On some Freescale SoC Internal DMA of eSDHC controller has bug.
So PIO Mode has been introduced to do data transfer using CPU.
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
The appropriate include/asm-$ARCH directory should already by symlinked
to include/asm so using the whole "asm-$ARCH" path is unnecessary.
This change should also allow us to move the include/asm-$ARCH
directories into their appropriate lib/$ARCH/ directories.
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Add NEC EHCI controller to the list of the supported devices.
Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
drivers/usb/host/ehci-pci.c | 1 +
1 file changed, 1 insertion(+)
Commit b416191a14770c6bcc6fd67be7decf8159b2baee (Fix EHCI port reset.) didn't
move the code that checked for successful clearing of the port reset bit from
ehci_submit_root(), relying on wait_ms() call instead. The mentioned code also
erroneously reported port reset state when the reset was already completed.
USB devices on the 2nd port are not detected and I get the following message:
The request port(1) is not configured
That's with default CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS value of 2. 'req->index'
is 1-based, so the comparison in ehci_submit_root() can't be correct.
On little endian machines, EHCI root hub's USB revision is reported as 0.2 --
cpu_to_le16() was missed in the initializer for the 'bcdUSB' descriptor field.
The same should be done for the 'bcdDevice' field.
Fixes this warning:
ati_radeon_fb.c: In function 'radeon_probe':
ati_radeon_fb.c:598: warning: format '%x' expects type 'unsigned int',
but argument 2 has type 'void *'
Use pci_bus_to_virt() to convert the bus address from the BARs to
virtual address' to eliminate the direct mapping requirement.
Rename variables to better match usage (_phys -> _bus or no-suffix)
This fixes the mpc8572ds CONFIG_PHYS_64BIT mode failure:
"videoboot: Video ROM failed to map!"
Tested on mpc8572ds with and without CONFIG_PHYS_64BIT.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Console was being switched to video even if emulator fails and
causing this hang:
Scanning PCI bus 04
04 00 1095 3132 0104 00
PCIE3 on bus 03 - 04
Video: ATI Radeon video card (1002, 5b60) found @(2:0:0)
videoboot: Booting PCI video card bus 2, function 0, device 0
640x480x8 31kHz 59Hz
radeonfb: FIFO Timeout !
Tested-by: Anatolij Gustschin <agust@denx.de>
Allow displaying 8-bit RLE BMP images.
This patch adds reset_timer() before the flash status check
waiting loop.
Since the timer is basically running asynchronous to the cfi
code, it is possible to call get_timer(0), then only a few
_SYSCLK_ cycles later an interrupt is generated. This causes
timeout even though much less time has elapsed. So the timer
period registers should be reset before get_timer(0) is
called.
There is similar usage in nand_base.c.
There are various locations that we have chip specific info:
* Makefile for which ddr code to build
* Added P1012/P1013/P1021/P1022 to cpu_type_list and SVR list
* Added number of LAWs for P1012/P1013/P1021/P1022
* Set CONFIG_MAX_CPUS to 2 for P1021/P1022
* PCI port config
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
If the PCI controller wasn't configured or enabled delete from the
device tree (include its alias).
For the case that we didn't even configure u-boot with knowledge of
the controller we can use the fact that the pci_controller pointer
is NULL to delete the node in the device tree. We determine that
a controller was not setup (because of HW config) based on the fact
that cfg_addr wasn't setup.
When we set the read or write watermark in WML we should maintain the
rest of the register as is, rather than using some hard coded value.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
To support multiple block read command we must set abort or use auto
CMD12. If we booted from eSDHC controller neither of these are used
and thus we need to reset the controller to allow multiple block read
to function.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
We need to stop the clocks on 83xx/85xx as well as imx. No need to make
this code conditional to just imx.
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
This patch is part of migrating the AT91 support towards
using C struct for all SOC access.
It removes one more CONFIG_AT91_LEGACY warning.
at91_pmc.h needs cleanup after migration of the drivers
has been done.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This converts the at91 watchdog driver to new c structure
type to access registers of the SoC
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
The outx/writex macros were using writex(addr, val) rather than
the standard writex(val, addr), resulting in incompatibilty with
architecture independent components. This change set uses standard
parameter order.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
The standard Altera UART & JTAG UART as well as the OpenCores
YANU driver are now in individual files in drivers/serial
rather than a single file uner cpu/nios2.
Only fill the device enetaddr with the contents of the eeprom,
do not program it in MAC address registers
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds status polling method to offer an alternative to
data toggle method for amd flash chips.
This patch is needed for nios2 cfi flash interface, where the bus
controller performs 4 bytes read cycles for a single byte read
instruction. The data toggle method can not detect chip busy
status correctly. So we have to poll DQ7, which will be inverted
when the chip is busy.
This feature is enabled with the config def,
CONFIG_SYS_CFI_FLASH_STATUS_POLL
With old configuration it could happen tout=0 if CONFIG_SYS_HZ<1000.
Signed-off-by: Renato Andreola <renato.andreola@imagos.it>
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
Provide proper port passing from serial_init to uart_part_conf.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Using seperate function calls for each bit-bang of slave serial
load can be painfully slow. This patch adds the possibility to
supply a block write function that loads the complete block of
data in one call (like it can already be done with Altera FPGAs).
On an MCF5373L (240 MHz) loading an XC3S4000 this reduces the load
time from around 15 seconds to around 3 seconds
Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
This is a patch to use the hardware ECC controller of
the AT91SAM9260 for the AT91 nand. Taken from the kernel 2.6.33.
Signed-off-by: Nikolay Petukhov <Nikolay.Petukhov@gmail.com>
Modified to use IO accessor routines consistently. Eliminated volatile usage
to keep checkpatch.pl happy.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
If a splashscreen is used the console scrolling used the
scroll size as needed when a logo was displayed. This
patch sets the scroll size to the whole screen if
a splashscreen is shown.
Signed-off-by: Matthias Weisser <matthias.weisser@graf-syteco.de>
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;'
Signed-off-by: Thomas Weber <swirl@gmx.li>
Add some more: neither Makefile nor config.mk need execute permissions.
Some registers of the mxcmmc driver were accessed using
16 bit accessor functions, because only the LSB is
significant. This is not needed and generates
warnings.
Signed-off-by: FUJITA Kazutoshi <fujita@soum.co.jp>
Signed-off-by: <wd@denx.de>
Coding style cleanup, update CHANGELOG.
