If ECC is not enabled, data init can be disabled to speed up booting.
Signed-off-by: York Sun <york.sun@nxp.com>
When multiple PCI cards are present in an ls2080a board, the second
card does not get its msi-map set up properly due to a bug in
computing the bus number.
The bus number returned by PCI_BDF() is not the actual PCI bus
number, but instead represents a global u-boot PCI bus number. A
given bus number is relative to hose->first_busno, so that has to be
subtracted from the PCI device id.
Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com>
Acked-by: Stuart Yoder <stuart.yoder@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Commit 34e026f9 added one extra bit to wr_lat for timing_cfg_2, but
with wrong bit position. It is bit 13 in big-endian, or left shift
18 from LSB. This error hasn't had any impact because we don't have
fast enough DDR4 using the extra bit so far.
In function check_and_invalidate_dcache_range(), there are incorrect
start address and end address of the dcache range calculated for
Layerscape platforms. This patch is to fix this issue.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
The clk_adjust is of SDRAM_CLK_CNTL[5:8] 4-bits on MPC85xx and P-series,
but is of SDRAM_CLK_CNTL[5:9] 5-bits on T-series and LS-series SoCs.
We should update it to adapt the case that clk_adjust is odd data.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com>
The index returned by get_sys_clk_index() is not exactly what we expect.
Let's not rely on that and use get_sys_clk_freq() instead.
This fixes missing USB3 devices in the Linux kernel when USB is started
in u-boot. It still doesn't fix missing USB3 devices in u-boot though.
Signed-off-by: Roger Quadros <rogerq@ti.com>
The CONFIG_OMAP1510 is no longer defined, so remove this dead code.
Acked-by: Nishanth Menon <nm@ti.com>
The ns16550 driver needs serial_in_shift() and serial_out_shift()
when compiled in debug UART mode, so shift the DM_SERIAL check a
little to make these functions available.
The MXS certainly does not support any sort of networking in GPIO code,
remove the netdev.h header.
Tegra186's MMC controller needs to be explicitly identified. Add another
compatible value for it.
Tegra186 will use an entirely different clock/reset control mechanism to
existing chips, and will use standard clock/reset APIs rather than the
existing Tegra-specific custom APIs. The driver support for that isn't
ready yet, so simply disable all clock/reset usage if compiling for
Tegra186. This must happen at compile time rather than run-time since the
custom APIs won't even be compiled in on Tegra186. In the long term, the
plan would be to convert the existing custom APIs to standard APIs and get
rid of the ifdefs completely.
The system's main eMMC will work without any clock/reset support, since
the firmware will have already initialized the controller in order to
load U-Boot. Hence the driver is useful even in this apparently crippled
state.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Tegra186's GPIO controller register layout is significantly different from
previous chips, so add a new driver for it. In fact, there are two
different GPIO controllers in Tegra186 that share a similar register
layout, but very different port mapping. This driver covers both.
The DT binding is already present in the Linux kernel (in linux-next via
the Tegra tree so far).
Reviewed-by: Simon Glass <sjg@chromium.org> # v1
Future chips will contain different GPIO HW. This change will enable
future SoC support to select the appropriate GPIO driver for their HW,
in a future-looking fashion, using Kconfig.
TEGRA_GPIO is not simply selected by TEGRA_COMMON (even though all
current Tegra chips used this GPIO HW) to simplify the later addition
of support for Tegra SoCs that use different GPIO HW.
Add ethernet driver for the AR933x and AR934x Atheros MIPS machines.
The driver could be easily extended to other WiSoCs.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Wills Wang <wills.wang@live.com>
[fixed Kconfig dependency]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
If dev->iobase is 64 bits wide then writing the value of the BAR into a
pointer to iobase will not work on big endian systems, where the BAR
value will incorrectly get written to the upper 32 bits of the 64 bit
variable. Fix this by reading the BAR into a u32, matching the type
expected by pci_read_config_dword.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fix the pcnet driver to build safely on 64 bit platforms, in preparation
for allowing MIPS64 builds for Malta boards.
Now that MIPS virt_to_phys can handle kseg1 addresses on MIPS32, stop
manually converting addresses to their kseg0 equivalents in the pcnet
driver.
For odroid-c2 (arch-meson) for now disable designware eth as meson
now needs to do some harder GPIO work.
lib/efi_loader/efi_disk.c
Modified:
configs/odroid-c2_defconfig
When offset is not aligned to page address, it is possible that extra offset
will be read from nand. Adjust the image such that first byte of the image
is at load address after the first page is read.
Detect a FIT when loading from SPI and handle it using the
new FIT SPL support.
It is pointless to build gadget driver if USB_GADGET is disabled.
This adds platform code for the Amlogic Meson GXBaby (S905) SoC and a
board definition for ODROID-C2. This initial submission only supports
UART and Ethernet (through the existing Designware driver). DTS files
are the ones submitted to Linux arm-soc for 4.7 [1].
[1] https://patchwork.ozlabs.org/patch/603583/
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
All members of the DMA descriptor must be 32-bit, even on 64-bit
architectures: change the type to u32 to ensure this. Also, fix
other warnings.
[trini: Use phys_addr_t not unsigned long long to test that we're within
DMA'able memory]
This small change tidies up the code slightly.
When these functions are not compiled in, we still need to declare the
correct function signature to avoid a build warnings in SPL. Fix this.
Allow driver model to be used for block devices in the rockchip mmc driver.
Add support for using driver model for block devices in this driver.
Update sdhci.c so that it works with driver model enabled for block devices.
Enable this option to correct display artifacts when a write-back cache is
in use.
Setup the clocks for the gmac ethernet interface. This assumes the mac
clock is fed by an external clock which is common on RK3288 based
devices.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
The rgmii_pins node in rk3288.dtsi configures 15 pins. Increase the size
of the cell array to accomedate that, otherwise only the first 10 get
configured.
Add support for the snps,reset-gpio, snps,reset-active-low (optional) and
snps,reset-delays-us device-tree bindings. The combination of these
three define how the PHY should be reset to ensure it's in a sane state.
A DM driver for PCA953x was recently introduced by Peng Fan, which lacked
support for the 40 GPIO versions.
This patch adds support for these chips.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Reviewed-by: Peng Fan <van.freenix@gmail.com>
We don't need an int since no value is over 80. This saves a small amount of
SPL space (about 44 bytes).
This function is no longer used.
This adds to code size and is not needed, since hang() will print a message.
This adds a sandbox mailbox implementation (provider), a test client
device, instantiates them both from Sandbox's DT, and adds a DM test
that excercises everything.
Acked-by: Simon Glass <sjg@chromium.org> # v1
A mailbox is a hardware mechanism for transferring small message and/or
notifications between the CPU on which U-Boot runs and some other device
such as an auxilliary CPU running firmware or a hardware module.
This patch defines a standard API that connects mailbox clients to mailbox
providers (drivers). Initially, DT is the only supported method for
connecting the two.
The DT binding specification (mailbox.txt) was taken from Linux kernel
v4.5's Documentation/devicetree/bindings/mailbox/mailbox.txt.
The current reset API implements a method to reset the entire system.
In the near future, I'd like to introduce code that implements the device
tree reset bindings; i.e. the equivalent of the Linux kernel's reset API.
This controls resets to individual HW blocks or external chips with reset
signals. It doesn't make sense to merge the two APIs into one since they
have different semantic purposes. Resolve the naming conflict by renaming
the existing reset API to sysreset instead, so the new reset API can be
called just reset.
Now that the DM core sets driver_data before calling bind(), this driver
can make use of driver_data to determine the set of child devices to
create, rather than manually re-implementing the matching logic in code.
Cc: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
This will allow a driver's bind function to use the driver data. One
example is the Tegra186 GPIO driver, which instantiates child devices
for each of its GPIO ports, yet supports two different HW instances each
with a different set of ports, and identified by the udevice_id .data
field.
If the UART is to be accessed using I/O port accessors (inb & outb) then
using map_physmem doesn't make sense, since it operates in a different
memory space. Remove the call to map_physmem when
CONFIG_SYS_NS16550_PORT_MAPPED is defined, allowing I/O port addresses
to not be mangled by the incorrect mapping.
Support ISA busses in much the same way as Linux does. This allows for
ISA bus addresses to be translated, and only if CONFIG_OF_ISA_BUS is
selected in order to avoid including the code in builds which won't need
it.
The A80 uses the AXP809 as its primary PMIC.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Adds poweroff support for axp818 pmic.
The AXP818 has a switchable output, SW. This is commonly used for
controlling power to the LCD backlight.
