Make it so we keep track of which LAWs have allocated and provide
a function (set_next_law) which can allocate a LAW for us if one is
free.
In the future we will move to doing more "dynamic" LAW allocation
since the majority of users dont really care about what LAW number
they are at.
Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them
Signed-off-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
This patch adds basic support for the TQM8548 module from TQ-Components
(http://www.tqc.de/) including DDR2 SDRAM initialisation and support for
eTSEC 3 and 4
Furthermore Flash buffer write has been enabled to speed up output to
the Flash by approx. a factor of 10.
Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de>
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This is a re-write of the NAND FSL UPM driver using the more universal
hwcontrol callback (instead of the cmdfunc callback). Here is a brief
list of furher modifications:
- For the time being, the UPM setup writing the UPM array has been
removed from the driver and must now be done by the board specific
code.
- The bus width definition in "struct fsl_upm_nand" is now in bits to
comply with the corresponding Linux driver and 8, 16 and 32 bit
accesses are supported.
- chip->dev_read is only set if fun->dev_ready != NULL, which is
required for boards not connecting the R/B pin.
- A few issue have been fixed with MxMR bit manipulation like in the
corresponding Linux driver.
Note: I think the "io_addr" field of "struct fsl_upm" could be removed
as well, because the address is already determined by
"nand->IO_ADDR_[RW]", but I'm not 100% sure.
This patch has been tested on a TQM8548 modules with the NAND chip
Micron MT29F8G08FABWP.
This patch is based on the following patches posted to this list a few
minutes ago:
PPC: add accessor macros to clear and set bits in one shot
83xx/85xx/86xx: add more MxMR local bus definitions
Acked-by: Anton Vorontsov <avorontsov@ru.mvista.com>
On AD7414 the first value upon bootup is not read correctly.
This is most likely because of the 800ms update time of the
temp register in normal update mode. To get current values
each time we issue the "dtt" command including upon powerup
we switch into one-short mode.
This patch fixes the problem on AD7414 equipped boards (Sequoia,
Canyonlands etc), that temp value printed in the bootup log was
incorrect.
This adds a new SPI flash subsystem.
Currently, only AT45 DataFlash in non-power-of-two mode is supported,
but some preliminary support for other flash types is in place as
well.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
This adds a driver for the SPI controller found on most AT91 and AVR32
chips, implementing the new SPI API.
Changed in v4:
- Update to new API
- Handle zero-length transfers appropriately. The user may send a
zero-length SPI transfer with SPI_XFER_END set in order to
deactivate the chip select after a series of transfers with chip
select active. This is useful e.g. when polling the status
register of DataFlash.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
This patch gets rid of the spi_chipsel table and adds a handful of new
functions that makes the SPI layer cleaner and more flexible.
Instead of the spi_chipsel table, each board that wants to use SPI
gets to implement three hooks:
* spi_cs_activate(): Activates the chipselect for a given slave
* spi_cs_deactivate(): Deactivates the chipselect for a given slave
* spi_cs_is_valid(): Determines if the given bus/chipselect
combination can be activated.
Not all drivers may need those extra functions however. If that's the
case, the board code may just leave them out (assuming they know what
the driver needs) or rely on the linker to strip them out (assuming
--gc-sections is being used.)
To set up communication parameters for a given slave, the driver needs
to call spi_setup_slave(). This returns a pointer to an opaque
spi_slave struct which must be passed as a parameter to subsequent SPI
calls. This struct can be freed by calling spi_free_slave(), but most
driver probably don't want to do this.
Before starting one or more SPI transfers, the driver must call
spi_claim_bus() to gain exclusive access to the SPI bus and initialize
the hardware. When all transfers are done, the driver must call
spi_release_bus() to make the bus available to others, and possibly
shut down the SPI controller hardware.
spi_xfer() behaves mostly the same as before, but it now takes a
spi_slave parameter instead of a spi_chipsel function pointer. It also
got a new parameter, flags, which is used to specify chip select
behaviour. This may be extended with other flags in the future.
This patch has been build-tested on all powerpc and arm boards
involved. I have not tested NIOS since I don't have a toolchain for it
installed, so I expect some breakage there even though I've tried
fixing up everything I could find by visual inspection.
I have run-time tested this on AVR32 ATNGW100 using the atmel_spi and
DataFlash drivers posted as a follow-up. I'd like some help testing
other boards that use the existing SPI API.
But most of all, I'd like some comments on the new API. Is this stuff
usable for everyone? If not, why?
Changed in v4:
- Build fixes for various boards, drivers and commands
- Provide common struct spi_slave definition that can be extended by
drivers
- Pass a struct spi_slave * to spi_cs_activate and spi_cs_deactivate
- Make default bus and mode build-time configurable
- Override default SPI bus ID and mode on mx32ads and imx31_litekit.
Changed in v3:
- Add opaque struct spi_slave for controller-specific data associated
with a slave.
- Add spi_claim_bus() and spi_release_bus()
- Add spi_free_slave()
- spi_setup() is now called spi_setup_slave() and returns a
struct spi_slave
- soft_spi now supports four SPI modes (CPOL|CPHA)
- Add bus parameter to spi_setup_slave()
- Convert the new i.MX32 SPI driver
- Convert the new MC13783 RTC driver
Changed in v2:
- Convert the mpc8xxx_spi driver and the mpc8349emds board to the
new API.
Tested-by: Guennadi Liakhovetski <lg@denx.de>
* The cfi_flash.c memset fix actual allows the board to boot so there is
a bit more going on here than just resolving warnings associated with
uninitialized variables.
* include/asm/bitops.h:302: warning: '__swab32p' is static but used in
inline function 'ext2_find_next_zero_bit' which is not static
For NAND erase sizes smaller than one NAND erase block, erase
percentage output becomes grater than 100% e.g.
-- cut --
> nand info
Device 0: NAND 64MiB 1,8V 8-bit, sector size 16 KiB
> nand erase 0x100000 0x2000
NAND erase: device 0 offset 0x100000, size 0x2000
Erasing at 0x100000 -- 200% complete.
OK
-- cut --
Correct this and give user a warning that more is erased than specified:
-- cut --
Warning: Erase size 0x00002000 smaller than one erase block 0x00004000
Erasing 0x00004000 instead
Erasing at 0x100000 -- 100% complete.
OK
-- cut --
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Merge branch 'testing-V2'
board/atmel/at91cap9adk/Makefile
Fixing copyright
board/atmel/at91sam9260ek/Makefile
Fixing copyright
board/atmel/at91sam9260ek/u-boot.lds
Delete no more needed ld script
Signed-off-by: Christian Eggers <ceggers@gmx.de>
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Add new configuration variable CONFIG_PCI_OHCI_DEVNO.
In case of several PCI USB controllers on a board this variable
specifys which controller to use.
Also add USB support for sokrates board.
See doc/README.generic_usb_ohci for details.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This reverts commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2
which broke many PowerPC boards.
This patch adds support for the ATMEL LCDC driver which is used on some
AT91 and AVR platforms.
Is has been tested with the AT91CAP9ADK, AT91SAM9261EK, AT91SAM9263EK and
AT91SAM9RLEK boards. Adaptation for AVR32 should probably be easy.
Signed-off-by: Stelian Pop <stelian@popies.net>
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK
board.
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK
board.
Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
When applying the AT91CAP9 patches upstream, something transformed
the '@' character into the ' <at> ' sequence.
The patch below restores the original form in all the places where
it has been modified (the AT91CAP9 files, the AT91SAM9260 files which
were copied from AT91CAP9, and a couple of other files where the
' <at> ' sequence was present).
The Vitesse VSC8601 RGMII PHY has internal delay for both Rx
and Tx clock lines. They are configured using 2 bits in extended
register 0x17.
Therefore CFG_VSC8601_SKEW_TX and CFG_VSC8601_SKEW_RX have
been introduced with valid values 0-3 giving 0.0, 1.4,1.7 and 2.0ns delay.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Andy Fleming <afleming@freescale.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
drivers/net/tsec.c | 6 ++++++
drivers/net/tsec.h | 3 +++
2 files changed, 9 insertions(+), 0 deletions(-)
This patch fixes a problem with the month being read and written
incorrectly (offset by one). This only gets visible by also using
the Linux driver (rtc-m41t80).
Tested on AMCC Canyonlands.
Onenand needs a version of memcpy() which performs 16 bit accesses
only; make sure the name does not conflict with the standard
function.
The ethernet hang is caused by receiving buffer in DRAM is not
yet ready due to access cycles require longer time in DRAM.
Relocate DMA buffer descriptors from DRAM to internal SRAM.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Move non-inlied functions into specific drivers file
Set get_prom as weak
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
Remove a redundant register definition, clean up some coding style
violations.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Fix multiple compiler warnings related to argument type mismatch.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch adds a configurable flash auto protection list that can be used
to make U-Boot protect flash regions in flash_init().
The idea has been discussed on the u-boot mailing list starting
on Nov 18th, 2007.
Even this patch brings a new feature it is used as a bugfix for 4xx
platforms where flash_init() does not completely protect the
monitor's flash range in all situations.
U-Boot protects the flash range from CFG_MONITOR_BASE to
(CFG_MONITOR_BASE + monitor_flash_len - 1) by default. This does not
include the reset vector at 0xfffffffc.
Example:
#define CFG_FLASH_AUTOPROTECT_LIST {{0xfff80000, 0x80000}}
This config option will auto protect the last 512k of flash that
contains the bootloader on board like APC405 and PMC405.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Bus and phys address are not always the same
pme_msg_det exists only on PCIe controllers only set it if we are a "bridge".
Signed-off-by: Detlev Zundel <dzu@denx.de>
This patch adds two missing free()s.
This patch correctly sets the oobavail variable
and fixes a bug where the oob data was not valid when
there where multiple groups in oobfree.
First segment fixes a typo
Second segment fixes a bug where oob data may be copied incorrectly.
Third segment adds an error message when exiting due to write protect.
Forth segment fixes a bug where oobavail may be set incorrectly.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
MC13783 is a multifunction IS with an SPI interface to the host. This
driver handles the RTC controller in this chip.
This is an SPI driver for i.MX and MXC based SoCs from Freescale. So far
only implemented and tested on i.MX31, can with a modified register layout
and definitions be used for i.MX27, I think, MXC CPUs have similar SPI
controllers too.
This patch removes the board dependent parts from
"drivers/mtd/dataflash.c".
Each board relying on this, will have the appropriate
code in a new file, "partition.c" in the board directory.
board Makefiles updated to use the file.
The dataflash partitions are aligned on sector/page boundaries.
The CONFIG_NEW_DF_PARTITION was used to create named partitions
This is now the default operation, and the CONFIG variable is removed.
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
There are two NAND entries with ID 0xDC and this obviously causes problems.
In the kernel, they punted the first entry, so we should do the same.
See this upstream e-mail for more info:
http://lists.infradead.org/pipermail/linux-mtd/2007-July/018795.html
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
