This adds support for the AT91SAM9G20-EK board in the mainline U-Boot.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
The function parse_line() in common/main.c was exposed globally by commit
6636b62a6efc7f14e6e788788631ae7a7fca4537, Result in conflict with the same
name funciton in drivers/bios_emulator/x86emu/debug.c when define the DEBUG.
This patch fix this by renaming the function in the debug.c file.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
The checks for CFG_EEPROM_PAGE_WRITE_ENABLE and
CFG_EEPROM_PAGE_WRITE_BITS in various temperature
sensor drivers are not necessary
When the total size of all NAND devices exceeds 4 GiB, the size will
overflow. This patch tries to fix this.
Note that we still have a problem when a single NAND device is bigger
than 4 GiB: then the overflow would actually happen earlier, i. e.
when storing the size in nand_info[].size, as nand_info[].size is an
"u_int32_t".
Signed-off-by: Louis Su <louis@asix.com.tw>
Currently VSC8601 doesn't link with 10/100M partners if the
EEPROM/Strapping is not set up.
Setting the auto-neg register fixes this.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
get_prom function was used __attriute__ , but it is not enable.
ax88796.o does not do link besides ne2000.o. When ld is carried
out, get_prom function of ax88796.c is ignored.
This problem is a thing by specifications of ld.
I checked and test this patch on SuperH and MIPS.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
The flash_unlock_seq requires a sector for AMD_LEGACY.
Fix a retcode check typeo.
The CFI flash driver starts at flash_init() which calls down into
flash_get_size(). This starts by calling flash_detect_cfi(). If said
function fails, flash_get_size() finishes by attempting to reset the
flash. Unfortunately, it does this with an info->portwidth set to 0x10
which filters down into flash_make_cmd() and that happily smashes the
stack by sticking info->portwidth bytes into a cfiword_t variable that
lives on the stack. On a 64bit system you probably won't notice, but
killing the last 8 bytes on a 32bit system usually leads to a corrupt
return address. Which is what happens on a Blackfin system.
Fix TBI PHY accesses to use the proper offset in CPU register space. The
previous code would incorrectly access the TBI PHY by reading/writing to CPU
register space at the same location as would be used to access external PHYs.
This patch deletes oobavail assignments, they're calculated by the nand
core code in nand_scan_tail, plus current oobavail values are wrong for
the LP NANDs.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch implements support for flash-based BBT for chips working
through ELBC NAND controller, so that NAND core will not have to re-scan
for bad blocks on every boot.
Because ELBC controller may provide HW-generated ECCs we should adjust
bbt pattern and bbt version positions in the OOB free area.
For large page chips, nand_bbt is looking into OOB area, and checking
for "0xff 0xff" pattern at OOB offset 0. That is, two bytes should be
reserved for bbt means.
But ELBC driver is specifying ecclayout so that oobfree area starts at
offset 1, so only one byte left for the bbt purposes.
This causes problems with any OOB users, namely JFFS2: after first mount
JFFS2 will fill all OOBs with "erased marker", so OOBs will contain:
OOB Data: ff 19 85 20 03 00 ff ff ff 00 00 08 ff ff ff ff
OOB Data: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
And on the next boot, NAND core will rescan for bad blocks, then will
see "0xff 0x19" pattern, and will mark all blocks as bad ones.
To fix the issue we should implement our own bad block pattern: just one
byte at OOB start. Though, this will work only for x8 chips. For x16
chips two bytes must be checked. Since ELBC driver does not support x16
NANDs (yet), we're safe for now.
The i.MX31 has three SPI buses and each bus has several chip selects
and the MC13783 chip can be connected to any of these. The current
RTC driver for MC13783 is hardcoded for CSPI2/SS2.
This patch makes make MC13783 SPI bus and chip select configurable
via CONFIG_MC13783_SPI_BUS and CONFIG_MC13783_SPI_CS.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
On AMCC Arches board DTT_I2C_DEV_CODE is different then canyonlands
and glacier.
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
Fix printf format-string/arg mismatches under -DDEBUG.
These warnings occur with DEBUG defined for a platform using
cpu/mpc85xx. Users of other architectures can unearth similar
problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right
after "CFLAGS += $(call cc-option,-fno-stack-protector)".
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add MTD SPI Flash support for M25P16, M25P20, M25P32,
M25P40, M25P64, M25P80, M25P128.
Signed-off-by: Jason McMullan <mcmullan@netapp.com>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
A recent commit (936897d4d1365452bbbdf8430db5e7769ef08d38)
enabled the usb_stop() command in common/cmd_bootm.c which was
not enabled for some time, because no board did actually set the
CFG_CMD_USB flag. So, now the usb_stop() is executed before
loading the linux kernel.
However, the usb_ohci driver hangs up (at least on AT91SAM) if the
driver is stopped twice (e.g. the peripheral clock is stopped on AT91).
If some other piece of code calls usb_stop() before the bootm command,
this command will hangup the system during boot.
(usb start and stop is typically used while booting from usb memory stick)
But, stopping the usb stack twice is useless anyway, and a flag already
existed that kept track on the usb_init()/usb_stop() calls.
So, we now check if the usb stack is really started before we stop it.
This problem is now fixed in both the upper as low-level layer.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Acked-by: Markus Klotzbuecher <mk@denx.de>
Several source files need to be compiled and linked when one or more
config options are selected. To allow for easy selection in the
Makefiles yet to avoild multiple compilation (which costs build time)
and especially multiple linking (which causes errors), we use
"COBJS = $(sort COBJS-y)" which eliminates duplicates.
By courtesy of Detlev Zundel who suggested this approach.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
They only differ in the init function.
This also adds the missing watchdog support for the PL011.
Attempt to bring i386 / sc520 inline with master
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This patch adds Lime GDC support together with support for the PWM
backlight control through the w83782d chip. The reset pin of the
latter is attached to GPIO, so we need to reset it in
early_board_init_r.
rearrange some #if !defined() / #else / #endif statements to remove
the negative logic.
Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
Some of multi-function USB controllers (e.g. ISP1562) allow root hub
resetting only via EHCI registers. So, this patch adds the
corresponding kind of reset to OHCI's hc_reset() if the newly
introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates
board).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
The RSK7203 board has the SMSC9118 wired up 'incorrectly'.
Byte-swapping is necessary, and so poor performance is inevitable.
This problem cannot evade by the swap function of CHIP, this can
evade by software Byte-swapping.
And this has problem by FIFO access only. pkt_data_pull/pkt_data_push
functions necessary to solve this problem.
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Removed initialization of the driver from net/eth.c
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Affected boards:
ap1000
mvbc_p
PM854
