This patch adds check for command response CRC failure. The driver
is currently ignoring CRC check failure on command resposes which
have CRC atteched to it, which can be potentially dangerous. Even
more grueling problem happens when the command response is followed
by data transfer though, as in that case, the dwmci_data_transfer()
function will spin until it reaches the 240s timeout.
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The commit
484fdf5ba058 ("dm: Add support for all targets which requires MANUAL_RELOC")
introduces subtle typo, i.e. missed semicolon.
Fixes: 484fdf5ba058 ("dm: Add support for all targets which requires MANUAL_RELOC")
Cc: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
It is perfectly fine to write th DTCNTL TAP count and enable the
SCC sampling clock operation in the same write.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
When the bus switches to 1.8V mode of operation, it is necessary to
verify that the card correctly initiated and completed the voltage
switch. This is done by reading out the state of DATA0 line.
This patch implement support for reading out the state of the DATA0
line, so the MMC core code can correctly switch to 1.8V mode.
Make sure to clear HS400 configuration when resetting the SCC block.
Add check to avoid touching the SCC tuning registers in case the IP
doesn't support them or if the support isn't in place yet.
Preinitialize the SD card signals regulator to 3.3V, which is the
default post-reset setting, to be sure the regulator is set to a
valid value.
Configure the clock settings before reconfiguring any other IO settings.
This is required when the clock must be stopped before changing eg. the
pin configuration or any of the other properties of the bus. Running the
clock configuration first allows the MMC core to do just that.
In case the controller performs card tuning, that is, sends MMC
command 19 or 21, silence possible CRC error warning prints. The
warnings are bound to happen, since the tuning will fail for some
settings while searching for the optimal configuration of the bus
and that is perfectly OK.
This patch passes around the MMC command structure and adds check
into tmio_sd_check_error() to avoid printing CRC error warning
when the tuning happens.
Properly handle return values and abort operations when they are
non-zero. This is a minor improvement, which fixes two remaining
unchecked return values.
The SD UHS SDR12, SDR25, SDR50, SDR104, DDR50 and MMC HS200, HS400
modes all use 1.8V signaling, while all the legacy modes use 3.3V
signaling. While there are extra modes which use 1.2V signaling,
the existing hardware does not support those.
Simplify the pinmux such that 3.3V signaling implies legacy mode
pinmux and the rest implies UHS mode pinmux. This prevents the
massive case statement from growing further. Moreover, it fixes
an edge case where during SD 1.8V switch, the bus mode is still
set to default while the signaling is already set to 1.8V, which
results in an attempt to communicate with a 1.8V card using pins
in 3.3V mode and thus communication failure.
Add definition of the POCCTRL register and bits therein to R8A77990 E3
pincontrol driver. This allows the pincontrol driver to configure SDHI
pin voltage according to power-source DT property.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Use fixed 4bit size for generating the DRV register element mask,
not the size of the value, which can be smaller.
The Makefile already tests for SPL_DM_REGULATOR_GPIO, but Kconfig
does not provide it. This adds SPL_DM_REGULATOR_GPIO to Kconfig.
When the "w1 bus" command is used with no bus master present
a data abort may occur.
This is because uclass_first_device() returns zero, but sets the output
struct udevice pointer to NULL in the no device found case.
Fix w1_get_bus() to account for this and return an error code
as is expected by the callers.
Signed-off-by: Martin Fuzzey <martin.fuzzey@flowbird.group>
Reviewed-by: Eugen Hristev <eugen.hristev@microchip.com>
Data abort was occurring when using "w1 bus" with a DS24B33 present.
The abort occurred in the ds24xxx_probe() because the struct w1_device
pointer was NULL. This is because that structure is allocated by
the parent device uclass (by .per_child_platdata_auto_alloc_size)
and thus the correct accessor is dev_get_parent_platdata() not
dev_get_platdata()
The 'status' variable in 'socfpga_load()' for both gen5 and arria10
is of type 'unsigned long' while it is always used as 'int' only.
Change it to 'int'.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Per T1040RM (Rev. 1, 08/2015), there are 2 issues with the RCW EC2
settings.
- The value of FSL_CORENET_RCWSR13_EC2_FM1_GPIO is wrong and should
be 0x04000000 (value of 1 in RCW bit [420:421])
- Value of 2/3 are reserved in RCW bit [420:421], hence there is no
macro FSL_CORENET_RCWSR13_EC2_FM1_DTSEC5_MII.
Acked-by: Poonam Aggrwal <poonam.aggrwal@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Workaround makes FS as default mode on all affected socs.
Add support to check erratum-A005275 validity for an soc. This info is
required to determine whether a given soc is affected by this erratum.
Add quirk for this erratum "has_fsl_erratum_a005275" . This quirk is used
to enable workaround for the errata
Force FS mode as default by:
- making EPS as FS
- setting PFSC bit to disable HS chirping
This workaround can be disabled by mentioning "no_erratum_a005275" in
hwconfig string
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Complete in the drivers directory the work started with
commit 83d290c56fab ("SPDX: Convert all of our single
license tags to Linux Kernel style").
Merged imx8 architecture, fix build for imx8 + warnings
Add compatible property and enable the FEC ipg clock when probing
on i.MX8X. Add specific function for reading FEC clock rate via
clock driver when configuring MII speed register. Allow FEC_MXC
selection for i.MX8.
The default Linux PHY reset delay is 10ms. This is also the requirement
for Marvell 88E151x PHYs, which are likely to be used with this Ethernet
MAC.
Cc: Stefan Chulski <stefanc@marvell.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
The dm_gpio_set_value() call sets the logical level of the GPIO signal.
That is, it takes the GPIO_ACTIVE_{LOW,HIGH} property into account. The
driver needs to assert the reset, and then deassert it. Not the other
way around.
The DT property "phy-mode" already provides the transceiver type.
Use it so that we do not have to also set CONFIG_FEC_XCV_TYPE
Configure the phy regulator if defined by the "phy-supply" DT phandle.
The DT binding says:
- phy-reset-duration : Reset duration in milliseconds. Should present
only if property "phy-reset-gpios" is available. Missing the property
will have the duration be 1 millisecond. Numbers greater than 1000 are
invalid and 1 millisecond will be used instead.
However the current code:
- clamps values greater than 1000ms to 1000ms rather than 1.
- does not initialize the delay if the property does not exist
(else clause mismatch)
- returns an error if phy-reset-gpios is not defined
Fix all this and simplify by using dev_read_u32_default()
The DT binding says that phy-reset-duration is in ms, but the driver
currently uses udelay().
Switch to mdelay() to fix this.
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
If the phy reports a valid firmware version and doesn't indicate
a fault, skip loading the firmware. This allows the same image
to be used on boards that have firmware storage and those that do not.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
Aquantia phys have firmware that can be loaded automatically
from storage directly attached to the phy or via MDIO commands.
Add support for loading firmware from either a file or a
raw location on an MMC device.
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
sunxi_rgb2yuv_coef is readonly and never modified.
Signed-off-by: Priit Laes <plaes@plaes.org>
Acked-by: Anatolij Gustschin <agust@denx.de>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Choose best prescaler to improve PWM resolution. Without this change
driver chooses first prescaler that gives us period value within
range, but it could be not the best one.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@debian.org>
Looks like old prescaler was used when configuring PWM, fix it.
Fix off-by-one that prevented PWM driver to use prescaler bypass.
Without this change prescaler is always enabled.
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
This is required for the current Linux kernel to reboot. It should also
probably be fixed in Linux.
Signed-off-by: Cédric Le Goater <clg@kaod.org>
Currently in pmecc_get_sigma(), the code tries to clear the memory
pointed by smu with wrong size 'sizeof(int16_t) * ARRAY_SIZE(smu)'.
Since smu is actually a pointer, not an array, so ARRAY_SIZE(smu)
does not generate correct size to be cleared.
In fact, GCC 8.1.0 reports a warning against it:
error: division 'sizeof (int16_t * {aka short int *}) / sizeof (int16_t
{aka short int})' does not compute the number of array elements
[-Werror=sizeof-pointer-div]
Fix it by using the correct size.
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
Output the register base address in hex notation.
Acked-by: Heiko Schocher <hs@denx.de>
Move this option to Kconfig and tidy up the config file of eight
boards which use it.
Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
When CONIFG_CLK is enabled, use uclass clk api to handle
the clock.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Add CONFIG_ARCH_IMX8 to use the 64bits support in usdhc driver.
Signed-off-by: Ye Li <ye.li@nxp.com>
Modify most APIs to use udevice as the first parameter, then
it will be easy to get the clk reference by using udevice pointer.
Use uclass api to get lpuart clk when CONFIG_CLK is enabled.
Enable the RX and TX FIFO in LPUART driver to avoid the input lost
during U-Boot boot up.
Acked-by: Peng Fan <peng.fan@nxp.com>
Add i.MX8 compatible string and cpu type support to lpuart driver,
to use little endian 32 bits configurations.
Also, according to RM, the Receive FIFO Enable (RXFE) field in LPUART
FIFO register is bit 3, so this definition should change to 0x08
(not 0x40) for i.MX8, otherwise the Receive FIFO is not disabled.
