When the LM73 temperature sensor measures a temperature below 0 C, the
current driver does not perform sign extension, so the result returned is
512 C too high. This patch fixes the problem, and does general cleanup
of the code.
Signed-off-by: Larry Johnson <lrj@acm.org>
Some NOR flash chip from Spansion, for example, the s29ws-n MirrorBit
series require different addresses for buffered write commands. Define a
configuration option to support buffered writes on those chips. A more
elegant solution would be to automatically detect those chips by parsing
their CFI records, but that would require introduction of a fixup table
into the cfi_flash driver.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
Add phy_info for Vitesse VSC8601.
Add config option, CFG_VSC8601_SKEWFIX, to enable RGMII skew timing compensation.
Signed-off-by: Tor Krill <tor@excito.com>
Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
This patch makes SPARC/LEON processors able to read and write
to the SMC91111 chip using the chip external I/O bus of the memory
controller. This patchs defines the standard in and out macros
expected by the SMC9111 driver.
To access that I/O bus one must set up the memory controller
(MCTRL or FTMCTRL) correctly. It is assumed that the user sets
up this correctly when the other MCTRL parameters are set up. It
can be set up from the board configuration header file.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Support for booting from internal DataFlash, external DataFlash card
or NAND flash is available.
Signed-off-by: Stelian Pop <stelian@popies.net>
DataFlash partition information has become a mess. This patch
defines a single partition scheme for Atmel DataFlashes. This partition
scheme will be used by all AT91CAP9 and AT91SAM9 boards.
This patch adds a driver for the following smsc network controllers:
LAN9115
LAN9116
LAN9117
LAN9215
LAN9216
LAN9217
This patch adds an i2c driver for Freescale i.MX processors
Add 82541ER device with latest integrated IGP2 PHY.
Introduced CONFIG_E1000_FALLBACK_MAC for NIC bring-up with empty eeprom.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
GRETH is an Ethernet 10/100 or 10/100/1000 MAC with out without
a debug link (EDCL). The GRETH core is documented in GRIP.pdf
available at www.gaisler.com.
If the GRETH has GigaBit support (GBIT, Scatter gather, checksum
offloading etc.) can be determined by a bit in the control register.
The GBIT MAC is supported by operating in GRTEH 10/100 legacy mode.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
SPARC has implemented __raw_readq, it reads 64-bit from any 32-bit address.
SPARC CPUs implement flash_read64 which calls __raw_readq.
For current SPARC architectures (LEON2 and LEON3) each read from the
FLASH must lead to a cache miss. This is because FLASH can not be set
non-cacheable since program code resides there, and alternatively disabling
cache is poor from performance view, or doing a cache flush between each
read is even poorer.
Forcing a cache miss on a SPARC is done by a special instruction "lda" -
load alternative space, the alternative space number (ASI) is processor
implementation spcific and can be found by including <asm/processor.h>.
Add entry for 512Kx16 AMD flash to jedec_table.
Read out 16bit device id if chipwidth is 16bit.
Fixed coding style after Stefans feedback
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com>
Receive FIFO level register is different in SH4A.
Because register is different, cannot occasionally receive data.
SH7780 is CPU of Renesas Technology.
This CPU has
- CPU clock 400MHz
- PCI support
- DDR-SDRAM controller
- etc ...
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
Add support to the Freescale I2C driver (fsl_i2c.c) for setting and querying
the I2C bus speed. Current 8[356]xx boards define the CFG_I2C_SPEED macro,
but fsl_i2c.c ignores it and uses conservative value when programming the
I2C bus speed.
Acked-by: Andy Fleming <afleming@freescale.com>
Add the Freescale on-chip SATA controller driver to u-boot,
The SATA controller is used on the 837x and 8315 targets,
The driver can be used to load kernel, fs and dtb.
The features list:
- 1.5/3 Gbps link speed
- LBA48, LBA28 support
- DMA and FPDMA support
- Two ports support
Signed-off-by: Dave Liu <daveliu@freescale.com>
add simple libata support in u-boot
original ata_piix driver is using IDE framework, not real
SATA framework. For now, the ata_piix driver is only used
by x86 sc520_cdp board. This patch makes the ata_piix driver
use the new SATA framework, so
- remove the duplicated command stuff
- remove the CONFIG_CMD_IDE define in the sc520_cdp.h
- add the CONFIG_CMD_SATA define to sc520_cdp.h
move the sata.h from include/ to drivers/block/ata_piix.h
move the cmd_sata.c from common/ to drivers/ata_piix.c,
the cmd_sata.c have some part of ata_piix controller drivers.
consolidate the driver to have better framework.
The default settings for RTC DS1337 keeps the OSC
output, 32,768 Hz, on. This add CFG_RTC_DS1337_NOOSC to
turn it off.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
RTL8211B sets link state register after autonegotiation complete,
so with bootdelay=0 RTL8211B will report lack of the link.
To fix this, we should wait for aneg to complete, even if the
link is currently down.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch adds basic support for Broadcom BCM5481 PHY.
RXD-RXC delay quirk comes from MPC8360E-RDK BSP source, author is
Peter Barada <peterb@logicpd.com>.
PHY drivers will use it to setup software delay between RXD and RXC
signals.
The Vitesse VSC7385 is a 5-port switch found on the Freescale MPC8349E-mITX
and other boards. A small firwmare must be uploaded to its on-board memory
before it can be enabled. This patch adds the code which uploads firmware
(but not the firmware itself).
Previously, this feature was provided by a U-Boot application that was
made available only on Freescale BSPs. The VSC7385 firmware must still
be obtained separately, but at least there is no longer a need for a separate
application.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
