path: root/drivers
2012-12-17pxa25x_udc: Remove usbdescriptors.hLukasz Dalek
usbdescriptors.h conflicts with linux/usb/ch9.h. Remove it. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-12-13env: Add a baudrate env handlerJoe Hershberger
Remove the hard-coded baudrate handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-11designware_i2c.h: Define IC_CLK only if not already defined in config fileArmando Visconti
Signed-off-by: Armando Visconti <armando.visconti@st.com>
2012-12-11designware_i2c.h: Fixed the correct values for SCL low/high timeArmando Visconti
2012-12-11designware_i2c: Fixed the setting of the i2c bus speedArmando Visconti
There are three couple (hcnt/lcnt) of registers for each speed (SS/FS/HS). The driver needs to set the proper couple of regs according to what speed we are setting. Signed-off-by: Armando Visconti <armando.visconti@st.com>
2012-12-11designware_i2c: Added s/w generation of stop bitArmando Visconti
In the newer versions of designware i2c IP there is the possibility of configuring it with IC_EMPTYFIFO_HOLD_MASTER_EN=1, which basically requires the s/w to generate the stop bit condition directly, as the h/w will not automatically generate it when TX_FIFO is empty. To avoid generation of an extra 0x0 byte sent as data, the IC_STOP command must be sent along with the last IC_CMD. This patch always writes bit[9] of ic_data_cmd even in the older versions, assuming that it is a noop there. Signed-off-by: Armando Visconti <armando.visconti@st.com>
2012-12-11designware_i2c.c: Added the support for MULTI_BUSArmando Visconti
This patch adds the capability to switch between 10 different I2C busses (from 0 to 9). Signed-off-by: Armando Visconti <armando.visconti@st.com>
2012-12-11drivers:i2c: Modify I2C driver for Exynos4Piotr Wilczek
This patch modifies the S3C i2c driver to support both Exynos4 and Exynos5 Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com>
2012-12-11omap24xx_i2c: Handle OMAP5 like OMAP2,3,4Vincent Stehlé
OMAP5 has 8b i2c data register field, like OMAP2, 3 and 4. Handle in the same way. This fixes the following error on OMAP5: OMAP5430 EVM # mmc rescan timed out in wait_for_bb: I2C_STAT=1410 twl6035: could not turn on LDO9. Signed-off-by: Vincent Stehlé <v-stehle@ti.com>
2012-12-11mxs: i2c: Implement algorithm to set up arbitrary i2c speedMarek Vasut
This algorithm computes the values of TIMING{0,1,2} registers for the MX28 I2C block. This algorithm was derived by using a scope, but the result seems correct. The resulting values programmed into the registers do not correlate with the contents in datasheet. When using the values from the datasheet, the I2C clock were completely wrong. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Wolfgang Denk <wd@denx.de>
2012-12-11mxs: i2c: Restore speed setting after block resetMarek Vasut
The I2C block reset configures the I2C bus speed to strange value. Read the I2C speed from the block before reseting the block and restore it afterwards, so the I2C operates correctly. This issue can be replicated by doing unsuccessful I2C transfer, after such transfer finishes, the I2C block clock speed is misconfigured. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11i2c: mxs: Fix TIMING2 register valueMarek Vasut
According to FSL, the value in the TIMING2 register shall be 0x00300030 instead of what's written in the datasheet. This new value correlates with older STMP36xx datasheet. Issues were detected in Linux when this register was misconfigured, so write this correct value. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11i2c: mxs: Use i2c_set_bus_speed() in i2c_init()Marek Vasut
Use i2c_set_bus_speed() in i2c_init() within the mxs i2c driver to avoid duplication of code. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11i2c: mxs: Implement i2c_get/set_bus_speed()Marek Vasut
This patch implements the setup and retrieval functions for the I2C bus speed on the MXS I2C IP. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11i2c: mxs: Abstract out the MXS I2C speed setupMarek Vasut
This patch pulls out the I2C speed setup from the i2c_init() call and implements the bus configuration lookup table with register values that needs to be programmed into the I2C IP to run at particular speed. This patch is a first step towards implementing run-time I2C bus speed configuration for the MXS I2C IP. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-11i2c: Staticize local functions in mxc i2c driverMarek Vasut
Some functions in the MXC i2c driver were not static, fix this by making them so. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-12-11soft_i2c: add necessary includes for AVR32Andreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2012-12-07Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2012-12-07serial_pl011: Set RTS during initializationJoshua Housh
If the pl011 is connected to another device which has hardware flow-control on, characters are never received by the pl011. Asserting RTS when flow-control is off will have no effect. This is in line with how Linux behaves. Signed-off-by: Joshua Housh <joshua.housh@calxeda.com> Tested-by: Marek Vasut <marex@denx.de>
2012-12-06video: Check for valid FB pointer before clearingDuncan Laurie
This command will start erasing at memory address zero if there is not a valid framebuffer address that was found during video_init(). This is a common case with Chrome OS devices in normal mode when we do not execute the video option rom in coreboot. Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-06x86: gpio: Add additional GPIO banks to the ICH6 driverBill Richardson
We can generally trust the ICH to have GPIO Bank 0 (the first 32 pins) in the same place across all versions. This change adds two more banks, for up to 96 GPIOS. BUT: - Not all chipsets have the same number of GPIOs - Not all chipsets have the same number of GPIO banks - Not all chipsets put the additional banks at the same offset from GPIOBASE - There so many chipset variants that it's pretty much impossible to support them all, or even keep track of the new ones. So, although this adds suppport for the additional banks that seem to work for the particular variants of CougarPoint Mobile chipsets that we've tried, there's no chance it will support everything Intel produces. Good luck. Signed-off-by: Bill Richardson <wfrichar@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-06x86: gpio: Add GPIO driver for Intel ICH6 and later.Bill Richardson
Implement <asm-generic/gpio.h> functions for Intel ICH6 and later. Only GPIOs 0-31 are handled by this code. Signed-off-by: Bill Richardson <wfrichar@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-03Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2012-11-30x86: video: Add coreboot framebuffer supportStefan Reinauer
Add a basic driver for the coreboot framebuffer. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: Add console command to display CBMEM console bufferVadim Bendebury
This command is useful to allow to observe messages generated by coreboot and u-boot until present. In particular it is handy when u-boot is instrumented to fall through into console mode on startup errors. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: Add CBMEM console driver for corebootVadim Bendebury
This patch builds upon the recently introduced CBMEM console feature of coreboot. CBMEM console uses a memry area allocated by coreboot to store the console output. The memory area has a certain structure, which allows to determine where the buffer is, the buffer size and the location of the pointer in the buffer. This allows different phases of the firmware (rom based coreboot, ram based coreboot, u-boot after relocation with this change) to keep adding text to the same buffer. Note that this patch introduces a new console driver and adds the driver to the list of drivers to be used for console output, i.e. it engages only after u-boot relocates. Usiong CBMEM console for capturing the pre-relocation console output will be done under a separate change. >From Linux, run the cbmem.py utility (which is a part of the coreboot package) to see the output, e.g.: vvvvvvvvvvvvvvvvv SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode flags: 64bit ilck stag led pmp pio ... Magic signature found Kernel command line: "cros_secure quiet loglevel=1 console=tty2... ^^^^^^^^^^^^^^^^^ Note that the entire u-boot output fits into the buffer only if the coreboot log level is reduced from the most verbose. Ether the buffer size will have to be increased, or the coreboot verbosity permanently reduced. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30serial: serial_sh: bugfix: autoboot fails if serial console is not connectedTetsuyuki Kobayashi
On kzm9g board (rmobile SoC), autoboot fails if serial console cable is not connected. When serial cable is not connected, serial error occurs and some garbage comes in data register. sh_serial_tstc() in serial_sh.c does not check error status and misunderstand there is some input data. It is the reason that autoboot fails. This patch adds checking error status in sh_serial_tstc(). This patch is based on v2013.01-rc1 tag of u-boot master git. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-11-28Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2012-11-27powerpc/p4080ds: fix PCI-e x8 link training down failureYuanquan Chen
Due to SerDes configuration error, if we set the PCI-e controller link width as x8 in RCW and add a narrower width(such as x4, x2 or x1) PCI-e device to PCI-e slot, it fails to train down to the PCI-e device's link width. According to p4080ds errata PCIe-A003, we reset the PCI-e controller link width to x4 in u-boot. Then it can train down to x2 or x1 width to make the PCI-e link between RC and EP. Signed-off-by: Yuanquan Chen <B41889@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27powerpc/85xx: add support for the Freescale P5040DS Superhydra reference boardTimur Tabi
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of P3041DS/P5020DS ("Hydra") reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27mmc: Properly determine maximum supported bus widthAndy Fleming
At some point, a confusion arose about the use of the bit definitions in host_caps for bus widths, and the value in ext_csd. By coincidence, a simple shift could convert between one and the other: MMC_MODE_1BIT = 0, EXT_CSD_BUS_WIDTH_1 = 0 MMC_MODE_4BIT = 0x100, EXT_CSD_BUS_WIDTH_4 = 1 MMC_MODE_8BIT = 0x200, EXT_CSD_BUS_WIDTH_8 = 2 However, as host_caps is a bitmask of supported things, there is not, in fact, a one-to-one correspondence. host_caps is capable of containing MODE_4BIT | MODE_8BIT, so nonsensical things were happening where we would try to set the bus width to 12. The new code clarifies the very different namespaces: host_caps/card_caps = bitmask (MMC_MODE_*) ext CSD fields are just an index (EXT_CSD_BUS_WIDTH_*) mmc->bus_width integer number of bits (1, 4, 8) We create arrays to map between the namespaces, like in Linux. Signed-off-by: Andy Fleming <afleming@freescale.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2012-11-27mmc: tegra: use bounce buffer APIsStephen Warren
Tegra's MMC driver does DMA, and hence needs cache-aligned buffers. In some cases (e.g. user load commands) this cannot be guaranteed by callers of the MMC APIs. To solve this, modify the Tegra MMC driver to use the new bounce_buffer_*() APIs. Note: Ideally, all U-Boot code will always provide address- and size- aligned buffers, so a bounce buffer will only ever be needed for user- supplied buffers (e.g. load commands). Ensuring this removes the need for performance-sucking bounce buffer cache management and memcpy()s. The one known exception at present is the SCR buffer in sd_change_freq(), which is only 8 bytes long. Solving this requires enhancing struct mmc_data to know the difference between buffer size and transferred data size, or forcing all callers of mmc_send_cmd() to have allocated buffers using ALLOC_CACHE_ALIGN_BUFFER(), which while true in this case, is not enforced in any way at present, and so cannot be assumed by the core MMC code. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27common: rework bouncebuf implementationStephen Warren
The current bouncebuf API requires all parameters to be passed to both bounce_buffer_start() and bounce_buffer_stop(). Modify the bouncebuf start function to accept a state structure as a parameter, and only require that state struct to be passed to the stop function. This simplifies usage of the bounce buffer by clients. Don't modify the data pointer, but rather store the temporary buffer in this state struct. The bouncebuf code ensures that client code can always use a single buffer pointer in the state structure, irrespective of whether a bounce buffer actually had to be allocated. Move cache management logic into the bounce buffer code, so that each client doesn't have to duplicate this. I believe there's no need to invalidate the buffer before a DMA operation, since flushing the cache should prevent any write-backs. Update the MXS MMC driver for this change. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27mmc: add no simultaenous power and vddMela Custodio
Bring in the code from Linux kernel. Added to Linux kernel by: commit e08c1694d9e2138204f2b79b73f0f159074ce2f5 Author: Andres Salomon <dilinger@queued.net> Date: Fri Jul 4 10:00:03 2008 -0700 Some HW balks when writing both voltage setting and power up at the same time to SDHCI_POWER_CONTROL register. Signed-off-by: Rommel G Custodio <sessyargc@gmail.com> CC: Andy Fleming <afleming@freescale.com> v2: fix attribution and SOB Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27mmc: Fix interpretation of MMC_CMD_ALL_SEND_CIDTaylor Hutt
The interpretation of the data returned by the MMC_CMD_ALL_SEND_CID command was incorrect with respect to the JEDEC Standard No. 84-A441. This change makes the interpretation correct with respect to the defined fields of the CID register. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27EXYNOS: mmc: support DesignWare Controller for Samsung-SoCJaehoon Chung
Support DesignWare MMC Controller for Samsung Specific. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Rajeshawari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27Remove obsolete header filePantelis Antoniou
usbdescriptors.h conflicts with linux/usb/ch9.h Remove it. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2012-11-26Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2012-11-26nand: Add torture featureBenoît Thébaudeau
This patch adds a NAND Flash torture feature, which is useful as a block stress test to determine if a block is still good and reliable (or should be marked as bad), e.g. after a write error. This code is ported from mtd-utils' lib/libmtd.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-26nand: Fix nand_erase_opts() offset checkBenoît Thébaudeau
NAND Flash is erased by blocks, not by pages. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com>
2012-11-26nand: Clean up nand_utilBenoît Thébaudeau
This patch cleans up nand_util.c: - Fix tabs. - Fix typos. - Remove space character before opening parenthesis in function calls. - Fix comments. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com>
2012-11-26nand: Move the sub-page read support enable to a flagJoe Hershberger
Use a flag instead of a hard-coded macro so that sub-page reads can be enabled in other cases (such as on-die ecc). This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-26driver/mtd:IFC NAND:Initialise internal SRAM before any writePrabhakar Kushwaha
IFC-1.1.0 uses 28nm techenology for SRAM. This tech has known limitaion for SRAM i.e. "byte select" is not supported. Hence Read Modify Write is implemented in IFC for any "system side write" into sram buffer. Reading an uninitialized memory results in ECC Error from sram wrapper. Hence we must initialize/prefill SRAM buffer by any data before writing anything in SRAM from system side. To initialize SRAM user can use "READID" NAND command with read bytes equal to SRAM size. It will be a one time activity post boot Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [scottwood@freescale.com: fix fsl_ifc_sram_init prototype] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-26nand/fsl: add NAND_NO_SUBPAGE_WRITE to eLBC and IFC driversScott Wood
These controllers can only do hardware ECC on full page transfers. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-26spl/nand: config symbol documentationScott Wood
Document parameters used for specifying the NAND image to be loaded. Also fix the definition of CONFIG_SPL_NAND_SIMPLE -- it's only nand_spl_simple.c, not the entire nand directory. The word "simple" is there for a reason. :-) Signed-off-by: Scott Wood <scottwood@freescale.com> --- v2: updated for makefile changes earlier in patchset
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-11-26powerpc/mpc8xxx: move LAW code into arch/powerpc/cpu/mpc8xxxScott Wood
It's arch code and not a driver, so move it where it belongs. When it originally went into drivers/misc there was no 8xxx CPU directory. This will make new-SPL support a little easier since we can keep the CPU stuff together and not need to pull stuff in from drivers/misc. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2012-11-26serial/ns16550: wait for TEMT before initializingScott Wood
TEMT is set when the transmitter is totally empty and all output has finished. This prevents output problems (including a loss of synchronization observed on p2020 that persisted for quite a while) if SPL has output still on its way out. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: fixed typo in subject, and explained what the bit does in the changelog
2012-11-26serial/ns16550: don't build serial_ns16550 with MIN_FUNCTIONSScott Wood
CONFIG_NS16550_MIN_FUNCTIONS is used by small SPLs to gain access to basic ns16550 output code without pulling in things not needed by the SPL. This previously only worked with non-MULTI configs. Recently MULTI was made mandatory, and MIN_FUNCTIONS fails like this: drivers/serial/libserial.o: In function `calc_divisor.clone.0': serial_ns16550.c:(.text.calc_divisor.clone.0+0x24): undefined reference to `get_bus_freq' drivers/serial/libserial.o: In function `_serial_getc': (.text._serial_getc+0x30): undefined reference to `NS16550_getc' drivers/serial/libserial.o: In function `_serial_tstc': (.text._serial_tstc+0x30): undefined reference to `NS16550_tstc' drivers/serial/libserial.o: In function `_serial_setbrg': (.text._serial_setbrg+0x3c): undefined reference to `NS16550_reinit' make[1]: *** [/tmp/u-boot/spl/u-boot-spl] Error 1 make: *** [/tmp/u-boot/spl/u-boot-spl.bin] Error 2 With MIN_FUNCTIONS we don't need anything from this file, so don't build it. The conditional needs to be in the file itself rather than the makefile, because the config symbols are only imported to the makefiles once, not separately for the SPL phase of the build. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-20usb: r8a6659: Fix build by missing of parenthesisNobuhiro Iwamatsu
By commit c7e3b2b5, this was chanded to support multiple controllers. But this has missing of parenthesis. This commit fix it. ----- r8a66597-hcd.c: In function ‘usb_lowlevel_init’: r8a66597-hcd.c:911:52: error: expected declaration specifiers before ‘)’ token r8a66597-hcd.c:935:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or‘__attribute__’ before ‘{’ token r8a66597-hcd.c:939:1: error: expected ‘{’ at end of input ----- Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Lucas Stach <dev@lynxeye.de>
