path: root/drivers
2016-01-24x86: ivybridge: Use the I2C driver to perform SMbus initSimon Glass
Move the init code into the I2C driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: i2c: Add a stub driver for Intel I2C/SMbusSimon Glass
This is used on most Intel platforms. We don't have a driver for it yet, but add a stub to handle the init. For now this targets ivybridge so we may want to add a device tree binding and generalise it when other platforms are supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24ahci: Add a disk-controller uclassSimon Glass
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or other controller types. There are no operations and no interface so far, but it is possible to probe a SATA device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: pci: Convert bios_emu to use the driver model PCI APISimon Glass
At present this BIOS emulator uses a bus/device/function number. Change it to use a device if CONFIG_DM_PCI is enabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: syscon: Allow finding devices by driver dataSimon Glass
We have a way to find a regmap by its syscon driver data value. Add the same for syscon itself. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: usb: Add a compatible string for PCI EHCI controllerSimon Glass
Add a compatible string to allow this to be specified in the device tree if needed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: core: Display the error number when driver binding failsSimon Glass
This is often -96 (-EPFNOSUPPORT) which indicates that the uclass is not compiled in. Display the error number to make this easier to spot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: spi: Convert ICH SPI driver to driver model PCI APISimon Glass
At present this SPI driver works by searching the PCI buses for its peripheral. It also uses the legacy PCI API. In addition the driver has code to determine the type of Intel PCH that is used (version 7 or version 9). Now that we have proper PCH drivers we can use those to obtain the information we need. While the device tree has a node for the SPI peripheral it is not in the right place. It should be on the PCI bus as a sub-peripheral of the LPC device. Update the device tree files to show the SPI controller within the PCH, so that PCI access works as expected. This patch includes Bin's fix-up patch from here: https://patchwork.ozlabs.org/patch/569478/ Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24spi: ich: Separate out the read/write trace from normal debuggingSimon Glass
The trace is seldom useful for basic debugging. Allow it to be enabled separately so that it is easier to see the more important init and error debug messages. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Add a driver for Intel PCH9Simon Glass
At some point we may need to distinguish between different types of PCHs, but for existing supported platforms we only need to worry about version 7 and version 9 bridges. Add a driver for the PCH9. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Add a driver for Intel PCH7Simon Glass
At some point we may need to distinguish between different types of PCHs, but for existing supported platforms we only need to worry about version 7 and version 9 bridges. Add a driver for the PCH7. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: Expand the uclass for Platform Controller Hubs (PCH)Simon Glass
A Platform Controller Hub is an Intel concept - it is like the peripherals on an SoC and is often in a separate chip from the CPU. The chip is typically found on the first PCI bus and integrates multiple devices. We have a very simple uclass to support PCHs. Add a few operations, such as setting up the devices on the PCH and finding the SPI controller base address. Also move it into drivers/pch/ since we will be adding a few PCH drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: pci: Avoid using pci_bus_to_hose() in the uclassSimon Glass
This function is only available for compatibility with old code. Avoid using it in the uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: pci: Add a function to write a BARSimon Glass
Add a driver-model version of the pci_write_bar32 function so that this is supported in the new API. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: pci: Move pci_bus_to_hose() to compatibilitySimon Glass
This function should not be used by driver-model code, so move it to the compatibility portion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-21rockchip: spl: Support full-speed CPU in SPLSimon Glass
Add a feature which speeds up the CPU to full speed in SPL to minimise boot time. This is only supported for certain boards (at present only jerry). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: rk3288: pinctrl: Fix HDMI pinctrlSimon Glass
Since the device tree does not specify the EDID pinctrl option for HDMI we must set it manually. Fix the driver to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: rk3288: clock: Fix various minor errorsSimon Glass
Fix a number of small errors which were found in reviewing the clock code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: video: Add a video-output driverSimon Glass
Some rockchip SoCs include video output (VOP). Add a driver to support this. It can output via a display driver (UCLASS_DISPLAY) and currently HDMI and eDP are supported. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: video: Add a display driver for rockchip eDPSimon Glass
Some Rockchip SoCs support embedded DisplayPort output. Add a display driver for this so that these displays can be used on supported boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: video: Add a display driver for rockchip HDMISimon Glass
Some Rockchip SoCs support HDMI output. Add a display driver for this so that these displays can be used on supported boards. Unfortunately this driver is not fully functional. It cannot reliably read EDID information over HDMI. This seems to be due to the clocks being incorrect - the I2C bus speed appears to be up to 100x slower than the clock settings indicate. The root cause may be in the clock logic. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: clk: Add support for clocks needed by the displaysSimon Glass
The displays need to use NPLL and also select some new peripheral clocks. Add support for these to the clock driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Rename the CRU_MODE_CON fieldsSimon Glass
These should match the datasheet naming. Adjust them. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: video: Repurpose the 'displayport' uclass to 'display'Simon Glass
The current DisplayPort uclass is too specific. The operations it provides are shared with other types of output devices, such as HDMI and LVDS LCD displays. Generalise the uclass so that it can be used with these devices as well. Adjust the uclass to handle the EDID reading and conversion to display_timing internally. Also update nyan-big which is affected by this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21video: panel: Add a simple panel driverSimon Glass
Most panels are very simple - they just have a power supply and a backlight. Add a driver which supports this and implements the enable_backlight() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: panel: Add a panel uclassSimon Glass
LCD panels can usefully be modelled as their own uclass. They can be probed (which powers them up ready for use). If they have a backlight, this can be enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: backlight: Add a driver for a PWM backlightSimon Glass
Many backlights need to use a PWM to control the brightness. Add a driver for this. It understands the standard device tree binding. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: backlight: Add a backlight uclassSimon Glass
LCD panels normally have a backlight which can be controlled to illuminate the LCD contents. Add a uclass to support this. Initially it only has a method to enable the backlight. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21pwm: rockchip: Add a PWM driver for Rockchip SoCsSimon Glass
Add a simple driver which implements the standard PWM uclass interface. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pwm: Add a PWM uclassSimon Glass
Add a uclass that supports Pulse Width Modulation (PWM) devices. It provides methods to enable/disable and configure the device. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21video: bridge: Allow GPIOs to be optionalSimon Glass
Some video bridges will not have GPIOs to control reset, etc. Allow these to be optional. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21video: Add a function to control cache flushingSimon Glass
Allow the cache-flushing function of a video device to be controlled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21video: Name consoles by their numberSimon Glass
We must use the console name in the 'stdout' variable to select the one we want. At present the name is formed from the driver name with a suffix indicating the rotation value. It seems better to name them sequentially since this can be controlled by driver order. So adjust the code to use 'vidconsole' for the first, 'vidconsole1' for the second, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spi: Remove the explicit pinctrl settingSimon Glass
The correct pinctrl is handled automatically so we don't need to do it in the driver. The exception is when we want to use a different chip select (other than 0). But this isn't used at present. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spi: Correct chip-enable codeSimon Glass
At present there is an incorrect call to rkspi_enable_chip(). It should be disabling the chip, not enabling it. Correct this and ensure that the chip is disabled when releasing the bus. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spi: Implement the delaysSimon Glass
Some devices need delays before and after activiation. Implement these features in the SPI driver so that we will be able to enable the Chrome OS EC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: gpio: Implement the get_function() methodSimon Glass
Provide this method so that 'gpio status' works fully. It now shows whether a pin is used for input, output or some other function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: gpio: Read the GPIO value correctlySimon Glass
This function should return 0 or 1, not a mask. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: pinctrl: Implement the get_gpio_mux() methodSimon Glass
Implement this so that the GPIO command will be able to report whether a GPIO is used for input or output. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: pinctrl: Reduce the size for SPLSimon Glass
This file has many features that are not needed by SPL. Use #ifdef to remove the unused features and reduce the code size. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: clk: Make rkclk_get_clk() SoC-specificSimon Glass
The current method assumes that clocks are numbered from 0 and we can determine a clock by its number. It is safer to use an ID in the clock's platform data to avoid the situation where another clock is bound before the one we expect. Move the existing code into rk3036 since it still works there. Add a new implementation for rk3288. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spi: Correct the bus init codeSimon Glass
Two of the init values are created locally so cannot be out of range. The masking is unnecessary and in one case is incorrect. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spi: Remember the last speed to avoid re-setting itSimon Glass
Rather than changing the clock to the same value on every transaction, remember the last value and don't adjust the clock unless it is necessary. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: clk: Add a simple version of clk_get_by_index()Simon Glass
This function adds quite a bit of code to SPL and we probably don't need all the features in SPL. Add a simple version (for SPL only) to save space. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: power: Allow regulators to not implement all operationsSimon Glass
Some regulators will not implement any operations (e.g. fixed regulators). This is not an error, so allow the autoset process to continue when one of these regulators is found. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: power: Tidy up debugging output and return valuesSimon Glass
The currect PMIC debugging is a little confusing. Adjust it so that it is clear whether the operation succeeded or failed. Also, avoid creating a new error return value when a perfectly good one is already available. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: core: Export uclass_find_device_by_of_offset()Simon Glass
It is sometimes useful to be able to find a device before probing it, perhaps to set up some platform data for it. Allow finding by of_offset also. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pinctrl: Add a way for a GPIO driver to obtain a pin functionSimon Glass
GPIO drivers want to be able to show if a pin is enabled for input, output, or is being used by another function. Some drivers can easily find this and the code is included in the driver. For some SoCs this is more complex. Conceptually this should be handled by pinctrl rather than GPIO. Most pinctrl drivers will have this feature anyway. Add a method by which a GPIO driver can obtain the pin mux value given a GPIO reference. This avoids repeating the code in two places. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: power: Allow regulators to be omitted from SPLSimon Glass
For some boards the pmic interface is useful but the regulator interface (which comes with it) is too large. Allow them to be separated such that SPL can decide which it needs. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21spi: Correct device tree usage in spi_flash_decode_fdt()Simon Glass
This function currently searches the entire device tree for a node that it thinks is relevant. But the node is known and is passed in. Correct the code and enable it only with driver model, since only driver-model boards will use it. This avoids bringing in a large number of strings from fdtdec. Signed-off-by: Simon Glass <sjg@chromium.org>
