturers. For example, for Winbond, it is enabled by writing
values to the volatile configuration register. So, let the
manufacturer's code have their own implementation for switching to
Octal DTR SPI mode.
Check for the SPI NAND device's support for Octal DTR mode using
spinand flags, and if the data_ops and ctrl_ops are 8D-8D-8D, call
change_mode() manufacturer op. If the SPI controller doesn't
supports these modes, the selected data_ops and ctrl_ops will
prevent switching to the Octal DTR mode. And finally update the
spinand protocol and ctrl_ops on success.
