path: root/drivers
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-niosTom Rini
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2014-02-13Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-11serial: opencores_yanu: Avoid duplicate oc_serial_setbrg() implementationAxel Lin
The implementation of oc_serial_setbrg() for CONFIG_SYS_NIOS_FIXEDBAUD and !CONFIG_SYS_NIOS_FIXEDBAUD are very similar. Add a baudrate variable and set it to either CONFIG_BAUDRATE or gd->baudrate. Then we can unify the code for both cases. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2014-02-11serial: opencores_yanu: Fix build errorAxel Lin
Fix build error due to missing include of serial.h and a trivial typo. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2014-02-07serial/serial_arc - add driver for ARC UARTAlexey Brodkin
Driver for non-standard on-chip UART, instantiated in the ARC (Synopsys) FPGA Boards such as ARCAngel4/ML50x Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-02-07cmd_mmc.c: Drop open/close mmc sub-commandsTom Rini
The open and close mmc sub-commands implement a hard-coded set of values specific to the SMDK5250 platform. Remove these commands as what they did can be done instead with a series of mmc dev / bootpart / bootbus commands instead now. Cc: Amar <amarendra.xt@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add bootbus mmc sub-commandTom Rini
Add a bootbus sub-command to the mmc command to allow for setting the boot_bus_width, reset_boot_bus_width and boot_mode fields of BOOT_BUS_WIDTH (EXT_CSD[177]). Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add 'partconf' command to mmcTom Rini
Add a partconf sub-command to the mmc command to allow for setting the boot_ack, boot_partition and partition_access fields of PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this requires changing the check for 'part' from an strncmp to a strcmp, like the rest of the sub-commands. Cc: Andy Fleming <afleming@gmail.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07mmc: Enabled quirk SDHCI_QUIRK_BROKEN_R1BSiva Durga Prasad Paladugu
As per the below commit "mmc: sdhci: add the quirk for broken r1b response" (sha1: 3a6383207be3f71b39004e64464a6e99290b16fa) need to add quirk SDHCI_QUIRK_BROKEN_R1B, when the response type is R1b. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07MMC: DWMMC: Correct the CLKDIV register valueRajeshwari S Shinde
This patch corrects the divider value written to CLKDIV register. Since SDCLKIN is divided inside controller by the DIVRATIO value set in the CLKSEL register, we need to use the same output clock value to calculate the CLKDIV value. as per user manual: cclk_in = SDCLKIN / (DIVRATIO + 1) Input parameter to mmc_clk is changed to dwmci_host, since we need the same to read DWMCI_CLKSEL register. This improves the read timing values for channel 0 on SMDK5250 from 0.288sec to 0.144sec Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07mmc: set rca to 1 for MMC cardsStephen Warren
U-Boot currently sets MMC cards' RCA register to 0. This value is reserved according to the specification. Use a value of 1 instead, just like the Linux kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07net/designware: make driver compatible with data cacheAlexey Brodkin
Up until now this driver only worked with data cache disabled. To make it work with enabled data cache following changes were required: * Flush Tx/Rx buffer descriptors their modification * Invalidate Tx/Rx buffer descriptors before reading its values * Flush cache for data passed from CPU to GMAC * Invalidate cache for data passed from GMAC to CPU Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-02-07net/designware: add explicit reset of {tx|rx}_currdescnumAlexey Brodkin
Driver "init" function might be called multiple times. On every "init" Tx/Rx buffer descriptors are initialized: "descs_init" -> "{tx|rx}_descs_init". In its turn those init functions set MAC's "{tx|rx}desclistaddr" to point on the first buffer descriptor in the list. So CPU to start operation from the first buffer descriptor as well after every "init" we have to reset "{tx|rx}_currdescnum". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-02-07blackfin: Initialize the EMAC VLAN with proper default valueAaron Wu
EMAC_VLANx regs is not properly initiallized in u-boot, once it's overwrite in the kernel when DSA enabled, hot reset will lead to bringing up EMAC fail in u-boot. Signed-off-by: Aaron Wu <Aaron.Wu@analog.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-02-06Merge branch 'fpga' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-02-06fpga: zynq: Correct fpga load when buf is not alignedNovasys Ingenierie
When ARCH_DMA_MINALIGN is greater than header size of the bit file, and buf is not aligned, new_buf address became greater then buf_start address and the load_word loop corrupts bit file data. A work around is to decrease new_buf of ARCH_DMA_MINALIGN, it might corrupt data before buf but permits to load correctly. Signed-off-by: Stany MARCEL <smarcel@novasys-ingenierie.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-06usb: mv_udc: Rename to ci_udcMarek Vasut
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Stefano Babic <sbabic@denx.de>
2014-02-06usb:gadget:f_thor: cosmetic: Remove debug memsetLukasz Majewski
Apparently debug memset (with a 0x55 value) has been overlooked in the f_thor code. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-06usb:gadget:f_thor: Allocate request up to THOR_PACKET_SIZE not ep->maxpacketLukasz Majewski
Now it is possible to allocate static request - which receives data from the host (OUT transaction) to the size of THOR packet. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-06usb:udc:samsung: Zero copy approach for data passed to Samsung's UDC driverLukasz Majewski
The Samsung's UDC driver is not anymore copying data from USB requests to aligned internal buffers. Now it works directly in data allocated in the upper layers like UMS, DFU, THOR. This change is possible since those gadgets now must take care to allocate buffers aligned to cache line (CONFIG_SYS_CACHELINE_SIZE). This can be achieved by using DEFINE_CACHE_ALIGN_BUFFER() or ALLOC_CACHE_ALIGN_BUFFER() macros. Those take care to allocate buffer aligned to cache line in both starting address and its size. Sometimes it is enough to just use memalign() with size being a multiplication of cache line size. Test condition - test HW + measurement: Trats - Exynos4210 rev.1 - test HW Trats2 - Exynos4412 rev.1 400 MiB compressed rootfs image download with `thor 0 mmc 0` Measurement: Transmission speed: 27.04 MiB/s Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-06usb:udc:samsung: Allow burst transfers for non EP0 endpintsLukasz Majewski
This patch removed obscure restriction on the HW setting of DMA transfers. Before this change each transaction sent up to 512 bytes (with packet count equal to 1) for non EP0 transfer. Now it is possible to setup DMA transaction up to DMA_BUFFER_SIZE. Test condition - test HW + measurement: Trats - Exynos4210 rev.1 - test HW Trats2 - Exynos4412 rev.1 400 MiB compressed rootfs image download with `thor 0 mmc 0` Measurement: Transmission speed: 20.74 MiB/s Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-06usb:udc:samsung: Remove redundant cache operation from Samsung UDC driverLukasz Majewski
A set of cache operations (both invalidation and flush) were redundant in the S3C HS OTG Samsung driver: 1. s3c_udc_ep0_zlp - to transmit EP0's ZLP packets one don't need to flush the cache (since it is the zero length transmission) 2. s3c_udc_pre_setup and s3c_ep0_complete_out - cache invalidation is not needed when the buffer for OUT EP0 transmission is setup, since no data has yet arrived. Cache cleanups presented above don't contribute much to transmission speed up, hence shall be regarded as cosmetic changes. 3. setdma_rx - here the s3c UDC driver's internal buffers were invalidated. This call is not needed anymore since we reuse the buffers passed from gadgets. This is a key contribution to transmission speed improvement. Test condition - test HW + measurement: Trats - Exynos4210 rev.1 - test HW Trats2 - Exynos4412 rev.1 400 MiB compressed rootfs image download with `thor 0 mmc 0` Measurements: Base values (without improvement): Transmission speed: 9.51 MiB/s After the change: Transmission speed: 10.15 MiB/s Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-06usb:gadget:ums: Replace malloc calls with memalign to fix cache buffer alignmentLukasz Majewski
Calls to malloc() have been replaced by memalign. It now provides proper buffer alignment. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-02-05serial: s5p: set automatically clears after resetting Rx FIFOInha Song
This patch fix the u-boot shell problem on TRATS2 board. - If hold the key while booting is in progress, white spaces are written in u-boot shell. Set Automatically clears after resetting Rx FIFO. Signed-off-by: Inha Song <ideal.song@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-04Merge branch 'serial' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-02-04Merge branch 'net' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-02-04serial: uartlite: Reset RX/TX in initMichal Simek
Just to be sure that there is no pending data. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-04net: axi_emac: Check if phy was correctly detectedMichal Simek
As tsec and fm drivers checking phydev->link ensure that u-boot don't try access device if link is not ready. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-03mmc: tegra: support Tegra124Stephen Warren
Tegra124's MMC controller is very similar to earlier SoC generations, and can be supported by the same driver. However, there are some non-backwards-compatible HW differences, and hence a new DT compatible value must be used to describe the HW. This patch updates the driver to support that new compatible value. That said, the HW differences are only relevant when enabling certain high-performance transfer modes. Since the driver is currently very simple and doesn't enable those modes, we don't actually need to address any of these HW differences in the code yet, hence the simple nature of this patch. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Tested-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-03driver/ifc:Change accessor function to take care of endiannessPrabhakar Kushwaha
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP. So update acessor functions with common IFC acessor functions to take care both type of endianness. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-02-03boards/t1040qds: Adds ethernet support for T1040Prabhakar Kushwaha
Enable entherent for T1040QDS. It enables FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5 Define MDIO related configs Added eth.c file Update t1040.c to support RGMII and SGMII Update t1040qds.c to support ethernet Define the PHY address Signed-off-by: Arpit Goel <B44344@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: remove dash from commit message] Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-03driver/fsl_pci:Update print to display PCIe generationPrabhakar Kushwaha
Current print only display width of PCIe device. Add print to display PCIe generation supported by the device. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-03video: exynos: fimd: add support for various display color modesPrzemyslaw Marczak
Now fimd BPP color mode depends on vl_bpp value in struct "panel_info". There is only 16BPP mode check, default mode is 24BPP. Other fimd modes are usually unneeded and also needs some fimd driver modifications and tests. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03samsung: common: Add file for common functions, draw_logo() cleanup.Przemyslaw Marczak
Changes: new file: - board/samsung/common/misc.c depends on: CONFIG_MISC_COMMON - move draw_logo() to misc.c configs: trats, trats2, universal: - enable CONFIG_MISC_COMMON, - enable CONFIG_MISC_INIT_R, - add misc_init_r() and call draw_logo() in it. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03trats2: Code cleanup.Przemyslaw Marczak
Remove wrong and unused env variables Trats2 is not as GT-I8800. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-03s5p: gpio: change gpio coding method for s5p gpio.Przemyslaw Marczak
Old s5p gpio coding method was not clean and was not working properly for all parts and banks. New method is clean and easy to extend. Gpio coding mask: 0x000000ff - pin number 0x00ffff00 - bank offset 0xff000000 - part number Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-01-24drivers: delete unused header filesMasahiro Yamada
2014-01-22esdhc: Detecting 8 bit width before mmc initializationHaijun.Zhang
The upper 4 data signals of esdhc are shared with spi flash. So detect if the upper 4 pins are assigned to esdhc before enable sdhc 8 bit width. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-22esdhc: Workaround for card can't be detected on T4240QDSHaijun.Zhang
Card detection pin is ineffective on T4240QDS Rev1.0. There are two cards can be connected to board. 1. eMMC card is built-in board, can not be removed. so For eMMC card it is always there. 2. Card detecting pin is functional for SDHC card in Rev2.0. This workaround force sdhc driver scan and initialize the card regardless of whether the card is inserted or not in case Rev1.0. Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21net/fm: revert commit 732dfe090d50af53bb682d0c8971784f8de1f90fShengzhou Liu
This patch reverts patch 'add ft_fixup_xgec to support 3rd and 4th 10GEC'. When dual-role MAC acts as 10G,it still uses fsl,fman-port-1g-rx/tx as before. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc:mpc85xx: Add ifc nand boot support for TPL/SPLPo Liu
Using the TPL method for nand boot by sram was already supported. Here add some code for mpc85xx ifc nand boot. - For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec. - Use a clear function name for nand spl boot. - Add CONFIG_SPL_DRIVERS_MISC_SUPPORT to compile the fsl_ifc.c in spl/Makefile; Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx: Revise workaround for DDR-A003York Sun
Existing workaround only handles one RDIMM on reference design. In case of two RDIMMs being used, the workaround requires two separate writes to DDR_SDRAM_MD_CNTL register. This patch also restores two debug registers changed by the workaround. Signed-off-by: York Sun <yorksun@freescale.com> CC: Ben Collins <ben.c@servergy.com> CC: James Yang <James.Yang@freescale.com>
2014-01-21powerpc/t2080qds: some update for t2080qdsShengzhou Liu
- add more serdes protocols support. - fix some serdes lanes route. - fix SGMII doesn't work and incorrect mdio display for XFI when serdes 0x6d. - correct boot location info for SD/SPI boot. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21net: gem: Check if phy was correctly detectedMichal Simek
2014-01-20Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2014-01-17nand, gpmc: fix reading after switching eccJeroen Hofstee
The omap_gpmc allows switching ecc at runtime. Since the NAND_SUBPAGE_READ flag is only set, it is kept when switching to hw ecc, which is not correct. This leads to calling chip->ecc.read_subpage which is not a valid pointer. Therefore clear the flag when switching ecc so reading in hw mode works again. Cc: Scott Wood <scottwood@freescale.com> Cc: Pekon Gupta <pekon@ti.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-01-16Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
