Makefile
doc/README.standalone
MCD_tasks.c lacks [subject] so compilation of mips targets (and more, probably)
fails
Signed-off-by: Vlad Lungu <vlad@comsys.ro>
update comments
Fix coding style
Signed-off-by: Stelian Pop <stelian@popies.net>
Move the flat device tree setup for QE related devices into
a common file shared between 83xx & 85xx platforms that have QE's.
According to the OMAP5912 Serial Interfaces Reference Guide (see
http://focus.ti.com/lit/ug/spru760c/spru760c.pdf, page 150), the
FIFO_EN enable bit in the FIFO Control Register (FCR) can only be
changed when the baud clock is not running, i. e. when both DLL and
DLH are set to 0.
Thus make sure that DLL and DLH are 0 when writing the FCR.
This driver should only compile if CONFIG_MPC8XXX_SPI is set
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
..and rm unused CONFIG_FSL_SPI define
This patch adds support for the SPI controller found on Freescale PowerPC
processors such as the MCP834x family. Additionally, a new config option,
CONFIG_HARD_SPI, is added for general purpose SPI controller use.
This patch fixed wrong SH7720 CPU macro and changed macro that
calculated value of SCBRR register.
Move the initialization of the LAWs into C code and provide an API
to allow modification of LAWs after init.
Board code is responsible to provide a law_table and num_law_entries.
We should be able to use the same code on 86xx as well.
rx_status on the memory is basically in LE, but needs to be handled in CPU
endian. le32_to_cpu() takes up this mission. Even if on the sane hardware,
it'll work fine.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Cc: Masami Komiya <mkomiya@sonare.it>
Cc: Lucas Jin <lucasjin@gmail.com>
Current driver is meant for cache coherent systems. This patch adds
flush_cache() routines to support cache non-coherent systems.
"to = (currticks() + RTL_TIMEOUT)" has possibilities to wrap around. If it
does, the condition "(currticks() < to)" becomes invalid and immediately
leads to tx timeout error. This patch introduces the fine-graded udely(10)
loops to ease the impact of wrapping around.
Add the support of RealTek RTL8211B PHY, the RTL8211B
PHY only supports RGMII and MII mode.
Signed-off-by: Dave Liu <daveliu@freescale.com>
PHY less board prints out lots of "read wrong ...":
read wrong value : mii_id 3,mii_reg 2, base e0102320
read wrong value : mii_id 3,mii_reg 3, base e0102320
UEC: PHY is Generic MII (ffffffff)
read wrong value : mii_id 3,mii_reg 4, base e0102320
read wrong value : mii_id 3,mii_reg 0, base e0102320
read wrong value : mii_id 3,mii_reg 1, base e0102320
read wrong value : mii_id 3,mii_reg 5, base e0102320
FSL UEC0: Full Duplex
FSL UEC0: Speed 100BT
FSL UEC0: Link is up
Using FSL UEC0 device
Make this printout depend on UEC_VERBOSE_DEBUG and
remove its definition in uec_phy.c
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
actually polling for PHY autonegotiation to finish enables us to remove the
5 second boot prompt latency present on QE based boards.
call to qe_set_mii_clk_src in init_phy, and mv call to init_phy from
uec_initialize to uec_init by Joakim Tjernlund; autonegotiation wait
code shamelessly stolen from tsec driver.
also rm unused CONFIG_RMII_MODE code.
The current TSEC driver limits MDIO access to the devices that have been configured as attached
to a TSEC MAC. This patch allows access to any PHY device on the MDIO bus through the 'mii' commands.
Signed-off-by: Michael Firth <michael.firth@bt.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
OneNAND: Separate U-Boot dependent code from OneNAND
This patch extends the number of supported UECs to 4. Note that the
problem of QE thread resources exhaustion is resolved by setting the
correct number of QE threads according to Ethernet type (GBE or FE).
Signed-off-by: David Saada <david.saada@ecitele.com>
SH7710/SH7712 of SH3 CPU are supported.
SH771X is called SH-Ether, and has the Ether controller in CPU.
The driver of Ether is not included in this patch.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
qe.c: In function 'qe_upload_firmware':
qe.c:390: warning: pointer targets in passing argument 2
uec.c: In function 'uec_initialize':
uec.c:1236: warning: 'uec_info' may be used uninitialized
Signed-off-by: Michael Schwingen <michael@schwingen.org>
(needed for M5475EVB)
(1) Remove unused symbol "CFG_EEPROM_PAGE_WRITE_ENABLE".
(2) Use conditional Makefile.o.
Signed-off-by: Larry Johnson <lrj@acm.org>
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Lines of the lenght CONSOLE_COLS or greater than CONSOLE_COLS
are not displayed correctly. This is an attempt to fix
this issue. Also add carriage return handling.
Change return values of init() functions in all Ethernet drivers to conform
to the following:
>=0: Success
<0: Failure
All drivers going forward should return 0 on success. Current drivers that
return 1 on success were left as-is to minimize changes.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-By: Timur Tabi <timur@freescale.com>
Define the layout of a binary blob that contains a QE firmware and instructions
on how to upload it. Add function qe_upload_firmware() to parse the blob and
perform the actual upload. Add command-line command "qe fw" to take a firmware
blob in memory and upload it. Update ft_cpu_setup() on 85xx to create the
'firmware' device tree node if U-Boot has uploaded a firmware. Fully define
'struct rsp' in immap_qe.h to include the actual RISC Special Registers.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
