Add $(obj) to LIB avoiding objects be built in the source dir
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch fix the compile issue on the board that did not enable the bios emulator
The change entitled "Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx"
broke multiple PHY support in tsec.c. This fixes it.
Signed-off-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
Allow the address of the Ten Bit Interface (TBI) to be changed in the
event of a conflict with another device.
Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
ATI video card BIOS. and can be used for x86 code emulation by some
modifications.
X300, X700, X800 ATI video cards.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
All of the PCI/PCI-Express driver and initialization code that
was in the MPC8641HPCN port has now been moved into the common
drivers/fsl_pci_init.c. In a subsequent patch, this will be
utilized by the 85xx ports as well.
Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added.
Also enable the second PCI-Express controller on 8641
by getting its BATS and CFG_ setup right.
Fixed a u16 vendor compiler warning in AHCI driver too.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
The Marvel 88E1111S driver for the TSEC was copied from the
88E1101 driver, and included a fix for an erratum which does not
exist on that part. Now it is removed
Signed-off-by: Andy Fleming <afleming@freescale.com>
Jarrold Wen noticed that the generic PHY code always matches
under the current implementation. Change it so the first match
wins, and *only* unknown PHYs trigger the generic driver
Fix a bug in the Marvell 88e1145 PHY init code in the TSEC driver
where the reset was being done after the errata code instead of
before.
Signed-off-by: Haiying Wang <haiying.wang@freescale.com>
PCI_CLASS_PROCESSOR_POWERPC.
The P2P bridge bus numbers programmed into the device are relative to
hose->first_busno.
FSL PCIe block has extended cfg registers in the 100 and 400 range.
For example, to read the LTSSM register: pci display <busn>.0 404 1
- Make pciauto_{pre,post}scan_setup_bridge non-static
- Added physical address display in debug messages.
Ensure hose->current_busno is not less than first_busno. This fixes
broken board code which leaves current_busno=0 when first_busno is
greater than 0 for the cases with multiple controllers.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
__BIG_ENDIAN and __LITTLE_ENDIAN.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
This patch added USB PCI-OHCI chips support, interrupt pipe support
and usb event poll support. For supporting the USB interrupt pipe, the
globe urb_priv is moved to purb in ed struct. Now, we can process
several urbs at one time. The interrupt pipe support codes are ported
from Linux kernel 2.4.
Using some (very) slow USB keys cause the USB host controller buffers
are not ready to be read by the CPU so we need an extra delay before
reading the USB storage data.
Thanks to Liew Tsi Chung <Tsi-chung.Liew@freescale.com> for pointing
this out.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
This patch updates the nand_ecc code to the latest Linux version.
The main reason for this is the more compact code. This makes
it possible to include the ECC code into the NAND bootloader
image (NAND_SPL) for PPC4xx.
For all practical u-boot purposes, TSECs don't differ throughout the
mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx.
