path: root/drivers
2014-11-23pci: Honour pci_skip_dev()Thierry Reding
When enumerating devices, honour the pci_skip_dev() function. This can be used by PCI controller drivers to restrict which devices will be probed. This is required by the NVIDIA Tegra PCIe controller driver, which will fail with a data abort exception if an access is attempted to a device number larger than 0 outside of bus 0. pci_skip_dev() is therefore implemented to prevent any such accesses. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23sata: fix a bug in init_sata() for pci-sata cardli pengbo
Except the first loop, init_sata() should return 0 instead of 1 in the others. This patch fix the issue of the 2nd sata port not workable on pci-sata card. Signed-off-by: Pengbo Li <Pengbo.Li@freescale.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20replace DIV_ROUND with DIV_ROUND_CLOSESTMasahiro Yamada
The Linux-compatible macro DIV_ROUND_CLOSEST is a bit more flexible and safer than DIV_ROUND. For example, foo = DIV_ROUND_CLOSEST(x, y++) works expectedly, but foo = DIV_ROUND(x, y++) does not. (y is incremented twice.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20ARM: remove CONFIG_ARM920T definesMasahiro Yamada
CONFIG_CPU_ARM920T was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM920T and replaces the only reference in drivers/usb/host/ohci-hcd.c with CONFIG_CPU_ARM920T. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-19Merge branch 'master' of git://git.denx.de/u-boot-ubiTom Rini
2014-11-19Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2014-11-19mtd: Handle 29LV800BTDirk Eibach
The device id makes u-boot think that this chip needs cfi_reverse_geometry(), which is not the case. Add it to jedec_flash, so it is handled properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-19mtd, cfi, ubi: add missing writebufsize initializationHeiko Schocher
ff94bc40af3481d47546595ba73c136de6af6929 "mtd, ubi, ubifs: resync with Linux-3.14" introduced the writebufsize field in struct mtd_info, which is not initialized in the cfi_flash driver, which leads in not working ubi on cfi flashes. Fix it Signed-off-by: Heiko Schocher <hs@denx.de> Reported-by: Andrew Ruder <andrew.ruder@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
2014-11-17net: macb: enable GMAC IP without GE feature supportBo Shen
The User Register in GMAC IP is used to select interface type. When with GE feature, it is used to select interface between RGMII and GMII. If without GE feature, it is used to select interface between MII and RMII. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17mtd: atmel_nand: runtime to build gf table for pmeccJosh Wu
As in SAMA5D4 SoC, the gf table in ROM code can not be seen. So, when we try to use PMECC, we need to build it when do initialization. Add a macro NO_GALOIS_TABLE_IN_ROM in soc header file. If it is defined we will build gf table runtime. The PMECC use the BCH algorithm, so based on the build_gf_tables() function in lib/bch.c, we can build the Galois Field lookup table. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17spl, mtd, nand, atmel_nand: invert device ready pin logicHeiko Schocher
device ready pin is signalling that the device is ready on state 1 not on 0. Simmiliar as it is in drivers/mtd/nand/nand_spl_simple.c Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Bo Shen <voice.shen@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17spl, nand, atmel_nand: add erase one block functionHeiko Schocher
erase one nand block in spl code. keep it simple, as size matters This is used on the upcoming taurus spl support. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17mtd: atmel_nand: add missing includeHeiko Schocher
using this driver in SPL code with CONFIG_SPL_NAND_ECC configured leads in an compileerror. Fix this. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Bo Shen <voice.shen@atmel.com> [fix subject] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17spi, atmel: move CONFIG_SYS_SPI_WRITE_TOUT into common headerHeiko Schocher
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h and define a default value. Delete this define in the board config files, where it is possible (all boards use currently the same value). Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17net: macb: write mac address when initializationBo Shen
When boot up without mac address setting, it will give the warning message like: "Warning: failed to set MAC address", however when execute network related command, it still execute them without any warning information. With this patch, it will exit directly with following information: "gmac0: mac address is not valid" It also solve the problem after bootup then set mac address and the mac address won't set to net device issue. Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2014-11-17blackfin: convert to use CONFIG_SYS_I2C frameworkScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
2014-11-17adi_i2c: convert to use general io accessors.Scott Jiang
2014-11-17blackfin: rename bfin-twi_i2c driver to adi_i2cScott Jiang
2014-11-14Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-11-14Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2014-11-14driver/net/fm/memac_phy: set NEG bit for external MDIOsShaohui Xie
NEG bit default is '1' for external MDIOs as per FMAN-v3 RM, but on some platforms, e.g. T2080QDS, this bit is '0', which leads to MDIO failure on XAUI PHY, so set this bit definitely to align with the RM. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14Fman/mEMAC: mEMAC fix for 10G MAC and PHYShaohui Xie
1. use Payload length check disable when enable MAC; 2. add XGMII support for setting MAC interface mode; 3. only enable auto negotiation for Non-XGMII mode; 4. return 0xffff if clause 22 is used to read 10G phy_id; Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-By: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-13Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2014-11-13sun6i: ehci: Add sun6i ehci supportHans de Goede
Add support for the 2 ehci controllers found on the sun6i (A31) soc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Marek Vasut <marex@denx.de>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sun6i: Add basic axp221 driverOliver Schinagl
The A31 uses the AXP221 pmic for various voltages. Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> -- Changes in v2: -Rebase Changes in v3: -Add support for all dldo and aldo-s -Add Kconfig option to select building AXP221 and to select voltage of dldo and aldo-s Changes in v4: -Add axp221_setbits helper function -Use symbolic names for enabled bits in CTRL1 - CTRL3 registers
2014-11-13sh: move CONFIG_{SH2, SH2A, SH3, SH4} to KconfigMasahiro Yamada
This commit moves CONFIG_SH2, CONFIG_SH2A, CONFIG_SH3, CONFIG_SH4 to Kconfig renaming into CONFIG_CPU_SH2, CONFIG_CPU_SH2A, CONFIG_CPU_SH3, CONFIG_CPU_SH4, respectively because arch/sh/Kconfig of Linux uses CONFIG_CPU_SH* convention. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-11-12usb: UniPhier: add UniPhier on-chip EHCI host driver supportMasahiro Yamada
Support EHCI host driver used on Panasonic UniPhier platform. Since Device Tree is not supported on UniPhier yet, the base address of USB cores are passed from board files (platdevice.c). TODO for me: Move the base address to device trees. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2014-11-12usb: add basic USB configs in KconfigMasahiro Yamada
2014-11-12serial: UniPhier: borrow macros from linux/serial_reg.hMasahiro Yamada
The same bit-field macros are defined in include/linux/serial_reg.h so let's include it and delete duplicated defines. Also, remove unnecessary inclusion of <common.h>. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2014-11-10i2c: rcar_i2c: Fix order of restart and clear statusNobuhiro Iwamatsu
In case of repeated START condition, the restart has to be kicked before clear status (MSR register). If it is kicked after clear status, R-Car I2C may transfer data (TXD register) or receive data (RXD register) instead of transferring slave address (MAR register). Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-11-10drivers/i2c/fsl_i2c: Change CONFIG_I2C_TIMEOUT to 100msShaveta Leekha
Some slow I2C devices like Power Monitor(ZM7304) at times do not work well with low timeout value, so I2C bus get stuck during read cycle with this device, changing it to 100ms from 10ms works fine A lot of other i2c drivers like mxc and i2c drivers of BOOTROM also use relax timeouts to give sufficient ticks to work well with slower devices Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2014-11-10ppc4xx: Handle i2c stuck on combined xferDirk Eibach
ppc4xx i2c master gets stuck on errors while repeated start is active. Can be easily reproduced by "i2c md" on an unpopulated i2c address. There is not stop condition given, scl remains pulled low. The only way out seems to be doing a stop manually and then a soft reset. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2014-11-10ppc4xx: Fix i2c repeated startDirk Eibach
Debugging some i2c trouble I saw on my scope that repeated start is not working properply. The 4xx even held clock pulled down after transfers. Having a look in the driver I realized that IIC_CNTL_RPST is set on that part of the transfer that should begin with a repeated start. But repeated start is about not sending a stop condition, so IIC_CNTL_RPST has to be set on the last transfer before the repeated start happens. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de>
2014-11-07drivers/net/uli526x.c: fix syntax errorWolfgang Denk
Fix error detected by cppcheck: [drivers/net/uli526x.c:551]: (error) printf format string requires 3 parameters but only 2 are given. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Roy Zang <tie-fei.zang@freescale.com>
2014-11-07power_spi.c: Rewrite pmic_reg functionTom Rini
The pmic_spi_free function isn't ever used, and as the frameworks stand today, cannot be, so remove it. Integrate the probe function into pmic_reg as it's not really a "probe" today. Finally, add an err label for the common failure cases. Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-07net: smc911x: Keep MAC programmedMarek Vasut
Make sure to keep the MAC address programmed in the SMC911x ADDRH and ADDRL registers. Linux can read those registers to determine the MAC address on EEPROM-less configurations. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Tom Rini <trini@ti.com>
2014-11-07sort drivers/mmc/MakefilePavel Machek
Sort drivers/mmc makefile, as requested by wd. Signed-off-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2014-11-07Merge git://git.denx.de/u-boot-tiTom Rini
2014-11-07usb: eth: fix MakefileRene Griessl
fix obj-y term Signed-off-by: Rene Griessl <rgriessl@cit-ec.uni-bielefeld.de>
2014-11-07usb: rmobile: Use ARRAY_SIZE(usb_base_address) instead of ↵Nobuhiro Iwamatsu
CONFIG_USB_MAX_CONTROLLER_COUNT Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Marek Vasut <marex@denx.de>
2014-11-07usb: ehci: fix Interrupt on Doorbell flag of USBCMDMasahiro Yamada
CMD_IAAD (Interrupt on Async Advance Doorbell) is bit 6, not bit 5. While we are here, sort the flags. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07usb: s3c-otg: Allow custom gusbcfgMarek Vasut
Allow passing in a custom configuration of the gusbcfg register via platform data. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2014-11-07usb: s3c-otg: Split out PHY controlMarek Vasut
Split the Samsung specific PHY control into a separate file and compile this into the S3C OTG driver only if used on a Samsung system. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2014-11-06usb: s3c-otg: Encapsulate PHY controlMarek Vasut
Encapsulate the Samsung PHY control and its register accesses into the otg_phy_init() and otg_phy_off() functions. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
