path: root/drivers
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-12-09at91: add new gpio pin definitionsAndreas Bießmann
This patch define new names for GPIO pins on at91 devices. Follow up patches will convert the whole infrastructure to use these new definitions. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Bo Shen <voice.shen@atmel.com>
2013-12-08mmc: add Faraday FTSDC021 SDHCI controller supportKuo-Jung Su
Faraday FTSDC021 is a controller which is compliant with SDHCI v3.0, SDIO v2.0 and MMC v4.3. However this driver is only verified with SD memory cards. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> CC: Andy Fleming <afleming@gmail.com>
2013-12-08powerpc: mmc: Add corenet devices support in esdhc splPriyanka Jain
Existing eSDHC SPL framework assumes booting from sd-image with boot_format header which contains final u-boot Image offset and size. No such header is present in case of corenet devices like T1040 as corenet deivces use PBI-RCW based intialization. So, for corenet deives, SPL bootloader use values provided at compilation time. These values can be defined in board specific config file. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-08mmc/dwmmc: modify FIFO threshold only if value explicitly setAlexey Brodkin
If platform provides "host->fifoth_val" it will be used for initialization of DWMCI_FIFOTH register. Otherwise default value will be used. This implementation allows: * escape unclear and recursive calculations that are currently in use * use whatever custom value for DWMCI_FIFOTH initialization if any particular SoC requires it Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Alim Akhtar <alim.akhtar@samsung.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Andy Fleming <afleming@freescale.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-08mmc: dw_mmc: remove the exynos specific code in dw-mmc.cJaehoon Chung
dw-mmc.c is the general driver file. So, remove the exynos specific code at dw-mmc.c. Instead, exynos specific cod can be move into exynos-dw_mmc.c. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-06Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-12-06Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-12-06usb: ehci-omap: Reset the USB Host OMAP moduleRoger Quadros
In commit bb1f327 we removed the UHH reset to fix NFS root (over usb ethernet) problems with Beagleboard (3530 ES1.0). However, this seems to cause USB detection problems for Pandaboard, about (3/8). On further investigation, it seems that doing the UHH reset is not the cause of the original Beagleboard problem, but in the way the reset was done. This patch adds proper UHH RESET mechanism for OMAP3 and OMAP4/5 based on the UHH_REVISION register. This should fix the Beagleboard NFS problem as well as the Pandaboard USB detection problem. Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com> CC: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-06spi: bfin_spi6xx: Remove unnecessary test for bus and pins[bus]Axel Lin
For invalid bus number, current code returns NULL in the default case of switch-case statements. In additional, pins[bus] is always not NULL because it is the address of specific row of the two-dimensional array. Thus this patch removes these unnecessary test. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-12-06spi: bfin_spi: Remove unnecessary test for bus and pins[bus]Axel Lin
2013-12-06i2c: samsung: register i2c busses for Exynso5420 and Exynos5250Naveen Krishna Ch
This patch adds the U_BOOT_I2C_ADAP_COMPLETE defines for channels on Exynos5420 and Exynos5250 and also adds support for init function for hsi2c channels Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-12-05arm: omap: i2c: don't zero cnt in i2c_writeNikita Kiryanov
Writing zero into I2Ci.I2C_CNT register causes random I2C failures in OMAP3 based devices. This seems to be related to the following advisory which apears in multiple erratas for OMAP3 SoCs (OMAP35xx, DM37xx), as well as OMAP4430 TRM: Advisory: I2C Module Does Not Allow 0-Byte Data Requests Details: When configured as the master, the I2C module does not allow 0-byte data transfers. Note: Programming I2Ci.I2C_CNT[15:0]: DCOUNT = 0 will cause undefined behavior. Workaround(s): No workaround. Do not use 0-byte data requests. The writes in question are unnecessary from a functional point of view. Most of them are done after I/O has finished, and the only one that preceds I/O (in i2c_probe()) is also unnecessary because a stop bit is sent before actual data transmission takes place. Therefore, remove all writes that zero the cnt register. Cc: Heiko Schocher <hs@denx.de> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Tom Rini <trini@ti.com> Cc: Lubomir Popov <lpopov@mm-sol.com> Cc: Enric Balletbo Serra <eballetbo@gmail.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Lubomir Popov <lpopov@mm-sol.com>
2013-12-05i2c: fti2c010: serial out r/w address in MSB orderKuo-Jung Su
For a eeprom with a 2-bytes address (e.g., Ateml AT24C1024B), the r/w address should be serial out in MSB order. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Heiko Schocher <hs@denx.de>
2013-12-05i2c: fti2c010: migrate to new i2c modelKuo-Jung Su
Replace the legacy i2c model with the new one. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Heiko Schocher <hs@denx.de>
2013-12-05i2c: fti2c010: cosmetic: coding style cleanupKuo-Jung Su
Coding style cleanup Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Heiko Schocher <hs@denx.de>
2013-12-05driver:i2c:s3c24x0: fix clock init for hsi2cPiotr Wilczek
Fix clock value initialisation for Exynos other than Exynos5 for hsi2c. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2013-12-05driver:i2c:s3c24x0: adapt driver to new i2cPiotr Wilczek
This patch adapts the s3c24x0 driver to the new i2c framework. Config file is modified for all the boards that use the driver. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Heiko Schocher <hs@denx.de> CC: Inderpal Singh <inderpal.singh@linaro.org> CC: David Müller <d.mueller@elsoft.ch> CC: Chander Kashyap <k.chander@samsung.com> CC: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-12-04powerpc: spiflash:Add corenet devices support in eSPI SPLPriyanka Jain
Existing eSPI SPL framework assumes booting from spi-image with boot_format header which contains final u-boot Image offset and size. No such header is present in case of corenet devices like T1040 as corenet deivces use PBI-RCW based intialization. So, for corenet deives, SPL bootloader use values provided at compilation time. These values can be defined in board specific config file. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-04am335x: cpsw: optimize cpsw_recv to increase network performanceVladimir Koutny
In 48ec5291, only TX path was optimized; this does the same also for RX path. This results in huge increase of TFTP throughput on custom am3352 board (from 312KiB/s to 1.8MiB/s) and eliminates occasional transfer timeouts. Signed-off-by: Vladimir Koutny <vladimir.koutny@streamunlimited.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Tom Rini <trini@ti.com>
2013-12-04ahci: Fix cache align error messagesRoger Quadros
Align the ATA ID buffer to the cache-line boundary. This gets rid of the below error mesages on ARM v7 platforms. scanning bus for devices... ERROR: v7_dcache_inval_range - start address is not aligned - 0xfee48618 ERROR: v7_dcache_inval_range - stop address is not aligned - 0xfee48818 CC: Aneesh V <aneesh@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-04ahci: Error out with message on malloc() failureRoger Quadros
If malloc() fails, we don't want to continue in ahci_init() and ahci_init_one(). Also print a more informative error message on malloc() failures. CC: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-04ARMV7: OMAP4: Add twl6032 supportOleg Kosheliev
Added chip type detection and twl6032 support in the battery control and charge functions. Based on Balaji T K <balajitk@ti.com> patches for TI u-boot. Signed-off-by: Oleg Kosheliev <oleg.kosheliev@ti.com>
2013-12-04ARMV7: OMAP4: Add struct for twl603x dataOleg Kosheliev
The data struct is used to support different PMIC chip types. It contains the chip type and the data (e.g. registers addresses, adc multiplier) which is different for twl6030 and twl6032. Replaced some hardcoded values with the structure vars. Based on Balaji T K <balajitk@ti.com> patches for TI u-boot. Signed-off-by: Oleg Kosheliev <oleg.kosheliev@ti.com>
2013-12-04video: ipu_disp: Return a negative value on errorFabio Estevam
We should return a negative error number (-EINVAL) on error. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-12-02Merge branch 'serial' of git://git.denx.de/u-boot-microblazeTom Rini
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-12-02serial: zynq: Remove unused #definesSoren Brinkmann
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Series-to: trini, uboot
2013-12-02driver:usb:s3c_udc: add support for Exynos4x12Piotr Wilczek
This patch add new defines for usb phy for Exynos4x12. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-11-27power: power_fsl: Pass p->bus in the same way for SPI and I2C casesFabio Estevam
There is no need to pass p->bus differently when the PMIC is connected via SPI or via I2C. Handle the both cases in the same way. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-25powerpc/mpc85xx: Add T2080/T2081 SoC supportShengzhou Liu
Add support for Freescale T2080/T2081 SoC. T2080 includes the following functions and features: - Four dual-threads 64-bit Power architecture e6500 cores, up to 1.8GHz - 2MB L2 cache and 512KB CoreNet platform cache (CPC) - Hierarchical interconnect fabric - One 32-/64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving - Data Path Acceleration Architecture (DPAA) incorporating acceleration - 16 SerDes lanes up to 10.3125 GHz - 8 mEMACs for network interfaces (four 1Gbps MACs and four 10Gbps/1Gbps MACs) - High-speed peripheral interfaces - Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV) - Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz - Additional peripheral interfaces - Two serial ATA (SATA 2.0) controllers - Two high-speed USB 2.0 controllers with integrated PHY - Enhanced secure digital host controller (SD/SDHC/SDXC/eMMC) - Enhanced serial peripheral interface (eSPI) - Four I2C controllers - Four 2-pin UARTs or two 4-pin UARTs - Integrated Flash Controller supporting NAND and NOR flash - Three eight-channel DMA engines - Support for hardware virtualization and partitioning enforcement - QorIQ Platform's Trust Architecture 2.0 Differences between T2080 and T2081: Feature T2080 T2081 1G Ethernet numbers: 8 6 10G Ethernet numbers: 4 2 SerDes lanes: 16 8 Serial RapidIO,RMan: 2 no SATA Controller: 2 no Aurora: yes no SoC Package: 896-pins 780-pins Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-11-25net/fman: Add support for 10GEC3 and 10GEC4Shengzhou Liu
There are more than two 10GEC in single FMAN in some SoCs(e.g. T2080). This patch adds support for 10GEC3 and 10GEC4. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-11-25Driver/IFC: Move Freescale IFC driver to a common driverYork Sun
Freescale IFC controller has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the driver to driver/misc and fix the header file includes. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Update DDR driver to allow non-zero base addressYork Sun
The DRAM base has been zero for Power SoCs. It could be non-zero for ARM SoCs. Use a macro instead of hard-coding to zero. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25powerpc/mpc8xxx: Extend DDR registers' fieldsYork Sun
Some DDR registers' fields have expanded to accommodate larger values. These changes are backward compatible. Some fields are removed for newer DDR controllers. Writing to those fields are safely ignored. TIMING_CFG_2 register is fixed. Additive latency is added to RD_TO_PRE automatically. It was a misunderstanding in commit c360ceac. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Add Freescale DDR driver for ARMYork Sun
Make PowerPC specific code conditional so ARM SoCs can reuse this driver. Add DDR3 driver for ARM. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-11-25bios_emulator: delete an unnecessary include pathMasahiro Yamada
-I$(TOPDIR)/include is defined in the top config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25drivers: delete unnecessary HOSTCFLAGSMasahiro Yamada
HOSTCFLAGS is meaningless because no host programs are compiled there. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25gpio_led: add support for inverted polarityIgor Grinberg
Some GPIO connected LEDs have inverted polarity. Introduce new config option: CONFIG_GPIO_LED_INVERTED_TABLE for the specifying the inverted GPIO LEDs list and add support for this in the gpio_led driver. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Ilya Ledvich <ilya@compulab.co.il>
2013-11-25gpio_led: check gpio_request() return valueIgor Grinberg
Add a check for the gpio_request() function return value and do not try to configure the GPIO if the gpio_request() call fails. Also, print an error message indicating the gpio_request() has failed. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Ilya Ledvich <ilya@compulab.co.il>
2013-11-22net: rtl8169: Add support for RTL8168d/8111dThierry Reding
This chip is compatible with the existing driver, except that it uses BAR2 instead of BAR1 for the I/O memory region. Using this patch I can use the PCIe ethernet interface on the CompuLab Trimslice to boot from the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Patch: 276477
2013-11-22net: rtl8169: Improve cache maintenanceThierry Reding
Instead of directly calling the low-level invalidate_dcache_range() and flush_cache() functions, provide thin wrappers that take into account alignment requirements. While at it, fix a case where the cache was flushed but should have been invalidated, two cases where the buffer data was flushed instead of the descriptor and a missing cache invalidation before reading the packet data that the NIC just wrote to memory. Signed-off-by: Thierry Reding <treding@nvidia.com> Patch: 276474
2013-11-22net: zynq_gem: Add d-cache supportSrikanth Thokala
Added d-cache support for zynq_gem.c, Observed a difference of +0.8 MiB/s when downloading a file of size of 3007944Bytes. With d-cache OFF: ---------------- Filename 'uImage'. Load address: 0x800 Loading: ################################################################# ################################################################# ################################################################# ########## 1.3 MiB/s done Bytes transferred = 3007944 (2de5c8 hex) With d-cache ON: --------------- Filename 'uImage'. Load address: 0x800 Loading: ################################################################# ################################################################# ################################################################# ########## 2.1 MiB/s done Bytes transferred = 3007944 (2de5c8 hex) Changes on zynq_gem for d-cache support: - Tx and Rx buffers are cache-aligned - Updated logic for invalidating Rx buffers and flushing Tx buffers. - Tx and Rx BD's are allocated from non-cacheable region. (When BDs are cached, we don't see a consistent link) - Use TX BD status intead of txsr status checks. Signed-off-by: Srikanth Thokala <sthokal@xilinx.com> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-11-22phy: Use general phy code for smsc lan8720aDavid Dueck
Signed-off-by: David Dueck <davidcdueck@googlemail.com>
2013-11-22phy: Use supported field during autonegotiationDavid Dueck
The current code incorrectly detects gigabit capabilities for some 100Mbit/s phys. (lan8720a) Signed-off-by: David Dueck <davidcdueck@googlemail.com>
