Some buses need to set up their devices before they can be used. This setup
may well be common to all buses in a particular uclass. Support a common
pre-probe method for the uclass, called before any bus devices are probed.
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Use a single exit point when we have an error and add debugging there.
For buses, after a child is bound, allow the uclass to perform some
processing. This can be used to figure out the address of the child (e.g.
the chip select for SPI slaves) so that it is ready to be probed.
This avoids bus drivers having to repeat the same process, which really
should be done by the uclass, since it is common.
This is common to all SPI drivers and specifies a structure used by the
uclass. It makes more sense to define it in the uclass.
In many cases the per-child private data for a device's children is defined
by the uclass rather than the individual driver. For example, a SPI bus
needs to store information about each of its children, but all SPI drivers
store the same information. It makes sense to allow the uclass to define
this data.
If the driver provides a size value for its per-child private data, then use
it. Failng that, fall back to that provided by the uclass.
At present we try to use the 'reg' property and device tree aliases to give
devices a sequence number. The 'reg' property is often actually a memory
address, so the sequence numbers thus-obtained are not useful. It would be
better if the devices were just sequentially numbered in that case. In fact
neither I2C nor SPI use this feature, so drop it.
Some devices need us to look up an alias to number them within the uclass.
Add a flag to control this, so it is not done unless it is needed.
Adjust the tests to test this new behaviour.
This is useful to check which uclass a device is in.
Allow parent drivers to be called when a new child is bound to them. This
allows a bus to set up information it needs for that child.
In many cases the child platform data for a device's children is defined by
the uclass rather than the individual devices. For example, a SPI bus needs
to know the chip select and speed for each of its children. It makes sense
to allow this information to be defined the SPI uclass rather than each
individual driver.
If the device provides a size value for its child platdata, then use it.
For buses it is common for parents to need to know the address of the child
on the bus, the bus speed to use for that child, and other information. This
can be provided in platform data attached to each child.
Add driver model support for this, including auto-allocation which can be
requested using a new property to specify the size of the data.
When using allocated platform data, allocate it when we bind the device.
This makes it possible to fill in this information before the device is
probed.
This fits with the platform data model (when not using device tree),
since platform data exists at bind-time.
Make the error handling more standard to make it easier to build on top of
it. Also correct a bug in the error path where there is no parent.
The root device corresponds to the root device tree node, so set this up.
Also add a few notes to the documentation.
Rather than assuming that the chip offset length is 1, allow it to be
provided. This allows chips that don't use the default offset length to
be used (at present they are only supported by the command line 'i2c'
command which sets the offset length explicitly).
Acked-by: Heiko Schocher <hs@denx.de>
For boards which use multiple I2C devices, or for SOCs which support
multiple boards, we might want to convert these to driver model at different
times. At present this is difficult because we need to either use
CONFIG_DM_I2C for a board or not.
Add a compatibility layer which implements the old API, thus allowing a
board to move to driver model for I2C without requiring that everything it
uses is moved in the same commit.
Add a dm_ prefix to driver model I2C functions so that we can keep the old
ones around.
This is a little unfortunate, but on reflection it is too difficult to
change the API. We can undo this rename when most boards and drivers are
converted to use driver model for I2C.
These functions are going away, so use the new uclass support instead.
This deals with the polarity bit. It also changes the GPIO devices so that
the correct device tree node is linked to each one. This allows us to use
the new uclass phandle functionality to implement a proper GPIO binding.
This deals with the polarity bit and selecting the correct bank device
given a GPIO number.
Add a new 'demo light' command which uses GPIOs to control imaginary lights.
Each light is assigned a bit number in the overall value. This provides an
example driver for using the new GPIO API.
At present U-Boot sort-of supports the standard way of reading GPIOs from
device tree nodes, but the support is incomplete, a bit clunky and only
works for GPIO bindings where #gpio-cells is 2.
Add new functions to request GPIOs, taking full account of the device
tree binding. These permit requesting a GPIO with a simple call like:
gpio_request_by_name(dev, "cd-gpios", 0, &desc, GPIOD_IS_IN);
This will request the GPIO, looking at the device's node which might be
this, for example:
cd-gpios = <&gpio TEGRA_GPIO(B, 3) GPIO_ACTIVE_LOW>;
The GPIO will be set to input mode in this case and polarity will be
honoured by the GPIO calls.
It is also possible to request and free a list of GPIOs.
Only the GPIO driver knows about the full GPIO device tree binding used by
a device. Add a method to allow the driver to provide this information to the
uclass, including the GPIO offset within the device and flags such as the
polarity.
So far driver model's GPIO uclass just implements the existing GPIO API.
This has some limitations:
- it requires manual device tree munging to support GPIOs in device tree
(fdtdec_get_gpio() and friends)
- it does not understand polarity
- it is somewhat slower since we must scan for the GPIO device each time
- Global GPIO numbering can change if other GPIO drivers are probed
- it requires extra steps to set the GPIO direction and value
The new functions have a dm_ prefix where necessary to avoid name conflicts
but we can remove that when it is no-longer needed. The new struct gpio_desc
holds all required information about the GPIO. For now this is intended to
be stored by the client requesting the GPIO, but in future it might be
brought into the uclass in some way.
With these changes the old GPIO API still works, and uses the driver model
API underneath.
This commit adds on-chip I2C driver used on newer SoCs of Panasonic
UniPhier platform.
This commit adds on-chip I2C driver used on some old Panasonic
UniPhier SoCs.
This information help with debugging issues with uart.
This change enables to change baudrate on command line.
Each board with defines it's own set of values. If we do not define
CONFIG_MVGBE_PORTS we will hit following error:
mvgbe.c: In function 'mvgbe_initialize':
mvgbe.c:700:34: error: 'CONFIG_MVGBE_PORTS' undeclared (first use in this function)
u8 used_ports[MAX_MVGBE_DEVS] = CONFIG_MVGBE_PORTS;
This patch fixes above described problem.
Signed-off-by: Luka Perkov <luka@openwrt.org>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
As a temporary measure before the ICH driver moves over to driver model,
add device tree support to the driver.
On x86 we use CMOS RAM to read and write some settings. Add basic support
for this, including access to registers 128-255.
Era property is added in the crypto node in device tree.
Move the code to do so from arch/powerpc/mpc8xxx/fdt.c to
drivers/sec/sec.c so that it can be used across arm and
powerpc platforms having crypto node.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
[York Sun: Fix commit message indentation]
Reviewed-by: York Sun <yorksun@freescale.com>
Internal memory controller counters can reach a bad state after
training in DDR4 mode if accumulated ECC or DBI mode is eanbled.
Signed-off-by: York Sun <yorksun@freescale.com>
commit a62e84d7b1824a202dd incorrectly changed the tegra pci code to the
new fdtdec pci helpers. To get the device index of the root port, the
"reg" property should be parsed from the dtb (as was previously the
case).
With this patch i can successfully network boot my jetson tk1
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Thierry Reding <treding@nvidia.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Some machines are very slow to scroll their displays. To cope with this,
support the CONFIG_CONSOLE_SCROLL_LINES option. Setting this to 5 allows
the display to operate at an acceptable speed by scrolling 5 lines at
a time.
This same option is available for LCDs so when these systems are unified
this code can be unified also.
Acked-by: Anatolij Gustschin <agust@denx.de>
Add code to the generic pci_rom file to access the VGA ROM in PCI space
when needed.
Each time U-Boot boots on Intel Crown Bay board, the displayed hard
drive information is wrong. It could be either wrong capacity or just
a 'Capacity: not available' message. After enabling the debug switch,
we can see the scsi inquiry command did not execute successfully.
However, doing a 'scsi scan' in the U-Boot shell does not expose
this issue.
SCSI: Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
ahci_device_data_io: 0 byte transferred. <--- scsi inquiry fails
ahci_device_data_io: 512 byte transferred.
Device 0: (0:0) Vendor: ATA Prod.: Rev: ?8
Type: Hard Disk
Capacity: 912968.3 MB = 891.5 GB (1869759264 x 512)
Found 1 device(s).
So uninitialized contents on the stack were passed to dev_print() to
display those wrong information.
The symptom were observed on two hard drives (one is Seagate, the
other one is Western Digital). The fix is to make sure the AHCI
interface is not busy by checking the error and status information
from task file register after enabling the port in ahci_port_start()
before proceeding other operations like scsi_scan().
Now that we have a full VESA driver we may as well use that. We need to
support the VESA layer being set up by early start-up code or by
running a VGA ROM.
Add a driver intended to cope with any VESA-compatible x86 graphics
adapter. It will not support ROMs which use OpenFirmware (Forth) since
there is no support for that in U-Boot. This means that MAC OS cards
will not work.
These are quite common and we may as well press on and not be so picky.
Allow the supported modes to be listed when in debug mode.
As it turns out this is a normal condition, so suppress the error.
