path: root/drivers
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-31Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
Please pull another update for Broadcom MIPS. This contains new SoC's, new boards and new drivers and some bugfixes.
2017-05-31dm: serial: bcm6345: fix baud rate clock calculationÁlvaro Fernández Rojas
It's currently bugged and doesn't work for even cases. Right shift bits instead of dividing and fix even cases. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2017-05-31dm: serial: bcm6345: fix uart stop bitsÁlvaro Fernández Rojas
I missed this when I added support for BMIPS UART driver and it's needed to achieve a real 115200 8N1 setup. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2017-05-31dm: cpu: bmips: add BCM6338 supportÁlvaro Fernández Rojas
BCM6338 has a fixed CPU frequency of 240 MHz. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: cpu: bmips: add BCM3380 supportÁlvaro Fernández Rojas
As far as I know BCM3380 has a fixed CPU frequency since I couldn't find its PLL registers in any documentation. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: ram: bmips: add BCM6338/BCM6348 supportÁlvaro Fernández Rojas
2017-05-31dm: ram: bmips: split bcm6358_get_ram_sizeÁlvaro Fernández Rojas
This is done in order to reuse ram size calculation for BCM6338/BCM6348 Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: cpu: bmips: add BCM6348 supportÁlvaro Fernández Rojas
2017-05-31dm: cpu: bmips: rename cpu_desc specific functionsÁlvaro Fernández Rojas
Use a generic name for cpu_desc functions instead of using a specific SoC one. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: sysreset: add watchdog-reboot driverÁlvaro Fernández Rojas
Add a new sysreset driver that uses the recently added watchdog support. It performs a full SoC reset by calling wdt_expire_now op. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: watchdog: add BCM6345 watchdog driverÁlvaro Fernández Rojas
This driver is a simplified version of linux/drivers/watchdog/bcm63xx_wdt.c Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31pinctrl: mvebu: Enable support for the Armada 37xx pinctrl driverStefan Roese
To enable support for the Armada 37xx pinctrl driver, we need to change the Kconfig symbol for the Armada 7k/8k pinctrl driver and its dependencies to distinguish between both platforms and drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Konstantin Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com>
2017-05-31pinctrl: armada-37xx: Add gpio supportGregory CLEMENT
GPIO management is pretty simple and is part of the same IP than the pin controller for the Armada 37xx SoCs. This patch adds the GPIO support to the pinctrl-armada-37xx.c file, it also allows sharing common functions between the gpio and the pinctrl drivers. Ported to U-Boot based on the Linux version by Stefan Roese. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: Konstantin Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com>
2017-05-31pinctrl: armada-37xx: Add pin controller support for Armada 37xxGregory CLEMENT
The Armada 37xx SoC come with 2 pin controllers: one on the south bridge (managing 28 pins) and one on the north bridge (managing 36 pins). At the hardware level the controller configure the pins by group and not pin by pin. This constraint is reflected in the design of the driver: only the group related functions are implemented. Ported to U-Boot based on the Linux version by Stefan Roese. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: Konstantin Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com>
2017-05-29power: pmic: tps65218: Fix tps65218_voltage_update functionKeerthy
Currently while setting the vsel value for dcdc1 and dcdc2 the driver is wrongly masking the entire 8 bits in the process clearing PFM (bit7) field as well. Hence describe an appropriate mask for vsel field and modify only those bits in the vsel mask. Source: http://www.ti.com/lit/ds/symlink/tps65218.pdf Signed-off-by: Keerthy <j-keerthy@ti.com> Fixes: 86db550b38 ("power: Add support for the TPS65218 PMIC") Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-05-29mmc: meson: increase max block number per requestHeiner Kallweit
Number of blocks is a 9 bit field where 0 stands for a unlimited number of blocks. Therefore the max number of blocks which can be set is 511. Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
2017-05-29drivers/power/regulator/max77686.c: Fix comparisons of unsigned expressionsTom Rini
Inside of max77686_buck_volt2hex/max77686_buck_hex2volt/max77686_ldo_volt2hex we check that the value we calculate is >= 0 however we declare 'hex' as unsigned int making these always true. Mark these as 'int' instead. We also move hex_max to int as they are constants that are 0x3f/0xff. Given that the above functions are marked as returning an int, make the variables we assign their return value to also be int to be able to catch the error condition now. Reported by clang-3.8. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-05-26Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
Move FTMAC100 to where it should be, alphabetically in drivers/net/Kconfig Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: drivers/net/Kconfig
2017-05-23Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-05-23armv8: ls2080ardb: Add LS2081ARDB board supportPriyanka Jain
LS2081ARDB board is similar to LS2080ARDB board with few differences It hosts LS2081A SoC Default boot source is QSPI-boot It does not have IFC interface RTC and QSPI flash device are different It provides QIXIS access via I2C Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: fsl-layerscape: Add NXP LS2081A, LS2041A SoC supportPriyanka Jain
The QorIQ LS2081A SoC has eight 64-bit ARM v8 Cortex A72 cores and is built on layerscape architecture. It is 40-pin derivative of LS2084A (non-AIOP personality of LS2088A). So feature-wise it is same as LS2084A. LS2041A is a 4-core personality of LS2081A. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23driver: net: fsl-mc: Update fsl_mc_ldpaa_exit() pathYogesh Gaur
Earlier when MC is loaded but DPL is not deployed results in FDT fix-up code execution hangs. For this case now print message on console and return success instead of return -ENODEV. This update allows fdt fixup to continue execution. Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Signed-off-by: Priyanka Jain <Priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23nds32: eth: Support ftmac100 DM.rick
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform. Verification: Boot linux kernel via dhcp and bootm ok. NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000; NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4899 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'boomimage-310y-ae300-spi.bin'. Load address: 0x600000 Loading: ################################################################# ################################################################# ################################################################# ... ... ################################### 233.4 KiB/s done Bytes transferred = 13872076 (d3abcc hex) NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4592 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'ae300.dtb'. Load address: 0x2000000 Loading: # 82 KiB/s done Bytes transferred = 2378 (94a hex) NDS32 # bootm 0x600000 - 0x2000000 Image Name: Created: 2017-03-22 6:52:03 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13872012 Bytes = 13.2 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Booting using the fdt blob at 0x2000000 Loading Kernel Image ... OK Loading Device Tree to 01efc000, end 01eff949 ... OK Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) ) #293 PREEMPT Wed Mar 22 14:49:28 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159) ... ... Signed-off-by: rick <rick@andestech.com>
2017-05-22Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2017-05-22Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_SYS_I2C_DS4510_ADDRSimon Glass
This is only used by one board and always set to 0x51. Drop this option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Drop digital thermometer and thermostat (DTT) driversSimon Glass
This subsystem is quite old. It has been replaced with a driver-model version (UCLASS_THERMAL). Boards are free to convert to that if required, but here is a removal patch that could be applied in the meantime. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Drop three-wire serial (TWS) supportSimon Glass
This subsystem has not been converted to driver model, there is only one driver and only one board that uses it. Drop it and its CONFIG option. Also drop the rtc4543 RTC driver since it uses TWS. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Kconfig: Drop CONFIG_SYS_I2C_DTT_ADDRSimon Glass
This option is only defined to a non-default value by canyonlands, which needs conversion to driver model (where the I2C address would be defined by the device tree). Drop this option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Convert CONFIG_DS4510 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_DS4510 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510Simon Glass
This option enables a command in the driver. But the functions defined by the driver are not called anywhere else in U-Boot. So it does not seem useful to have this driver without its commands. Drop this option, move the header file out of the common include/ directory and make all the function static. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_RSTSimon Glass
This option is only used in one driver and is not enabled by any board. It does not seem worth having the ability to remove this part of the support. Drop the option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_MEMSimon Glass
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510_INFOSimon Glass
This option is only used in one driver and two boards. It does not seem worth having the ability to remove this part of the support. Drop the option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22usb: ehci: Add Renesas RCar M3/H3 EHCI supportHiroyuki Yokoyama
Add a USB controller driver for the EHCI block in R8A7795/R8A7796 SoC. This is a stopgap measure until we have proper DT support, clock and reset framework in place, at which point we can switch to ehci-generic. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Reviewed-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22nds32: Support AE3XX platform.rick
Support Andestech AE3xx platform: serial, timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P timer DM.rick
Support AG101P timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22serial: sh: Add r8a7796 supportHiroyuki Yokoyama
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22net: ravb: Add Renesas Ethernet RAVB driverMarek Vasut
Add driver for the Renesas Ethernet AVB block found in RCar H3/M3. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Tom Rini <trini@konsulko.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Based on work of: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Takeshi Kihara <takeshi.kihara.df@renesas.com> Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
2017-05-22gpio: rcar_gen3: Fix GPIO read supportKouei Abe
This patch fixes to read the GPIO status after confirming the INOUT setting. Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Tom Rini <trini@konsulko.com>
2017-05-21net: usb: mcs7830: fix non-DM ingress pathUri Mashiach
The mcs7830_recv() (non-DM) function discards good packets and tries to process "bad" packets due to incorrect test condition. Fix the condition and return the proper value as described in function doc. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2017-05-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-05-18usb: lpc32xx: add i2c DM supportLiam Beguin
Add DM support for i2c functions. Signed-off-by: Liam Beguin <lbeguin@tycoint.com> Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-18pinctrl: imx: fix memory leakPeng Fan
Each time set_state is called, a new piece memory will be allocated for pin_data, but not freed, this will incur memory leak. When error, the devm API could not free memory automatically. So need call devm_kfree when error. Issue reported by Coverity Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Stefano Babic <sbabic@denx.de>
2017-05-18gpio: 74x164: make oe-pins optionalPeng Fan
Make oe-pins optional because some boards have fixed it to enable. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
