When using CMD6 to switch eMMC card timing from HS200/HS400 to HS/legacy,
do not poll for the completion status using CMD13, but rather wait 50mS.
Once the card receives the CMD6 and starts executing it, the bus is in
undefined state until both the card finishes executing the command and
until the controller switches the bus to matching timing configuration.
During this time, it is not possible to transport any commands or data
across the bus, which includes the CMD13.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
The mmc_select_mode_and_width() function can be called while the card
is in HS200/HS400 mode and can be used to downgrade the card to lower
mode, e.g. HS. This is used for example by mmc_boot_part_access_chk()
which cannot access the card in HS200/HS400 mode and which is in turn
called by saveenv if env is in the MMC.
In such case, forcing the card clock to legacy frequency cannot work.
Instead, the card must be switched to HS mode first, from which it can
then be reprogrammed as needed.
However, this procedure needs additional code changes, since the current
implementation checks whether the card correctly switched to HS mode in
mmc_set_card_speed(). The check only expects that the card will be going
to HS mode from lower modes, not from higher modes, hence add a parameter
which indicates that the HS200/HS400 to HS downgrade is happening. This
makes the code send the switch command first, reconfigure the controller
next and finally perform the EXT_CSD readback check. The last two steps
cannot be done in reverse order as the card is already in HS mode when
the clock are being switched on the controller side.
Fix coverity issue: CID 2970630: Resource leak (RESOURCE_LEAK)
leaked_storage: Variable cdns going out of scope leaks the storage
it points to.
Memory allocated by devm_kzalloc() won't be freed automatically in
u-boot, free the memory manually here.
Test: Coverity scan pass.
Change-Id: I3000a2385941cef3b8b7e01611cfdc999971a4ca
Signed-off-by: Luo Ji <ji.luo@nxp.com>
Fix coverity issue:
CID 43787: Buffer not null terminated (BUFFER_SIZE_WARNING)
buffer_size_warning: Calling strncpy with a maximum size argument
of 32 bytes on destination array sdev.name of size 32 bytes might
leave the destination string unterminated.
Change-Id: Ib10e631bab893cb9cd1484082229f806b02849ba
Fix coverity issue: CID 1477258: Uninitialized scalar variable (UNINIT)
uninit_use_in_call: Using uninitialized value txbuf when calling __fswab32.
Change-Id: If57f70c272ef49a6636a59ae3b5dcc5430fd1753
Trusty is not supported for xen so we don't need to check
the keyslot package or rollback index in spl. Reassign the
dram address for spl and u-boot to avoid conflicts.
Support serial init functions to enable debug console
in spl when xen is running.
Test: Boot and A/B slot switch on imx8qm_mek.
Change-Id: If6829252f1ec2e32255f951715c8747181951fd0
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
We are currently using SC_R_LAST as a marker for imx8 power domain tree
nodes without a resource attached. This value is compiled into dtb as
part of the linux build and used by uboot.
The SC_R_LAST constant changes frequently as SCFW resources are added
(by design) and every time we need to update linux and uboot headers
together or boot can fail.
Fix this by replacing SC_R_LAST usage with a new constant SC_R_NONE
defined to be 0xFFF0.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Currenlty U1 and U2 low power modes are allowed in device mode.
Allowing U1 and U2 low power modes during data transfers in
device mode is causing U1 exit failure on some USB3 host: which
will transite to SS.inactive instead of U0, then host will send
warm reset and ultimately result in reenumeration. This is observed
on UUU tool with some PC host. Hence disable U1 and U2 low power
modes for now.
USB3 spec 7.5.10.4.2 Exit from Recovery.Configuration
The port shall transition to eSS.Inactive when the following
conditions are met:
1. Either the Ux_EXIT_TIMER or the 6-ms timer
(tRecoveryConfigurationTimeout) times out.
2. For a downstream port, the transition to Recovery is not to
attempt a Hot Reset.
Signed-off-by: Li Jun <jun.li@nxp.com>
The HDMI digital PLL, bus clock and core clock need to change to improve the
firmware loading time. The clock are now set to 800 MHz for DPLL, 200 MHz for
HDMI core, and 100 MHz for HDMI bus.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
On iMX8MM, the V flag in TRISTR register only reflect the state of SNSR
value, not the calibrated TEMP value. So checking this flag is not
reliable. Per IC suggestion, change to read the TEMP/AVG_TEMP directly
and check whether it in valid range 10-125C.
Signed-off-by: Ye Li <ye.li@nxp.com>
Current SPL code only support ONFI-compatible NAND, porting the code
from nand_base.c to support legacy full id NAND chips, such as Toshiba
TC58NVG2S0H.
Signed-off-by: Han Xu <han.xu@nxp.com>
When the temperature is out of sensor's range, the Valid bit won't be
set in TRITSR register. So the polling loop won't go out.
Change the codes to retry 10 times with 100ms interval for the Valid bit.
If the timeout, we give a warning for the invalid data.
Reviewed-by: Bai Ping <ping.bai@nxp.com>
When we probe device with virtual i2c driver, it will definitely
fail to power up the PD. Becasue the resource is owned by M4. So
set this driver to ignore the power up result
If a device has relevant power domain, we will check the power up
result in probing the device. If the power up is failed, the device_probe
will return failure immediately.
The only exception is the new FLAG (DM_FLAG_IGNORE_POWER_ON) is set by driver
to indicate ignore the power up result.
When fspi is assigned to M4, we have to let the fspi probe failed when
its power domain is failed to power up. Because not all devices have power
domain (for example, external devices on the board). Current checking
resource owner in power domain probe is not good, change to check it in
power on.
Add a new private flag I2C_M_SRTM_STOP(0x0200) to indicate if STOP
is needed for current message.
When reading/writing registers for slave devices, generally we have two messages,
the first message writes the register address, second message reads/writes the value.
Only the last message needs STOP. But previously M4 sends STOP for each message,
this causes some slave devices treat it as end of transfer. Then, second message won't
have any effect. To solve the problem, we introduce this private STOP flag, so M4 can
STOP according to the flag.
The HDMI digital PLL, bus clock and core clock need to change to match the
settings used by the Linux driver. This allows the SECO to start and
initialize the HDMI/DP firmware.
Add firmware athentication to the hdp and hdprx load functions.
If hdp_authenticate_fw is set to yes, the hdp tx firmware is athenticated.
If hdprx_authenticate_fw is set to yes, the hdp rx firmware is athenticated.
As endpoint.maxpackt is set at init for super speed, we can't use it
for USB2 connection, we need use the right max packet length according
to connection speed.
If the resource is not owned by current partition, we can't power on/off
it, so we'd better return probe failure.
If a pad is not owned by current partition we should not set its
pinmux.
We provide override binding function, so the ARCH level can use it
to determine if it is ok to bind with lpi2c driver.
Add virtual i2c driver which replies on the VService to send SRTM i2c
messages with M4.
For each output on i2c mux, M4 side abstracts a i2c bus with special bus
id. The virtual i2c mux follows basic mux design, but uses dedicated flag
to pass the abstract bus id for the mux output to virtual i2c driver.
Virtual i2c and virtual i2c mux will bind nodes with compatible string
"fsl,imx-virt-i2c" and "fsl,imx-virt-i2c-mux".
To support binding local i2c driver or virtual i2c driver at runtime. We
provides a override function for the driver bind. ARCH level is responsible
to implement it.
Add a common iMX MU driver in misc uclass to communicate with M4.
The MU message format is defined to use 4 words as below, the driver
will use all 4 TR/RR in MU to pass one message
|WORD 0 | WORD 1 | WORD 2 | WORD 3 |
|SEQ | TYPE | PAYLOAD ADDRESS | PAYLOAD LENGTH |
- SEQ:
A sequence id starts from 0 and increases for each request message
- TYPE:
0x1: Request. Message sent from AP will set to this value.
0x2: Response. Message responded from M4 set to this value.
0x3: MU A side is ready.
0x4: MU B side is ready.
- PAYLOAD ADDRESS:
A pointer to the memory address where the uplayer message is stored
- PAYLOAD LENGTH:
The uplayer message length
The usb mass storage (f_mass_storage.c) uses fixed usb index 0,
this causes problem while CDNS3 USB controller index is 1.
Modify the API of fsg to pass the controller index.
Reviewed-by: Jun Li <jun.li@nxp.com>
For dual bootloader, slot selection is made at spl stage, go to
fastboot when current slot is marked as unbootable in AVB will
give the user a chance to recover current slot with fastboot
commands. But in this scenario, the device can't switch to another
bootable slot automatically when a slot is marked as unbootable.
Reboot the board when current slot is marked as unbootable to make the
slot switch happen in spl.
Test: Slot switch to 'b' automatically when 'a' is marked as unbootable
on imx8qxp_mek.
Change-Id: I94237965970d0c17ed564cf76e08d353f7b9c047
Since imx8mm TMU needs to load some registers from fuse, this is arch
dependent operation and may vary on different platforms. So add
a interface for arch level initialization.
Fix some warinings as "defined but not used [-Wunused-function]".
for CAAM.
Test: Build and boot on imx8qm_mek.
Change-Id: I632257615a237ca2de96937e121e7a4bcab415ce
The previous driver uses a hard coded value which generates the DSI
PHY clock can fit HX8363 WVGA screen. But when switching to new WXGA
screen which needs higher pixclock and higher DSI PHY clock, the
hard coded parameters can't work.
Change to follow kernel codes to find the best value of CM, CN, CO
parameters for DSI PHY clock to meet pixclock requirement.
mx7ulp EVK B will use two mipi dsi panels, the new panel RM68200_WXGA
supports WXGA resolution.
Support dual bootloader feature for imx8q which uses the
container format. Move the A/B slot select and verify to
SPL stage, the bootloader rollback index will be stored
at the last 8K bytes of eMMC rpmb storage.
Test: Boot and rbindex verify pass on imx8q.
Change-Id: I0a48210f65984a083037a0cd3f9558951029ed7d
The CAAM driver in u-boot will use JR0 by default, but for
imx8q, both JR0 and JR1 are assigned to SECO and A core
should never access them.
Power on the JR3 in this patchset and use it to complete
the CAAM operations for imx8q.
Test: CAAM self test cases pass for imx8q.
Change-Id: Ie3d77d1f2910e7f4c257c797c12b5c8a30ad936a
Add CAAM RNG generating and BLOB encap/decap
self test cases.
Test: Test cases pass on imx8qm_mek/imx6qp_sabresd.
Change-Id: I538f7b1581b36df83a3006ac133ca9e7b57ab4f0
Current MXC NAND driver uses memory BBT, it will create memory BBT in each
booting by searching bad blocks.
This patch enables the flash BBT, so the NAND driver can read back Bad block
table on the flash chip to create memory BBT.
Acked-by: Peng Fan <peng.fan@nxp.com>
Add support to f_sdp to search and load iMX8 container image or iMX8M
FIT image by new UUU command SDPV.
When using the SDPV, the uuu will continue to send out data after first
level boot loader used by ROM. This means uuu won't skip to the offset
of the second boot loader, and the padding data before second boot loader
will be sent out. So we have to search the FIT header or container header
in the buffer that SDP received.
The new BCD value is used by uuu to distinguish if the SPL supports the
SDPV.
Because SDP directly jumps to next level boot image, we'd better
clean up the USB driver before it. Implement a weak callback function,
that spl sdp can use it to clean up USB driver.
Because the buffer length of sdp usb request is 65, we have to allocate
65 bytes not 64 bytes. Otherwise there is potential buffer overflow.
Add HS endpoint descriptor for SDP. So that we can use high speed endpoint,
and the SDP device can send packet with 512 byte size.
Keystore attestation requires provision keys and cerificate chains into
secure storage. Add commands to support rsa/ecdsa keys and certificate
chains provision, each key/certificate should be staged before provision.
Usage:
Set rsa attestation key:
fastboot stage <path-to-rsa-atte-key>
fastboot oem set-rsa-atte-key
Set ec attestation key:
fastboot stage <path-to-ec-atte-key>
fastboot oem set-ec-atte-key
Append rsa attestation certs:
fastboot stage <path-to-rsa-atte-cert>
fastboot oem append-rsa-atte-cert
Append ec attestation certs:
fastboot stage <path-to-ec-atte-cert>
fastboot oem append-ec-atte-cert
Test: Pass CTS cases:
android.keystore.cts.KeyAttestationTest#testRsaAttestation
android.keystore.cts.KeyAttestationTest#testEcAttestation
Change-Id: Ic3ed87e7e328a39b0f1bfb163356ea9e37d2f4fc
Pass the verified boot key hash to keymaster, it will be
treated as the root trust in keymaster service.
Also set the 'initialized' flag after initializing the
keymaster client or set keymaster boot parameters will fail.
Change-Id: I486b5493826160f42c61a3da0e6cd769df92254d
The tstc function in Non-DM driver does not check the LPUART_FLAG_REGMAP_32BIT_REG
flag, it always use 8 bits register version and cause issue in 8QM/QXP SPL.
The port index is not calculated correctly. It should not be descreased,
because the gpio number is from 0 on imx8 platform.
Otherwise we will access wrong registers.
Sometimes we need to set random rpmb key which is invisible
except for the device.
Generate the random key with hwcrypto interface and support
fastboot command "fastboot oem set-rpmb-random-key" to set it.
Test: build and boot on imx8q.
Change-Id: I44e1b6b091366d8ffceb1159fc65c17610ce5243
For mek_8qm, bootloader offset in SD card is 32kb, in eMMC
bootpartition, it's 0kb. This patch fix the issue that bootloader offset
used in uboot is always based on the device that the board boot from.
Now, if uboot environment variable "target_ubootdev" is set, bootloader
offset used in uboot is based on the device "target_ubootdev" specified.
So boot from eMMC to flash SD, the board can boot from SD and vice versa.
Change-Id: Ia2cd64ba6ece02b98ea3d2addbce00b1661077de
Signed-off-by: faqiang.zhu <faqiang.zhu@nxp.com>
To avoid end user executing uboot command through fastboot, the fastboot
command of "ucmd" and "acmd" in the uboot to be flashed into
non-volatile storage device is removed in this partch.
Change-Id: I999b8688a53c2201d02979be68266afc110dfb15
As we need standard usb_ep's desc, so set it when enable ep.
Reviewed-by: Peter Chen <peter.chen@nxp.com>
Change to use wMaxPacketSize of current speed EP desc for request
length wrap up.
Remove the gadget driver speed check, and set its max_speed to
be USB_SPEED_HIGH.
Reviewed-by: Ye Li <ye.li@nxp.com>
Tested-by: faqiang.zhu <faqiang.zhu@nxp.com>
If one of functions is not super speed capable, we need force the udc
to be high speed, this is an equivalent implementation of
usb_gadget_udc_set_speed() in kernel but simple, which set the gadget
max_speed to be high speed, so afterwards when start gadget duc can
set the HW to be USB 2.0 mode.
Change the dwc3 device mode to be super speed capable.
