* 'master' of git://git.denx.de/u-boot-video:
video: atmel/lcd: add LCD driver for new Atmel SoC
video: cfb_console: flush dcache for frame buffer in DRAM
cfb_console: Ignore bell character
cfb_console: Add console_clear_line function
cfb_console: Fix function console_back
omap3_dss: cosmetic changes
omap3_dss: add optional framebuffer
mx53loco: Add LCD support
mx5: Rename mx51_fb_init()
mx53: Allow IPUv3 driver to also work on mx53
mx51evk: Add LCD support
EXYNOS: display 32bpp bitmap TIZEN logo
create lib/tizen directory
LCD: display 32bpp decompressed bitmap image
common/lcd.c: reduce one CONFIG_LCD_LOGO ifdef
common/lcd.c: reduce some CONFIG_LCD_*_LOGO ifdefs
common/lcd.c: use ARRAY_SIZE
cmd_bmp.c: make bmp_display() usable by drivers or board code
LCD: support another s6e8ax0 panel type
LCD: change s6e8ax0 panel gamma value
include/video.h: drop unused video_printf()
The new Atmel SoC (at91sam9x5 series and at91sam9n12) add a totally
different LCD controller. Add this new driver to support it.
Using CONFIG_ATMEL_HLCD (distinguish with CONFIG_ATMEL_LCD) to enable
this in board configuration file.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Data cache flushing is required for frame buffer in RAM to fix the
distorted console text output. Currently this text distortion is
observed with cfb on beagleboard and N900 when running with data
cache enabled.
Reported-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
console_clear_line() clears part of specified line or the full line.
* Do not disable and enable the cursor again.
console_back() is called only from video_putc() which already turns
the cursor off at the beginning and turns it on at the end, so there
is no need to change the cursor in console_back().
This is an sh2a device (max 266MHz) with FPU, video display
controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports,
SD and on-chip USB.
The RSK2+SH7269 board uses the SH7269 processor. It is often
referred to as just rsk7269.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Remove unnecessary brackets.
Unwrap lines which are below 80 chars.
Single line comment as single line (as the rest).
Moved init values to the source code.
cc: s-paulraj@ti.com
cc: khasim@ti.com
Signed-off-by: Jeroen Hofstee <jhofstee@victronenergy.com>
The beagle board uses the background color to show an orange screen during
startup. This patch adds the ability to add a frame buffer, with the
intention not to break the beagle board use case (I don't have one).
videomodes.c is not used. Scrolling depends on this patch:
http://patchwork.ozlabs.org/patch/155662/
cc: trini@ti.com
cc: khasim@ti.com
The ipuv3 driver is currently only used on mx51, but it can be extended to work
on mx53 and mx6 as well.
Rename mx51_fb_init(), so that it can be used by other SoCs.
Acked-by: Jason Liu <r64343@freescale.com>
Adjust the IPU base registers so that ipuv3 driver can work on both mx51 and
mx53 SoCs.
This patch supports drawing 32bpp bitmap TIZEN logo in exynos fb.
"tizen_hd_logo.h" data is compressed from trats_logo.bmp to
trats_logo.bmp.gz by gzip and converted to tizen_hd_logo.h header file
format by some application. The logo data is decompressed in the exynos
fb driver by bmp_display().
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
s6e8ax0 panel has many panel of types. This patch support another panel
on TIZEN lunchbox board(HWREVISION 2). This panel has reversed panel
display type. So, I had added necessary command.
s6e8ax0 panel init gamma value is changed because existing it was not
proper value for this panel.
Signed-off-by: Inki Dae <inki.dae@samsung.com>
SH7734 support GMII. This add register infomation and the function
which enable GMII.
SH7734 has one channel ethernet device.
This support 10/100/1000Base, and RMII/MII/GMII.
And this has the same structure as SH7763.
Add several levels of DEBUG prints so that you can limit the noise to
the severety of your problem.
DEBUG_LL_STATE = Link local state machine changes
DEBUG_DEV_PKT = Packets or info directed to the device
DEBUG_NET_PKT = Packets on info on the network at large
DEBUG_INT_STATE = Internal network state changes
Fix NetConsole bug that causes first packet header to claim a
source IP address of 0.0.0.0
Call a built-in dummy if none is registered... don't require
protocols to register a handler (eliminating dummies)
NetConsole now uses the ARP handler when waiting on arp
(instead of needing a #define hack in arp.c)
Clear handlers at the end of net loop
Changes to NetState now go through an accessor function called
net_set_state()
Rename IP header related things to IP_UDP. The existing definition
of IP_t includes UDP header, so name it to accurately describe the
structure.
These are all the files which use the API incorrectly but did not get
built using MAKEALL -a powerpc|arm. I have no compiler for them, but
the remaining issues should be far less than without this patch.
Any outstanding issues are left to the maintainers of boards that use
these drivers.
Fix this:
rtl8169.c: In function 'rtl8169_initialize':
rtl8169.c:907:13: warning: assignment from incompatible pointer type
Fix this:
pcnet.c: In function 'pcnet_initialize':
pcnet.c:224:13: warning: assignment from incompatible pointer type
Fix this:
xilinx_axi_emac.c: In function 'xilinx_axiemac_initialize':
xilinx_axi_emac.c:646: warning: assignment from incompatible pointer type
Signed-off-by: Stephan Linz <linz@li-pro.net>
Fix this:
xilinx_emaclite.c: In function 'xilinx_emaclite_initialize':
xilinx_emaclite.c:371: warning: assignment from incompatible pointer type
Fix this:
xilinx_ll_temac.c: In function 'xilinx_ll_temac_initialize':
xilinx_ll_temac.c:332: warning: assignment from incompatible pointer type
xilinx_ll_temac.c:340: warning: assignment from incompatible pointer type
Fix this:
uec.c: In function 'uec_initialize':
uec.c:1404:12: warning: assignment from incompatible pointer type
Fix this:
uli526x.c: In function 'uli526x_initialize':
uli526x.c:243:13: warning: assignment from incompatible pointer type
Fix this:
tsi108_eth.c: In function 'tsi108_eth_initialize':
tsi108_eth.c:745:13: warning: assignment from incompatible pointer type
tsi108_eth.c: In function 'tsi108_eth_recv':
tsi108_eth.c:989:4: warning: passing argument 1 of 'NetReceive' discards qualifiers from pointer target type
Fix this:
rtl8139.c: In function 'rtl8139_initialize':
rtl8139.c:234:13: warning: assignment from incompatible pointer type
Fix this:
ns8382x.c: In function 'ns8382x_initialize':
ns8382x.c:352:13: warning: assignment from incompatible pointer type
Fix this:
natsemi.c: In function 'natsemi_initialize':
natsemi.c:338:13: warning: assignment from incompatible pointer type
Fix this:
eth.c: In function 'fm_eth_initialize':
eth.c:651:12: warning: assignment from incompatible pointer type
Fix this:
e1000.c: In function 'e1000_initialize':
e1000.c:5264:13: warning: assignment from incompatible pointer type
Fix this:
smc91111.c: In function 'smc91111_initialize':
smc91111.c:1363:12: warning: assignment from incompatible pointer type
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Fix this:
macb.c: In function 'macb_eth_initialize':
macb.c:564:15: warning: assignment from incompatible pointer type
Fix this:
lan91c96.c: In function 'lan91c96_initialize':
lan91c96.c:811:12: warning: assignment from incompatible pointer type
Fix this:
ks8695eth.c: In function 'ks8695_eth_initialize':
ks8695eth.c:236:12: warning: assignment from incompatible pointer type
Fix this:
ftmac100.c: In function 'ftmac100_initialize':
ftmac100.c:266:12: warning: assignment from incompatible pointer type
Fix this:
fec_mxc.c: In function 'fec_probe':
fec_mxc.c:926:13: warning: assignment from incompatible pointer type
Fix this:
enc28j60.c: In function 'enc28j60_initialize':
enc28j60.c:967:12: warning: assignment from incompatible pointer type
Fix this:
eepro100.c: In function 'eepro100_initialize':
eepro100.c:464:13: warning: assignment from incompatible pointer type
eepro100.c: In function 'eepro100_recv':
eepro100.c:694:4: warning: passing argument 1 of 'NetReceive' discards qualifiers from pointer target type
include/net.h:438:13: note: expected 'uchar *' but argument is of type 'volatile u8 *'
The use of a descriptor like this may mean DMA will update this at will
Beware this may be a source of trouble on some boards
Fix this:
dnet.c: In function 'dnet_eth_initialize':
dnet.c:380:15: warning: assignment from incompatible pointer type
Fix this:
dm9000x.c: In function 'dm9000_initialize':
dm9000x.c:636:12: warning: assignment from incompatible pointer type
Fix this:
dc2114x.c: In function 'dc21x4x_initialize':
dc2114x.c:305:15: warning: assignment from incompatible pointer type
Fix this:
cs8900.c: In function 'cs8900_initialize':
cs8900.c:326:12: warning: assignment from incompatible pointer type
Cc Joe Hershberger <joe.hershberger@gmail.com>
Fix this:
calxedaxgmac.c: In function 'xgmac_rx':
calxedaxgmac.c:479:2: warning: passing argument 1 of 'NetReceive' discards qualifiers from pointer target type
include/net.h:438:13: note: expected 'uchar *' but argument is of type 'volatile unsigned char *'
calxedaxgmac.c: In function 'calxedaxgmac_initialize':
calxedaxgmac.c:547:12: warning: assignment from incompatible pointer type
Fix this:
at91_emac.c: In function 'at91emac_register':
at91_emac.c:524:12: warning: assignment from incompatible pointer type
