path: root/drivers
2006-10-28[PATCH] NAND: Partition name support added to NAND subsystemStefan Roese
chpart, nboot and NAND subsystem related commands now accept also partition name to specify offset. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-26Fix TSEC driver (now for real): avoid crashes if PHY is not attachedBen Warren
to a TSEC (e.g. a switch is connected via RMII) or if the PHY is defective/incorrectly configured. Signed-off-by: Ben Warren <bwarren@qstreams.com>
2006-10-24Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-24Add common serial driver for Atmel AT32 and AT91 chipsWolfgang Denk
Patch by Haavard Skinnemoen, 06 Sep 2006 This is a first attempt at creating a common serial driver for Atmel chips. For now, it supports the AT32AP7000 AVR32 chip, but it should be possible to support AT91RM9200 and other ARM-based chips with some minor modifications. There's nothing fundamentally AVR32-specific in this driver, but it does use some features which are currently only defined for the AT32AP CPU port: * pm_get_clock_freq: Obtain the clock frequency of a given domain * gd->console_uart: A "struct device" containing information about register mappings, gpio resources and clocks associated with the UART device. For more information about these features, please see the "AT32AP CPU" patch.
2006-10-20Merge with http://www.jdl.com/software/u-boot-86xx.gitWolfgang Denk
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-20Add board/cpu specific NAND chip select function to 440 NDFCStefan Roese
Based on idea and implementation from Jeff Mann Patch by Stefan Roese, 20 Oct 2006
2006-10-19Rewrite a series of goto statements as a sequences ofJon Loeliger
conditional expressions instead. Use consistent return code 0/-1 for good/bad indicators. Include one fewer file if the driver isn't used at all. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-19Moved i2c driver out of cpu/mpc86xx/i2c.c into drivers/fsl_i2c.cJon Loeliger
in an effort to begin to unify the umpteen FSL I2C drivers that are all otherwise very similar. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-12Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-12Remove unneeded include files and local variable.Jon Loeliger
2006-10-12Fix spelling; minor code cleanup.Wolfgang Denk
2006-10-11Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-10Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-10Ran lindent and cleaned up whitespace issues.Jon Loeliger
Format for 80-columns too.
2006-10-10* Several improvements to the new NAND subsystem:Stefan Roese
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006
2006-10-09Coding style cleanupWolfgang Denk
2006-09-19Merge branch 'mpc85xx'Jon Loeliger
Conflicts: drivers/tsec.c
2006-09-19Add support for eTSEC 3 & 4 on 8548 CDSAndy Fleming
* Added support for using eTSEC 3 and eTSEC 4 on the 8548 CDS. This will only work on rev 1.3 boards (but doesn't break older boards) * Cleaned up some comments to reflect the expanded role of tsec in other systems
2006-09-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
Conflicts: board/stxxtc/Makefile
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-08-30Make the serial driver framework work with CONFIG_SERIAL_MULTI enabledWolfgang Denk
2006-08-23Merge branch 'mpc86xx'Jon Loeliger
2006-08-23Cleanup and lindent new AHCI driver.Jon Loeliger
2006-08-23Add AHCI support to u-bootJin Zhengxiong
Add AHCI support in u-boot, enable the sata disk controllers which following the AHCI protocol. Signed-off-by:Jason Jin<jason.jin@freescale.com>
2006-08-22Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-08-14Fix drivers/dm9000.c when configured in 32 bit mode.Wolfgang Denk
Patch by Eric Benard, 17 Nov 2005
2006-08-09Merge branch 'mpc85xx'Jon Loeliger
Conflicts: include/ft_build.h include/pci.h Resolved, though.
2006-08-09* Made sure the code which disables prefetch for PCI devices sets the size ↵Matthew McClintock
of the prefetch region to 0 Patch by Andy Fleming on 17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-08-09Merge branch 'wd'Jon Loeliger
2006-07-21Code cleanupWolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2006-07-19Fix support for PS/2 keyboard on TQM85xx boardsWolfgang Denk
The PS/2 keyobard driver for the TQM85xx modules only supports the internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't include a DUART, the TQM8560 modules can't be used with the PS/2 keyboard controller on the STK85xx board. The PS/2 keyboard driver should work with the modules TQM8540, TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet. Make sure the PS/2 controller on the STK85xx is programmed. Jumper settings: X66 1-2, 9-10; X61 2-3 Patch by Martin Krause, 21 Jun 2006
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-28Merge branch 'mpc86xx'Jon Loeliger
2006-06-28Change Id to symbolic name for RTL8139Jin Zhengxiong
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2006-06-27Merge branch 'mpc86xx'Jon Loeliger
2006-06-27Fix RTL8139 in big endianJin Zhengxiong-R64188
signed-off-by: Jason Jin <Jason.Jin@freescale.com> signed-off-by: Wei Zhang <wei.zhang@freescale.com>
2006-06-27Fix Tsec bug when no linkJin Zhengxiong-R64188
When tftp a non-exist file from the tftp server, u-boot will check the link of all eth port. The original file will return wrong link state on the no link ports. signed-off-by: Jason Jin <Jason.Jin@freescale.com>
2006-06-27Fix bug for io_bar size during pci scanJin Zhengxiong-R64188
During the pci scan process, Some devices return bar_reponse with the highest bytes 0, such as the pci bridge in uli1575 return bar_response with 0xffffff, So the bar_size should be manually set under 64K. Signed-off-by: Jason Jin <jason.jin@freescale.com>
2006-06-19Add support for wrPPMC7xx/74xx boardsHeiko Schocher
Patch from Richard Danter, 12 Aug 2005
2006-06-16Add support for PS/2 keyboard on TQM85xx boardWolfgang Denk
Patch by Martin Krause, 07 Nov 2005 Tested on a STK85XX baseboard. Make sure the PS/2 controller has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
2006-06-07Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-06-02Fix watchdog handling in CFI flash driverWolfgang Denk
Just use udelay() when waiting for status changes which will implicitely trigger the watchdog.
