path: root/drivers
2007-11-25drivers/mtd : move mtd drivers to drivers/mtdJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/misc : move misc drivers to drivers/miscJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/block : move block drivers to drivers/blockJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/rtc : move rtc drivers to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/hwmon : move hardware monitor drviers to drivers/hwmonJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/input : move input drivers to drivers/inputJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/usb : move usb drivers to drivers/usbJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/serial : move serial drivers to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-11-25drivers/video : move video drivers to drivers/videoJean-Christophe PLAGNIOL-VILLARD
2007-11-24drivers/pcmcia : move pcmcia drivers to drivers/pcmciaJean-Christophe PLAGNIOL-VILLARD
2007-11-24drivers/pci : move pci drivers to drivers/pciJean-Christophe PLAGNIOL-VILLARD
2007-11-20drivers/i2c : move i2c drivers to drivers/i2cJean-Christophe PLAGNIOL-VILLARD
2007-11-20Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
2007-11-19Fix build problems with mp2usb boardWolfgang Denk
2007-11-18Fix compiler warnings for ARM systems.Wolfgang Denk
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-11-16Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
Conflicts: drivers/Makefile
2007-11-15Group PCI and PCMCIA drivers in drivers/MakefileGrant Likely
2007-11-15Group block/flash drivers in drivers/MakefileGrant Likely
2007-11-15Group USB drivers in drivers/MakefileGrant Likely
2007-11-15Group i2c drivers in drivers/MakefileGrant Likely
2007-11-15Group console drivers in drivers/MakefileGrant Likely
2007-11-15Group network drivers in drivers/MakefileGrant Likely
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-06Implement general ULi 526x Ethernet driver support in U-bootRoy Zang
This patch implements general ULi 526x Ethernet driver. Until now, it is the only native Ethernet port on MPC8610HPCD board, but it could be used on other boards with ULi 526x Ethernet port as well. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-11-03Trimmed some variables in ne2000.cVlad Lungu
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2007-11-02Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2007-11-01Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2007-11-01Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2007-10-24fsl_pci_init enable COMMAND_MEMORY if inbound windowEd Swarthout
Patch 16e23c3f removed PCSRBAR allocation. But passing zero windows to pciauto_setup_device has the side effect of not getting COMMAND_MEMORY set. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-10-23Coding style: keep lists sorted; update CHANGELOGWolfgang Denk
2007-10-23Fix missing drivers makefile entries ds1722.c mw_eeprom.cJean-Christophe PLAGNIOL-VILLARD
2007-10-23Move PL01* serial drivers to drivers/serial and adjust Makefiles.Peter Pearse
2007-10-21Minor coding style cleanup; update CHANGELOGWolfgang Denk
2007-10-21Fix NE2000 driver:Vlad Lungu
Fixed typo in ne2000.h, thinko re n2k_inb() usage, don't try to do anything in eth_stop() if eth_init() was not called. Simplified RX path in order to avoid timeouts on really really fast NE2000 cards (read: qemu with internal tftp), NetLoop() is clever enough to cope with 1 packet per eth_rx(). Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2007-10-19tsec driver should clear RHALT on startupDan Wilson
This was causing problems for some people. Signed-off-by: Alain Gravel <agravel@fulcrummicro.com> Signed-off-by: Dan Wilson <dwilson@fulcrummicro.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-10-15Merge branch 'master' of git://www.denx.de/git/u-boot-usbWolfgang Denk
2007-10-13Merge branch 'merge' of git://www.denx.de/git/u-boot-microblazeWolfgang Denk
2007-10-13Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2007-10-13Coding Style cleanup.Wolfgang Denk
2007-10-04Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-10-02Bugfix: Use only one PTD for one endpointTimo Ketola
Original isp116x-hcd code prepared multiple PTDs for longer than 16 byte transfers for one endpoint. That is unnecessary because the ISP116x is able to split long data from one PTD into multiple transactions based on the buffer size of the endpoint. It also caused serious problems if the endpoint NAKed some of the transactions. In that case ISP116x wouldn't notice that the other PTDs were for the same endpoint and would try the other PTDs possibly out of order. That would break the whole transfer. This patch makes isp116x_submit_job to use one PTD for one transfer. Signed-off-by: Timo Ketola <timo.ketola@exertus.fi> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2007-09-24[PATCH] Change macro name for UartLiteMichal Simek
because PowerPC 405 can use UartLite as console
2007-09-24synchronizition with mainlineMichal Simek
2007-09-24Merge ../u-bootMichal Simek
2007-09-18Move coloured led API to status_led.hPeter Pearse
Improve indentation in drivers/at45.c
2007-09-18Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-09-17Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-09-17Description: Add NEC's PCI OHCI module ID to the USB OHCI driverDavid Saada
Signed-off-by: David Saada <david.saada@ecitele.com>
