path: root/drivers
2011-09-30spl: add NAND Library to new SPLSimon Schwarz
Adds NAND library to SPL. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30net: Adds Fast Ethernet Controller driver for Armada100Ajay Bhargav
This patch adds support for Fast Ethernet Controller driver for Armada100 series. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-09-30gpio: Add GPIO driver framework for Marvell SoCsAjay Bhargav
This patch adds generic GPIO driver framework support for Marvell SoCs. To enable GPIO driver define CONFIG_MARVELL_GPIO and for GPIO commands define CONFIG_CMD_GPIO in your board configuration file. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-28Revert "phylib: remove a couple of redundant code lines"Wolfgang Denk
This reverts commit 041c542219af7f31c372d89b4c7c6f4c8064a8ce. The lines removed by this commit weren't redundant. The logic is (and probably should be better commented): Find the intersection of the advertised capabilities of both sides of the link (lpa). From that intersection, find the highest capability we can run at (that will be the negotiated link). Now imagine that the intersection (lpa) is (LPA_100HALF | LPA_10FULL). The code will now set phydev->speed to 100, and phydev->duplex to 1, but this link does not support 100FULL. Kudos to Andy Fleming <afleming@gmail.com> for binging this to attention and for the explanation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-24ASIX: Fix buffer access in asix_get_phy_addr()Marek Vasut
2011-09-21sf: fix debug format string warningVadim Bendebury
On some systems, we get a warning when %lu is used with size_t's, so use the correct format string. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-12ARMV7: OMAP: I2C driver: cosmetic: make checkpatch-compatibleMichael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12ARMV7: OMAP: Write more than 1 byte at a time in i2c_writeMichael Jones
This allows the EEPROM layer to send a single i2c write command per page, and wait CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS between i2c write commands. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10phylib: remove a couple of redundant code linesVladimir Zapolskiy
This change slightly improves readability of the phydev speed/duplex assignment logic. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-09-10phylib: reset mii bus only if reset handler is registeredVladimir Zapolskiy
This change allows to cope with a mii bus device registered using miiphy_register(), which doesn't assign a default reset handler. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-09-09smc911x: Fix build warningsWolfgang Denk
Commit 6af1d41 "smc911x MII made available" was missing a few "const" qualifiers. Fix the resulting in build warnings: smc911x.c: In function 'smc911x_initialize': smc911x.c:297: warning: passing argument 2 of 'miiphy_register' from incompatible pointer type smc911x.c:297: warning: passing argument 3 of 'miiphy_register' from incompatible pointer type Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Helmut Raiger <helmut.raiger@hale.at>
2011-09-07smc911x MII made availableHelmut Raiger
The driver already had the MII functions, but they have not been registered using miiphy_register(). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2011-09-07Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mmc: ftsdc010: add support of ftsdc010 mmc controller mmc: Fix mmc_send_status()
2011-09-07Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
* 'master' of git://git.denx.de/u-boot-video: VIDEO: mb86r0xgdc.c: fix warning: unused variable 'i'
2011-09-07I2C: mxc: fix compilation for MX31Stefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2011-09-06VIDEO: mb86r0xgdc.c: fix warning: unused variable 'i'Wolfgang Denk
Fix build warning: Configuring for jadecpu board... mb86r0xgdc.c: In function 'dsp_init': mb86r0xgdc.c:60: warning: unused variable 'i' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2011-09-05sf: winbond: Add support for the Winbond W25X40James Le Cuirot
The Winbond W25X40 is now being used in the IP02 (and possibly IP04). Tested and working on the actual device.
2011-09-05FPGA: constify Lattice FPGA codeWolfgang Denk
The Lattice code was missed by commit e6a857d "fpga: constify to fix build warning" resulting in such warnings: fpga.c: In function 'fpga_load': fpga.c:238: warning: passing argument 2 of 'lattice_load' discards qualifiers from pointer target type fpga.c: In function 'fpga_dump': fpga.c:278: warning: passing argument 2 of 'lattice_dump' discards qualifiers from pointer target type Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Stefano Babic <sbabic@denx.de>
2011-09-05drivers/video/Makefile: include object files only onceWolfgang Denk
Use "$(sort $(COBJS-y))" to prevent multiple inclusion of the same object files. Also sort driver list. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-05video: Fix build error with global inclusion of videomodesKumar Gala
The following commit: commit de701d118380de12a48c8a4fb345e9f909329432 Author: Syed Mohammed Khasim <khasim@ti.com> Date: Tue Apr 19 14:00:34 2011 -0500 OMAP3: Add DSS driver for OMAP3 Added videomodes to the object list w/o any protection. This causes build issues like: videomodes.o:(.rodata.res_mode_init+0x0): multiple definition of `res_mode_init' videomodes.o:(.rodata.res_mode_init+0x0): first defined here videomodes.o: In function `video_get_params': /local/home/galak/git/u-boot/drivers/video/videomodes.c:160: multiple definition of `video_get_params' videomodes.o:/local/home/galak/git/u-boot/drivers/video/videomodes.c:160: first defined here videomodes.o: In function `video_get_video_mode': /local/home/galak/git/u-boot/drivers/video/videomodes.c:229: multiple definition of `video_get_video_mode' videomodes.o:/local/home/galak/git/u-boot/drivers/video/videomodes.c:229: first defined here videomodes.o:(.rodata.vesa_modes+0x0): multiple definition of `vesa_modes' videomodes.o:(.rodata.vesa_modes+0x0): first defined here make[1]: *** [libvideo.o] Error 1 Remove the unconditional inclusion and move to adding to CONFIG_VIDEO_OMAP3 case. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-04ftsdc010: add support of ftsdc010 mmc controllerMacpaul Lin
Faraday FTSDC010 controller is a SD/MMC controller for SoC chip. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-09-04mmc: Fix mmc_send_status()Marek Vasut
The mmc_send_status() function sets cmd.arg = 0. That's incorrect, so fix it. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Andy Fleming <afleming@freescale.com> Tested-by: Lei Wen <adrian.wenl@gmail.com>
2011-09-04ehci-hcd: Allow cleanups to happen gracefully on a timeout.Joel Fernandes
With this, the EHCI seems to "recover" from a timeout. This is particularly observable if you were to ping the wrong IP Address and then ping the correct one or if there was a temporary failure during tftp sessions. All it takes is one timeout to disable it. If you have a noisy network (lot of traffic), even if the traffic is not for the board, the timeouts don't occur. Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3: Add DSS driver for OMAP3Syed Mohammed Khasim
* Supports dynamic panel configuration * Supports dynamic tv standard selection * Adds support for DSS register access through generic APIs * Incorporated DSS register access using structures. * DSS makefile update Previous discussions are here: http://www.mail-archive.com/u-boot@lists.denx.de/msg27150.html Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04USB: Remove __attribute__ ((packed)) for struct ehci_hccr and ehci_hcorJason Kridner
Remove __attribute__ ((packed)) to prevent byte access to soc registers in some gcc versions. Having patches to enable ehci for the BeagleBoard lying around for several months, this one was the show-stopper. Switched to align(4), rather than remove the attribute, per suggestion from Alexander. Credits have to go to Laine Walker-Avina <lwalkera@ieee.org> for finding the problem. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Cc: Alexander Holler <holler@ahsoftware.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04da850: fix the channel number for EMAC teardown initNagabhushana Netagunte
TX and RX channel numbers programmed as '1' during EMAC teardown initialization is wrong. This patch fixes the same by setting channel number to '0' which is used by U-boot. Signed-off-by: Sugumar Natarajan <sugumar@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3: Remove legacy mmc driverTom Rini
Now that all platforms have been migrated to the new MMC driver, remove the old one. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c)Łukasz Majewski
This patch adds support for software I2C for GONI and Universal C210 reference targets. It adds support for access to GPIOs by number, not as it is present, by bank and offset. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2011-09-04IMX: uniform GPIO interface using GPIO frameworkStefano Babic
IMX processors has a slightly different interface to access GPIOs and do not make use of the provided GPIO framework. The patch substitutes mxc_ specific functions and make use of the API in asm/gpio.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-03gpio:samsung s5p_ suffix add for GPIO functionsŁukasz Majewski
This change is driven by need of general gpio_* functions, which as their parameter are accepting the GPIO pin number, NOT block and pin. This makes the code alike to omap, and allows for using more generic frameworks (e.g. software I2C). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-03mmc: S5P: Support DMA restarts at buffer boundariesAnton Staaf
Currently if a DMA buffer straddles a buffer alignment boundary (512KiB) then the DMA engine will pause and generate a DMA interrupt. Since the DMA interrupt is not enabled it will hang the MMC driver. This patch adds support for restarting the DMA transfer. The SYSTEM_ADDRESS register contains the next address that would have been read/written when a boundary is hit. So we can read that and write it back. The write triggers the resumption of the transfer. Signed-off-by: Anton Staaf <robotboy@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Tested-by : Jaehoon Chung <jh80.chung@samsung.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-31phy.c: make less verbose - turn printf() into debug()Wolfgang Denk
The PHY driver was too verbose and corrupted the boot message display like this: ... Net: TSEC0 connected to Marvell 88E1111S TSEC1 connected to Marvell 88E1111S TSEC0, TSEC1 ... Turn printf() into debug() so we het the expected output again: ... Net: TSEC0, TSEC1 ... Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-08-26Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: add calling mmc_initialize in board.c sh: sh7757lcr: Add KEEP order to start.o section usb: r8a66597: Fix argument mistake of inl sh: Clean up rsk7264 board settings sh: sh2a: Add sh2a optimize to config.mk sh: Fix rsk7203 alignment problem sh: Add support for SH2A freestanding build sh: Add Renesas rsk7264 board
2011-08-22usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
Fail in build, because argument of inl used in r8a66597_read_fifo is wrong. r8a66597.h:441:35: error: macro "inl" passed 2 arguments, but takes just 1 In file included from r8a66597-hcd.c:25: r8a66597.h: In function ‘r8a66597_read_fifo’: r8a66597.h:441: error: ‘inl’ undeclared (first use in this function) r8a66597.h:441: error: (Each undeclared identifier is reported only once r8a66597.h:441: error: for each function it appears in.) Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-08usb: r8a66597: Fix argument mistake of inlNobuhiro Iwamatsu
2011-08-08Add Ethernet hardware MAC address framework to usbnetSimon Glass
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr). This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add support for SMSC95XX USB 2.0 10/100MBit Ethernet AdapterSimon Glass
The SMSC95XX is a USB hub with a built-in Ethernet adapter. This adds support for this, using the USB host network framework. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2011-08-04Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: drivers/rtc: add Marvell Integrated RTC Armada100: Add Board Support for Marvell GuruPlug-Display Armada100: MFP macro naming correction arm: auto gen asm-offsets.h for mb86r0x spear: fix build errors for spear3xx/spear600 platforms cosmetic: arm: lib/board.c: Coding Style cleanup ARM: versatile: fix board support SMDKV310: Enable device tree support SMDKV310: MMC_SPL: Fix building when using "make O=" arm: a320: enable tagged list support arm: a320: fix multiline comment style ARMv7: u8500_href: Add missing header to fix compiler warning Removed unused define, CONFIG_ARMV7. avr32: add grasshopper (ICnova AP7000) board AT91/SPI: fix atmel_dataflash_spi.c to allow building without warnings MAKEALL: remove AT91 boards that are in boards.cfg AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9263 SoC build correctly against u-boot-atmel/master AT91: Board fix for AT91SAM9261-EK AT91: SoC fix at91sam9261_matrix.h AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/master AT91: Makes AT91SAM9RL SoC build correctly against u-boot-atmel/master AT91: change common at91sam9261 files to compile with new scheme AT91: fix mistake in at91sam9260_devices.c(spi1_hw_init) a/a/c/arm920t/at91/reset.c: drop obsolete CONFIG_AT91RM9200_USART README: fix arm920t/at91 path net/eth.c: drop obsolete at91rm9200 support README.at91-soc: remove AT91(RM9200) joining notice a/a/c/arm920t/cpu.c: remove CONFIG_AT91_LEGACY warning MAKEALL: remove obsolete at91rm9200 soc ARM: remove obsolete at91rm9200 omap4: clock init support for omap4460 omap4: support TPS programming omap: reuse omap3 gpio support in omap4 omap4: sdram init changes for omap4460 omap4: add omap4460 revision detection mkimage: Add OMAP boot image support omap: add MMC and FAT support to SPL omap: add basic SPL support armv7: start.S: fixes and enhancements for SPL omap4: automatic sdram detection omap4: calculate EMIF register values omap4: add sdram init support omap4: add clock support omap4: add OMAP4430 revision check omap4: cleanup pin mux data omap4: utility function to identify the context of hw init DA8xx: fix LPSC constants DA8xx: switch an enum to defines for consistency DA8xx: add MMC/SD controller addresses DaVinci EMAC: declare function for all DA8xx CPUs DA8xx: add generic GPIO driver DaVinci: rename gpio_defs.h to gpio.h omap3evm: eth: Include functions only when necessary omap3evm: Update ethernet reset sequence for Rev.G board omap3evm: eth: split function setup_net_chip omap3: Include array definition only when it is used omap730p2: fix build breaks omap2420h4: fix build breaks omap1610inn: fix build breaks omap1510inn: fix build breaks omap5912osk: fix build breaks omap1610h2: fix build breaks
2011-08-04video: mb862xx: change controller detection messageAnatolij Gustschin
2011-08-04video: mb862xx: support Coral-PA controllerAnatolij Gustschin
Add detection of Coral-PA and configure Coral CCF an MMR parameters using CONFIG_SYS_MB862xx_CCF and CONFIG_SYS_MB862xx_MMR macros. Use CCF and MMR parameters for Coral-P Eval. Board if the appropriate macros weren't defined. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-04video: Add SHARP LQ084S3LG01 LCD support on P1022DSTimur Tabi
The SHARP LQ084S3LG01 is a TFT LCD used on the P1022DS (revision "C") board. This device only supports 800x600 resolution, so if that resolution is selected, assume that this is the device. The device is attached to the LVDS port on the P1022DS board. The existing 800x600 entry (for the PDM360NG board) is actually 800x480, so we fix that. To support two different 800x resolutions, the Y-resolution is now passed to fsl_diu_init() and both values are used to pick the proper fb_videomode structure. The data for the 800x600 video mode is originally from Jiang Yutang. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com>
2011-08-04drivers/rtc: add Marvell Integrated RTCJason Cooper
This driver can be used for kirkwood SoCs by enabling CONFIG_RTC_MV. Tested on Global Scale Technologies Dreamplug. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-08-03AT91/SPI: fix atmel_dataflash_spi.c to allow building without warningsReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03DA8xx: add generic GPIO driverLaurence Withers
Add a generic GPIO driver for the DaVinci DA8xx processors. It is turned on by defining CONFIG_DA8XX_GPIO and fulfills the generic GPIO interface specified in <asm/gpio.h> . The driver has support for both manipulating GPIO pins as well as automatically configuring the pin multiplexor registers to set the pin function to GPIO. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03DaVinci: rename gpio_defs.h to gpio.hLaurence Withers
In preparation for a generic GPIO driver for the DA8xx processors, rename <asm/arch/gpio_defs.h> to <asm/arch/gpio.h> and fix up all files which include it. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
