drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/woodburn_common.h
board/woodburn/woodburn.c
These boards still use the old old PMIC framework, so they
do not merge properly after the power framework was merged into
mainline.
Fix all conflicts and update woodburn to use Power Framework.
If the pl011 is connected to another device which has hardware
flow-control on, characters are never received by the pl011.
Asserting RTS when flow-control is off will have no effect.
This is in line with how Linux behaves.
Signed-off-by: Joshua Housh <joshua.housh@calxeda.com>
Tested-by: Marek Vasut <marex@denx.de>
This command will start erasing at memory address zero
if there is not a valid framebuffer address that was found
during video_init().
This is a common case with Chrome OS devices in normal mode
when we do not execute the video option rom in coreboot.
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
We can generally trust the ICH to have GPIO Bank 0 (the first 32 pins) in the
same place across all versions. This change adds two more banks, for up to
96 GPIOS.
BUT:
- Not all chipsets have the same number of GPIOs
- Not all chipsets have the same number of GPIO banks
- Not all chipsets put the additional banks at the same offset from GPIOBASE
- There so many chipset variants that it's pretty much impossible to support
them all, or even keep track of the new ones.
So, although this adds suppport for the additional banks that seem to work
for the particular variants of CougarPoint Mobile chipsets that we've tried,
there's no chance it will support everything Intel produces. Good luck.
Signed-off-by: Bill Richardson <wfrichar@chromium.org>
Implement <asm-generic/gpio.h> functions for Intel ICH6 and later.
Only GPIOs 0-31 are handled by this code.
Add a basic driver for the coreboot framebuffer.
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
This command is useful to allow to observe messages generated by
coreboot and u-boot until present. In particular it is handy when
u-boot is instrumented to fall through into console mode on startup
errors.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
This patch builds upon the recently introduced CBMEM console
feature of coreboot.
CBMEM console uses a memry area allocated by coreboot to store
the console output. The memory area has a certain structure,
which allows to determine where the buffer is, the buffer size
and the location of the pointer in the buffer. This allows
different phases of the firmware (rom based coreboot, ram based
coreboot, u-boot after relocation with this change) to keep
adding text to the same buffer.
Note that this patch introduces a new console driver and adds the
driver to the list of drivers to be used for console output, i.e.
it engages only after u-boot relocates. Usiong CBMEM console for
capturing the pre-relocation console output will be done under a
separate change.
>From Linux, run the cbmem.py utility (which is a part of the coreboot
package) to see the output, e.g.:
vvvvvvvvvvvvvvvvv
SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode
flags: 64bit ilck stag led pmp pio
Magic signature found
Kernel command line: "cros_secure quiet loglevel=1 console=tty2...
Note that the entire u-boot output fits into the buffer only if
the coreboot log level is reduced from the most verbose. Ether
the buffer size will have to be increased, or the coreboot
verbosity permanently reduced.
On kzm9g board (rmobile SoC), autoboot fails if serial console cable is not
connected. When serial cable is not connected, serial error occurs and
some garbage comes in data register.
sh_serial_tstc() in serial_sh.c does not check error status and misunderstand
there is some input data. It is the reason that autoboot fails.
This patch adds checking error status in sh_serial_tstc().
This patch is based on v2013.01-rc1 tag of u-boot master git.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Due to SerDes configuration error, if we set the PCI-e controller link width
as x8 in RCW and add a narrower width(such as x4, x2 or x1) PCI-e device to
PCI-e slot, it fails to train down to the PCI-e device's link width. According
to p4080ds errata PCIe-A003, we reset the PCI-e controller link width to x4 in
u-boot. Then it can train down to x2 or x1 width to make the PCI-e link between
RC and EP.
Signed-off-by: Yuanquan Chen <B41889@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of
P3041DS/P5020DS ("Hydra") reference board.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
At some point, a confusion arose about the use of the bit
definitions in host_caps for bus widths, and the value
in ext_csd. By coincidence, a simple shift could convert
between one and the other:
MMC_MODE_1BIT = 0, EXT_CSD_BUS_WIDTH_1 = 0
MMC_MODE_4BIT = 0x100, EXT_CSD_BUS_WIDTH_4 = 1
MMC_MODE_8BIT = 0x200, EXT_CSD_BUS_WIDTH_8 = 2
However, as host_caps is a bitmask of supported things,
there is not, in fact, a one-to-one correspondence. host_caps
is capable of containing MODE_4BIT | MODE_8BIT, so nonsensical
things were happening where we would try to set the bus width
to 12.
The new code clarifies the very different namespaces:
host_caps/card_caps = bitmask (MMC_MODE_*)
ext CSD fields are just an index (EXT_CSD_BUS_WIDTH_*)
mmc->bus_width integer number of bits (1, 4, 8)
We create arrays to map between the namespaces, like in Linux.
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
Tegra's MMC driver does DMA, and hence needs cache-aligned buffers. In
some cases (e.g. user load commands) this cannot be guaranteed by callers
of the MMC APIs. To solve this, modify the Tegra MMC driver to use the
new bounce_buffer_*() APIs.
Note: Ideally, all U-Boot code will always provide address- and size-
aligned buffers, so a bounce buffer will only ever be needed for user-
supplied buffers (e.g. load commands). Ensuring this removes the need
for performance-sucking bounce buffer cache management and memcpy()s.
The one known exception at present is the SCR buffer in sd_change_freq(),
which is only 8 bytes long. Solving this requires enhancing struct
mmc_data to know the difference between buffer size and transferred data
size, or forcing all callers of mmc_send_cmd() to have allocated buffers
using ALLOC_CACHE_ALIGN_BUFFER(), which while true in this case, is not
enforced in any way at present, and so cannot be assumed by the core MMC
code.
The current bouncebuf API requires all parameters to be passed to both
bounce_buffer_start() and bounce_buffer_stop(). Modify the bouncebuf
start function to accept a state structure as a parameter, and only
require that state struct to be passed to the stop function. This
simplifies usage of the bounce buffer by clients.
Don't modify the data pointer, but rather store the temporary buffer in
this state struct. The bouncebuf code ensures that client code can
always use a single buffer pointer in the state structure, irrespective
of whether a bounce buffer actually had to be allocated.
Move cache management logic into the bounce buffer code, so that each
client doesn't have to duplicate this. I believe there's no need to
invalidate the buffer before a DMA operation, since flushing the cache
should prevent any write-backs.
Update the MXS MMC driver for this change.
Bring in the code from Linux kernel.
Added to Linux kernel by:
commit e08c1694d9e2138204f2b79b73f0f159074ce2f5
Author: Andres Salomon <dilinger@queued.net>
Date: Fri Jul 4 10:00:03 2008 -0700
Some HW balks when writing both voltage setting and power up at the same
time to SDHCI_POWER_CONTROL register.
Signed-off-by: Rommel G Custodio <sessyargc@gmail.com>
CC: Andy Fleming <afleming@freescale.com>
v2: fix attribution and SOB
The interpretation of the data returned by the MMC_CMD_ALL_SEND_CID
command was incorrect with respect to the JEDEC Standard No. 84-A441.
This change makes the interpretation correct with respect to the
defined fields of the CID register.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Support DesignWare MMC Controller for Samsung Specific.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Rajeshawari Shinde <rajeshwari.s@samsung.com>
usbdescriptors.h conflicts with linux/usb/ch9.h
Remove it.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
This patch adds a NAND Flash torture feature, which is useful as a block stress
test to determine if a block is still good and reliable (or should be marked as
bad), e.g. after a write error.
This code is ported from mtd-utils' lib/libmtd.c.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Scott Wood <scottwood@freescale.com>
[scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings]
NAND Flash is erased by blocks, not by pages.
This patch cleans up nand_util.c:
- Fix tabs.
- Fix typos.
- Remove space character before opening parenthesis in function calls.
- Fix comments.
Use a flag instead of a hard-coded macro so that sub-page reads can be
enabled in other cases (such as on-die ecc).
This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux
IFC-1.1.0 uses 28nm techenology for SRAM. This tech has known limitaion for
SRAM i.e. "byte select" is not supported. Hence Read Modify Write is
implemented in IFC for any "system side write" into sram buffer. Reading an
uninitialized memory results in ECC Error from sram wrapper.
Hence we must initialize/prefill SRAM buffer by any data before writing
anything in SRAM from system side. To initialize SRAM user can use "READID"
NAND command with read bytes equal to SRAM size. It will be a one time
activity post boot
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
[scottwood@freescale.com: fix fsl_ifc_sram_init prototype]
These controllers can only do hardware ECC on full page transfers.
Document parameters used for specifying the NAND image to be loaded.
Also fix the definition of CONFIG_SPL_NAND_SIMPLE -- it's only
nand_spl_simple.c, not the entire nand directory. The word "simple" is
there for a reason. :-)
v2: updated for makefile changes earlier in patchset
Some small SPLs do not use nand_base.c, and a subset of those also
require a special driver. Some SPLs need software ECC but others can't
fit it.
All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these
symbols added to preserve existing behavior.
v2: use positive logic for including bits of NAND, rather than
a MINIMAL symbol that excludes things.
It's arch code and not a driver, so move it where it belongs. When it
originally went into drivers/misc there was no 8xxx CPU directory.
This will make new-SPL support a little easier since we can keep the CPU
stuff together and not need to pull stuff in from drivers/misc.
Cc: Andy Fleming <afleming@freescale.com>
TEMT is set when the transmitter is totally empty and all output has
finished.
This prevents output problems (including a loss of synchronization
observed on p2020 that persisted for quite a while) if SPL has output
still on its way out.
v2: fixed typo in subject, and explained what the bit does in the changelog
CONFIG_NS16550_MIN_FUNCTIONS is used by small SPLs to gain access to basic
ns16550 output code without pulling in things not needed by the SPL.
This previously only worked with non-MULTI configs. Recently MULTI was
made mandatory, and MIN_FUNCTIONS fails like this:
drivers/serial/libserial.o: In function `calc_divisor.clone.0':
serial_ns16550.c:(.text.calc_divisor.clone.0+0x24): undefined reference to `get_bus_freq'
drivers/serial/libserial.o: In function `_serial_getc':
(.text._serial_getc+0x30): undefined reference to `NS16550_getc'
drivers/serial/libserial.o: In function `_serial_tstc':
(.text._serial_tstc+0x30): undefined reference to `NS16550_tstc'
drivers/serial/libserial.o: In function `_serial_setbrg':
(.text._serial_setbrg+0x3c): undefined reference to `NS16550_reinit'
make[1]: *** [/tmp/u-boot/spl/u-boot-spl] Error 1
make: *** [/tmp/u-boot/spl/u-boot-spl.bin] Error 2
With MIN_FUNCTIONS we don't need anything from this file, so don't build
it. The conditional needs to be in the file itself rather than the
makefile, because the config symbols are only imported to the makefiles
once, not separately for the SPL phase of the build.
By commit c7e3b2b5, this was chanded to support multiple controllers.
But this has missing of parenthesis. This commit fix it.
r8a66597-hcd.c: In function ‘usb_lowlevel_init’:
r8a66597-hcd.c:911:52: error: expected declaration specifiers before ‘)’
token
r8a66597-hcd.c:935:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or‘__attribute__’ before ‘{’ token
r8a66597-hcd.c:939:1: error: expected ‘{’ at end of input
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Lucas Stach <dev@lynxeye.de>
Some variables are initialized with a value defined by macro.
This was changed to use the macro directly. And the variable not to
use deleted it.
Backend driver for MUSB OTG controllers found on TI OMAP2/3/4
(tested only on OMAP3 Beagle).
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Backend driver for MUSB OTG controllers found on TI AM35x.
It seems that on AM35X interrupt status registers can be updated
_before_ core registers. As we don't use true interrupts in U-Boot
and poll interrupt status registers instead this can result in
interrupt handler being called with non-updated core registers.
This confuses the code and result in hanged transfers.
Add a small delay in am35x_interrupt as a workaround.
Backend driver for MUSB OTG controllers found on TI AM33xx and
TI81xx SoCs (tested with AM33xx only).
Existing U-Boot musb driver has no support for the new gadget framework
and also seems to have other limitations. As gadget framework is ported
from Linux it seems pretty natural to port musb gadget driver as well.
This driver supports both host and peripheral modes.
This is not a replacement for current musb driver (at least now) as
there are still some consumers of the old UDC interface.
No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be
defined.
Virtual root hub device is not implemented.
Known problems: with no devices connected usb_lowlevel_start() fails.
Linux usb/ch9.h seems to have all the same information (and more)
as usbdescriptors.h so use the former instead of the later one.
As a consequense of this change USB_SPEED_* values don't correspond
directly to EHCI speed encoding anymore, I've added necessary
recoding in EHCI driver. Also there is no point to put speed into
pipe anymore so it's removed and a bunch of host drivers fixed to
look at usb_device->speed instead.
Old usbdescriptors.h included is not removed as it seems to be
used by old USB device code.
This makes usb.h and usbdevice.h incompatible. Fortunately the
only place that tries to include both are the old MUSB code and
it needs usb.h only for USB_DMA_MINALIGN used in aligned attribute
on musb_regs structure but this attribute seems to be unneeded
(old MUSB code doesn't support any DMA at all).
The correct bit for H1_PM is 16, not 8, which is the DP pull-up impedance
selection bit.
This issue has been reported by Eric Bénard <eric@eukrea.com> and fixed by
Christoph Fritz <chf.fritz@googlemail.com> on Linux, from which these #define-s
had been copied.
selection bit.
This issue has been reported by Michael Burkey <mdburkey@gmail.com> and fixed by
had been copied.
Measuring the spi clock line on a scope shows a 'glitch' during the reset of the
spi.
Fix this by toggling only the MXC_CSPICTRL_EN bit, so that the clock line becomes
always stable.
In decode_cs() function the polarity of the chip select must be taken into
account.
Also, for the case of low active chip select, the CS was activated too early.
A custom board_ehci_hcd_init() may be unneeded, so add a weak default
implementation doing nothing.
By the way, use simple __weak from linux/compiler.h for
board_ehci_hcd_postinit() instead of weak alias with full attribute.
Some MXC SoCs like the i.MX35 have hosts located at unusual offsets, so prepare
to the introduction of i.MX35 support by defining the ehci-mxc hosts offsets at
SoC level.
Use EHCI MXC configuration options for i.MX25.
Cc: Matthias Weisser <weisserm@arcor.de>
