path: root/drivers
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of E1000 Ethernet controller to board_eth_init()Ben Warren
Affected boards: ap1000 mvbc_p PM854 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of plb2800 Ethernet driver to board_eth_initBen Warren
Affected boards: purple Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC512x_FEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to MPC512x CPU directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of IncaIP Ethernet controller to board_eth_initBen Warren
Affected boards: IncaIP Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of PCNET Ethernet controller to board_eth_init()Ben Warren
Affected boards: PN62 sc520_cdp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NATSEMI Ethernet controller to board_eth_init()Ben Warren
Affected boards: a3000 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of TSI108 Ethernet controller to board_eth_init()Ben Warren
Affected boards: mpc7448hpc2 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of RTL8139 Ethernet controller to board_eth_init()Ben Warren
Affected boards: hidden_dragon MPC8544DS MPC8610HPCN R2DPLUS TB0229 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of RTL8169 Ethernet controller to board_eth_init()Ben Warren
Affected boards: linkstation r7780mp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Add SGMII support to the tsecAndy Fleming
Adds support for configuring the TBI to talk properly with the SerDes. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Pass in tsec_info struct through tsec_initializeAndy Fleming
The tsec driver contains a hard-coded array of configuration information for the tsec ethernet controllers. We create a default function that works for most tsecs, and allow that to be overridden by board code. It creates an array of tsec_info structures, which are then parsed by the corresponding driver instance to determine configuration. Also, add regs, miiregs, and devname fields to the tsec_info structure, so that we don't need the kludgy "index" parameter. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02tsec: Move tsec.h to include/Andy Fleming
This is to prepare the way for board code passing in the tsec_info structure Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02PHY: Add support for the M88E1121R Marvell chip.Sergei Poselenov
Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-01Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-01Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-01Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2008-08-31Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2008-08-31sh: add support Renesas SH7723Nobuhiro Iwamatsu
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other. This patch supports CPU register's header file and SCIF serial driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Add support Renesas SH7203 processorNobuhiro Iwamatsu
2008-08-31NAND: add NAND driver for S3C64XXGuennadi Liakhovetski
Based on the original S3C64XX NAND driver by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-31S3C64XX: remove broken HWFLOW support from the serial driverGuennadi Liakhovetski
As noted by Harald Welte, HWFLOW support in the S3C64XX serial driver is broken and currently unused. Remove it. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-31serial: add S3C64XX serial driverGuennadi Liakhovetski
Based on the original S3C64XX UART driver by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-31USB: Add support for OHCI controller on S3C6400Guennadi Liakhovetski
Notice: USB on S3C6400 currently works _only_ with switched off MMU. One could try to enable the MMU, but map addresses 1-to-1, and disable data cache, then it should work too and we could still profit from instruction cache. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-29Move MPC512x_FEC driver to drivers/netBen Warren
2008-08-29Move MPC5xxx_FEC driver to drivers/netBen Warren
2008-08-29miiphyutil: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-29miiphybb: move to drivers/net/phyJean-Christophe PLAGNIOL-VILLARD
2008-08-29soft_spi: move to drivers/spiJean-Christophe PLAGNIOL-VILLARD
2008-08-29soft_i2c: move to drivers/i2cJean-Christophe PLAGNIOL-VILLARD
2008-08-28Add I2C frequency dividers for ColdFireTsiChung Liew
The existing I2C freqency dividers for FDR does not apply to ColdFire platforms; thus, a seperate table is added based on MCF5xxx Reference Manual Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Tabi Timur <timur@freescale.com>
2008-08-28Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-08-27mpc85xx: Add support for the MPC8536Kumar Gala
The MPC8536 Adds SDHC and SATA controllers to the PQ3 family. We also have SERDES init code for the 8536. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-08-26dm9000 remove dead external phy support, gpio fixAndrew Dyer
dm9000 has code to detect and initialize external phy parts, but later on in the code the part is forced to use the internal phy unconditionally. Remove the unused/untested code. change the GPIO initialization so that only the GPIO used as an internal phy reset (hardwired in the chip) is set as an output. The remaining GPIO need to be handled by board specific code to prevent possible drive conflicts. Set as inputs for safety. replace a few magic numbers with defines Signed-off-by: Andrew Dyer <adyer@righthandtech.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26ColdFire: Add FEC Buffer descriptors in SRAMTsiChung Liew
Add FEC Buffer descriptors and data buffer in SRAM for faster execution and access. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Fix ColdFire FEC warning messagesTsiChung Liew
Types mismatch and implicit declaration of icache_invalid() warning messages Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of SKGE Ethernet driver to board code.Ben Warren
The only board using this driver is the SL8245 board. Removed initialization for the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved conditional compilation to Makefile for SK98 Ethernet driverBen Warren
Brute-force removal of #ifdefs. Didn't touch the code. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of Blackfin EMAC Ethernet controller to board_eth_init()Ben Warren
Added board_eth_init() function to bf537-stamp board. Removed initialization for the Blackin EMAC driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of GRETH Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to leon2/leon3 CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of MCFFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to coldfire CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of FSL_MCDMAFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-27FSL DDR: Provide a generic set_ddr_laws()Kumar Gala
Provide a helper function that will setup the last available LAWs (upto 2) for DDR. Useful for SPD/dyanmic DDR setting code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-25Minor coding style cleanup, updte CHANGELOGWolfgang Denk
2008-08-25Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2008-08-25RTC: Fix Makefile problem with COBJS-$(CONFIG_RTC_DS1307 || CONFIG_RTC_DS1338)Stefan Roese
This "||" doesn't seem to work. Now using the idea suggest by Scott Wood to combine both config options into one line. This even allows defining both options and not generating the target object twice. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-25Add ARM AMBA PL031 RTC SupportGururaja Hebbar K R
Signed-off-by: Gururaja Hebbar K R <gururajakr@sanyo.co.in>
