Uart status register is named USART_ISR on STM32F7, STM32H7
and STM32MP1 SoCs family, but USART_SR only on STM32F4 SoCs.
Use USART_ISR_ prefix instead of USART_SR_ .
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Enable uart overrun feature which allows to benefits of uart
FIFO usage.
Previously overrun management was disabled, this has to effect
to bypassed the uart FIFO usage even if FIFO was enabled.
In particular configuration, for example when video console is
enabled, copy/pasting a long command line in console results in
corruption. This is due to the fact that a lot of time is consumed
in flushing the cache during frame buffer update, so uart chars are
not read fast enough.
By using uart FIFO and managing overrun, long command line can by
copy/paste in console without being corrupted.
If SPL serial support is disabled nothing brings in sprintf, snprintf
or simple_strtoul:
env/built-in.o: In function `regex_callback':
env/attr.c:128: undefined reference to `sprintf'
disk/built-in.o: In function `blk_get_device_by_str':
disk/part.c:386: undefined reference to `simple_strtoul'
disk/part.c:395: undefined reference to `simple_strtoul'
disk/built-in.o: In function `blk_get_device_part_str':
disk/part.c:522: undefined reference to `simple_strtoul'
disk/built-in.o: In function `part_set_generic_name':
disk/part.c:704: undefined reference to `sprintf'
drivers/built-in.o: In function `init_peripheral_ep':
drivers/usb/musb-new/musb_gadget.c:1826: undefined reference to `sprintf'
drivers/built-in.o: In function `musb_core_init':
drivers/usb/musb-new/musb_core.c:1451: undefined reference to `snprintf'
Add those dependencies here.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Commit 2baa997240d ("arm: socfpga: Add FPGA driver support for Arria 10")
Polling on wrong cleared bit. Fix with correct polling on bit is set.
Fixes: 2baa997240d ("arm: socfpga: Add FPGA driver support for Arria 10")
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
In case usb configuration is unknown (cdev->config == NULL), non standard
request should not be processed.
Remove also the cdev->config check below which will never happen.
This issue was seen using ums feature.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
When no PHYs are declared in the dwc3 node, the phy init fails.
This patch checks if the "phys" property is presend and reports
the error returned by dev_count_phandle_with_args().
This patchs also fixes the styles issues added in last commit.
This patch should fix the DWC3 support on the UniPhier SoC family.
Fixes: 7c839ea70c49 ("usb: host: dwc3: Add support for multiple PHYs")
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
After this change the DM FEC ETH driver can be also reused on some imx53
devices.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
CONFIG_FEC_MXC_PHYADDR
Without this commit we do have an explicit dependency on CONFIG_PHYLIB
when one wants to set PHY ADDR on a iMX board (FEC + driver model).
This shall be changed to CONFIG_FEC_MXC_PHYADDR, as only when we do have
it set, we shall mask out other devices.
As a side effect, when CONFIG_FEC_MXC_PHYADDR is not set, we scan PHY bus
for connected PHY devices.
Parse of data in dedicated api instead of in probe().
The clk_set_rate() may be called before the clk driver is probed,
after core support set default clock.
This patch fix system abort issue since:
f4fcba5 clk: implement clk_set_defaults()
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-sytems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-sytems.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The DM driver for ockchip timer blocks is also applicable to the
RK3188 and RK3288 timer blocks: add 'rockchip,rk3188-timer' and
'rockchip,rk3288-timer' to its compatible list to support devices
claiming compatibility with these.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The generic ehci-driver (ehci-generic.c) will try to enable the clocks
listed in the DTSI. If this fails (e.g. due to clk_enable not being
implemented in a driver and -ENOSYS being returned by the clk-uclass),
the driver will bail our and print an error message.
This implements a minimal clk_enable for the RK3288 and supports the
clocks mandatory for the EHCI controllers; as these are enabled by
default we simply return success.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
Throughput tests have shown the sunxi_mmc driver to take over 10s to
read 10MB from a fast eMMC device due to excessive delays in polling
loops.
This commit restructures the main polling loops to use get_timer(...)
to determine whether a (millisecond) timeout has expired. We choose
not to use the wait_bit function, as we don't need interruptability
with ctrl-c and have at least one case where two bits (one for an
error condition and another one for completion) need to be read and
using wait_bit would have not added to the clarity.
The observed speedup in testing on a A31 is greater than 10x (e.g. a
10MB write decreases from 9.302s to 0.884s).
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Tested-by: Mylène Josserand <mylene.josserand@bootlin.com>
Acked-by: Jagan Teki <jagan@openedev.com>
With clang-4.0 and later we see:
warning: logical not is only applied to the left hand side of this bitwise
operator [-Wlogical-not-parentheses]
if ((!gd->flags & GD_FLG_RELOC))
And while the compiler suggests adding parenthesis around gd->flags, a
reading of the code says that we want to know when GD_FLG_RELOC is not
set and then return.
Staticize the function since it's only used in mmc.c .
Cc: Jaehoon Chung <jh80.chung@samsung.com>
The last clock consumer in SPL, SD/eMMC driver, gave up using the
clock driver. The clock driver is only used in U-Boot proper.
The size of SPL is hitting the limit (64KB) for uniphier_v7_defconfig.
When booting from SD/eMMC, obviously its clock has been properly set up
by the boot ROM. Acutually, no need to re-initialize the clock in SPL.
Using a clock driver would generalize the SoC specific code, but
solving the memory footprint problem would win.
I need to differentiate the clock handling for uniphier-sd. Move it
to each driver's probe function from the tmio common code so that
renesas-sdhi will not be affected.
Xilinx fixes for v2018.05-rc3
- Fix nand initialization
- Runtime ddr detection for static DDR setting
- Enable rewriting env locations
- Sync defconfig for zc770 xm011
- Remove useless ioremap in watchdog
- Check return value from soc_clk_dump()
The Odroid C2 fails to read from mmc with U-Boot v2018.03.
The change avoids a division by zero.
The fix was suggested by Jaehoon in
https://lists.denx.de/pipermail/u-boot/2018-January/318577.html
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Suggested-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
There is no need to call ioremap. Also reg pointer is completely unused
in the driver.
CONFIG_NAND_ZYNQ selects CONFIG_SYS_NAND_SELF_INIT, so the
driver doesn't have to play any ifdef game.
Also, we can mark zynq_nand_init() as static and get rid
of the mach-specific nand.h header.
This is really a revert of:
"mtd: zynq: nand: Move board_nand_init() function to board.c"
(sha1: 310995d9f91ae56082b49be06fe8c3d01424f8f6)
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
This driver is currently broken, refusing to initialize properly.
The reason is that get_nand_dev_by_index() was being called before
nand_register(), thus returning a pointer into uninitialized memory.
In other words, the struct mtd_info used by the driver is total junk.
Fix it by getting the correct struct mtd_info, via nand_to_mtd()
on the driver's struct nand_chip.
Tested on a custom board, where the CPU is halted without this patch.
U-boot driver for sunxi-mmc uses PLL6, unlike linux kernel where
PLL5 is used, with clock rates respectively 600MHz and 768MHz.
Thus there are different phase degree steps - 24 for the kernel and
30 for u-boot.
In the kernel driver the phase is set 90 deg for output and 120 for
sample. Dividing by 30 will result values 3 and 4. Those are the
values set in the u-boot driver.
However, the condition defining delays is wrong. MMC core driver
requests clock of 52MHz, sunxi-driver sets clock of 50MHz, but
phase is set 30 deg for output and 120 deg for sample.
Apparently this works for most cards.
On A20-SOM204-EVB-eMMC there is eMMC card (KLMAG2GEND) which complains
about it. Maybe there is other boards with similar problem?
So the fix is to match delays for both u-boot and kernel.
Signed-off-by: Stefan Mavrodiev <stefan@olimex.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
While switching to readl_poll_timeout macros from custom code
the waiting condition was accidently inverted, so it was pure
luck that this code works at least in some conditions.
Fix that by inverting exit condition for readl_poll_timeout.
Fixes: c6b4f031d9 ("DW SPI: fix tx data loss on FIFO flush")
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
The disabled clk API returns -ENOSYS unlike the reset API returning -ENOTSUPP.
Fixes: ca7fdc8b1267 ("usb: host: Add simple of glue driver for DWC3 USB Controllers integration")
Reported-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Add the compatibility with "ti,dwc3" and enable it by default if DM_USB
is enabled.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This simple glue layer does not require CONFIG_MISC, but it does require
CONFIG_DM_USB.
Add Kconfig entry for SH MMCIF driver.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add MMC DM and DT probing support into the SH MMCIF driver.
This patch abstracts out the common bits of the send command
and set ios functions, so they can be used both by DM and non
DM setups and adds the DM probe support.
The initconst is not used in U-Boot, drop it. The r8a7794_crit_mod_clks
is also not used in U-Boot, so drop it too.
The initconst is not used in U-Boot, drop it. The r8a7792_crit_mod_clks
Add entry for Spansion s25fl208k part.
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
This commit adds support for the SST sst26wf016, sst26wf032
and sst26wf064 flash IC.
sst26wf flash series block protection implementation differs
from other SST series, so add specific implementation
flash_lock/flash_unlock/flash_is_locked functions for sst26wf
flash ICs.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Add reset lines for ethernet controller on each SoC.
Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com>
Add clock control for ethernet controller on each SoC.
