Add i.MX8 thermal driver to support get temperature from SCU.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add sc_misc_get_temp to support get temperature
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix pwm backlight
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is
not implemented, leaving the backlight dark. Fix this by returning
no error if set_invert() is not implemented and no polarity change
is requested.
Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell")
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
dwc3-generic has been broken since MISC uclass has been modified to scan DT
sub-nodes after bind.
Fixing it by a using the no-op uclass.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This uclass is intended for devices that do not need any features from the
uclass, including binding children.
This will typically be used by devices that are used to bind child devices
but do not use dm_scan_fdt_dev() to do it. That is for example the case of
several USB wrappers that have 2 child devices (1 for device and 1 for
host) but bind only one at a any given time.
There is simply no reason to do that here.
The EHCI iMX6 driver is only partly converted to DT probing and
still uses a tremendous amount of hard-coded addresses. Worse,
the driver uses hard-coded SoC-model-specific base addresses, which
are derived from values protected by SoC-specific macros, hence the
driver is also compiled for a specific SoC model. Even worse, the
driver depends on specific sequential indexing of the controllers,
from which it derives offsets in the PHY and ANATOP register sets.
However, when the driver is probed from DT, the indexing is not
correct. In fact, each controller has index 0. This patch derives
the index for DT probing case from the controller base addresses,
which is not the way this should be done, however it is the least
intrusive approach, favorable this close to release.
The necessary steps to convert this driver fully to DT probing are
described inside the patch, however this should be done in the next
release and depends on iMX clock driver patches.
Cc: Abel Vesa <abel.vesa@nxp.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Ludwig Zenz <lzenz@dh-electronics.com>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Add pin-mux settings for SPI controller.
Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Add support for loading u-boot FIT images over the USB SDP protocol in
the SPL
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
[Various build fixes]
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Lukasz Majewski <lukma@denx.de>
- boot failure fix for Intel edison
- tangier wdt conversion to driver model
Convert legacy driver to use watchdog class.
The default timeout value had been left in order to leave some traces
about default setup of watchdog done by firmware.
For better understanding and compiler burden, replace it with a comment.
Suggested-by: Stefan Roese <sr@denx.de>
commit b7598a43f2b4 ("[PATCH] Avoid assigning PCI resources from
zero address") only moved the bus lower address to 0x1000 if the
given bus start address is zero. The comment said 0x1000 is a
reasonable starting value, hence we'd better apply the same
adjustment when the given bus start address is below 0x1000.
Signed-off-by: Shannon Barber <sbarber@dataspeedinc.com>
The driver was using milliseconds and programming it into a register
which takes ticks of the watchdog clock, which runs at 1MHz. This meant
we were off by 1000 with the desired value.
When 06985289d452 ("watchdog: Implement generic watchdog_reset()
version") was added the aspeed board would leave the watchdog running,
causing it to bite before u-boot was done.
Discovered by booting in qemu:
$ qemu-system-arm -M ast2500-evb -drive file=test.img,format=raw,if=mtd -nographic -no-reboot -d cpu_reset
U-Boot 2019.07-rc3-00091-g2253e40caef5 (Jun 06 2019 - 16:53:23 +0930)
Model: Aspeed BMC
DRAM: 496 MiB
WDT: Started with servicing (60s timeout)
MMC:
In: serial@1e784000
Out: serial@1e784000
Err: serial@1e784000
Watchdog timer expired.
Fixes: 06985289d452 ("watchdog: Implement generic watchdog_reset() version")
Signed-off-by: Joel Stanley <joel@jms.id.au>
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Update STM32MP entry in MAINTAINERS
- Handle correctly binding for g-tx-fifo-size for USB DWC2 driver
- Fix trusted STM32MP1 defconfig with correct ethernet driver
- Avoid HS400 mode when accessing boot partitions
Add PCIe DM driver for Freescale PowerPC PCIe controllers.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
Allow device mode in DWC2 driver when device tree select the dr_mode
"peripheral" or "otg".
The device mode is not allowed when dr_mode = "host" in device tree.
Manage g-tx-fifo-size as a array as specify in the binding.
u-boot is trying to make CONFIG_BLK as a hard requirement
for DM_MMC. But now it's still not.
config BLK
bool "Support block devices"
depends on DM
default y if DM_MMC
When fsl_esdhc driver was reworked for DM_MMC support, DM_MMC
without CONFIG_BLK enabled wasn't considered. This patch is to
fix probe issue without CONFIG_BLK enabled.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
U-Boot code currently only applies this restriction to HS200 mode,
extend this to HS400 mode as well.
Currently U-Boot code not support accessing boot partition in HS200/400
mode. This needs more check.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
- Assorted gadget fixes
Currently getvar_has_slot() invocation for "boot" and "system"
partitions always returns affirmative response regardless the fact of
existence of these partitions, which leads to impossibility to flash them
on old non-A/B AOSP setups, where _a/_b suffixes aren't used:
$ fastboot flash boot boot.img
Sending 'boot__a' (11301 KB) OKAY [ 0.451s]
Writing 'boot__a' FAILED (remote: 'cannot find partition')
fastboot: error: Command failed
Although partition layout is:
-> part list mmc 0
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00000800 0x000107ff "boot"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
guid: ea2e2470-db4a-d646-b828-10167f736d63
2 0x00010800 0x000127ff "environment"
guid: 10a819d2-6004-3d48-bd87-114e2a796db9
3 0x00012800 0x0001a7ff "recovery"
guid: 9ea116e4-8a34-0c48-8cf5-2fe9480f56cd
4 0x0001a800 0x0031a7ff "system"
This patch adds checks of existence for requested partitions
on eMMC/NAND.
Fixes: f73a7df984a9 ("net: fastboot: Merge AOSP UDP fastboot")
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Extract fastboot_*_get_part_info() usage for MMC and NAND into
getvar_get_part_info() function, as it will be needed further in other
functions. This way we can avoid code duplication and mess with
preprocessor directives across all points of usage.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
In fastboot_*_get_part_info() functions we can use stronger typing by
expecting const strings.
In commit [1] fastboot tool was changed w.r.t. new A/B specification [2],
and now we should report slot names in "a" format instead of "_a".
Latter is now considered legacy and we shouldn't rely on that anymore.
Due to this one can observe next error with recent fastboot tool:
OKAY [ 0.451s]
Writing 'boot__a'
Let's use new slot format in order to fix double underscores "__" and to
be in sync with AOSP master.
[1] https://android.googlesource.com/platform/system/core/+/8091947847d5e5130b09d2ac0a4bdc900f3b77c5
[2] https://source.android.com/devices/tech/ota/ab/ab_implement#partitions
Mark LPC32XX_SSP as DEPRECATED, this so the resulting build shows
warning for deprecated configuration enabled and associated code
will remove in v2019.07 release.
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Sylvain Lemieux <slemieux@tycoint.com>
[trini: Switch to DEPRECATED]
Mark SOFT_SPI as DEPRECATED, this so the resulting build shows
Cc: Vasily Khoruzhick <anarsoul@gmail.com>
Mark SH_SPI as DEPRECATED, this so the resulting build shows
warning for a deprecated configuration enabled and associated code
Mark MXS_SPI as DEPRECATED, this so the resulting build shows
warning for broken configuration enabled and associated code
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
- pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groups
- pinctrl: meson-gxbb: add hdmi related pins to fix HDMI on GXBB
- pinctrl: meson: add support for getting pinmux status
- pinctrl: meson-g12a: add support for drive-strength-microamp property
The GXBB pinctrl is missing pins related to HDMI, namely hot plug
detection (hpd) and I2C (sda + scl).
This fixes HDMI support for GXBB in u-boot.
Reported-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Tested-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
add drive-strength bank regiter and bit value for G12A SoC
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Tested-by: Neil Armstrong <narmstrong@baylibre.com>
drive-strength-microamp is a new feature needed for G12A SoC.
the default DS setting after boot is usually 500uA and it is not enough for
many functions. We need to be able to set the drive strength to reliably
enable things like MMC, I2C, etc ...
In order to support the "pinmux status" command, use the common functions
to get the pins count and names, and add the AXG specific function to get
the current function from registers.
to get the pins count and names, and add the GX specific function to get
Tested-by: Maxime Jourdan <mjourdan@baylibre.com>
In order to support the "pinmux status" command, add common function
to get pins count and pin name.
The GPIO_TEST_N was in the wrong pmx group table, move it back with the AO
groups, GPIODV_18 was missing, add it back, and finally the GPIOCLK_*
group names were missing.
- Add Ethernet support for STM32MP1
- Add saveenv support for STM32MP1
- Add STM32MP1 Avenger96 board support
- Add SPI driver suport for STM32MP1
- Add watchdog support for STM32MP1
- Update power supply check via USB TYPE-C for STM32MP1 discovery board
u-boot-imx-20190612
- Board fixes:
- imx6logic
- wandboard
- mx6sabre boots again
- imx8qm_mek
- pico-* boards
- Toradex apalis / colibri
- engicam imx6 (environment)
- KP MX53
- opos6ul
- Switch to DM:
- vining2000
- dh MX6
- Toradex colibri i.MX7
- Novena
- Security : fix CSF size for HAB
- Other:
- imx: fix building for i.mx8 without spl
- pcie and switch to DM
mx6sabreauto: Enable SPL SDP support
This commit is necessary to be able to re-use the pinctrl code in early
SPL to properly configure pins.
The problem is that those "static" structures (without explicit
initialization) are placed in the SDRAM area, which corresponds to
u-boot proper (not even SPL).
Hence, when one wants to configure pins before relocation via DTS/DM,
the board hangs (imx6q SoC powered one) as only OCRAM area is available
(0x009xxxxx).
This commit prevents from this issue by moving the imx6_pinctrl_soc_info
structure to data section (from BSS).
Signed-off-by: Lukasz Majewski <lukma@denx.de>
We should not access reserved register on i.MX8, otherwise met SERROR
Add compatible string for iMX6SX.
Cc: Silvio Fricke <silvio.fricke@softing.com>
Add DM support and support for probing the iMX PCI driver from DT.
The legacy non-DM support is retained, however shall be removed once
DM PCI is the only option remaining.
Cc: Bin Meng <bmeng.cn@gmail.com>
