path: root/drivers
2011-08-31phy.c: make less verbose - turn printf() into debug()Wolfgang Denk
The PHY driver was too verbose and corrupted the boot message display like this: ... Net: TSEC0 connected to Marvell 88E1111S TSEC1 connected to Marvell 88E1111S TSEC0, TSEC1 ... Turn printf() into debug() so we het the expected output again: ... Net: TSEC0, TSEC1 ... Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-08-26Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: add calling mmc_initialize in board.c sh: sh7757lcr: Add KEEP order to start.o section usb: r8a66597: Fix argument mistake of inl sh: Clean up rsk7264 board settings sh: sh2a: Add sh2a optimize to config.mk sh: Fix rsk7203 alignment problem sh: Add support for SH2A freestanding build sh: Add Renesas rsk7264 board
2011-08-22usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
Fail in build, because argument of inl used in r8a66597_read_fifo is wrong. r8a66597.h:441:35: error: macro "inl" passed 2 arguments, but takes just 1 In file included from r8a66597-hcd.c:25: r8a66597.h: In function ‘r8a66597_read_fifo’: r8a66597.h:441: error: ‘inl’ undeclared (first use in this function) r8a66597.h:441: error: (Each undeclared identifier is reported only once r8a66597.h:441: error: for each function it appears in.) Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-08usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
2011-08-08Add Ethernet hardware MAC address framework to usbnetSimon Glass
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr). This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add support for SMSC95XX USB 2.0 10/100MBit Ethernet AdapterSimon Glass
The SMSC95XX is a USB hub with a built-in Ethernet adapter. This adds support for this, using the USB host network framework. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2011-08-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: drivers/rtc: add Marvell Integrated RTC Armada100: Add Board Support for Marvell GuruPlug-Display Armada100: MFP macro naming correction arm: auto gen asm-offsets.h for mb86r0x spear: fix build errors for spear3xx/spear600 platforms cosmetic: arm: lib/board.c: Coding Style cleanup ARM: versatile: fix board support SMDKV310: Enable device tree support SMDKV310: MMC_SPL: Fix building when using "make O=" arm: a320: enable tagged list support arm: a320: fix multiline comment style ARMv7: u8500_href: Add missing header to fix compiler warning Removed unused define, CONFIG_ARMV7. avr32: add grasshopper (ICnova AP7000) board AT91/SPI: fix atmel_dataflash_spi.c to allow building without warnings MAKEALL: remove AT91 boards that are in boards.cfg AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9263 SoC build correctly against u-boot-atmel/master AT91: Board fix for AT91SAM9261-EK AT91: SoC fix at91sam9261_matrix.h AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9RL SoC build correctly against u-boot-atmel/master AT91: change common at91sam9261 files to compile with new scheme AT91: fix mistake in at91sam9260_devices.c(spi1_hw_init) a/a/c/arm920t/at91/reset.c: drop obsolete CONFIG_AT91RM9200_USART README: fix arm920t/at91 path net/eth.c: drop obsolete at91rm9200 support README.at91-soc: remove AT91(RM9200) joining notice a/a/c/arm920t/cpu.c: remove CONFIG_AT91_LEGACY warning MAKEALL: remove obsolete at91rm9200 soc ARM: remove obsolete at91rm9200 omap4: clock init support for omap4460 omap4: support TPS programming omap: reuse omap3 gpio support in omap4 omap4: sdram init changes for omap4460 omap4: add omap4460 revision detection mkimage: Add OMAP boot image support omap: add MMC and FAT support to SPL omap: add basic SPL support armv7: start.S: fixes and enhancements for SPL omap4: automatic sdram detection omap4: calculate EMIF register values omap4: add sdram init support omap4: add clock support omap4: add OMAP4430 revision check omap4: cleanup pin mux data omap4: utility function to identify the context of hw init DA8xx: fix LPSC constants DA8xx: switch an enum to defines for consistency DA8xx: add MMC/SD controller addresses DaVinci EMAC: declare function for all DA8xx CPUs DA8xx: add generic GPIO driver DaVinci: rename gpio_defs.h to gpio.h omap3evm: eth: Include functions only when necessary omap3evm: Update ethernet reset sequence for Rev.G board omap3evm: eth: split function setup_net_chip omap3: Include array definition only when it is used omap730p2: fix build breaks omap2420h4: fix build breaks omap1610inn: fix build breaks omap1510inn: fix build breaks omap5912osk: fix build breaks omap1610h2: fix build breaks
2011-08-04video: mb862xx: change controller detection messageAnatolij Gustschin
2011-08-04video: mb862xx: support Coral-PA controllerAnatolij Gustschin
Add detection of Coral-PA and configure Coral CCF an MMR parameters using CONFIG_SYS_MB862xx_CCF and CONFIG_SYS_MB862xx_MMR macros. Use CCF and MMR parameters for Coral-P Eval. Board if the appropriate macros weren't defined. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-04video: Add SHARP LQ084S3LG01 LCD support on P1022DSTimur Tabi
The SHARP LQ084S3LG01 is a TFT LCD used on the P1022DS (revision "C") board. This device only supports 800x600 resolution, so if that resolution is selected, assume that this is the device. The device is attached to the LVDS port on the P1022DS board. The existing 800x600 entry (for the PDM360NG board) is actually 800x480, so we fix that. To support two different 800x resolutions, the Y-resolution is now passed to fsl_diu_init() and both values are used to pick the proper fb_videomode structure. The data for the 800x600 video mode is originally from Jiang Yutang. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com>
2011-08-04drivers/rtc: add Marvell Integrated RTCJason Cooper
This driver can be used for kirkwood SoCs by enabling CONFIG_RTC_MV. Tested on Global Scale Technologies Dreamplug. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-08-03AT91/SPI: fix atmel_dataflash_spi.c to allow building without warningsReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03DA8xx: add generic GPIO driverLaurence Withers
Add a generic GPIO driver for the DaVinci DA8xx processors. It is turned on by defining CONFIG_DA8XX_GPIO and fulfills the generic GPIO interface specified in <asm/gpio.h> . The driver has support for both manipulating GPIO pins as well as automatically configuring the pin multiplexor registers to set the pin function to GPIO. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03DaVinci: rename gpio_defs.h to gpio.hLaurence Withers
In preparation for a generic GPIO driver for the DA8xx processors, rename <asm/arch/gpio_defs.h> to <asm/arch/gpio.h> and fix up all files which include it. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-02video: Use memset instead of loopMatthias Weisser
There is a optimized version of memset in u-boot available so use it instead of the hand written loop version. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mmc: Revert "AT91:mmc:fix multiple read/write error"
2011-08-02sf: macronix: disable write protection when initializingSimon Guinot
Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-08-02sf: spansion: add support for S25FL129P_64KShaohui Xie
Signed-off-by: Shaohui Xie <b21989@freescale.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-08-02mtd/spi/macronix.c: add MX25L4005 and MX25L8005Macpaul Lin
Add support of MX25L4005 and MX25L8005 according to the datasheet http://www.mct.net/download/macronix/mx25l8005.pdf This patch has been tested with MX25L4005 and MX25L8005 Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: net/4xx: Install interrupt handler after driver registration
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2011-08-01cfb_console.c: checkpatch cleanupWolfgang Denk
Fix the following: ERROR: do not initialise statics to 0 or NULL ERROR: do not use assignment in if condition Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-08-01cfb_console.c: drop custom PRINTD() and use debug() insteadWolfgang Denk
2011-08-01Cosmetic: reformat drivers/video/cfb_console.cWolfgang Denk
Run cfb_console.c through indent and manually fix some of he deficiencies of the automatic line breaking. Fix multiline comments, excessive line spacing and such. No changes to code done. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-29cfb_console: fix build breakageAndreas Bießmann
Commit 09c2e90c110ef99f1203685acd1059114a51b167 "unify version_string" introduced a build breakage in cfb_console.c ---8<--- cfb_console.c:1497: warning: format '%s' expects type 'char *', but argument 3 has type 'const char (*)[]' --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-28Revert "AT91:mmc:fix multiple read/write error"Andy Fleming
This reverts commit c310fc840472a36e4b9d2505830e9dc8d458d63c. The Atmel custodian had apparently rejected this patch's approach in another thread, so this patch reverts it for now. Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-28net/4xx: Install interrupt handler after driver registrationStefan Roese
Only install der 4xx-EMAC interrupt handlers *after* the core network driver is registered. This problem was noticed on the APM Taishan 440GX board, where the board hung upon bootup after displaying "Net:". Signed-off-by: Stefan Roese <sr@denx.de>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28fpga: support FPP Cyclone configurationMichael Jones
Support FPGAs which use Fast Passive Parallel configuration Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-07-28altera: fix printf typoMichael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-28cosmetic: spell fixes etc.Michael Jones
2011-07-27net: Add SMSC89128 supportPhil Edworthy
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-07-27phylib: Detect link on 10G devices correctlyAndy Fleming
gen10g_startup() had 2 bugs: 1) It had a boolean logic error in checking the MMD mask, and always checked all of them. 2) It checked devices which don't actually report link state, which meant that it would never believe the link was fully up. Fix the boolean logic, and then mask the MMD mask so only link-reporting devices are checked. Signed-off-by: Andy Fleming <afleming@freescale.com> Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-26serial: push default_serial_console to driversMike Frysinger
Rather than sticking arch/board/driver specific logic in the common serial code, push it all out to the respective drivers. The serial drivers declare these funcs weak so that boards can still override things with their own definition. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com> Tested-by: Minkyu Kang <mk7.kang@samsung.com>
2011-07-26sf: sst: support newer standardized flashesMike Frysinger
Newer SST flashes have dropped the Auto Address Increment (AAI) word programming (WP) modes in favor of the standard page programming mode that most flashes now support. So add a flags field to the different flashes to support both modes with new and old styles. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: unify write disable commandsMike Frysinger
Every spi flash uses the same write disable command, so unify this in the common code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Fixed commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-26sf: eon/stmicro: inline useless ID definesMike Frysinger
These defines are used in only one place, so just inline them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: kill off now-unused local stateMike Frysinger
Now that the common spi_flash structure tracks all the info that these drivers need, kill off their local state indirection and use just what the common code provides. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: unify write funcsMike Frysinger
Once we add a new page_size field for write lengths, we can unify the write methods for most of the spi flash drivers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: unify write enable commandsMike Frysinger
Every spi flash uses the same write enable command, so unify this in the common code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Allow reset_timer() only for systems with low resolution timersGraeme Russ
2011-07-26scaled down version of generic libraries for SPLAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-26scsi/ahci: add support for non-PCI controllersRob Herring
Add support for AHCI controllers that are not PCI based. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Wolfgang Denk <wd@denx.de>
2011-07-26scsi/ahci: ata id little endian fixRob Herring
The ata id string always needs swapping, not just on BE machines. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
