This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
This driver was never converted to NET_MULTI, and no board uses it.
So punt it and be done.
These drivers have never been converted to NET_MULTI, and they are only
used by one board (BMW). So drop the drivers until someone feels like
rewriting them for NET_MULTI support.
Rather than punting the BMW board completely, just disable net support
in its board config. Seems to build fine without it.
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
* 'master' of git://git.denx.de/u-boot-nand-flash:
PPC: Fix socrates NAND problem
PPC: Fix fsl_upm.c by renaming nand handling functions
NAND: Make page, erase, oob size available via cmd_nand
mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi
NAND: Add -y option to nand scrub command
NAND: Add nand read.raw and write.raw commands
NAND: Really ignore bad blocks when scrubbing
spl, nand: add 4bit HW ecc oob first nand_read_page function
mxc_nand: fix a problem writing more than 32MB
mxc_nand: fixed some typos (cosmetic)
nand: increase chip_delay in mv kirkwood nand driver
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/p3060: Add SoC related support for P3060 platform
powerpc/85xx: Add support for setting up RAID engine liodns on P5020
powerpc/85xx: Refactor some defines out of corenet_ds.h
fm-eth: Add ability for board code to disable a port
powerpc/mpc8548: Add workaround for erratum NMG_LBC103
powerpc/mpc8548: Add workaround for erratum NMG_DDR120
powerpc/mpc85xxcds: Fix PCI speed
powerpc/mpc8548cds: Fix booting message
powerpc/p4080: Add support for secure boot flow
powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH
powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards
powerpc/p2041rdb: remove watch dog related codes
powerpc/p2041rdb: updated description of cpld command
powerpc/p2041rdb: add more ddr frequencies support
powerpc/p2041rdb: set sysclk according to status of physical switch SW1
powerpc/p2041rdb: update cpld reset command according to CPLD 2.0
powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver
powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver
powerpc/mpc8xxx: Add DDR2 to unified DDR driver
powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps()
powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots
powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en
powerpc/85xx: Refactor P2041RDB to use common p_corenet files
powerpc/85xx: refactor common P-Series CoreNet files for FSL boards
powerpc/85xx: Enable CMD_REGINFO on corenet boards
powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries
powerpc/85xx: Fix USB protocol definitions for P1020RDB
powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM
powerpc/mpc8xxx: Move DDR RCW overriding to common code
powerpc/mpc8xxx: Extend CWL table
powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536
powerpc/85xx: Cleanup extern in corenet_ds board code
powerpc/p2041rdb: Add ethernet support on P2041RDB board
powerpc/85xx: Add networking support to P1023RDS
powerpc/hydra: Add ethernet support on P5020/P3041 DS boards
powerpc/85xx: Add FMan ethernet support to P4080DS
powerpc/85xx: Add support for FMan ethernet in Independent mode
powerpc/mpc8548cds: Cleanup mpc8548cds.c
powerpc/mp: add support for discontiguous cores
powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries
fdt: Add new fdt_create_phandle helper
fdt: Rename fdt_create_phandle to fdt_set_phandle
powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set
fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010)
powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC)
fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010)
powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M
powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB
nand: Freescale Integrated Flash Controller NAND support
powerpc/85xx: Add basic support for P1010RDB
powerpc/85xx: Add support for new P102x/P2020 RDB style boards
powerpc/85xx: relocate CCSR before creating the initial RAM area
powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros
powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0
powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
* 'master' of git://git.denx.de/u-boot-i2c:
I2C: mv_i2c: fix multi-bus init issue
I2C: mv_i2c: fix build issue when enable debug option
This avoids colision with nand subsystem's functions.
Cc: Scott Wood <scottwood@freescale.com>
The eLBC NAND driver currently follows up each program/write operation with a
read-back of the page, in order to [ostensibly] fill in ECC data for the
caller. However, the page address used for this read is always -1, so the read
will never work correctly. Remove this useless (and potentially problematic)
block of code.
v2: fix broken mailer
Signed-off-by: mhench <mhench@elutions.com>
Cc: Detlev Zundel <dzu@denx.de>
[scottwood@freescale.com: use chip instead of redundant priv_nand]
When writing 0x4000 to the unlockend_blkaddr register, large writes to
a 2k page NAND sometimes fail. The current kernel driver writes 0xFFFF
to this register for V2 of the nand controller.
However on an i.MX31 this also fixes writes larger than 32MB.
The datasheet is very unspecific, but (0x4000=16384)*2000
roughly fits the limits we're encountering with NAND writes.
This problem might be NAND chip specific.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The new SAMSUNG NAND Flash K9F1G08U0D require a bigger chip_delay.
The Data Transfer from Cell to Register is >= 35us. Other Vendors
and older chips normally use >= 25us. To have enough margin 40us
is selected.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Stefan Roese <sr@denx.de>
Add P3060 SoC specific information:cores setup, LIODN setup, etc
The P3060 SoC combines six e500mc Power Architecture processor cores with
high-performance datapath acceleration architecture(DPAA), CoreNet fabric
infrastructure, as well as network and peripheral interfaces.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
The SoC configuration may have more ports enabled than a given board
actually can utilize. Add a routinue that allows the board code to
disable a port that it knows isn't being used.
fm_disable_port() needs to be called before cpu_eth_init().
When enable the multi-bus, the current_bus is not inited in the original
implementation, which make the i2c operation unpredicatable.
Signed-off-by: Lei Wen <leiwen@marvell.com>
When DEBUG_I2C is open, the following build issue would shows up.
mv_i2c.c: In function 'i2c_transfer':
mv_i2c.c:257: error: 'ISR' undeclared (first use in this function)
mv_i2c.c:257: error: (Each undeclared identifier is reported only once
mv_i2c.c:257: error: for each function it appears in.)
Every emaclite instance use own setting.
Use dev->iobase instead of baseaddress.
Simplify driver logic and clear eth_device structure
in one command.
Cleanup structure.
Current xilinx emaclite use net multi registration
but doesn't support several emaclites interfaces.
Changing driver name with adding address to name
is the first step how to distiguish several drivers.
vmt.c: In function ‘ubi_free_volume’:
vmt.c:681:6: warning: variable ‘err’ set but not used
[-Wunused-but-set-variable]
nand_bbt.c: In function ‘search_bbt’:
nand_bbt.c:465:6: warning: variable ‘bits’ set but not used
ipu_disp.c: In function ‘ipu_disp_set_global_alpha’:
ipu_disp.c:1237:11: warning: variable ‘flow’ set but not used
ipu_disp.c: In function ‘ipu_disp_set_color_key’:
ipu_disp.c:1302:16: warning: variable ‘flow’ set but not used
There are some locations in the code which anticipate printf() being called
before the console is ready by squelching printf() on gd->have_console.
Move this squelching into printf(), vprintf(), puts() and putc(). Also
make tstc() and getc() return 0 if console is not yet initialised
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
If CONFIG_SYS_NS16550_MEM32 is defined then 32 bit memory
mapped access will be used to read/write the uart registers.
This is especially useful for SoC devices that implement 16550
compatible uarts but that have peripheral access width constraints.
Signed-off-by: Dave Aldridge <fovsoft@gmail.com>
* 'sf' of git://git.denx.de/u-boot-blackfin:
sf: eon: add support for EN25Q32B parts
cmd_sf: add "update" subcommand to do smart SPI flash update
mxc_ata.c: In function ‘set_ata_bus_timing’:
mxc_ata.c:118: warning: dereferencing type-punned pointer will break
strict-aliasing rules
mxc_ata.c:125: warning: dereferencing type-punned pointer will break
mxc_ata.c:129: warning: dereferencing type-punned pointer will break
Rewrite the mxc_i2c driver.
* This version is much closer to Linux implementation.
* Fixes IPG_PERCLK being incorrectly used as clock source
* Fixes behaviour of the driver on iMX51
* Clean up coding style a bit ;-)
Cc: Jason Hui <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linro.org>
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Jason Liu <jason.hui@linro.org>
Cc: Ben Warren <biggerbadderben@gmail.com>
This patch allows user to register multiple FEC controllers. To preserve
compatibility with older boards, the mxcfec_register() call is still in place.
To use multiple controllers, new macro is in place, the mxcfec_register_multi(),
which takes more arguments. The syntax is:
mxcfec_register_multi(bd, FEC ID, FEC PHY ID on the MII bus, base address);
To disable the fecmxc_register() compatibility stuff, define the macro
CONFIG_FEC_MXC_MULTI. This will remove the requirement for defining IMX_FEC_BASE
and CONFIG_FEC_MXC_PHYADDR.
The default is MII100, which was hardcoded previously in the driver.
This is cosmetic patch for the help message:
Before:
pmic dump [numregs] dump registers
After:
pmic dump [numregs] - dump registers
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Once the MDIO state machine has been initialized and enabled, it
starts polling all 32 PHY addresses on the MDIO bus, looking for
an active PHY. Add a 5 ms delay, so all PHYs are for sure detected.
This problem was detected on the cmc board with a KSZ8864 switch.
The PHY driver was too verbose and corrupted the boot message display
like this:
Net: Ethernet PHY: KSZ8873 @ 0x02
DaVinci-EMAC
Turn printf() into debug() so we get the expected output again:
Net: DaVinci-EMAC
cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Config VMMC voltage to 3V for MMC/SD card slot
and PBIAS settings needed for OMAP4
Fixes MMC/SD detection on boot from eMMC.
Signed-off-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Aneesh V <aneesh@ti.com>
Enable high capacity to host capability.
Fixes eMMC detection on boot from MMC/SD card.
Adds NAND library to SPL.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Acked-by: Scott Wood <scottwood@freescale.com>
