On DA850/OMAP-L138 it was observed that in RMII mode,
auto negotiation was not performed. This patch enables
auto negotiation in RMII mode. Without this patch, EMAC
initialization takes more time and sometimes tftp fails
in RMII mode.
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
DA850/OMAP-L138 does not support strict MMC/SD boot mode. SPL will
be in SPI flash and U-Boot image will be in MMC/SD card. SPL will
do the low level initialization and then loads the u-boot image
from MMC/SD card.
Define CONFIG_SPL_MMC_LOAD macro in the DA850/OMAP-L138
configuration file to enable this feature.
... after commit "net/miiphy/serial: drop duplicate NAMESIZE
define" (sha1:f6add13) was applied. The building of the new
LL TEMAC network driver fails with error below:
xilinx_ll_temac.c: In function 'xilinx_ll_temac_initialize':
xilinx_ll_temac.c:301: error: 'NAMESIZE' undeclared (first use in this function)
xilinx_ll_temac.c:301: error: (Each undeclared identifier is reported only once
xilinx_ll_temac.c:301: error: for each function it appears in.)
Signed-off-by: Stephan Linz <linz@li-pro.net>
Fix the warning
mmc.c: In function 'mmc_send_cmd':
mmc.c:87: warning: assignment from incompatible pointer type
in case CONFIG_MMC_TRACE is enabled.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
CC: Andy Fleming <afleming@freescale.com>
This is just a patch for the problem reported here:
http://lists.denx.de/pipermail/u-boot/2012-February/117580.html originally reported by Igor.
"Looks like this is copy paste error from my side,(for port2/3 it should have been bypass
for port2/3 rather its port1 set in bypass mode)"
I only submit the patch since it is missing in 2012.04-rc3 while the twister board
depends on it. Maybe it is already somewhere in the reposistory, but I cannot find it.
note: the twister boards still needs an additional `usb reset`, don't know why.
U-Boot 2012.04-rc3-dirty (Apr 19 2012 - 21:38:38)
AM35XX-GP ES1.0, CPU-OPP2, L3-165MHz, Max CPU Clock 600 Mhz
TAM3517 TWISTER Board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: 512 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Die ID #746c0000000000000155dc1405011024
Net: DaVinci-EMAC, smc911x-0
Hit any key to stop autoboot: 0
twister => usb start
(Re)start USB...
USB: Register 1313 NbrPorts 3
USB EHCI 1.00
scanning bus for devices... 1 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
twister => usb reset
(Re)start USB...
USB EHCI 1.00
(Re)start USB...
USB EHCI 1.00
(Re)start USB...
USB EHCI 1.00
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Acked-by: Govindraj.R <govindraj.raja <at> ti.com>
Acked-by: Tom Rini <trini@ti.com>
Fix gcc 4.6 build warnings:
onenand_base.c: In function 'onenand_probe':
onenand_base.c:2577:6: warning: variable 'maf_id' set but not used
[-Wunused-but-set-variable]
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
* 'master' of git://git.denx.de/u-boot-arm:
ARM926EJS: Fix cache.c to comply with checkpatch.pl
ARM926EJS: Make asm routines volatile in cache ops
MX35: mx35pdk: wrong board revision
ARM1136: MX35: Make asm routines volatile in cache ops
ARM: add u-boot.imx as target for i.MX SOCs
M28: Pull out CONFIG_APBH_DMA so it's always enabled
DMA: Split the APBH DMA init into block and channel init
imx: Return gpio_set_value in gpio_direction_output
imx: Use GPIO_TO_PORT macro in the gpio driver instead of (gpio >> 5)
imx: Add GPIO_TO_PORT macro in the mxc_gpio driver
imx: Remove unneeded/repititive definitions from imx headers
i.MX28: Allow coexistence of PIO and DMA mode for SD/MMC
MX31: mx31pdk: drop enable_caches from board file
i.MX28: Fix initial stack pointer position
mx35: mx35pdk: fix when cache functions are linked
mx35: flea3: fix when cache functions are linked
ARM: 926ejs: use debug() for misaligned addresses
ARM1136: add cache flush and invalidate operations
mx6qsabrelite: Fix the serial console port
mx6qsabrelite: Add boot switch setting information into the README
i.MX6: mx6qsabrelite: add cache commands if cache is enabled
i.MX6: implement enable_caches()
i.MX6: define CACHELINE_SIZE
MX53: DDR: Fix ZQHWCTRL field TZQ_CS
mx28evk: Add a README file
mx28: Split the README into a common part and a m28 specific part
tricorder: Load kernel from ubifs
tricorder: Add UBIFS
cm-t35: fix Ethernet reset timing
hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORT
BeagleBoard: Remove userbutton command and use gpio command instead
OMAP: Move omap1510inn to Unmaintained / Orphaned
This fixes the issue where mxs_dma_init() was called either twice or never,
without introducing any new init hooks.
The idea is to allow each and every device using the APBH DMA block to
configure and request only the channels it uses, instead of making it call init
for all the channels as is now.
The common DMA block init part, which only configures the block, is then called
from CPUs arch_cpu_init() call.
NOTE: This patch depends on:
http://patchwork.ozlabs.org/patch/150957/
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Return gpio_set_value in gpio_direction_output.
Earlier it returned 0 and ignored gpio_set_value's return value.
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Use the defined GPIO_TO_PORT macro. Remove gpio >> 5 references.
Add GPIO_TO_PORT macro in the mxc_gpio.c driver
This SD DMA function of i.MX28 is still apparently too experimental to be
enabled by default in 2012.04 release. Enable this feature only if the user
plans to tinker with DCache or explicitly enables it.
Fix:
spr_smi.c: In function 'smi_write':
spr_smi.c:325:15: warning: variable 'WM' set but not used
Cc: Vipin Kumar <vipin.kumar@st.com>
* 'master' of git://git.denx.de/u-boot-net:
net/designware: Change timeout loop implementation
net/designware: Set ANAR to 0x1e1
net/designware: Program phy registers when auto-negotiation is ON
net/designware: Try configuring phy on each dw_eth_init
net/designware: Consecutive writes must have delay
net/designware: Phy address fix
net/designware: Fix the max frame length size
net/designware: Fix to restore hw mac address
microblaze: Wire up LL_TEMAC driver initialization
microblaze: Add faked LL_TEMAC driver configuration
microblaze: Enable several ethernet driver compilation
net: ll_temac: Add LL TEMAC driver to u-boot
Update net subsystem maintainer in doc/git-mailrc
net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back
mvgbe: remove warning for unused methods
The new implementation changes the timeout loop implementation to avoid 1 ms
delay in each failing test. It also configures the delay to 10usec.
Signed-off-by: Amit Virdi <amit.virdi@st.com>
This patch forces the advertised capabilities during auto
negotiation to always be 10/100 Mbps and half/full as duplexing.
Signed-off-by: Armando Visconti <armando.visconti@st.com>
If AN(auto-negotiation) is ON, speed bit of control register are not
applicable. Also phy registers were not getting programmed as per the
result of AN. This patch sets only AN bit & restart AN bit for AN ON
selection & programs PHY registers as per AN result.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Phy autonegotiation works only when the ethernet cable is plugged in.
Since the phy was configured only at the init time, a plugged in cable
was necessary to initialize the phy properly.
This patch keeps a flag to check if the phy initialization has
succeeded, and calls configure_phy routine at every init if this flag
reports otherwise.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
This patch solves a TX/RX problem which happens at 10Mbps, due to the
fact that we are not respecting 4 cyles of the phy_clk (2.5MHz) between
two consecutive writes on the same register.
The code assumes the phy address to be > 0, which is not true, the phy address
can be in the range 0-31.
The max frame length for normal descriptor can be 0x7FF i.e 2047. It was wrongly
specified as 2048. Currently, the max descriptor length is around 1500, so
redefining the mask to 1600
The network controller mac resets hardware address stored in MAC_HI and MAC_LO
registers if mac is resetted. So, hw mac address needs to be restored in case
mac is explicitly resetted from driver.
This replacement causes 4KB page size devices to work properly with u-boot.
The old ONENAND_IS_MLC() behavior has been preserved by explicit
setting of ONENAND_HAS_4KB_PAGE for those devices.
This change makes the onenand_base.c file more resembling the respective
kernel sources.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW:
- Samsung S5PC110 GONI
- Samsung S5PC210 Universal
Xilinx LocalLink Tri-Mode Ether MAC driver can be
used by Xilinx Microblaze or Xilinx ppc405/440 in
SDMA and FIFO mode. DCR or XPS bus can be used.
The driver uses and requires MII and PHYLIB.
CP: 4 warnings: 'Use of volatile is usually wrong'
I won't fix this, because it depends on the network
driver subsystem.
Reported-by: Michal Simek <monstr@monstr.eu>
Separate callback for probing OneNAND memory chip.
If no special function is defined, default implementation will be used.
This approach gives more flexibility for OneNAND device probing.
Some baords may use the GBE interface but they have no
phy connected to the interface and a direct MAC/MAC interface.
For them we need to get rid of compiler warnings.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
flush_dcache is not declared in the common.h API,
flush_dcache_range however is
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Ben Warren <biggerbadderben@gmail.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Acked-by: Thomas Chou <thomas@wytron.com.tw>
* 'master' of git://git.denx.de/u-boot-usb:
Enable high speed support for USB device framework and usbtty
The FSL PCI driver uses local prototypes for
pciauto_[pre|post]scan_setup_bridge(), this does not seem right,
so move them to the <pci.h> file.
Fixed a small extern declaration too, this is harmless but distracts
the view since all other prototypes are explicitly external.
Fix:
mmc.c: In function 'mmc_bounce_buffer_start':
mmc.c:132:13: warning: no return statement in function returning
non-void [-Wreturn-type]
Cc: Andy Fleming <afleming@gmail.com>
Fix:
tegra2_mmc.c: In function 'mmc_send_cmd':
tegra2_mmc.c:230:3: warning: 'mask' may be used uninitialized in this
function [-Wuninitialized]
Cc: Doug Anderson <dianders@chromium.org>
Cc: Tom Warren <twarren@nvidia.com>
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
lzma: fix printf warnings
Remove CONFIG_SYS_EXTBDINFO from snapper9260.h
cmd_pxe.c: fix strict-aliasing warnings
net: smc91111: use mdelay()
doc: Fix some typos in different files
disk/part.c: Fix device enumeration through API
mkenvimage: Really set the redundant byte when applicable
mkenvimage: Don't try to detect comments in the input file
mkenvimage: Use mmap() when reading from a regular file
mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-"
mkenvimage: More error handling
mkenvimage: Correct an include and add a missing one
mkenvimage: correct and clarify comments and error messages
MAKEALL: display SPL size if present
ARMV7/Vexpress: add missing get_ticks() and get_tbclk()
mkenvimage: fix usage message
cmd_fat: add FAT write command
fs/fat/fat_write.c: Fix GCC 4.6 warnings
FAT write: Fix compile errors
* 'master' of git://git.denx.de/u-boot-arm: (146 commits)
arm: Use common .lds file where possible
arm: add a common .lds link script
arm: Remove unneeded setting of LDCSRIPT
Define CPUDIR for the .lds link script
arm: Remove zipitz2 link script
Allow arch directory to contain .lds without requiring Makefile
OMAP: Remove omap1610inn-based boards
arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings
board/ti/beagle/beagle.c: Fix build warnings
sdrc.c: Fix typo in do_sdrc_init() for SPL
tegra: i2c: Add I2C driver
tegra: fdt: i2c: Add extra I2C bindings for U-Boot
tegra: i2c: Select I2C ordering for Seaboard
tegra: i2c: Enable I2C on Seaboard
tegra: i2c: Select number of controllers for Tegra2 boards
tegra: i2c: Initialise I2C on Nvidia boards
tegra: Enhance clock support to handle 16-bit clock divisors
fdt: Add function to allow aliases to refer to multiple nodes
tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE
tegra: fdt: Enable FDT support for Ventana
tegra: fdt: Enable FDT support for Seaboard
tegra: usb: Enable USB on Seaboard
tegra: usb: Add common USB defines for tegra2 boards
tegra: usb: Add USB support to nvidia boards
arm: Check for valid FDT after console is up
fdt: Avoid early panic() when there is no FDT present
tegra: usb: Add support for Tegra USB peripheral
tegra: fdt: Add function to return peripheral/clock ID
usb: Add support for txfifo threshold
tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard
tegra: usb: fdt: Add additional device tree definitions for USB ports
tegra: fdt: Add clock bindings for Tegra2 Seaboard
tegra: fdt: Add additional USB binding
fdt: Add tegra-usb bindings file from linux
fdt: Add staging area for device tree binding documentation
tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel
tegra: fdt: Add Tegra2x device tree file from kernel
arm: fdt: Add skeleton device tree file from kernel
fdt: Add basic support for decoding GPIO definitions
fdt: Add functions to access phandles, arrays and bools
fdt: Tidy up a few fdtdec problems
fdt: Add tests for fdtdec
fdt: Add fdtdec_find_aliases() to deal with alias nodes
arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load
net: fec_mxc: allow use with cache enabled
net: force PKTALIGN to ARCH_DMA_MINALIGN
i.MX28: Enable caches by default
i.MX28: Make use of the bounce buffer
i.MX28: Do data transfers via DMA in MMC driver
MMC: Implement generic bounce buffer
i.MX28: Add cache support to MXS NAND driver
i.MX28: Add cache support into the APBH DMA driver
ARM926EJS: Implement cache operations
board/vpac270/onenand.c: Fix build errors
nhk8815: fix build errors
atmel-boards: add missing atmel_mci.h
ARM: highbank: setup env from boot source register
ARM: highbank: change env config to use nvram
ARM: highbank: add reset support
ARM: highbank: Add boot counter support
ARM: highbank: change TEXT_BASE to 0x8000
ARM: highbank: fix us_to_tick calculation
ARM: highbank: add missing get_tbclk
ARM: highbank: fix warning for calxedaxgmac_initialize
net: calxedaxgmac: fix build due to missing __aligned definition
EXYNOS: Add structure for Exynos4 DMC
EXYNOS: SMDK5250: Support all 4 UARTs
ARM: fix s3c2410 timer code
ARM: davinci: fixes for cam_enc_4xx board
omap3_spi: receive transmit mode
calimain, enbw_cmc: Fix typo in comments
Davinci: ea20: use gpio framework to access gpios
OMAP3: mt_ventoux: sets its own mtdparts
OMAP3: mt_ventoux: updated timing for FPGA
twl4030: fix potential power supply handling issues
NAND: TI: fix warnings in omap_gpmc.c
cam_enc_4xx: Rename 'images' to 'imgs'
arm: Add Prep subcommand support to bootm
OMAP3: twister: add support to boot Linux from SPL
SPL: call cleanup_before_linux() before booting Linux
OMAP3: SPL: do not call I2C init if no I2C is set.
Add cache functions to SPL for armv7
devkit8000: Implement and activate direct OS boot
omap/spl: change output of spl_parse_image_header
omap-common/spl: Add linux boot to SPL
devkit8000/spl: init GPMC for dm9000 in SPL
omap-common: Add NAND SPL linux booting
devkit8000: add config for spl command
Add cmd_spl command
mx53ard: Initialize return code with error
mx53: Make PLL2 to be the parent of UART clock
configs: imx: Use CONFIG_SF_DEFAULT_CS
mx28evk: Provide default values for SPI bus and chip select
USB: ehci-mx6: Add proper IO accessors
mx6: Read silicon revision from register
i.MX28: Drop __naked function from spl_mem_init
mxs_spi: Return proper timeout error
i.MX28: Make the stabilization delays shorter
pmic_i2c: Return error in case of invalid pmic_i2c_tx_num
mx6: Remove duplicate definition of ANATOP_BASE_ADDR
mx6: Fix reset cause for Power On Reset case
i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE
i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG
i.MX28: Enable additional DRAM address bits
mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment
mx31: add "ARM11P power gating" to get_reset_cause
mx31pdk: Fix CONFIG_SYS_MEMTEST_END
efikamx: Fix CONFIG_SYS_MEMTEST_END
mx53smd: Fix CONFIG_SYS_MEMTEST_END
mx53evk: Fix CONFIG_SYS_MEMTEST_END
mx51evk: Fix CONFIG_SYS_MEMTEST_END
i.MX6: mx6qsabrelite: add ext2 support
imximage: Remove overwriting of flash_offset
IXP: Fix GPIO_INT_ACT_LOW_SET()
IXP: Fix NAND build warning on PDNB3 and SCPU
IXP: Move PDNB3 and SCPU from Makefile to boards.cfg
IXP: Squash warnings in IXP NPE
IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST}
IXP: Make IXP buildable with arm-linux- toolchains
Examples: Properly append LDFLAGS to LD command
SPL: Enable YMODEM support on BeagleBone and AM335x EVM
SPL: Add YMODEM over UART load support
SPL: Add README.omap3
README: document more SPL config options
spl.c: Use __noreturn decorator
config.mk: Check for -fstack-usage support
config.mk: Make cc-option create a file under include/generated
Add basic i2c driver for Tegra2 with 8- and 16-bit address support.
The driver requires CONFIG_OF_CONTROL to obtain its configuration
from the device tree.
(Simon Glass: sjg@chromium.org modified for upstream)
Acked-by: Heiko Schocher <hs@denx.de>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This adds basic support for the Tegra2 USB controller. Board files should
call board_usb_init() to set things up.
Configuration is performed through the FDT, with aliases used to set the
order of the ports, like this fragment:
aliases {
/* This defines the order of our USB ports */
usb0 = "/usb@0xc5008000";
usb1 = "/usb@0xc5000000";
drivers/usb/host files ONLY: Acked-by: Remy Bohmer <linux@bohmer.net>
CONFIG_USB_EHCI_TXFIFO_THRESH enables setting of the txfilltuning
field in the EHCI controller on reset.
Ensure that transmit and receive buffers are cache-line aligned.
Invalidate cache for each packet as received, update receive buffer
descriptors one cache line at a time, flush cache before transmitting.
Original patch by Marek:
http://lists.denx.de/pipermail/u-boot/2012-February/117695.html
Signed-off-by: Eric Nelson <eric.nelson at boundarydevices.com>
Tested-by: Marek Vasut <marex@denx.de>
This utilizes the newly introduced bounce buffers in the MMC layer.
Cc: Fabio Estevam <festevam@gmail.com>
This implements generic bounce buffer at the end of MMC command submission
chain. Therefore if unaligned data are passed, they are copied. This stuff
should be pushed down into the MMC subsystem to squash all places generating
these unaligned data.
The desc_append() now flushes descriptors into RAM.
Include linux/compiler.h to fix build error due to missing __aligned
definition.
This patch adds the support for high speed in usb device framework and usbtty
driver. This feature has been kept within a macro CONFIG_USBD_HS, so the board
configuration files have to define this macro to enable high speed support.
Along with that specific peripheral drivers also need to define a function to
let the framework know that the enumeration has happened at high speed.
This function prototype is "int is_usbd_high_speed(void)"
Implementation of receive-transmit mode for
omap3 MCSPI.
Introduces full duplex communication, needed by
some spi devices (such as enc28j60).
Signed-off-by: jacopo mondi <mondi@cs.unibo.it> <j.mondi@voltaelectronics.com>
twl4030_pmrecv_vsel_cfg currently first sets up device group (effectively
enabling the supply), and only then sets vsel (selects voltage). This could
lead to wrong voltage for a short time, or even long time if second i2c
write fails.
Fix this by writing vsel first and device group after that. Also
introduce error checking to not enable the supply if we failed to set
the voltage, and start logging errors as power supply problems are
usually important.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
The following warnings are reported for boards using SOFT ECC.
omap_gpmc.c:33:30: warning: 'hw_nand_oob' defined but not used
omap_gpmc.c:78:13: warning: 'omap_hwecc_init' defined but not used
omap_gpmc.c:116:12: warning: 'omap_correct_data' defined but not used
omap_gpmc.c:182:12: warning: 'omap_calculate_ecc' defined but not used
omap_gpmc.c:208:13: warning: 'omap_enable_hwecc' defined but not used
Cc: Tom Rini <trini@ti.com>
Cc: Scott Wood <scottwood@freescale.com>
We've already got a mdelay() func in common code, so use that instead.
Add proper IO accessors for mx6 usb registers.
Acked-by: Jason Liu <r64343@freescale.com>
