Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
On some platform, such as vybrid, there is no scr register,
but the dis-order excution may wrongly excute the register write.
The barrier used to prevent this.
Without the fix, flash_write_cfibuffer will terminate the erased
status check once an all-0xFF word has been found instead of
continuing the erased status check utill the first non-0xFF word.
Signed-off-by: Tao Hou <hotforest@gmail.com>
Cc: Stefan Roese <sr@denx.de>
This patch adds support for USB EHCI driver for Armada100 SOCs.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
This patch adds USB host controller's UTMI PHY interface driver for
Armada100 SOCs.
The dev->req_config flag was indicating that the forwarded
request needs to perform the usb gadget delayed status.
This is however not needed anymore, so it can be removed.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
While receiving packets from FIFO sometimes the buffer provided was
nonaligned. Fix this by taking a temporary aligned buffer and then
copying the content to nonaligned buffer.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
This patch adds the support for usb device high speed for designware peripheral.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
This patch fixes a few bugs in USB device controller driver.
The fixes are as follows
1. Adding error condition checks eg. NULL return
2. Endpoint other than endpoint 0 (control endpoint) are initialized
only if usb state machine reaches STATE_ADDRESSED or above
3. Zero length packet handling corrected
4. Dead code removed
5. Bulk out endpoint returns after servicing 1 interrupt and returns
back to service if more interrupts are pending
The earlier usb device controller driver was specific to spear platforms. This
patch implements the usb device controller driver as a generic controller which
can be reused by other platforms using this peripheral.
Common code has a mdelay() func, so use that instead of the usb-specific
wait_ms() func. This also fixes the build errors:
ohci-hcd.c: In function 'submit_common_msg':
/usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available
ohci-hcd.c:1519:9: sorry, unimplemented: called from here
ohci-hcd.c:1816:10: sorry, unimplemented: called from here
ohci-hcd.c:1827:10: sorry, unimplemented: called from here
ohci-hcd.c:1844:10: sorry, unimplemented: called from here
ohci-hcd.c:1563:11: sorry, unimplemented: called from here
ohci-hcd.c:1583:9: sorry, unimplemented: called from here
make[1]: *** [ohci-hcd.o] Error 1
musb_hcd.c: In function 'musb_submit_rh_msg':
musb_hcd.c:827:2: warning: format '%d' expects type 'int',
but argument 3 has type 'long unsigned int'
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
* 'master' of git://git.denx.de/u-boot-avr32:
atmel_mci.h: remove outdated register macros
doc/git-mailrc: add <me> to avr32 alias
ATMEL: remove old atmel_mci driver
ATMEL: use generic mmc framework
* 'sandbox' of git://git.denx.de/u-boot-blackfin:
sandbox: mark os_exit as noreturn
sandbox: add getopt support
sandbox: allow processing before main loop
sandbox: add concept of sandbox state
sandbox: disable fortification
sandbox: u-boot.lds: tweak style
sandbox: add get_{tbclk,ticks}
sandbox: enable GPIO driver
sandbox: gpio: add basic driver for simulating GPIOs
sandbox: add flags for open() call
sandbox: config: enable fdt and snprintf() options
sandbox: fdt: add support for CONFIG_OF_CONTROL
sandbox: add lseek helper
sandbox: add ifdef protection to os.h
sandbox: add required header to os.c
sandbox: sort header files in os.c
All boards are using the gen_atmel_mci driver now, so no need
to carry the old driver around.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
gen_atmel_mci works on AVR32 as well, so no need to use the legacy
mmc driver. This also has the nice side effect of being able to use
SDHC cards an those boards.
This provides a way of simulating GPIOs by setting values which are seen
by the normal gpio_get/set_value() calls.
The generalised calculation of the serial bit rate reg also applies
to sh7264, it was just the clock speed that was set incorrectly.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
EDMR_INIT_CNT holds the check count of initialization.
Since there were more same values (1000), this collected as TIMEOUT_CNT.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
SH_ETH_PHY_DELAY is not used.
Signed-off-by: Thomas Weber <weber@corscience.de>
Fixing build regressions for the Integrator I get find that a few
boards try to work around the missing declaration of
pciauto_config_init() by declaring it in the local scope. This
does not make sense when the sibling functions are in <pci.h>
so move the function to the header, ridding the build error
in the Integrator and getting rid of the local declarations
here and there.
Reported-by: Wolfgang Denk <wd@denx.de>
This moves keyboard polling logic from USB HCD drivers into USB
keyboard driver. Remove usb_event_poll() as keyboard polling was
the only user of this API. With this patch USB keyboard works with
EHCI controllers again. Tested on a tegra2 seaboard.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Fix the crash when running several times usb_init() with a USB ethernet
device plugged.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Tested-by: Wolfgang Grandegger <wg@denx.de>
* 'master' of git://git.denx.de/u-boot-nand-flash:
cmd_nand.c: Fix 'nand dump' after latest MTD resync
mtd/nand:Fix wrong usage of is_blank() in fsl_ifc_run_command
mtd/nand: Fix IFC driver to support 2K NAND page
nand: reinstate lazy bad block scanning
Revert "nand: make 1-bit software ECC configurable"
Freescale IFC NAND Machine calculates ECC on 512byte sector and same is used in
fsl_ifc_run_command() during ECC status verification. Also this sector is passed
to is_blank() for blank checking. It is wrong at first place because
is_blank()'s implementation checks for Page size and OOB area size.
is_blank() should be called per page for main and OOB area verification.
Variables name are redefined to avoid confusion between buffer and ecc sector.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
1) OOB area should be updated irrespective of NAND page size. Earlier it was
updated only for 512byte NAND page.
2) During OOB update fbcr should be equal to OOB size.
commit 2a8e0fc8b3dc31a3c571e439fbf04b882c8986be ("nand: Merge changes
from Linux nand driver") accidentally reverted commit
13f0fd94e3cae6f8a0d9fba5d367e311edc8ebde ("NAND: Scan bad blocks
lazily.").
Reinstate the change, as amended by commit
ff49ea8977b56916edd5b1766d9939010e30b181 ("NAND: Mark the BBT as scanned
prior to calling scan_bbt.").
This reverts commit 4fee6c2f295f932b8febdc7ce8731ba045695fa5.
It breaks boards that currently rely on soft-ecc, as pointed out here:
http://patchwork.ozlabs.org/patch/140872/
The reverted patch should be resubmitted with documentation, and with the
CONFIG_MTD_ECC_SOFT selected from every board that needs it. We could
start by looking at what NAND driver the board selects, and whether
that driver ever asks for soft ECC.
Boards may have things they want done before or after normal phy config.
Letting the boards call drv->config allows them more flexibilty.
Boards affected by this change are corenet_ds and mpc8544ds.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Add the gigabit phy KSZ9021.
Also, add function ksz9021_phy_extended_write
/_read for access to the phys extended registers.
The environment variable "disable_giga"
can be used to disable 1000baseTx.
Surround non PHYLIB routines miiphy_restart_aneg
and miiphy_wait_aneg with ifndef CONFIG_PHYLIB.
When later PHYLIB is required it is easy to delete
the non-PHYLIB code. This separation idea
came from Andy Fleming.
fec_miiphy_read, and fec_miiphy_write changed to
fec_phy_read, and fec_phy_write with argument changes.
Deprecated miiphy_register is no longer used. Both
old and new PHYLIB code now use mdio_register.
Cleanup some debug prints.
Inline function fec_miiphy_fec_to_eth is no longer necessary.
Moved to the single call location.
Define FEC_QUIRK_ENET_MAC and add to
arch-mx6/imx-regs.h
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU
Introduce two new macros to control conditional setup
MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x)
MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x)
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Jason Liu <jason.hui@linaro.org>
This reverts commits 2faa76196af4b3e93bcb9e38ed9090cbd3b06db3 as
this has introduced some large problems on all other platforms and have
more changes in them than the commit message implies.
Cc: Patil, Rachna <rachna@ti.com>
This reverts commit 498cbdfe62a8330f6c89765bdd15e60328a26511 as we need
to revert the i2c changes that add the support for the platform.
* 'master' of git://git.denx.de/u-boot-mmc:
mmc: make mmc_send_status() more reliable
mmc: fix card busy polling
Tegra: mmc: Fixed handling of interrupts in timeouts.
omap_hsmmc: Wait for CMDI to be clear
* 'trini@ti.com' of git://git.denx.de/u-boot-staging:
usb_ether: fix typo
cmd_eeprom: typo
doc: complete, typos
Align the card status polling with the Linux kernel and retry the
command at least five times. Also some cards apparently mishandle the
status bits, so make sure to check the card state too.
Signed-off-by: Jan Kloetzke <jan.kloetzke@dspg.com>
Cc: Andy Fleming <afleming@gmail.com>
A MMC/SD card may always go into the programming state (and hence be
busy) after a block write. Therefore always check the card state, even
after single block writes. On the other hand there is no need to check
the card status after a read.
Also make sure that errors during busy polling are propagated upwards.
We are seeing occasional timeouts in the Tegra mmc code when
we are reading from external MMC cards. These don't seem to be
detrimental if they are handled properly. This CL properly
clears the "normal interrupt status register" (norintsts) in
error conditions. If we don't do this, when we come back into
mmc_send_cmd() the register will still contain status from the
last transaction.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Before we can send a command we need both the DATI (command inhibit on
mmc_dat line) bit and CMDI (command inhibit on mmc_cmd line) are clear.
The previous behavior of only checking on DATI was insufficient on some
cards and incorrect behavior in any case. This makes the code check
for both bits being clear and makes the error print more clear as
to what happened. DATI_CMDDIS is removed as it was unused elsewhere
in the code and stood for 'DATI is set, cmds are disabled still'.
Fix originally spotted by Peter Bigot.
Tested-by: Peter A. Bigot <bigotp@acm.org>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Andreas Müller <schnitzeltony@googlemail.com>
