If the UART is used in DTE mode the RI and DCD bits in UCR3 become
irq enable bits. Both are set to enabled after reset and both likely
are pending.
Disable the bits to prevent an interrupt storm when Linux enables
the UART interrupts.
Add USB serial download protocol support to SPL. If the SoC started
in recovery mode the SPL will immediately switch to SDP and wait for
further downloads/commands from the host side.
Support U-Boot images in SPL (which makes it possible to download
u-boot.img) and U-Boot scripts in full U-Boot.
Add SDP (Serial Downloader Protocol) implementation for U-Boot. The
protocol is used in NXP SoCs boot ROM and allows to download program
images. Beside that, it can also be used to read/write registers and
download complete Device Configuration Data (DCD) sets. Currently,
this implementation only supports downloading images and reading
registers.
On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
(cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
Integrate 16-bit BCH ECC handling required e.g. for the latest NAND
parts assembled on Colibri T20.
(cherry picked from commit dcca76ea36fc778fa750473aee09fa0297dc5e2b)
Hack driver to avoid the following error for now. This is required for
unprogrammed i210 operation.
e1000: e1000#0: ERROR: Hardware Initialization Failed
(cherry picked from commit 02bf24ad4a7c882e25771f656b973d5458695cf0)
(cherry picked from commit 68cecfdbe342f800a0b1f10a1f8fb019b491f04b)
(cherry picked from commit 2d8ea651b6da79047b6fa729863d25b5eb9e15d7)
Add common widescreen modes 800x480 and 1024x600.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
The MTD subsystem now uses mtd_to_nand to get to the struct
nand_chip pointer. Use mtd_to_nand in mxs_nand_get_ecc_strength
too.
Should have "&" to access the register address, otherwise uboot will hang.
Signed-off-by: Ye Li <ye.li@nxp.com>
This patch is a porting of
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=e4dacc44d22e9474ec456cb330df525cd805ea38
i.MX6QP and i.MX7D BCH module integrated a new feature to detect the
bitflip number for erased NAND page. So for these two platform, set the
erase threshold to gf/2 and if bitflip detected, GPMI driver will
correct the data to all 0xFF.
Also updated the imx6qp dts file to ditinguish the GPMI module for i.MX6Q
with the one for i.MX6QP.
In this patch, i.MX6UL is added and threshold changed to use ecc_strength.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This patch is porting from linux:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_4.1.15_1.0.0_ga&id=3d42fcece496224fde59f9343763fb2dfc5b0768
We may meet the bitflips in reading an erased page(contains all 0xFF),
this may causes the UBIFS corrupt, please see the log from Elie:
[ 3.831323] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.845026] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.858710] UBI warning: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read only 16384 bytes, retry
[ 3.872408] UBI error: ubi_io_read: error -74 (ECC error) while reading 16384 bytes from PEB 443:245760, read 16384 bytes
[ 4.011529] UBIFS error (pid 36): ubifs_recover_leb: corrupt empty space LEB 27:237568, corruption starts at 9815
[ 4.021897] UBIFS error (pid 36): ubifs_scanned_corruption: corruption at LEB 27:247383
[ 4.030000] UBIFS error (pid 36): ubifs_scanned_corruption: first 6569 bytes from LEB 27:247383
This patch does a check for the uncorrectable failure in the following steps:
[0] set the threshold.
The threshold is set based on the truth:
"A single 0 bit will lead to gf_len(13 or 14) bits 0 after the BCH
do the ECC."
For the sake of safe, we will set the threshold with half the gf_len, and
do not make it bigger the ECC strength.
[1] count the bitflips of the current ECC chunk, assume it is N.
[2] if the (N <= threshold) is true, we continue to read out the page with
ECC disabled. and we count the bitflips again, assume it is N2.
(We read out the whole page, not just a chunk, this makes the check
more strictly, and make the code more simple.)
[3] if the (N2 <= threshold) is true again, we can regard this is a erased
page. This is because a real erased page is full of 0xFF(maybe also has
several bitflips), while a page contains the 0xFF data will definitely
has many bitflips in the ECC parity areas.
[4] if the [3] fails, we can regard this is a page filled with the '0xFF'
data.
provide one config "CONFIG_NAND_MXS_BCH_LEGACY_GEO" to keep using legacy
bch geometry.
NOTICE: the feature must be enabled/disabled in both u-boot and kernel.
Signed-off-by: Han Xu <han.xu@nxp.com>
(cherry picked from commit 0abc9c182c24f88522bd74fa1b53cd2fa3477184)
The cod change updated the NAND driver BCH ECC layout algorithm to
support large oob size NAND chips(oob > 1024 bytes).
Current implementation requires each chunk size larger than oob size so
the bad block marker (BBM) can be guaranteed located in data chunk. The
ECC layout always using the unbalanced layout(Ecc for both meta and
Data0 chunk), but for the NAND chips with oob larger than 1k, the driver
cannot support because BCH doesn’t support GF 15 for 2K chunk.
The change keeps the data chunk no larger than 1k and adjust the ECC
strength or ECC layout to locate the BBM in data chunk. General idea for
large oob NAND chips is
1.Try all ECC strength from the minimum value required by NAND spec to
the maximum one that works, any ECC makes the BBM locate in data chunk
can be chosen.
2.If none of them works, using separate ECC for meta, which will add one
extra ecc with the same ECC strength as other data chunks. This extra
ECC can guarantee BBM located in data chunk, of course, we need to check
if oob can afford it.
Signed-off-by: Han Xu <b45815@freescale.com>
Introduce USB Gadget config option. This allows to combine Makefile
entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Ravi Babu <ravibabu@ti.com>
(cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Introduce CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK to disable the external clock
loopback and use the internal one on SDMMC3 as per the SDMMC_VENDOR_MISC_CNTRL_0
register's SDMMC_SPARE1 bits being set to 0xfffd according to the TRM.
Commit 35c204d8a9d0 ("nand: reinstate lazy bad block scanning")
introduced lazy BBT scanning. However, some controller do parts
of the initialization (mxs_nand.c) during scan_bbt, hence for
those controllers the BBT must be scanned at initialization time.
In most situation the U-Boot environment gets read first, and
the U-Boot environment code checks for bad blocks first. Checking
for bad blocks will ask for scan_bbt before reading the first page,
hence in most situation the issue does not appear in practice.
However, when there is no environment configured, other code might
access NAND first which does not explicitly checks for bad blocks,
in those cases ECC reads will fail always.
Cc: Rostislav Lisovy <lisovy@gmail.com>
Optional driver model handling integration.
(cherry picked from commit cbfa67a16b345cfb94840a41ee2fa0f728be296a)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
Compiling the 'bmp' command with DM and having one of the following macros
enabled:
CONFIG_BMP_16BPP, CONFIG_BMP_24BPP ONFIG_BMP_32BPP
generates this error:
drivers/video/video_bmp.c: In function ‘video_bmp_display’:
drivers/video/video_bmp.c:315:22: error: ‘lcd_line_length’ undeclared (first use in this function)
fb -= width * 2 + lcd_line_length;
This patch moves to using the correct variable instead and enables the
'bmp' command for DM again.
Fix the divider calculation logic to choose a value so that the
resulting baudrate is either equal to or closest possible baudrate less
than the requested value. While at that, cleanup ti_spi_set_speed().
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Commit 5a49f17481bb ("net: mii: Use spatch to update miiphy_register")
updated the mvgbe implementation of smi_reg_read/smi_reg_write. Prior to
that change mvgbe_phy_read and mvgbe_phy_write where used as wrappers to
satisfy the phylib APIs. Because these functions weren't updated in that
commit build errors where triggered when CONFIG_PHYLIB was enabled.
Fix these build errors by removing mvgbe_phy_read and mvgbe_phy_write
and using smi_reg_read/smi_reg_write directly.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Like [1], reset the FLP burst timing for the KSZ9031 to the 16ms
specified by the IEEE802.3 standard from the chip's default of 8ms.
For more details, see the "Auto-Negotiation Timing" section of the
KSZ9031RNX datasheet.
[1] https://patchwork.kernel.org/patch/6558371/
Signed-off-by: Ash Charles <ash.charles@savoirfairelinux.com>
This driver supports the Synopsys Designware Ethernet QoS (Quality of
Service) a/k/a eqos IP block, which is a different design than the HW
supported by the existing designware.c driver. The IP supports many
options for bus type, clocking/reset structure, and feature list. This
driver currently supports the specific configuration used in NVIDIA's
Tegra186 chip, but should be extensible to other combinations quite
easily, as explained in the source.
Reviewed-by: Simon Glass <sjg@chromium.org> # V1
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Cover-Letter: Fixes several spelling errors for the words "resetting",
"extended", "occur", and "multiple".
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
This function is called from outside the driver. It should be placed into
common SoC code. Move it.
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Also rename the driver symbol to be more consistent with the other rockchip
clock drivers.
clock drivers.
clk_rk3399 is driver name, not device name
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
OHCI has a known limitation of allowing only 32-bit DMA buffer
addresses, so we have a lot of u32 variables around, which are assigned
to pointers and vice versa. This obviously creates issues with 64-bit
systems, so the compiler complains here and there.
To allow compilation for 64-bit boards which use only memory below 4GB
anyway (and to avoid more invasive fixes), adjust some casts and types
and assume that the EDs and TDs are all located in the lower 4GB.
This fixes compilation of the OHCI driver for the Pine64.
Add driver model support while retaining the existing legacy code.
This allows the driver to support boards that have converted to
driver model as well as those that have not.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Add support to enable an early debug UART for debugging.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Add ATMEL_USART option to support to enable the Atmel usart driver
from Kconfig.
Due to the peripheral and generated clock driver improvement,
remove the unnecessary clock calling.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Due to the peripheral clock driver improvement, remove the
Change the error return value -ENODEV from to -EINVAL for more
reasonable.
