path: root/drivers
2018-04-03spl: nand: sunxi: make the reset column helper more genericMiquel Raynal
Prepare the future use of an helper to move the data pointer (the column) of the NAND chip by renaming nand_reset_column() to nand_change_column(). Resetting the column is just a matter of giving 0 as argument. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: ensure enough time has passed after changing the columnMiquel Raynal
When changing the column, the ONFI specification states that a minimum time of tCCS (Change Column Setup time) must elapse between the last address cycle is asserted on the bus and the first data cycle is clocked. An usual value for average NANDs is 500 nanoseconds. Round it up to 1 microsecond to be safe. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: create an helper to handle command executionMiquel Raynal
Executing a command is matter of always doing the following sequence: * Waiting for the FIFO to be empty so we can fill it with the new command. * Clearing the status register. * Writing the command in the FIFO. * Waiting for the command to finish. Add a nand_exec_cmd() helper to handle this instead of repeating the logic through the various functions. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: add missing status clearMiquel Raynal
It is best practice to always clear the status register before executing a command to be sure that the status read afterwards is relevant. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: introduce the nand_wait_cmd_fifo_empty() helperMiquel Raynal
One bit in the control registers indicates if the NAND controller is ready to receive a new command. Otherwise, the command FIFO is full and we should wait for this bit to flip. It then states that the last command has been processed and the FIFO is now free to welcome another command. Add this sanity check before starting any new command. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: introduce the nand_wait_int() helperMiquel Raynal
The pattern of polling on a status register until a bit is set or a timeout occurs is repeated multiple times in the driver. Mutualize the code by introducing the nand_wait_int() helper that does wait for the bit to flip or returns an error in case of timeout. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: fix typo on register nameMiquel Raynal
Change NFC_SEND_ADR to NFC_SEND_ADDR. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03spl: nand: sunxi: fix second case of modulo by zero errorMiquel Raynal
In the nand_read_buffer() step, the seed is calculated by doing a modulo by conf->nseeds which is always zero when not using the randomizer (most of SLC NANDs). This situation turns out to lead to a run time freeze with certain toolchains. Derive this seed only when the randomizer is enabled (and conf->nseeds logically not zero), exactly like what has been done before with an identical situation, see commit ea3f750c73e3 ("nand: sunxi: Fix modulo by zero error"). Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-03mtd: nand: sunxi: fix ECC strength choiceMiquel Raynal
When the requested ECC strength does not exactly match the strengths supported by the ECC engine, the driver is selecting the closest strength meeting the 'selected_strength > requested_strength' constraint. Fix the fact that, in this particular case, ecc->strength value was not updated to match the 'selected_strength'. For instance, one can encounter this issue when no ECC requirement is filled in the device tree while the NAND chip minimum requirement is not a strength/step_size combo natively supported by the ECC engine. Suggested-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-03-19sunxi: Add AXP_PMIC_BUS kconfig entryJagan Teki
Add simple and meaningful kconfig option for pmic_bus.c instead of using MACH type on Makefile. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-16watchdog: omap_wdt: improve watchdog reset pathRuslan Bilovol
Remove busy looping during watchdog reset. Each polling of W_PEND_WTGR bit ("finish posted write") after watchdog reset takes 120-140us on BeagleBone Black board. Current U-Boot code has watchdog resets in random places and often there is situation when watchdog is reset few times in a row in nested functions. This adds extra delays and slows the whole system. Instead of polling W_PEND_WTGR bit, we skip watchdog reset if the bit is set. Anyway, watchdog is in the middle of reset *right now*, so we can just return. This noticeably increases performance of the system. Below are some measurements on BBB: - DFU upload over USB 15% faster - fastboot image upload 3x times faster - USB ep0 transfers with 4k packets 20% faster Signed-off-by: Ruslan Bilovol <ruslan.bilovol@gmail.com> Tested-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-16clk: at91: clk-system: add set/get_rate operationsWenyou Yang
To support set/get the clock rate, add set/get_rate operations. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2018-03-16clk: at91: add PLLADIV driverWenyou Yang
As said in the SAMA5D2 datasheet, the PLLA clock must be divided by 2 by writing the PLLADIV2 bit in PMC_MCKR, if the ratio between PCK and MCK is 3 (MDIV = 3). This is the purpose of the driver. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2018-03-16clk: at91: add USB Host clock driverWenyou Yang
Add USB clock driver to configure the input clock and the divider in the PMC_USB register to generate a 48MHz and a 12MHz signal to the USB Host OHCI. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2018-03-15Merge git://git.denx.de/u-boot-spiTom Rini
2018-03-14spi: omap3: Fix redeclared errorJagan Teki
omap3_spi_set_speed|mode redeclared bus symbol, fix the same. error: drivers/spi/omap3_spi.c: In function ‘omap3_spi_set_speed’: drivers/spi/omap3_spi.c:650:18: error: ‘bus’ redeclared as different kind of symbol struct udevice *bus = dev->parent; Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-14Merge git://git.denx.de/u-boot-sunxiTom Rini
2018-03-13arch-stm32: Factorize stm32.h for STM32F4 and F7Patrice Chotard
For STM32F4 and F7 SoCx family, a specific stm32.h file exists. Some common defines are duplicated or even unused in each of these stm32.h. Factorize all common definition in arch/arm/include/asm/stm32f.h and keep specific definitions in each arch/arm/include/asm/arch-stm32fx/stm32.h. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Add DSI clock supportPatrice Chotard
DSI clock is available on STM32F769-disco and STM32F469-disco board. Signed-off-by: Yannick Fertre <yannick.fertre@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Add set_rate for LTDC clockPatrice Chotard
Implement set_rate() for LTDC clock only, set_rate for other clocks will be added if needed. This is needed by future LTDC driver improvements. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Configure SAI PLL to generate LTDC pixel clockPatrice Chotard
Configure SAI PLL configuration to generate LTDC pixel clock on the PLLSAIR output. PLLSAI is enabled only if CONFIG_VIDEO_STM32 flag is set. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Rework SDMMC stm32_clk_get_rate() partPatrice Chotard
Rework the way SDMMC clock get rate is done in a more generic way : _ Add stm32_clk_get_pllsai_rate() which give the PLLSAI indicated output rate. _ Add stm32_clk_get_pllsai_vco_rate() which give the VCO internal rate. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: No more need of 48Mhz from PLL_SAIPatrice Chotard
Initially, 48Mhz for SDIO clock was generated from SAI pll for STM32F469 and STM32F746 SoCs, but this solution was not suitable for STM32F429 SoCs. A generic solution is to used the PLL_Q output as 48Mhz clock for all STM32F SOCs family. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Fix RCC_PLLSAICFGR mask definesPatrice Chotard
Use the correct name for RCC_PLLSAICFGR_PLLSAIx_MASK masks. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Fix stm32_clk_get_rate()Patrice Chotard
Wrong parameter was passed to stm32_clk_pll48clk_rate(). sysclk (PLL_p output value) was passed instead of VCO value. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13mmc: stm32: sdmmc2: add support for st, pin-ckinsdmmc_ckinPatrick Delaunay
This patch adds "st,pin-ckin" support to activate sdmmc_ckin feature. When using an external driver (a voltage switch transceiver), it's advised to select SDMMC_CKIN feedback clock input to sample the received data. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13mmc: stm32: sdmmc2: add hardware flow control supportPatrick Delaunay
The hardware flow control functionality is used to avoid FIFO underrun (TX mode) and overrun (RX mode) errors. The behavior is to stop SDMMC_CK during data transfer and freeze the SDMMC state machines. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13board: stm32: switch to DM STM32 timerPatrice Chotard
Use available DM stm32_timer driver instead of dedicated mach-stm32/stm32fx/timer.c. Remove all defines or files previously used for timer usage in arch/arm/include/asm/arch-stm32fx and in arch/arm/mach-stm32/stm32fx Enable DM STM32_TIMER for STM32F4/F7 and H7. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32h7: Fix prescaler for Domain 3Patrice Chotard
d1cfgr register was used to calculate the domain 3 prescaler value instead of d3cfgr. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32h7: Fix stm32_clk_get_rate() for timerPatrice Chotard
For timer clock, an additional prescaler is used which was not taken into account previously. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13clk: clk_stm32f: Fix stm32_clk_get_rate() for timerPatrice Chotard
For timer clock, an additionnal prescaler is used which was not taken into account previously. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13timer: stm32: Add timer support for STM32 SoCs familyPatrice Chotard
This timer driver is using GPT Timer (General Purpose Timer) available on all STM32 SOCs family. This driver can be used on STM32F4/F7 and H7 SoCs family Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13Merge git://git.denx.de/u-boot-rockchipTom Rini
2018-03-13Merge branch 'next' of git://git.denx.de/u-boot-videoTom Rini
2018-03-13rockchip: pwm: convert to use live dtKever Yang
use live dt api to get base addr Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-03-13rockchip: clk: rk1108: convert to use live dtKever Yang
Use live dt api to get cru base addr. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-03-13rockchip: clk: rk3328: convert to use live dtKever Yang
2018-03-13rockchip: clk: rk3288: convert to use live dtKever Yang
2018-03-13rockchip: clk: rk322x: convert to use live dtKever Yang
2018-03-13rockchip: clk: rk3188: convert to use live dtKever Yang
2018-03-13rockchip: clk: rk3036: convert to use live dtKever Yang
2018-03-13Move CONFIG_PHY_ADDR to KconfigStefan Mavrodiev
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h). Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section. After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted. - ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted. - devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig. After the changes the suspicious defconfigs passes building. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [jagan: rebased on master] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-03-13net: sun8i_emac: Fix PHY initializationSamuel Holland
The previous code tried to update the PHY parameters without waiting for autonegotiation to complete. This caused wrong values to be written to the EMAC in sun8i_adjust_link(). As a result, any commands that called eth_start() before autonegotiation completed would find the network nonfunctional. Fix this by using the correct function to start up the PHY. Signed-off-by: Samuel Holland <samuel@sholland.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-03-13mmc: sunxi: support cd-invertedHeinrich Schuchardt
With CONFIG_DM_MMC the BananaPi does not detect SD cards. The sunxi device trees use the cd-inverted property to indicate that the card detect is inverted. This property is documented in Linux kernel devicetree/bindings/mmc/mmc.txt The property is not marked as deprecated. A similar patch was posted by Tuomas but is in status "Changes Requested". https://patchwork.ozlabs.org/patch/850377/ This patch is a stripped down version of his patch. Suggested-by: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-03-13arm: sunxi: Move spl spi sunxi code to mach-sunxiJagan Teki
This SUNXI variant SPL SPI code doesn't use either SPI or SPL_FLASG subsystems due to size constraints and also placing this code in drivers/mtd/spi will unnecessary build SPI_FLASH code(if defined) which never required, hence moved to arch area. And also renamed the file according to kconfig which resembles proper name. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-13spi: omap3: Skip set_mode, set_speed from claimJagan Teki
set_mode, set_seed functions has separate function pointers in dm_spi_ops, so use them in relevent one instead of calling from claim_bus. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-13spi: atcspi200: Drop non-dm codeJagan Teki
Boards adp-ae3xx_defconfig, nx25-ae250_defconfig already enabled DM_SPI, so non-dm code make no use of it hence droped. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-09bcm283x_pl011: Flush RX queue after setting baud rateAlexander Graf
After the UART was initialized, we may still have bogus data in the RX queue if it was enabled with incorrect pin muxing before. So let's flush the RX queue whenever we initialize baud rates. This fixes a regression with the dynamic pinmuxing code when enable_uart=1 is not set in config.txt on Raspberry Pis that use pl011 for serial. Fixes: caf2233b28 ("bcm283x: Add pinctrl driver") Reported-by: Göran Lundberg <goran@lundberg.email> Reported-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de> Tested-by: Peter Robinson <pbrobinson@gmail.com> Tested-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-03-09serial_bcm283x_mu: Flush RX queue after setting baud rateAlexander Graf
After the UART was initialized, we may still have bogus data in the RX queue if it was enabled with incorrect pin muxing before. So let's flush the RX queue whenever we initialize baud rates. This fixes a regression with the dynamic pinmuxing code when enable_uart=1 is not set in config.txt. Fixes: caf2233b28 ("bcm283x: Add pinctrl driver") Reported-by: Göran Lundberg <goran@lundberg.email> Reported-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de> Tested-by: Peter Robinson <pbrobinson@gmail.com> Tested-by: Tuomas Tynkkynen <tuomas@tuxera.com>
