Dealing with the sys ctrl register should touch only the
relevant bits and not accidently the whole register. On i.MX6,
the sys control register contains bits which shouldn't be reset to
0, e.g. SYS_CTRL[3-0] and IPP_RST_N (SYS_CTRL[23]).
Do this by read/modify/write instead of just a 32bit write.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
1. No contents of "asm/arch/clk.h" is used within "dw_mmc.c".
2. If arch doesn't have "asm/arch/clk.h" driver won't build.
Without mentioned inclusion dw_mmc driver could be built for arches
other than ARM. For ARM driver still builds without it.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Cc: Amar <amarendra.xt@samsung.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Fill the right command type when using CMD12 to stop data transfer.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
CC: Fleming Andrew-AFLEMING <AFLEMING@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
Add support for Atmel TPM devices with two wire interface.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
if alen is 0: no longer start a write cycle before reading data.
Acked-by: Heiko Schocher <hs@denx.de>
The driver triggered a BUG() in nand_base.c:3214/nand_scan_tail()
because the ecc.strength was not set in NAND_ECC_HW_SYNDROME ECC
mode.
Cc: Benoit Thebaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
The MX28 multi-layer AHB bus can be too slow and trigger the
FEC DMA too early, before all the data hit the DRAM. This patch
ensures the data are written in the RAM before the DMA starts.
Please see the comment in the patch for full details.
This patch was produced with an amazing help from Albert Aribaud,
who pointed out it can possibly be such a bus synchronisation
issue.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
Remove incorrectly called and duplicate flush_dcache_range() call
from fec_mxc driver. The call is not needed, since the caches are
already flushed in fec_tbd_init(), moreover the second argument should
be the ending address, not size.
Reported-by: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Tegra30 and Tegra114 are compatible except PLL parameters.
Tested on Tegra30 Cardhu, and Tegra114 Dalmore
platforms. All works well.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Newer gcc versions warn about unused variables. This patch corrects a few of
those warnings that popped up in a build for the palmtreo680 board.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
The DFU's state machine original implementation author and copyright were
missing.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
This patch resolves the below mentioned compilation error of i2c driver
for non-FDT case
Compilation error:
s3c24x0_i2c.c: In function 'board_i2c_init':
s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use
in this function) s3c24x0_i2c.c:544:18: note: each undeclared
identifier is reported only once for each function it appears in
s3c24x0_i2c.c:545:3: warning: implicit declaration of function
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Signed-off-by: Amar <amarendra.xt@samsung.com>
Code for checking "splashpos" environment variable is
duplicated in drivers, move it to the common function.
Call this function also in the bmp display command to
consider "splashpos" settings.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Add support for disabling battery charging with ctrl+C keyboard
combination pressed.
Moreover the battery update is done more frequently.
For the first eMMC read of data for upload, use the "large" dfu_buf (now
configurable) instead of usb request buffer allocated at composite layer
(which is 4KiB) [*].
For eMMC the whole file is read, which usually is larger than the buffer [*]
provided with usb request.
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
In the following commit:
"dfu: Support larger than memory transfers."
SHA1: ea2453d56b8860dbd18a3c517531ffc8dcb5c839
The ext4{read|write} command formatting has been changed. It removed
a write mandatory [sizebytes] parameter.
It extents DFU_FS_EXT4 case at mmc_file_op to provide mandatory
parameter for DFU write.
The omap_gpio driver is used by AM33XX, OMAP3/4, OMAP54XX and DRA7XX SoCs.
These SoCs have different gpio count but currently omap_gpio driver uses hard
coded 192 which is wrong.
This patch fixes this issue by:
1. Move define of OMAP_MAX_GPIO to all arch/arm/include/asm/arch-omap*/gpio.h.
2. Update gpio bank settings and enable GPIO modules 7 & 8 clocks for OMAP5.
Thanks for Lubomir Popov to provide valuable comments to fix this issue.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
This patch fix the omap access to the transceiver
configuration registers using the ulpi bus. As reported by
the documentation the bit31 is used only to check if the
transaction is done or still running and the reading and
writing operation have different offset and have different
values. What we need to do at the end of a transaction is
leave the bus in done state. Anyway an error using the ulpi
omap register is not recoverable so any error give out the
usage of this interface.
Tested on a custom OMAP5430 board with a TUSB1210 ULPI PHY
on USBB1.
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Create splash.c/h to put the function and any future common splash
screen code in.
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
This patch change 'data_to_send' array to static to avoid
unaligned access exeption on some platforms (ex Trats2).
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Minkyu Kang <mk7.kang@samsung.com>
CC: Anatolij Gustschin <agust@denx.de>
This trivial patch adds the definition of the vid/pid for the Ver C1 of the
USB Ethernet adapter D-Link DUB-E100.
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
CC: Marek Vasut <marex@denx.de>
This subtle change fix problem with too small amount of allocated
memory to store DFU function pointers.
One needs to allocate extra space for sentinel NULL pointer in this array
of function pointers.
With the previous code, the NULL value overwrites malloc internal data
and afterwards free(f_dfu->function) crashes.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Ilya Yanok <ilya.yanok@cogentembedded.com>
add a weak dummy function g_dnl_fixup to add the possibility to update
the device_desc board specific. Used on the upcoming siemens board
support, where idVendor and idProduct is stored in an eeprom.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
- set in to_dfu_mode() f_dfu->dfu_state = DFU_STATE_dfuIDLE
as after every to_dfu_mode call this is done, so move
this into to_dfu_mode
- switch in dfu_bind() into dfu mode:
This fixes wrong "dfu-util -l" output, when calling
"dfu-util -l" after a board reset, without doing a
download before. See also discussion here:
http://lists.denx.de/pipermail/u-boot/2013-June/157272.html
Cc: Samuel Egli <samuel.egli@siemens.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
This patch memcpy is used instead of an assignment to
avoid unaligned access execption on some ARM platforms.
CC: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Heiko Schocher <hs@denx.de>
This patch use get|put_unaligned_le16 to access structure data
to avoid data abort on some ARM platforms.
Dfu transfer uses a buffer before writing data to the
raw storage device. Make the size (in bytes) of this buffer
configurable through environment variable "dfu_bufsiz".
Defaut value is configurable through CONFIG_SYS_DFU_DATA_BUF_SIZE
Acked-by: Tom Rini <trini@ti.com>
Currently we have the following on boot:
CPU: Freescale i.MX28 rev1.2 at 454 MHz
BOOT: SSP SD/MMC #0, 3V3
DRAM: 128 MiB
MMC: MXS MMC: 0
Video: MXSFB: 'videomode' variable not set!In: serial
Break the line of the warning message in order to have a better reading format.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type,
which is required to represent block numbers for storage devices that
exceed 2TiB (the block size usually is 512B), e.g. recent hard drives.
For some obscure reason, the current U-Boot code uses lbaint_t for the
number of blocks to read (a rather optimistic estimation of how RAM
sizes will evolve), but not for the starting address. Trying to access
blocks beyond the 2TiB boundary will simply wrap around and read a
block within the 0..2TiB range.
We now use lbaint_t for block start addresses, too. This required
changes to all block drivers as the signature of block_read(),
block_write() and block_erase() in block_dev_desc_t changed.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
The spi clock divisor is of the form x * (2**y), or x << y, where x is
1 to 16, and y is 0 to 15. Note the similarity with floating point numbers.
Convert the desired divisor to the smallest number which is >= desired divisor,
and can be represented in this form. The previous algorithm chose a divisor
which could be almost twice as large as needed.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Fix two issues with the calculation of pre_div and post_div:
1. pre_div: While the calculation of pre_div looks correct, to set the
CONREG[15-12] bits pre_div needs to be decremented by 1:
The i.MX 6Dual/6Quad Applications Processor Reference Manual (IMX6DQRM
Rev. 0, 11/2012) states:
CONREG[15-12]: PRE_DIVIDER
0000 Divide by 1
0001 Divide by 2
0010 Divide by 3
1101 Divide by 14
1110 Divide by 15
1111 Divide by 16
I.e. if we want to divide by 2, we have to write 1 to CONREG[15-12].
2. In case the post divider becomes necessary, pre_div will be divided by
16. So set pre_div to 16, too. And not 15.
Both issues above are tested using the following examples:
clk_src = 60000000 (60MHz, default i.MX6 ECSPI clock)
a) max_hz == 23000000 (23MHz, max i.MX6 ECSPI read clock)
-> pre_div = 3 (divide by 3 => CONREG[15-12] == 2)
-> post_div = 0 (divide by 1 => CONREG[11- 8] == 0)
=> 60MHz / 3 = 20MHz SPI clock
b) max_hz == 2000000 (2MHz)
-> pre_div = 16 (divide by 16 => CONREG[15-12] == 15)
-> post_div = 1 (divide by 2 => CONREG[11- 8] == 1)
=> 60MHz / 32 = 1.875MHz SPI clock
c) max_hz == 1000000 (1MHz)
-> post_div = 2 (divide by 4 => CONREG[11- 8] == 2)
=> 60MHz / 64 = 937.5kHz SPI clock
d) max_hz == 500000 (500kHz)
-> post_div = 3 (divide by 8 => CONREG[11- 8] == 3)
=> 60MHz / 128 = 468.75kHz SPI clock
This patch adds the driver for keyboard that's controlled by ChromeOS EC.
Signed-off-by: Randall Spangler <rspangler@chromium.org>
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Hung-ying Tyan <tyanh@chromium.org>
This patch adds LPC support for carrying out the cros_ec protocol.
This patch adds SPI support for carrying out the cros_ec protocol.
