Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Add driver model support while retaining the existing legacy code.
This allows the driver to support boards that have converted to
driver model as well as those that have not.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Add support to enable an early debug UART for debugging.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Add ATMEL_USART option to support to enable the Atmel usart driver
from Kconfig.
Due to the peripheral and generated clock driver improvement,
remove the unnecessary clock calling.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Due to the peripheral clock driver improvement, remove the
Change the error return value -ENODEV from to -EINVAL for more
reasonable.
For the peripheral clock, provide the clock ops for the clock
provider, such as spi0_clk. The .of_xlate is to get the clk->id,
the .enable is to enable the spi0 peripheral clock, the .get_rate
is to get the clock frequency.
The driver for periph32ck node is responsible for recursively
binding its children as clk devices, not provide the clock ops.
So do the generated clock and system clock.
In order to make clk->dev available in ops->of_xlate() to get the
clock ID from the 'reg' property of the clock node, assign the
clk->dev before calling ops->of_xlate().
The at91-pmc and at91-sckc aren't the clock providers, change their
class ID from UCLASS_CLK to UCLASS_SIMPLE_BUS, they also don't
need to bind the child nodes explicitly, the .post_bind callback
of simple_bus uclass will do it for them.
common/Kconfig
configs/dms-ba16_defconfig
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
To prevent the wrong value check the SD version.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
If vmmc didn't supply, we didn't know which card didn't supply vmmc.
And changed from "put" to "debug".
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Now that CONFIG_BLK and CONFIG_MMC_OPS are enabled by default with
CONFIG_DM_MMC, the DWMMC driver on the socfpga platform fails at
runtime.
This adds the missing fields in the driver declaration.
Signed-off-by: Sylvain Lesne <lesne@alse-fr.com>
Drop unneeded variables and assignments.
This pathc is fixed the below thing.
If misaligned the cache range, Just flush to CACHLINE_SIZE.
"CACHE: Misaligned operation at range [7ae55b00, 7ae55b08]"
In device tree, there is vmmc-supply property for SD/MMC.
Introduce mmc_power_init function to handle vmmc-supply.
mmc_power_init will first invoke board_mmc_power_init to
avoid break boards which already implement board_mmc_power_init.
If DM_MMC and DM_REGULATOR is defined, the regulator
will be enabled to power up the device.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Add 'PCI' as a menu option and migrate all existing users.
Added kconfig for NAND_MXS driver.
Cc: Scott Wood <oss@buserror.net>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Added kconfig for FEC_MXC driver.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Added kconfig for IMX_THERMAL driver.
Added kconfig for MXC_UART driver.
Make sure the driver writes the cmd_data register only once per
read transfer instead of doing so potentially repeatedly.
In case the read transfer didn't finish quickly enough, the loop
in the driver code would spin fast enough to write the same value
into the cmd_data register again before re-checking whether the
transfer completed, which would cause another spurious read transfer
on the bus.
Cc: Stefan Roese <sr@denx.de>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Chin Liang See <clsee@altera.com>
Commit b02e4044ff8e ("libfdt: Bring in upstream stringlist
functions") broke codying style in some places especially
by inserting an extra whitespace before fdt_stringlist_count().
Commit a85362fb3e1fc7833723accddbbae431091d06b8 refactored the code
but the register read ended up in the wrong if branch.
Currently, the else branch checks a variable which is always 0.
Signed-off-by: Nicolae Rosia <nicolae_rosia@mentor.com>
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_CONSOLE_SCROLL_LINES
This should be defined in a header file so that arguments are checked.
Move it to video.h.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
This is not used in U-Boot.
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This is not used anywhere in U-Boot.
This is not used in U-Boot anymore.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_VIDEO
These two files have patch merge markers in them, within comments or
strings. Remove then, so that a search for merge markers does not show up
matches in these files.
Patch queue for efi - 2016-10-19
Highlights this time around:
- Add run time service (power control) support for PSCI (fixed in v3)
- Add efi gop pointer exposure
- SMBIOS support for EFI (on ARM)
- efi pool memory unmap support (needed for 4.8)
- initial x86 efi payload support (fixed up in v2)
- various bug fixes
include/tables_csum.h
