This adds an implementation of puts for DM. The implementation is not as
clean as for the non-DM puts because we have to handle non-nul-terminated
string. We also handle short writes (though these are probably very
unusual).
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
This adds a test to ensure that puts is equivalent to putc called in a
loop. We don't verify the contents of the message to avoid having to
record console output a second time (though that could be added in the
future). The globals are initialized to non-zero values to avoid a
warning; in particular, the character count is off-by-one (but we always
make relative measurements).
This implements puts for sandbox. It is fairly straightforward, except
that we break out the shared color printing functionality into its own
function.
A string like "test\n" would be broken up into the following sequence of
prints by _serial_puts:
puts("test\n")
putc('\r')
Although functionally this is the same as \r\n, it is not the standard
sequence and caused tests to fail. Fix this by excluding the '\n' from
the initial print. The above string will now be broken up like
puts("test")
puts("\r\n")
Since we may now need to call ops->puts twice (with the associated retry
logic), break that part of the function off into a helper.
Fixes: 7a76347189 ("serial: dm: Add support for puts")
In case the DT LED subnode contains "default-state" property set to
either "on" or "off", probe the LED driver and configure the LED state
automatically.
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
Cc: Philippe Reynes <philippe.reynes@softathome.com>
Cc: Sean Anderson <seanga2@gmail.com>
Cc: Steven Lawrance <steven.lawrance@softathome.com>
[trini: Update the relevant test now that we have support]
The OF "label" property parsing is now handled in LED core,
drop the duplicate implementation from this driver.
Every driver in drivers/led/ currently does some form of "label" OF
property parsing in its bind() callback. Move this label parsing to
LED core, since this "label" OF property is a generic property. This
permits code deduplication in subseuqent patches.
Callers of function atsha204a_crc16() expect to return value in host cpu
endianity. So remove cpu_to_le16() conversion.
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
It is possible for power domain IDs to be great than 31. If this
happens, the PTCMD and PTSTAT registers must overflow into adjacent
corresponding PTCMD_H and PTSTAT_H registers for each. Update the driver
to account for this.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Add Kconfig entry for the DM9000 MAC.
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
Add support for U-Boot DM and DT probing.
Instead of reading out the entire FIFO and possibly overwriting U-Boot
memory, read out one packet per recv call, pass it to U-Boot network
stack, and repeat.
Split network handling functions into non-DM specific parts and
common code in preparation for conversion to DM.
Pass private data into IO accessors and use the base addresses of
IO and DATA window from the private data instead of using the hard
coded macros DM9000_IO/DM9000_DATA. Currently both the DM9000_IO
and DM9000_DATA are assigned to the respecive private data fields
for the non-DM case backward compatibility.
Dispose of dm9000.h because none of the function prototypes declared in
it are called anywhere in the codebase. Staticize dm9000_read_srom_word()
because it is now called only from within the dm9000 driver. Drop
dm9000_write_srom_word() because it is no longer used.
Allocate driver private data dynamically in its init function and drop
the static driver private data variable. Pass the dynamic private data
throughout the driver. This is done in preparation for DM conversion.
Rename board_info structure to dm9000_priv to make it clear what this
structure really contains, the driver private data. No functional change.
Reorder the driver functions to get rid of forward declarations.
Staticize whatever is possible. No functional change.
Fix checkpatch errors and warnings. No functional change.
Remove volatile keyword usage from arrays, they are not really volatile
in any way, so this keyword is misused here. No functional change.
Rework DM9000_DMP_PACKET() into dm9000_dump_packet() function,
this brings better type checking. No functional change.
Drop unused function dump_regs() because it is unused.
Rename variables to lowercase to be consistent with coding style.
Use standard debug() macro to print debug messages instead of
reinventing driver-specific macro again. No functional change.
Make accessor names lowercase to be consistent with coding style.
Change type of private struct member mdio_base from void * to
phys_addr_t. This allows us to drop 2 casts.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Convert fdt parsing functions to ofnode parsing functions.
Deduplicate common code in ks2_eth_bind_slaves().
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20220413
i.MX patches for 2022.07
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/11710
Fix registration of 24M and 32k clock, those got applied or rebased
incorrectly, so fill in the correct code.
Fixes: 7a2c3be95a5 ("clk: imx8mp: Fill in DWC3 USB, USB PHY, HSIOMIX clock")
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Add clock tables required for bing up ECSPI interfaces
Signed-off-by: Elmar Albert <ealbert@data-modul.com>
Cc: Fabio Estevam <festevam@denx.de>
Cc: uboot-imx <uboot-imx@nxp.com>
Reviewed-by: Fabio Estevam <festevam@denx.de>
In Linux IMX and IMXRT use the device tree to hold the anatop address.
The anatop is used in clock drivers as it controls the internal PLLs
This will move the macro from asm/arch-imxrt to the device tree.
This presumably should also be done with the other IMX boards as well.
Signed-off-by: Jesse Taube <Mr.Bossman075@gmail.com>
Add compatible string for i.MX8MP, which permits i.MX8MP to use
HS400ES mode, just like all the other i.MX8M.
Cc: Haibo Chen <haibo.chen@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
The i.MX8M Mini and i.MX8M Plus flexspi IPs are compatible with one
another, however the linux kernel DT uses separate compatible string
for each SoC. Add the missing i.MX8MP compatible into this driver.
Add driver for the NXP TJA1100 and TJA1101 PHYs. These PHYs are special
BroadRReach 100BaseT1 PHYs used in automotive.
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Ariel D'Alessandro <ariel.dalessandro@collabora.com>
Add read-modify-write unlocked accessor for accessing a PHY register.
This macro currently supports only one parameter. Based on Linux iopoll,
let's extend read_poll_timeout common API to allow multiple variable
parameters.
This driver supports NXP C45 TJA11XX PHYs, but there're also other NXP
TJA11XX PHYs. Let's rename functions in this driver to be c45 variant
specific, so further drivers can be introduced adding support for NXP
TJA11XX PHYs.
Separe dm implementation from non dm implementation of pwm-imx
driver using CONFIG_DM_PWM
Signed-off-by: Tommaso Merciai <tommaso.merciai@amarulasolutions.com>
Move pwm_imx_get_parms, pwm_id_to_reg functions into pwm-imx.c
and drop off pwm-imx-util.c
This commit adds the possibility to choose the compatible
"regulator-fixed-clock" in devicetree.
This is a special case of regulator-fixed where a clock has to
be used to switch the regulator on and off.
- According to S400 API, the fuse bank 25 (Testconfig2) is able to
access. Add it into driver's mapping table.
- According to FSB words list, the reserved 48 words are ahead of
the bank 5 and bank 6. Fix the wrong position.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add ahab_dump_buffer API to dump AHAB buffer for debug purpose
Add ahab_release_caam() function to the S400 API.
Signed-off-by: Clement Faure <clement.faure@nxp.com>
