MAINTAINERS
Run fixups based on the JEDEC manufacturer ID independent of the
command set ID.
This changes current behaviour: Previously, geometry reversal for AMD
chips were done based on the command set ID, while they are now done
based on the JEDEC manufacturer and device ID.
Also add fixup for top-boot Atmel chips. A fixup is needed for
AT49BV6416(T) too, but since u-boot currently only reads the low byte
of the device ID, there's no way to tell it apart from AT49BV642D,
which should not have this fixup. Since AT49BV642D support is
necessary to get ATNGW100 board support into mainline, I've commented
out the fixup for now.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Move things like reading JEDEC IDs and fixing up geometry reversal
into separate functions. The geometry reversal fixup is now performed
by altering the qry structure directly, which makes the sector init
code slightly cleaner.
Read out the whole CFI Standard Query structure after successful cfi
identification. This allows subsequent code to access this information
directly without having to go through flash_read_uchar() and friends.
Use map_physmem() and unmap_physmem() to convert from physical to
virtual addresses. This gives the arch a chance to provide an uncached
mapping for flash accesses.
Introduce flash_read{8,16,32,64) and flash_write{8,16,32,64} and use
them to access the flash memory. This makes it clearer when the flash
is actually being accessed; merely dereferencing a volatile pointer
looks just like any other kind of access.
Reorder the functions in cfi_flash.c so that each function only uses
functions that have been defined before it. This allows the static
prototype declarations near the top to be eliminated and might allow
gcc to do a better job inlining functions.
Make functions not declared in any header file static.
This patch tries to keep all lines in the cfi_flash driver below 80
columns. There are a few lines left which don't fit this requirement
because I couldn't find any trivial way to break them (i.e. it would
take some restructuring, which I intend to do in a later patch.)
Fixes non-working CFI Flash on the Inka4x0 board.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
On the MPC85xx boards that have PCIe enable the PCIe errata fix.
(MPC8544DS, MPC8548CDS, MPC8568MDS).
The following patch adds support for non-CFI flash ROMS, by hooking into the
CFI flash code and using most of its code, as recently discussed here in the
thread "Mixing CFI and non-CFI flashs".
Signed-off-by: Michael Schwingen <michael@schwingen.org>
The composition of the directory in the drivers/ changed.
I moved SuperH serial driver and marubun PCMCIA driver.
drivers/Makefile
Marubun pcmcia is a chip for PCMCIA used with SuperH.
Of course, this can be used even by other architectures.
When use this driver, came to be able to use CompactFlash
and Ethernet.
- Changed volatile unsigned to vu_.
- Changed Makefile for kconfig.
drivers/Makefile
drivers/Makefile
This change is in preparation for condtitionial compile support in the
build system. By spliting them all into seperate lines now, subsequent
patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will
be less invasive and easier to review
This patch implements general ULi 526x Ethernet driver.
Until now, it is the only native Ethernet port on
MPC8610HPCD board, but it could be used on other boards
with ULi 526x Ethernet port as well.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
