CONFIG_CMD_TCA642X
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This driver is not used in U-Boot. Drop it and its associated CONFIG
options.
This driver is not used by any board. Drop it.
It does not seem worth having an option to enable another sub-command in
this legacy driver. Drop this option so that the sub-command is always
available.
CONFIG_CMD_PCA953X
Allow sending restart conditions upon direction change as this is
required by some chips.
Cc: Stefan Roese <sr@denx.de>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Reviewed-by: Heiko Schocher <hs@denxx.de>
CONFIG_SYS_I2C_OMAP24XX
Set BM poll size once during priv probe and do not
overwrite it during port probe procedure. Pool is common for
all CP ports.
Signed-off-by: Stefan Chulski <stefanc@marvell.com>
Tested-by: iSoC Platform CI <ykjenk@marvell.com>
Reviewed-by: Nadav Haklai <nadavh@marvell.com>
Reviewed-by: Igal Liberman <igall@marvell.com>
TX drain in transmit procedure could cause issues due
to race between drain procedure and transmition of descriptor
between AGGR TXQ and physical TXQ.
TXQ will be cleared before moving to Linux by stop procedure.
MVPP22 driver support 64 Bit arch and require BM pool
high address configuration.
Remove IRQ configuration from U-Boot PP driver.
U-Boot don't use interrupts and configuration of IRQ in U-Boot
caused crashes in Linux shared interrupt mode.
Also interrupt use is redundant in RX routine since a single RX
queue is used.
MBUS driver were replaced by AXI in PPv22 and relevant
only for PPv21.
U-boot use single physical tx queue with size 16 descriptors.
So aggregated tx queue size should be equal to physical tx queue
and cpu descriptor chunk(number of descriptors delivered from
physical tx queue to aggregated tx queue by one chunk) shouldn't be
larger than physical tx queue.
Fix:
Set AGGR_TXQ and CPU_DESC_CHUNK to be 16 descriptors, same as
physical TXQ.
Issue:
BM counters were overrun by probe that called per Network interface and
caused release of wrong number of buffers during remove procedure.
Fix:
Use probe_done and num_ports to call init and remove procedure
once per communication controller.
This patch enables padding of packets shorter than 64B in TX(set by default).
Disabling of padding causes crashes on MACCIATO board.
A8K marvell SoC has two South Bridge communication controllers(CP0 and CP1).
Each communication controller has packet processor ports and MDIO.
On MACHIATOBin board ports from CP1 are connected to mdio on CP0.
Issue:
Wrong base address is assigned to MDIO interface during probe.
Fix:
Get MDIO address from PHY handler parent base address.
This should be refined in the future when MDIO driver is implemented.
This patch add GPIO configuration support in mvpp2x driver.
Driver will handle 10G SFP gpio reset and SFP TX disable. GPIO pins should
be set in device tree.
Reviewed-by: Kostya Porotchkin <kostap@marvell.com>
In fsl_mc_ldpaa_exit(), in case of mc is booted and dpl is applied,
it should return earlier without executing dpbp_exit().
Signed-off-by: Santan Kumar <santan.kumar@nxp.com>
Acked-by: Priyanka Jain <priyanka.jain@nxp.com>
Acked-by: Yogesh Narayan Gaur <yogeshnarayan.gaur@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
We shouldn't always change the status to okay. There could be
situations that the esdhc is intentionally disabled in the device
tree.
Signed-off-by: Li Yang <leoyang.li@nxp.com>
This bug is brought by the commit 3d8553f0a3 (pci: layerscape: add
LS2088A series SoC pcie support), which only updated cfg_res.start
and did not update the .end field. This causes fdt_resource_size()
getting wrong value when calculate the cfg1 space address.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[YS: Revise subject and commit message]
Commit 4483b7eb added variable vqmmc_dev but only uses it under
CONFIG_DM_REGULATOR. Add the same macro to variable declaration to
get rid of compiling warning.
Signed-off-by: York Sun <york.sun@nxp.com>
The driver is for all boards 24XX and up, so let's eliminate the
extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks
for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX.
Add missing probe function to the device driver to active a device.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
The environment variable "disable_giga" can now be used to disable
1000baseTx on the Micrel's KSZ9031.
Signed-off-by: Sebastien Bourdelin <sebastien.bourdelin@savoirfairelinux.com>
Added the AFE (Analog Front End) settings for stability to the
Broadcom Cygnus phy. This improves the time take to perform
auto negotiation.
Signed-off-by: Arun Parameswaran <arun.parameswaran@broadcom.com>
move to Kconfig:
CONFIG_BCM_SF2_ETH
CONFIG_BCM_SF2_ETH_DEFAULT_PORT
CONFIG_BCM_SF2_ETH_GMAC
Also modified defconfigs of all platforms that use these configs.
Signed-off-by: Suji Velupillai <suji.velupillai@broadcom.com>
Tested-by: Suji Velupillai <suji.velupillai@broadcom.com>
Reviewed-by: JD Zheng <jiandong.zheng@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Signed-off-by: Steve Rae <steve.rae@raedomain.com>
The correct option is PHY_MICREL_KSZ90X1, but some configs still
select the 9021 and 9031 options, which are deprecated.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
There should be no longer be any ksz9000 users that pick up the PHY
driver from ksz8xxx, so remove ksz9000 remnants from there.
The KS8721BL and KSZ9021 PHYs are software-incompatible, yet they
share the same ID. Drivers for bothe PHYs cannot safely coexist, so
the solution was to use #ifdefs to select between the two drivers.
As a result KSZ9031, which has a unique ID, is now caught in the
crossfire. Unless CONFIG_PHY_MICREL_KSZ9031 is defined, the KSZ9031
will not function properly, as some essential configuration code is
ifdef'd-out.
To prevent such situations, move the KSZ9000 drivers to a separate
file, and place them under a separate Kconfig option. While it is
possible to enable both KSZ8000 and KSZ9000 drivers at the same time,
the assumption is that it is highly unlikely for a system to contain
both a KSZ8000 and a KSZ9000 PHY, and that only one of the drivers
will be enabled at any given time.
Don't wait forever.
Pass errors back to the caller.
The register constants don't use the exact names that are used in the
TRM, so add comments that use the exact names so that it is clear what
register is being referred to.
https://www.atheros-drivers.com/qualcomm-atheros-datasheets-for-AR9331.html
After upgrading to GCC 7.1, the duplicate const specifies in the
r8152 driver trigger the following build warnings with buildman
(observed on a 'buildman rockchip' test)::
../drivers/usb/eth/r8152.c:62:35: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier]
static const struct r8152_version const r8152_versions[] = {
This commit fixes these by removing the duplicate 'const' specifier
from the declarations.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
phy_device_create(..) sets the addr of phy_device with a sane value.
There is no need overwrite it.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add rk3288 soc specific driver for mipi dsi.
Add Makefile item for soc specific driver for rk3399 mipi dsi.
To compatible with different rockchip soc, we split the mipi dirver into
common and soc specific parts, and all the soc share the common
functions from common driver part.
[agust: fix build breakage and warnings]
This is not used in U-Boot.
Xilinx changes for v2017.09
Zynq:
- Add Z-Turn board support
fpga:
- Remove intermediate buffer from code
Zynqmp:
- dts cleanup
- change psu_init handling
- Add options to get silicon version
- Fix time handling
- Map OCM/TCM via MMU
- Add new clock driver
ahci_probe_scsi() now takes a 'base' argument, and there is an API
that prepares base address for us: ahci_probe_scsi_pci().
Reported-by: Tom Rini <trini@konsulko.com>
Add support for enabling and disabling the clock using the clock
framework based on the content of OF instead of doing it manually
in the board file.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
The order of parameters passed to the phy_connect() was wrong.
Moreover, only PHY address 0 was used. Replace this with code
capable of detecting the PHY address.
