Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
When applying the AT91CAP9 patches upstream, something transformed
the '@' character into the ' <at> ' sequence.
The patch below restores the original form in all the places where
it has been modified (the AT91CAP9 files, the AT91SAM9260 files which
were copied from AT91CAP9, and a couple of other files where the
' <at> ' sequence was present).
Signed-off-by: Stelian Pop <stelian@popies.net>
The Vitesse VSC8601 RGMII PHY has internal delay for both Rx
and Tx clock lines. They are configured using 2 bits in extended
register 0x17.
Therefore CFG_VSC8601_SKEW_TX and CFG_VSC8601_SKEW_RX have
been introduced with valid values 0-3 giving 0.0, 1.4,1.7 and 2.0ns delay.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Andy Fleming <afleming@freescale.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
drivers/net/tsec.c | 6 ++++++
drivers/net/tsec.h | 3 +++
2 files changed, 9 insertions(+), 0 deletions(-)
This patch fixes a problem with the month being read and written
incorrectly (offset by one). This only gets visible by also using
the Linux driver (rtc-m41t80).
Tested on AMCC Canyonlands.
Onenand needs a version of memcpy() which performs 16 bit accesses
only; make sure the name does not conflict with the standard
function.
The ethernet hang is caused by receiving buffer in DRAM is not
yet ready due to access cycles require longer time in DRAM.
Relocate DMA buffer descriptors from DRAM to internal SRAM.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Move non-inlied functions into specific drivers file
Set get_prom as weak
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
Remove a redundant register definition, clean up some coding style
violations.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Fix multiple compiler warnings related to argument type mismatch.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch adds a configurable flash auto protection list that can be used
to make U-Boot protect flash regions in flash_init().
The idea has been discussed on the u-boot mailing list starting
on Nov 18th, 2007.
Even this patch brings a new feature it is used as a bugfix for 4xx
platforms where flash_init() does not completely protect the
monitor's flash range in all situations.
U-Boot protects the flash range from CFG_MONITOR_BASE to
(CFG_MONITOR_BASE + monitor_flash_len - 1) by default. This does not
include the reset vector at 0xfffffffc.
Example:
#define CFG_FLASH_AUTOPROTECT_LIST {{0xfff80000, 0x80000}}
This config option will auto protect the last 512k of flash that
contains the bootloader on board like APC405 and PMC405.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Bus and phys address are not always the same
pme_msg_det exists only on PCIe controllers only set it if we are a "bridge".
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Signed-off-by: Detlev Zundel <dzu@denx.de>
This patch adds two missing free()s.
This patch correctly sets the oobavail variable
and fixes a bug where the oob data was not valid when
there where multiple groups in oobfree.
First segment fixes a typo
Second segment fixes a bug where oob data may be copied incorrectly.
Third segment adds an error message when exiting due to write protect.
Forth segment fixes a bug where oobavail may be set incorrectly.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
MC13783 is a multifunction IS with an SPI interface to the host. This
driver handles the RTC controller in this chip.
This is an SPI driver for i.MX and MXC based SoCs from Freescale. So far
only implemented and tested on i.MX31, can with a modified register layout
and definitions be used for i.MX27, I think, MXC CPUs have similar SPI
controllers too.
This patch removes the board dependent parts from
"drivers/mtd/dataflash.c".
Each board relying on this, will have the appropriate
code in a new file, "partition.c" in the board directory.
board Makefiles updated to use the file.
The dataflash partitions are aligned on sector/page boundaries.
The CONFIG_NEW_DF_PARTITION was used to create named partitions
This is now the default operation, and the CONFIG variable is removed.
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
There are two NAND entries with ID 0xDC and this obviously causes problems.
In the kernel, they punted the first entry, so we should do the same.
See this upstream e-mail for more info:
http://lists.infradead.org/pipermail/linux-mtd/2007-July/018795.html
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: gururaja hebbar <gururajakr@sanyo.co.in>
Replace direct register address derefencing with accessor functions.
Restrict explicitly 32-bit bus-width, extend affected configurations
respectively.
LAN9115
LAN9116
LAN9117
LAN9215
LAN9216
LAN9217
Signed-off-by: Guennadi Liakhovetski<lg@denx.de>
Current libata.h of u-boot is out of sync from linux kernel,
this patch make it be consistent with linux kernel.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Tor Krill <tor@excito.com>
It should access with 16-bit instead of 8-bit
Now it uses the generic memcpy with 8-bit access. It means it reads wrong data from OneNAND.
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define
CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files.
This patch adds an i2c driver for Freescale i.MX processors
When the LM73 temperature sensor measures a temperature below 0 C, the
current driver does not perform sign extension, so the result returned is
512 C too high. This patch fixes the problem, and does general cleanup
of the code.
Signed-off-by: Larry Johnson <lrj@acm.org>
Some NOR flash chip from Spansion, for example, the s29ws-n MirrorBit
series require different addresses for buffered write commands. Define a
configuration option to support buffered writes on those chips. A more
elegant solution would be to automatically detect those chips by parsing
their CFI records, but that would require introduction of a fixup table
into the cfi_flash driver.
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
